Duplicate Stats Page!?
Hi,
This is me: http://fah-web.stanford.edu/cgi-bin/mai ... me=sWiZzLe
When I select 'Stats - My Folding' from FAH i get this: http://fah-web.stanford.edu/cgi-bin/mai ... teamnum=10
But it doesn't work properly, for example... the Certificates display that i have completed 0 points and folder 0 units!
On the Team Stats page it's using this: http://fah-web.stanford.edu/cgi-bin/mai ... me=swizzle
Is there anyway to get rid of the swizzle page and get the sWiZzLe one to work?
Cheers
Cheers
Re: Duplicate Stats Page!?
As none of you seem to be able to help, could someone at least tell me some who might be able to?
Nathan_P
Not currently folding
Your client is evidently set up with the wrong user name, you need to edit the user name so it exactly matches the one you want it to be, Usernames are case sensitive so pake sure you type everything exactly the way you intend it to be, From the time youe edit your user name any new work units you complete will go to your new user name.
You will need to apply for a new passkey if you use one and any existing points under swizzle cannot be transferred
You do NOT need a new passkey. Passkeys are NOT limited to only one user name.
But you will have to requalify for the SMP bonus if you do change user names. That's 10 SMP Wus.
codysluder
If both swizzle and sWiZzLe have already submitted some bonus-qualified WUs using that passkey, you just need to bring the total for the name you're going to use up to 10. It's possible to qualify both names but that's not really what you want to do.
Thanks for replying.
My tracker is setup up to use sWiZzLe and yes i use a passkey which was registered using 'sWiZzLe'. But its recording the same data to both accounts which makes no sense.
I don't know what you mean by 'bonus-qualified'
Originally, the bonus plan was tested on SMP, so in early documentation the statement was that you needed 10 SMP WUs to qualify. Gradually the bonus plan is being added to uniprocessor clients, and they count too, so "bonus-qualified" is one way of saying either SMP or those Uniprocessor projects. If you look at the Project Summary page, when K-factor is non zero, there's a bonus.
Yeah well hmm....
I know what SMP is, the rest of what you are saying is just total nonsense to me.
Simple question..... can I get this fixed or not?
Maybe I don't understand your question, but I don't see anything that can be fixed. You have submitted WUs with two different names and they will NOT be combined. To have one account, you need to be consistent about how you spell your name.
MtM
sWiZZle are you using FAH GPU Tracker multiple installs ( atleast two systems? ) If so, could you post you config.xml without the passkey? Just to verify that it's set up right. If I understand the mods right you're submitting wu's on both accounts, so you have atleast two clients running with different names in the config.xml file. That also applies when you don't use FAH GPU Tracker, still got two client configured with another name.
Hello again,
I am only using the one name 'sWiZzLe' but it seems to be adding data to both
I have the normal Folding@Home Tracker and the FAH GPU Tracker V2 (only 1 install of each): (i removed the passkey for the screeny)
I've been having some problem with overheating in my case, so have been using the normal F@H app recently. But it turns out that my case was incompatible with the Accelero cooler i had on my 4870x2 and since replacing the stock cooler its been fine. Last night i went back to the GPU tracker and for the first time ever i was able to use both gpu's and keep them at low temps.
