I installed a Sapphire RADEON HD4650 video card a few months ago and have been very successful with it ~ going from about 130 to 830 ppd on an a sort of old AMD X2 4200 processor. Now some unknown problem has crept up with Project: 5737 (Run 1, Clone 583, Gen 412). Below is from the log file. I just cleared everything from the /work directory under my XP profile and the same job came up again.
Will see if it runs properly this go around. The second log file below shows it got 1% completed, maybe there is hope. If not, how do I completely remove all traces of it so can have a more stable work unit?
Thanks,
Robby / Team Firefox 39299
[09:30:13] Completed 100%
[09:30:13] Successful run
[09:30:13] DynamicWrapper: Finished Work Unit: sleep=10000
[09:30:23] Reserved 218868 bytes for xtc file; Cosm status=0
[09:30:23] Allocated 218868 bytes for xtc file
[09:30:23] - Reading up to 218868 from "work/wudata_04.xtc": Read 218868
[09:30:23] Read 218868 bytes from xtc file; available packet space=786211596
[09:30:23] xtc file hash check passed.
[09:30:23] Reserved 33528 33528 786211596 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[09:30:23] Allocated 33528 bytes for arc file
[09:30:23] - Reading up to 33528 from "work/wudata_04.trr": Read 33528
[09:30:23] Read 33528 bytes from arc file; available packet space=786178068
[09:30:23] trr file hash check passed.
[09:30:23] Allocated 560 bytes for edr file
[09:30:23] Read bedfile
[09:30:23] edr file hash check passed.
[09:30:23] Allocated 47403 bytes for logfile
[09:30:23] Read logfile
[09:30:23] GuardedRun: success in DynamicWrapper
[09:30:23] GuardedRun: done
[09:30:23] Run: GuardedRun completed.
[09:30:25] - Writing 300871 bytes of core data to disk...
[09:30:25] Done: 300359 -> 263180 (compressed to 87.6 percent)
[09:30:25] ... Done.
[09:30:25] - Shutting down core
[09:30:25]
[09:30:25] Folding@home Core Shutdown: FINISHED_UNIT
[09:30:29] CoreStatus = 64 (100)
[09:30:29] Sending work to server
[09:30:29] Project: 5737 (Run 0, Clone 610, Gen 403)
[09:30:29] + Attempting to send results [June 2 09:30:29 UTC]
[09:30:31] + Results successfully sent
[09:30:31] Thank you for your contribution to Folding@Home.
[09:30:31] + Number of Units Completed: 174
[09:30:35] - Preparing to get new work unit...
[09:30:35] + Attempting to get work packet
[09:30:35] - Connecting to assignment server
[09:30:36] - Successful: assigned to (171.64.65.102).
[09:30:36] + News From Folding@Home: Welcome to Folding@Home
[09:30:36] Loaded queue successfully.
[09:30:37] + Closed connections
[09:30:37]
[09:30:37] + Processing work unit
[09:30:37] Core required: FahCore_11.exe
[09:30:37] Core found.
[09:30:37] Working on queue slot 05 [June 2 09:30:37 UTC]
[09:30:37] + Working ...
[09:30:38]
[09:30:38] *------------------------------*
[09:30:38] Folding@Home GPU Core - Beta
[09:30:38] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:30:38]
[09:30:38] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:30:38] Build host: amoeba
[09:30:38] Board Type: AMD
[09:30:38] Core :
[09:30:38] Preparing to commence simulation
[09:30:38] - Looking at optimizations...
[09:30:38] - Created dyn
[09:30:38] - Files status OK
[09:30:38] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[09:30:38] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[09:30:38] - Digital signature verified
[09:30:38]
[09:30:38] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:30:38]
[09:30:38] Assembly optimizations on if available.
[09:30:38] Entering M.D.
[09:30:44] Tpr hash work/wudata_05.tpr: 3689892198 736089360 524997858 26911044 1357052578
[09:30:44] Working on Protein
[09:30:45] Client config found, loading data.
[09:30:45] Starting GUI Server
[09:31:41] mdrun_gpu returned
[09:31:41] NANs detected on GPU
[09:31:41]
[09:31:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:31:44] CoreStatus = 7A (122)
[09:31:44] Sending work to server
[09:31:44] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:31:44] - Error: Could not get length of results file work/wuresults_05.dat
[09:31:44] - Error: Could not read unit 05 file. Removing from queue.
