Project: 6503 (Run 16, Clone 557, Gen 91) EUE after 8%
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
Picked up new WU, and is now at 31% and successfully continuing folding.
WinXP SP3-32 FAH v7.1.21 client ~100 PPD uniprocessor.
04:05:47:Unit 00:Gromacs cannot continue further.
04:05:47:Unit 00:Going to send back what have done.
04:05:47:Unit 00:logfile size: 12056
04:05:47:Unit 00:- Writing 12592 bytes of core data to disk...
04:05:47:Unit 00:Done: 12080 -> 3925 (compressed to 32.4 percent)
04:05:47:Unit 00: ... Done.
04:05:47:Unit 00:
04:05:47:Unit 00:Folding@home Core Shutdown: EARLY_UNIT_END
04:05:48:FahCore running Unit 00 returned: BAD_WORK_UNIT (114)
*********************** Log Started 29/May/2011-23:30:08 ***********************
23:30:08:************************* Folding@home Client *************************
23:30:08:      Website: http://folding.stanford.edu/
23:30:08:    Copyright: (c) 2009,2010 Stanford University
23:30:08:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:30:08:         Args: --lifeline 4312
23:30:08:       Config: C:/Documents and Settings/Admin/Application
23:30:08:               Data/FAHClient/config.xml
23:30:08:******************************** Build ********************************
23:30:08:      Version: 7.1.21
23:30:08:         Date: Mar 23 2011
23:30:08:         Time: 15:13:48
23:30:08:      SVN Rev: 2883
23:30:08:       Branch: fah/trunk/client
23:30:08:     Compiler: Intel(R) C++ MSVC 1500 mode 1110
23:30:08:      Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE
23:30:08:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
23:30:08:     Platform: win32 XP
23:30:08:         Bits: 32
23:30:08:         Mode: Release
23:30:08:******************************* System ********************************
23:30:08:           OS: Microsoft Windows XP Home Edition
23:30:08:          CPU: Intel(R) Pentium(R) M processor 1.73GHz
23:30:08:       CPU ID: GenuineIntel Family 6 Model 13 Stepping 8
23:30:08:         CPUs: 1
23:30:08:       Memory: 1.99GiB
23:30:08:  Free Memory: 1.10GiB
23:30:08:      Threads: WINDOWS_THREADS
23:30:08:         GPUs: 0
23:30:08:         CUDA: Not detected
23:30:08:   On Battery: false
23:30:08:   UTC offset: -7
23:30:08:          PID: 5868
23:30:08:          CWD: C:/Documents and Settings/Admin/Application Data/FAHClient
23:30:08:Win32 Service: false
23:30:08:***********************************************************************
23:30:08:<config>
23:30:08:  <service-description v='Folding@home Client'/>
23:30:08:  <service-restart v='true'/>
23:30:08:  <service-restart-delay v='5000'/>
23:30:08:
23:30:08:  <!-- Client Control -->
23:30:08:  <cycle-rate v='4'/>
23:30:08:  <cycles v='-1'/>
23:30:08:  <data-directory v='.'/>
23:30:08:  <exec-directory v='C:\Program Files\FAHClient'/>
23:30:08:  <exit-when-done v='false'/>
23:30:08:  <max-delay v='21600'/>
23:30:08:  <min-delay v='60'/>
23:30:08:  <threads v='4'/>
23:30:08:
23:30:08:  <!-- Configuration -->
23:30:08:  <config-rotate v='true'/>
23:30:08:  <config-rotate-dir v='configs'/>
23:30:08:  <config-rotate-max v='16'/>
