Possible Banned IP
rgk
Possible Banned IP
Post by rgk »
I have a script that downloads a stat page every hour to display some stats, and my server can no longer connect to your server and I'm assuming its a ban. Is it possible to continue running the script at a 6 or 12 hour interval and have the server ip unbanned?
or is there a better way to display stats?
186961 - folding team
parkut
Re: Possible Banned IP
Post by parkut »
See the rules explained here: http://folding.stanford.edu/English/Stats
If you have truly been banned, your IP will be blocked for a month.
You will need to contact VijayPande - See a comment posted
by him about the same situation here: viewtopic.php?f=16&t=15256&p=151531&hilit=stats+ban#p151531
rgk
Post by rgk »
Thanks for the response, I will try to get in touch with VijayPande and in the meantime the script has been disabled.
noorman
Hardware configuration: Folders: Intel C2D E6550 @ 3.150 GHz + GPU XFX 9800GTX+ @ 765 MHZ w. WinXP-GPU
AMD A2X64 3800+ @ stock + GPU XFX 9800GTX+ @ 775 MHZ w. WinXP-GPU
Main rig: an old Athlon Barton 2500+ @2.25 GHz & 2* 512 MB RAM Apacer, Radeon 9800Pro, WinXP SP3+
Location: Belgium, near the International Sea-Port of Antwerp
Post by noorman »
I don't know why you are downloading that page; it is self-refreshing ...
(I don't know what the refresh-time is though)
- stopped Linux SMP w. HT on i7-860@3.5 GHz
Folded since 10-06-04 till 09-2010