[09:31:44] - Preparing to get new work unit...
[09:31:44] + Attempting to get work packet
[09:31:44] - Connecting to assignment server
[09:31:44] - Successful: assigned to (171.64.65.102).
[09:31:44] + News From Folding@Home: Welcome to Folding@Home
[09:31:45] Loaded queue successfully.
[09:31:46] + Closed connections
[09:31:51]
[09:31:51] + Processing work unit
[09:31:51] Core required: FahCore_11.exe
[09:31:51] Core found.
[09:31:51] Working on queue slot 06 [June 2 09:31:51 UTC]
[09:31:51] + Working ...
[09:31:51]
[09:31:51] *------------------------------*
[09:31:51] Folding@Home GPU Core - Beta
[09:31:51] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:31:51]
[09:31:51] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:31:51] Build host: amoeba
[09:31:51] Board Type: AMD
[09:31:51] Core :
[09:31:51] Preparing to commence simulation
[09:31:51] - Looking at optimizations...
[09:31:51] - Created dyn
[09:31:51] - Files status OK
[09:31:51] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[09:31:51] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[09:31:51] - Digital signature verified
[09:31:51]
[09:31:51] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:31:51]
[09:31:51] Assembly optimizations on if available.
[09:31:51] Entering M.D.
[09:31:57] Tpr hash work/wudata_06.tpr: 3689892198 736089360 524997858 26911044 1357052578
[09:31:57] Working on Protein
[09:31:58] Client config found, loading data.
[09:31:58] Starting GUI Server
[09:32:54] mdrun_gpu returned
[09:32:54] NANs detected on GPU
[09:32:54]
[09:32:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:32:57] CoreStatus = 7A (122)
[09:32:57] Sending work to server
[09:32:57] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:32:57] - Error: Could not get length of results file work/wuresults_06.dat
[09:32:57] - Error: Could not read unit 06 file. Removing from queue.
[09:32:57] - Preparing to get new work unit...
[09:32:57] + Attempting to get work packet
[09:32:57] - Connecting to assignment server
[09:32:58] - Successful: assigned to (171.64.65.102).
[09:32:58] + News From Folding@Home: Welcome to Folding@Home
[09:32:58] Loaded queue successfully.
[09:32:59] + Closed connections
[09:33:04]
[09:33:04] + Processing work unit
[09:33:04] Core required: FahCore_11.exe
[09:33:04] Core found.
[09:33:04] Working on queue slot 07 [June 2 09:33:04 UTC]
[09:33:04] + Working ...
[09:33:04]
[09:33:04] *------------------------------*
[09:33:04] Folding@Home GPU Core - Beta
[09:33:04] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:33:04]
[09:33:04] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:33:04] Build host: amoeba
[09:33:04] Board Type: AMD
[09:33:04] Core :
[09:33:04] Preparing to commence simulation
[09:33:04] - Looking at optimizations...
[09:33:04] - Created dyn
[09:33:04] - Files status OK
[09:33:05] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[09:33:05] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[09:33:05] - Digital signature verified
[09:33:05]
[09:33:05] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:33:05]
[09:33:05] Assembly optimizations on if available.
[09:33:05] Entering M.D.
[09:33:11] Tpr hash work/wudata_07.tpr: 3689892198 736089360 524997858 26911044 1357052578
[09:33:11] Working on Protein
[09:33:11] Client config found, loading data.
[09:33:11] Starting GUI Server
[09:34:07] mdrun_gpu returned
[09:34:07] NANs detected on GPU
[09:34:07]
[09:34:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:34:10] CoreStatus = 7A (122)
[09:34:10] Sending work to server
[09:34:10] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:34:10] - Error: Could not get length of results file work/wuresults_07.dat
[09:34:10] - Error: Could not read unit 07 file. Removing from queue.
[09:34:10] - Preparing to get new work unit...
[09:34:10] + Attempting to get work packet
[09:34:10] - Connecting to assignment server
[09:34:11] - Successful: assigned to (171.64.65.102).
