How to Stop FAH on WHS?
jpmarth
Post by jpmarth »
Have had FAH at home running on my WHS (HP ex495) for a couple days, but it's staying too hot due to where I have to keep the box.
Now I'm having trouble getting it to stop.
Here is what I have done so far:
- Removed the add-in, but that's just the face and not the guts.
- Tried deleting the folder through remote desktop, but it would not let me since the application was still running.
- Tried to stop the process, through Terminal Service Manager. But it says I don't have access.
- Used the -config options in the console to try and stop the application, but that doesn't help either.
- Walked through the uninstall options on the FAH website, and it didn't help.
Can someone suggest anything?
uncle fuzzy
Re: How to Stop FAH on WHS?
Post by uncle fuzzy »
Which version of FAH are you running? They each have their own method to stop and remove.
orion
Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB
Post by orion »
Does WHS have safe mode you can go into to uninstall the client?
iustus quia...
jpmarth
Post by jpmarth »
Was able to get it stopped by stopping the service from running, restarting WHS, then I could delete the folder from the C: drive. Thanks for the replies.
MtM
Hardware configuration: Q6600 - 8gb - p5q deluxe - gtx275 - hd4350 ( not folding ) win7 x64 - smp:4 - gpu slot
T5450 - 4gb - ?? - 8600M GT 512 ( DDR2 ) - win7 x64 - smp:2 - gpu slot
Post by MtM »
You might have redundant registry entries now then, look here [REGEDIT]
local_machine/system/currentcontrolset/services/
Remove everything you find which links to the removed client. ( can't be more specific since I don't know the original client setup/config but the entries should be self explanatory ) ).
If you don't, your event log will get pretty much filled with 'failed to start service ...' entries, not that much a deal if it's only this entry but registry problems have the tendency to compound.