Strangely though, the SMP got stuck on 0% and when i woke this morning, hadn't moved
Although now.... it has after closing the app and trying again, but the PPD refuses to appear
FAH GPU Tracker V2 - TRACKER CONFIG.txt:
CPUClient=SMP
SMPCores=All
BigAdv=False
EnableGPUSection=True
EnableGPU0=True
EnableGPU1=True
EnableGPU2=False
EnableGPU3=False
EnableGPU4=False
EnableGPU5=False
EnableGPU6=False
EnableGPU7=False
GPU3ClientGPU0=False
GPU3ClientGPU1=False
GPU3ClientGPU2=False
GPU3ClientGPU3=False
GPU3ClientGPU4=False
GPU3ClientGPU5=False
GPU3ClientGPU6=False
GPU3ClientGPU7=False
ForceGPU0=R700
ForceGPU1=R700
ForceGPU2=None
ForceGPU3=None
ForceGPU4=None
ForceGPU5=None
ForceGPU6=None
ForceGPU7=None
AdvmethodsCPU=False
Advmethods0=False
Advmethods1=False
Advmethods2=False
Advmethods3=False
Advmethods4=False
Advmethods5=False
Advmethods6=False
Advmethods7=False
ClientDebug=False
Verbosity9=False
SaveLogs=False
AutoConfig=False
UserName=sWiZzLe
Team=10
Passkey=
EOCID=
ConfigFile=
ProjectsList=http://fah-web.stanford.edu/psummaryC.html
SaveLocations=False
StopAll=False
BalloonNotify=False
DefaultStats=All
AutoUpdate=Prompt
HeatControl=False
OneUnitCPU=False
OneUnitGPU0=False
OneUnitGPU1=False
OneUnitGPU2=False
OneUnitGPU3=False
OneUnitGPU4=False
OneUnitGPU5=False
OneUnitGPU6=False
OneUnitGPU7=False
AutostartCPU=False
AutostartGPU0=False
AutostartGPU1=False
AutostartGPU2=False
AutostartGPU3=False
AutostartGPU4=False
AutostartGPU5=False
AutostartGPU6=False
AutostartGPU7=False
StartMinimized=False
GamingPause=False
PauseCPU=False
PauseGPU0=False
PauseGPU1=False
PauseGPU2=False
PauseGPU3=False
PauseGPU4=False
PauseGPU5=False
PauseGPU6=False
PauseGPU7=False
EnableXMLExport=False
ExportPath=
FTPUpload=False
FTPServer=
FTPUsername=
FTPPassword=
[/code]
Folding@Home Tracker - client.cfg:
Cheers
EnableCPUSection=True
Folder@Home Tracker: client.cfg
[code][settings]
username=sWiZzLe
team=10
passkey=
asknet=no
machineid=1
extra_parms=
local=78
bigpackets=normal
[http]
active=no
host=localhost
port=8080
usereg=no
proxy_name=
proxy_passwd=
[core]
priority=96
cpuusage=100
disableassembly=no
nocpulock=0
checkpoint=3
[power]
battery=no
SMPCores=All
BigAdv=False
EnableGPU0=True
EnableGPU1=True
EnableGPU2=False
EnableGPU3=False
EnableGPU4=False
EnableGPU5=False
EnableGPU6=False
EnableGPU7=False
ForceGPU0=R700
ForceGPU1=R700
ForceGPU2=None
ForceGPU3=None
ForceGPU4=None
ForceGPU5=None
ForceGPU6=None
ForceGPU7=None
AdvmethodsCPU=False
Advmethods0=False
Advmethods1=False
Advmethods2=False
Advmethods3=False
Advmethods4=False
Advmethods5=False
Advmethods6=False
Advmethods7=False
ClientDebug=False
Verbosity9=False
SaveLogs=False
AutoConfig=False
UserName=sWiZzLe
Team=10
Passkey=
EOCID=
ConfigFile=
SaveLocations=False
StopAll=False
BalloonNotify=False
DefaultStats=All
AutoUpdate=Prompt
HeatControl=False
OneUnitCPU=False
OneUnitGPU0=False
OneUnitGPU1=False
OneUnitGPU2=False
OneUnitGPU3=False
OneUnitGPU4=False
OneUnitGPU5=False
OneUnitGPU6=False
OneUnitGPU7=False
AutostartCPU=False
AutostartGPU0=False
AutostartGPU1=False
AutostartGPU2=False
AutostartGPU3=False
AutostartGPU4=False
AutostartGPU5=False
AutostartGPU6=False
AutostartGPU7=False
GamingPause=False
PauseCPU=False
PauseGPU0=False
PauseGPU1=False
PauseGPU2=False
PauseGPU3=False
PauseGPU4=False
PauseGPU5=False
PauseGPU6=False
PauseGPU7=False
ExportPath=
FTPUpload=False
FTPServer=
FTPUsername=
FTPPassword=
[/code]
[settings]
username=sWiZzLe
team=10
passkey=
asknet=no
machineid=1
extra_parms=
local=78
bigpackets=normal
[http]
active=no
host=localhost
port=8080
usereg=no
proxy_name=
proxy_passwd=
[core]
priority=96
cpuusage=100
disableassembly=no
nocpulock=0
checkpoint=3
[power]
battery=no
MtM
Both names seem set up right so you shouldn't be submitting with different names, if you still are then goto the tracker folder and locate the client you're running manually, look for the file client.cfg. Check the username(s) there.