[09:34:11] + News From Folding@Home: Welcome to Folding@Home
[09:34:11] Loaded queue successfully.
[09:34:12] + Closed connections
[09:34:17]
[09:34:17] + Processing work unit
[09:34:17] Core required: FahCore_11.exe
[09:34:17] Core found.
[09:34:17] Working on queue slot 08 [June 2 09:34:17 UTC]
[09:34:17] + Working ...
[09:34:17]
[09:34:17] *------------------------------*
[09:34:17] Folding@Home GPU Core - Beta
[09:34:17] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:34:17]
[09:34:17] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:34:17] Build host: amoeba
[09:34:17] Board Type: AMD
[09:34:17] Core :
[09:34:17] Preparing to commence simulation
[09:34:17] - Looking at optimizations...
[09:34:17] - Previous termination of core was improper.
[09:34:17] - Files status OK
[09:34:18] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[09:34:18] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[09:34:18] - Digital signature verified
[09:34:18]
[09:34:18] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:34:18]
[09:34:18] Entering M.D.
[09:34:24] Will resume from checkpoint file
[09:34:24] Tpr hash work/wudata_08.tpr: 3689892198 736089360 524997858 26911044 1357052578
[09:34:24] Working on Protein
[09:34:24] Client config found, loading data.
[09:34:24] Starting GUI Server
[09:34:30] Resuming from checkpoint
[09:34:30] fcCheckPointResume: retreived and current tpr file hash:
[09:34:30] 0 3488587582 3689892198
[09:34:30] 1 739070342 736089360
[09:34:30] 2 1516664930 524997858
[09:34:30] 3 4089038602 26911044
[09:34:30] 4 2174742970 1357052578
[09:34:30] fcCheckPointResume: file hashes different -- aborting.
[09:34:30] mdrun_gpu returned
[09:34:30] Checkpoint failure
[09:34:30]
[09:34:30] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:34:34] CoreStatus = 7A (122)
[09:34:34] Sending work to server
[09:34:34] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:34:34] - Error: Could not get length of results file work/wuresults_08.dat
[09:34:34] - Error: Could not read unit 08 file. Removing from queue.
[09:34:34] - Preparing to get new work unit...
[09:34:34] + Attempting to get work packet
[09:34:34] - Connecting to assignment server
[09:34:34] - Successful: assigned to (171.64.65.102).
[09:34:34] + News From Folding@Home: Welcome to Folding@Home
[09:34:34] Loaded queue successfully.
[09:34:35] + Closed connections
[09:34:40]
[09:34:40] + Processing work unit
[09:34:40] Core required: FahCore_11.exe
[09:34:40] Core found.
[09:34:40] Working on queue slot 09 [June 2 09:34:40 UTC]
[09:34:40] + Working ...
[09:34:41]
[09:34:41] *------------------------------*
[09:34:41] Folding@Home GPU Core - Beta
[09:34:41] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[09:34:41]
[09:34:41] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:34:41] Build host: amoeba
[09:34:41] Board Type: AMD
[09:34:41] Core :
[09:34:41] Preparing to commence simulation
[09:34:41] - Looking at optimizations...
[09:34:41] - Created dyn
[09:34:41] - Files status OK
[09:34:41] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[09:34:41] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[09:34:41] - Digital signature verified
[09:34:41]
[09:34:41] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:34:41]
[09:34:41] Assembly optimizations on if available.
[09:34:41] Entering M.D.
[09:34:47] Tpr hash work/wudata_09.tpr: 3689892198 736089360 524997858 26911044 1357052578
[09:34:47] Working on Protein
[09:34:48] Client config found, loading data.
[09:34:48] Starting GUI Server
[09:35:44] mdrun_gpu returned
[09:35:44] NANs detected on GPU
[09:35:44]
[09:35:44] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:35:47] CoreStatus = 7A (122)
[09:35:47] Sending work to server
[09:35:47] Project: 5737 (Run 1, Clone 583, Gen 412)
[09:35:47] - Error: Could not get length of results file work/wuresults_09.dat
[09:35:47] - Error: Could not read unit 09 file. Removing from queue.
[09:35:47] EUE limit exceeded. Pausing 24 hours.
[13:46:02] + Working...
