Can someone check it out please?
Project: 6903 (Run 3, Clone 11, Gen 2)
Assigned: 2011-06-15 19:58:22 UTC
Returned: 2011-06-16 17:13:22 UTC
Expected compensation: 644,580
Actual compensation: 261,190
Or has reward been lowered for P6903 (again) ?
Thanks
Project: 6903 (Run 3, Clone 11, Gen 2): insufficient credit
- Hardware configuration: None
One man's ceiling is another man's floor.
Re: Project: 6903 (Run 3, Clone 11, Gen 2): insufficient cre
Entered into logs at: 2011-06-16 11:05:22 (Pacific Time)
WU assigned to donor at: 2011-06-11 00:48:17
Days taken to complete WU: 5.43
Hi tear (team 100259),
Your WU (P6903 R3 C11 G2) was added to the stats database on 2011-06-16 11:07:18 for 261190 points of credit.
Thanks.
Right, except this WU was not assigned to me on June 11th.
What time zone is this: WU assigned to donor at: 2011-06-11 00:48:17 ? Pacific as well?
I indeed got assigned a WU at that time but it was a different WU: Project: 6903 (Run 7, Clone 11, Gen 2) (vs. R3C11G2).
Something odd is happening here. Can you also check the other one please?
[07:48:41] Connecting to http://assign.stanford.edu:8080/
[07:48:41] Posted data.
[07:48:41] Initial: ED82; - Successful: assigned to (130.237.232.237).
[07:48:41] + News From Folding@Home: Welcome to Folding@Home
[07:48:41] Loaded queue successfully.
[07:48:41] Sent data
[07:48:41] Connecting to http://130.237.232.237:8080/
[07:49:07] Posted data.
[07:49:07] Initial: 0000; - Receiving payload (expected size: 57245513)
[07:51:56] - Downloaded at ~330 kB/s
[07:51:56] - Averaged speed for that direction ~316 kB/s
[07:51:56] + Received work.
[07:52:03] Project: 6903 (Run 7, Clone 11, Gen 2)
Stanford servers do not operate on UTC
... They all operate on Pacific Time (Standard or Daylight, gaining and loosing an hour annually).
If you check carefully, I'm sure you'll find that the WU was reassigned to you at the time you stated. It's the FIRST TIME it was assigned that counts.
Entered into logs at: 2011-06-11 23:05:16
WU assigned to donor at: 2011-06-11 00:49:08
Days taken to complete WU: 0.93
Your WU (P6903 R7 C11 G2) was added to the stats database on 2011-06-11 23:07:08 for 643323 points of credit.
It looks like there was just time enough between 2011-06-11 00:48:17 and 2011-06-11 00:49:08 for an error or something.
It seems that sever marked the R3 WU as sent/assigned on the 11th even though the download never succeeded.
There was no simulation error. I'd expect the server to correctly account for failed downloads (regardless of the cause) OTOH.
Expanded log:
Expanded log:
[07:44:36] - Preparing to get new work unit...
[07:44:36] Cleaning up work directory
[07:44:36] + Attempting to get work packet
[07:44:36] Passkey found
[07:44:36] - Will indicate memory of 32240 MB
[07:44:36] - Connecting to assignment server
[07:44:36] Connecting to http://assign.stanford.edu:8080/
[07:44:37] Posted data.
[07:44:37] Initial: ED82; - Successful: assigned to (130.237.232.237).
[07:44:37] + News From Folding@Home: Welcome to Folding@Home
[07:44:37] Loaded queue successfully.
[07:44:37] Sent data
[07:44:37] Connecting to http://130.237.232.237:8080/
[07:45:07] - Couldn't send HTTP request to server
[07:45:07] + Could not connect to Work Server
[07:45:07] - Attempt #1 to get work failed, and no other work to do. <======================== failed
Waiting before retry.
[07:45:21] + Attempting to get work packet
[07:45:21] Passkey found
[07:45:21] - Will indicate memory of 32240 MB
[07:45:21] - Connecting to assignment server
[07:45:21] Connecting to http://assign.stanford.edu:8080/
[07:45:21] Posted data.
[07:45:21] Initial: ED82; - Successful: assigned to (130.237.232.237).
[07:45:21] + News From Folding@Home: Welcome to Folding@Home
[07:45:21] Loaded queue successfully.
[07:45:21] Sent data
[07:45:21] Connecting to http://130.237.232.237:8080/
[07:48:18] - Couldn't send HTTP request to server
[07:48:18] + Could not connect to Work Server
[07:48:18] - Attempt #2 to get work failed, and no other work to do. <======================== failed
[07:48:41] + Attempting to get work packet
[07:48:41] Passkey found
[07:48:41] - Will indicate memory of 32240 MB
[07:48:41] - Connecting to assignment server