Folding@Home Client Shutdown.
--- Opening Log file [June 2 16:07:48 UTC]
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Robby\Application Data\Folding@home-gpu
[16:07:48] - Ask before connecting: No
[16:07:48] - User name: Robby (Team 39299)
[16:07:48] - User ID:
[16:07:48] - Machine ID: 2
[16:07:48]
[16:07:48] Loaded queue successfully.
[16:07:48] Initialization complete
[16:07:48] - Preparing to get new work unit...
[16:07:48] + Attempting to get work packet
[16:07:48] - Connecting to assignment server
[16:07:49] - Successful: assigned to (171.64.65.102).
[16:07:49] + News From Folding@Home: Welcome to Folding@Home
[16:07:49] Loaded queue successfully.
[16:07:50] + Closed connections
[16:07:50]
[16:07:50] + Processing work unit
[16:07:50] Core required: FahCore_11.exe
[16:07:50] Core found.
[16:07:50] Working on queue slot 00 [June 2 16:07:50 UTC]
[16:07:50] + Working ...
[16:07:50]
[16:07:50] *------------------------------*
[16:07:50] Folding@Home GPU Core - Beta
[16:07:50] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:07:50]
[16:07:50] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:07:50] Build host: amoeba
[16:07:50] Board Type: AMD
[16:07:50] Core :
[16:07:50] Preparing to commence simulation
[16:07:50] - Looking at optimizations...
[16:07:50] - Created dyn
[16:07:50] - Files status OK
[16:07:51] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[16:07:51] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[16:07:51] - Digital signature verified
[16:07:51]
[16:07:51] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:07:51]
[16:07:51] Assembly optimizations on if available.
[16:07:51] Entering M.D.
[16:07:57] Tpr hash work/wudata_00.tpr: 3689892198 736089360 524997858 26911044 1357052578
[16:07:57] Working on Protein
[16:07:57] Client config found, loading data.
[16:07:58] Starting GUI Server
[16:08:56] mdrun_gpu returned
[16:08:56] NANs detected on GPU
[16:08:56]
[16:08:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:08:59] CoreStatus = 7A (122)
[16:08:59] Sending work to server
[16:08:59] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:08:59] - Error: Could not get length of results file work/wuresults_00.dat
[16:08:59] - Error: Could not read unit 00 file. Removing from queue.
[16:08:59] - Preparing to get new work unit...
[16:08:59] + Attempting to get work packet
[16:08:59] - Connecting to assignment server
[16:08:59] - Successful: assigned to (171.64.65.102).
[16:08:59] + News From Folding@Home: Welcome to Folding@Home
[16:09:00] Loaded queue successfully.
[16:09:00] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[16:09:12] + Attempting to get work packet
[16:09:12] - Connecting to assignment server
[16:09:13] - Successful: assigned to (171.64.65.102).
[16:09:13] + News From Folding@Home: Welcome to Folding@Home
[16:09:13] Loaded queue successfully.
[16:09:14] + Closed connections
[16:09:19]
[16:09:19] + Processing work unit
[16:09:19] Core required: FahCore_11.exe
[16:09:19] Core found.
[16:09:19] Working on queue slot 01 [June 2 16:09:19 UTC]
[16:09:19] + Working ...
[16:09:20]
[16:09:20] *------------------------------*
[16:09:20] Folding@Home GPU Core - Beta
[16:09:20] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:09:20]
[16:09:20] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:09:20] Build host: amoeba
[16:09:20] Board Type: AMD
[16:09:20] Core :
[16:09:20] Preparing to commence simulation
[16:09:20] - Looking at optimizations...
[16:09:20] - Created dyn
[16:09:20] - Files status OK
[16:09:20] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[16:09:20] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[16:09:20] - Digital signature verified
[16:09:20]
[16:09:20] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:09:20]
[16:09:20] Assembly optimizations on if available.
[16:09:20] Entering M.D.
[16:09:26] Tpr hash work/wudata_01.tpr: 3689892198 736089360 524997858 26911044 1357052578
[16:09:26] Working on Protein
[16:09:27] Client config found, loading data.
[16:09:27] Starting GUI Server
[16:10:25] mdrun_gpu returned
[16:10:25] NANs detected on GPU
[16:10:25]
[16:10:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:10:28] CoreStatus = 7A (122)
[16:10:28] Sending work to server
[16:10:28] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:10:28] - Error: Could not get length of results file work/wuresults_01.dat
[16:10:28] - Error: Could not read unit 01 file. Removing from queue.
[16:10:28] - Preparing to get new work unit...
[16:10:28] + Attempting to get work packet
[16:10:28] - Connecting to assignment server
[16:10:29] - Successful: assigned to (171.64.65.102).
[16:10:29] + News From Folding@Home: Welcome to Folding@Home
[16:10:29] Loaded queue successfully.
[16:10:30] + Closed connections
[16:10:35]
[16:10:35] + Processing work unit
[16:10:35] Core required: FahCore_11.exe
[16:10:35] Core found.
[16:10:35] Working on queue slot 02 [June 2 16:10:35 UTC]
[16:10:35] + Working ...
[16:10:35]
[16:10:35] *------------------------------*
[16:10:35] Folding@Home GPU Core - Beta
[16:10:35] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:10:35]
[16:10:35] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:10:35] Build host: amoeba
[16:10:35] Board Type: AMD
[16:10:35] Core :
[16:10:35] Preparing to commence simulation
[16:10:35] - Looking at optimizations...
[16:10:35] - Created dyn
[16:10:35] - Files status OK
[16:10:36] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[16:10:36] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[16:10:36] - Digital signature verified
[16:10:36]
[16:10:36] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:10:36]
[16:10:36] Assembly optimizations on if available.
[16:10:36] Entering M.D.
[16:10:42] Tpr hash work/wudata_02.tpr: 3689892198 736089360 524997858 26911044 1357052578
[16:10:42] Working on Protein
[16:10:42] Client config found, loading data.
[16:10:43] Starting GUI Server
[16:11:41] mdrun_gpu returned
[16:11:41] NANs detected on GPU
[16:11:41]
[16:11:41] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:11:43] CoreStatus = 7A (122)
[16:11:43] Sending work to server
[16:11:43] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:11:43] - Error: Could not get length of results file work/wuresults_02.dat
[16:11:43] - Error: Could not read unit 02 file. Removing from queue.
[16:11:43] - Preparing to get new work unit...
[16:11:43] + Attempting to get work packet
[16:11:43] - Connecting to assignment server
[16:11:44] - Successful: assigned to (171.64.65.102).
[16:11:44] + News From Folding@Home: Welcome to Folding@Home
[16:11:44] Loaded queue successfully.
[16:11:45] + Closed connections
[16:11:50]
[16:11:50] + Processing work unit
[16:11:50] Core required: FahCore_11.exe
[16:11:50] Core found.
[16:11:50] Working on queue slot 03 [June 2 16:11:50 UTC]
[16:11:50] + Working ...
[16:11:50]
[16:11:50] *------------------------------*
[16:11:50] Folding@Home GPU Core - Beta
[16:11:50] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:11:50]
[16:11:50] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:11:50] Build host: amoeba
[16:11:50] Board Type: AMD
[16:11:50] Core :
[16:11:50] Preparing to commence simulation
[16:11:50] - Looking at optimizations...
[16:11:50] - Created dyn
[16:11:50] - Files status OK
[16:11:51] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[16:11:51] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[16:11:51] - Digital signature verified
[16:11:51]
[16:11:51] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:11:51]
[16:11:51] Assembly optimizations on if available.
[16:11:51] Entering M.D.
[16:11:57] Tpr hash work/wudata_03.tpr: 3689892198 736089360 524997858 26911044 1357052578
[16:11:57] Working on Protein
[16:11:57] Client config found, loading data.
[16:11:57] Starting GUI Server
[16:12:56] mdrun_gpu returned
[16:12:56] NANs detected on GPU
[16:12:56]
[16:12:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:12:59] CoreStatus = 7A (122)
[16:12:59] Sending work to server
[16:12:59] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:12:59] - Error: Could not get length of results file work/wuresults_03.dat
[16:12:59] - Error: Could not read unit 03 file. Removing from queue.
[16:12:59] - Preparing to get new work unit...
[16:12:59] + Attempting to get work packet
[16:12:59] - Connecting to assignment server
[16:12:59] - Successful: assigned to (171.64.65.102).
[16:12:59] + News From Folding@Home: Welcome to Folding@Home
[16:12:59] Loaded queue successfully.
[16:13:01] + Closed connections
[16:13:06]
[16:13:06] + Processing work unit
[16:13:06] Core required: FahCore_11.exe
[16:13:06] Core found.
[16:13:06] Working on queue slot 04 [June 2 16:13:06 UTC]
[16:13:06] + Working ...
[16:13:06]
[16:13:06] *------------------------------*
[16:13:06] Folding@Home GPU Core - Beta
[16:13:06] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:13:06]
[16:13:06] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:13:06] Build host: amoeba
[16:13:06] Board Type: AMD
[16:13:06] Core :
[16:13:06] Preparing to commence simulation
[16:13:06] - Looking at optimizations...
[16:13:06] - Created dyn
[16:13:06] - Files status OK
[16:13:06] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[16:13:06] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[16:13:06] - Digital signature verified
[16:13:06]
[16:13:06] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:13:06]
[16:13:06] Assembly optimizations on if available.
[16:13:06] Entering M.D.
[16:13:12] Tpr hash work/wudata_04.tpr: 3689892198 736089360 524997858 26911044 1357052578
[16:13:12] Working on Protein
[16:13:13] Client config found, loading data.
[16:13:13] Starting GUI Server
[16:14:12] mdrun_gpu returned
[16:14:12] NANs detected on GPU
[16:14:12]
[16:14:12] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:14:16] CoreStatus = 7A (122)
[16:14:16] Sending work to server
[16:14:16] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:14:16] - Error: Could not get length of results file work/wuresults_04.dat
[16:14:16] - Error: Could not read unit 04 file. Removing from queue.
[16:14:16] EUE limit exceeded. Pausing 24 hours.
--- Opening Log file [June 2 16:30:29 UTC]
[16:30:29] - Ask before connecting: No
[16:30:29] - User name: Robby (Team 39299)
[16:30:29] - User ID:
[16:30:29] - Machine ID: 2
[16:30:29]
[16:30:30] Loaded queue successfully.
[16:30:30] Initialization complete
[16:30:30] - Preparing to get new work unit...
[16:30:30] + Attempting to get work packet
[16:30:30] - Connecting to assignment server
[16:30:30] - Successful: assigned to (171.64.65.102).
[16:30:30] + News From Folding@Home: Welcome to Folding@Home
[16:30:32] + Closed connections
[16:30:32]
[16:30:32] + Processing work unit
[16:30:32] Core required: FahCore_11.exe
[16:30:32] Core found.
[16:30:32] Working on queue slot 05 [June 2 16:30:32 UTC]
[16:30:32] + Working ...
[16:30:32]
[16:30:32] *------------------------------*
[16:30:32] Folding@Home GPU Core - Beta
[16:30:32] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:30:32]
[16:30:32] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:30:32] Build host: amoeba
[16:30:32] Board Type: AMD
[16:30:32] Core :
[16:30:32] Preparing to commence simulation
[16:30:32] - Looking at optimizations...
[16:30:32] - Created dyn
[16:30:32] - Files status OK
[16:30:32] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[16:30:32] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[16:30:32] - Digital signature verified
[16:30:32]
[16:30:32] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:30:32]
[16:30:32] Assembly optimizations on if available.
[16:30:32] Entering M.D.
[16:30:38] Tpr hash work/wudata_05.tpr: 3689892198 736089360 524997858 26911044 1357052578
[16:30:38] Working on Protein
[16:30:39] Client config found, loading data.
[16:30:39] Starting GUI Server
[16:31:38] mdrun_gpu returned
[16:31:38] NANs detected on GPU
[16:31:38]
[16:31:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:31:42] CoreStatus = 7A (122)
[16:31:42] Sending work to server
[16:31:42] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:31:42] - Error: Could not get length of results file work/wuresults_05.dat
[16:31:42] - Error: Could not read unit 05 file. Removing from queue.
[16:31:42] - Preparing to get new work unit...
[16:31:42] + Attempting to get work packet
[16:31:42] - Connecting to assignment server
[16:31:43] - Successful: assigned to (171.64.65.102).
[16:31:43] + News From Folding@Home: Welcome to Folding@Home
[16:31:43] Loaded queue successfully.
[16:31:44] + Closed connections
[16:31:49]
[16:31:49] + Processing work unit
[16:31:49] Core required: FahCore_11.exe
[16:31:49] Core found.
[16:31:49] Working on queue slot 06 [June 2 16:31:49 UTC]
[16:31:49] + Working ...
[16:31:49]
[16:31:49] *------------------------------*
[16:31:49] Folding@Home GPU Core - Beta
[16:31:49] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:31:49]
[16:31:49] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:31:49] Build host: amoeba
[16:31:49] Board Type: AMD
[16:31:49] Core :
[16:31:49] Preparing to commence simulation
[16:31:49] - Looking at optimizations...
[16:31:49] - Created dyn
[16:31:49] - Files status OK
[16:31:50] - Expanded 96694 -> 489152 (decompressed 505.8 percent)
[16:31:50] Called DecompressByteArray: compressed_data_size=96694 data_size=489152, decompressed_data_size=489152 diff=0
[16:31:50] - Digital signature verified
[16:31:50]
[16:31:50] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:31:50]
[16:31:50] Assembly optimizations on if available.
[16:31:50] Entering M.D.
[16:31:56] Tpr hash work/wudata_06.tpr: 3689892198 736089360 524997858 26911044 1357052578
[16:31:56] Working on Protein
[16:31:56] Client config found, loading data.
[16:31:56] Starting GUI Server
[16:32:55] mdrun_gpu returned
[16:32:55] NANs detected on GPU
[16:32:55]
[16:32:55] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:32:57] CoreStatus = 7A (122)
[16:32:57] Sending work to server
[16:32:57] Project: 5737 (Run 1, Clone 583, Gen 412)
[16:32:57] - Error: Could not get length of results file work/wuresults_06.dat
[16:32:57] - Error: Could not read unit 06 file. Removing from queue.
[16:32:57] - Preparing to get new work unit...
[16:32:57] + Attempting to get work packet
[16:32:57] - Connecting to assignment server
[16:32:58] - Successful: assigned to (171.64.65.102).
[16:32:58] + News From Folding@Home: Welcome to Folding@Home
[16:32:58] Loaded queue successfully.
[16:32:59] - Attempt #1 to get work failed, and no other work to do.
[16:33:16] + Attempting to get work packet
[16:33:16] - Connecting to assignment server
[16:33:17] - Successful: assigned to (171.64.65.102).
[16:33:17] + News From Folding@Home: Welcome to Folding@Home
[16:33:17] Loaded queue successfully.
[16:33:18] + Closed connections
[16:33:23]
[16:33:23] + Processing work unit
[16:33:23] Core required: FahCore_11.exe
[16:33:23] Core found.
[16:33:23] Working on queue slot 07 [June 2 16:33:23 UTC]
[16:33:23] + Working ...
[16:33:23]
[16:33:23] *------------------------------*
[16:33:23] Folding@Home GPU Core - Beta
[16:33:23] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:33:23]
[16:33:23] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:33:23] Build host: amoeba
[16:33:23] Board Type: AMD
[16:33:23] Core :
[16:33:23] Preparing to commence simulation
[16:33:23] - Looking at optimizations...
[16:33:23] - Created dyn
[16:33:23] - Files status OK
[16:33:24] - Expanded 98699 -> 492188 (decompressed 498.6 percent)
[16:33:24] Called DecompressByteArray: compressed_data_size=98699 data_size=492188, decompressed_data_size=492188 diff=0
[16:33:24] - Digital signature verified
[16:33:24]
[16:33:24] Project: 5733 (Run 3, Clone 567, Gen 435)
[16:33:24]
[16:33:24] Assembly optimizations on if available.
[16:33:24] Entering M.D.
[16:33:30] Tpr hash work/wudata_07.tpr: 2059916722 2743129824 1933651617 797618201 2454578248
[16:33:30] Working on Protein
[16:33:30] Client config found, loading data.
[16:33:31] Starting GUI Server
[16:42:25] Completed 1%