23:30:08:
23:30:08:  <!-- Debugging -->
23:30:08:  <assignment-servers>
23:30:08:    assign3.stanford.edu:8080 assign4.stanford.edu:80
23:30:08:  </assignment-servers>
23:30:08:  <capture-directory v='capture'/>
23:30:08:  <capture-sockets v='false'/>
23:30:08:  <debug-sockets v='false'/>
23:30:08:  <exception-locations v='true'/>
23:30:08:  <gpu-assignment-servers>
23:30:08:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
23:30:08:  </gpu-assignment-servers>
23:30:08:  <stack-traces v='false'/>
23:30:08:
23:30:08:  <!-- Error Handling -->
23:30:08:  <max-slot-errors v='5'/>
23:30:08:  <max-unit-errors v='5'/>
23:30:08:
23:30:08:  <!-- FahCore Control -->
23:30:08:  <checkpoint v='15'/>
23:30:08:  <core-dir v='cores'/>
23:30:08:  <core-priority v='idle'/>
23:30:08:  <cpu-affinity v='false'/>
23:30:08:  <cpu-usage v='100'/>
23:30:08:  <no-assembly v='false'/>
23:30:08:
23:30:08:  <!-- Folding Slot Configuration -->
23:30:08:  <client-subtype v='STDCLI'/>
23:30:08:  <client-type v='normal'/>
23:30:08:  <cpu-species v='X86_PENTIUM_II'/>
23:30:08:  <cpu-type v='X86'/>
23:30:08:  <cpus v='1'/>
23:30:08:  <extra-core-args v='-forceasm'/>
23:30:08:  <gpu v='false'/>
23:30:08:  <gpu-id v='0'/>
23:30:08:  <max-packet-size v='normal'/>
23:30:08:  <os-species v='WIN_XP'/>
23:30:08:  <os-type v='WIN32'/>
23:30:08:  <project-key v='0'/>
23:30:08:  <smp v='false'/>
23:30:08:
23:30:08:  <!-- Logging -->
23:30:08:  <log v='log.txt'/>
23:30:08:  <log-color v='false'/>
23:30:08:  <log-crlf v='true'/>
23:30:08:  <log-date v='false'/>
23:30:08:  <log-debug v='true'/>
23:30:08:  <log-domain v='false'/>
23:30:08:  <log-header v='true'/>
23:30:08:  <log-level v='true'/>
23:30:08:  <log-no-info-header v='true'/>
23:30:08:  <log-redirect v='false'/>
23:30:08:  <log-rotate v='true'/>
23:30:08:  <log-rotate-dir v='logs'/>
23:30:08:  <log-rotate-max v='16'/>
23:30:08:  <log-short-level v='false'/>
23:30:08:  <log-simple-domains v='true'/>
23:30:08:  <log-thread-id v='false'/>
23:30:08:  <log-time v='true'/>
23:30:08:  <log-to-screen v='true'/>
23:30:08:  <log-truncate v='false'/>
23:30:08:  <verbosity v='4'/>
23:30:08:
23:30:08:  <!-- Process Control -->
23:30:08:  <child v='false'/>
23:30:08:  <daemon v='false'/>
23:30:08:  <pid v='false'/>
23:30:08:  <pid-file v='Folding@home Client.pid'/>
23:30:08:  <respawn v='false'/>
23:30:08:  <service v='false'/>
23:30:08:
23:30:08:  <!-- Remote Command Server -->
23:30:08:  <command-address v='0.0.0.0'/>
23:30:08:  <command-allow v='127.0.0.1'/>
23:30:08:  <command-allow-no-pass v='127.0.0.1'/>
23:30:08:  <command-deny v='0.0.0.0/0'/>
23:30:08:  <command-deny-no-pass v='0.0.0.0/0'/>
23:30:08:  <command-port v='36330'/>
23:30:08:  <password v=''/>
23:30:08:
23:30:08:  <!-- Slot Control -->
23:30:08:  <max-shutdown-wait v='60'/>
23:30:08:  <pause-on-battery v='true'/>
23:30:08:  <pause-on-start v='false'/>
23:30:08:
23:30:08:  <!-- User Information -->
23:30:08:  <machine-id v='0'/>
23:30:08:  <passkey v='********************************'/>
23:30:08:  <team v='0'/>
23:30:08:  <user v='GreyWhiskers'/>
23:30:08:
23:30:08:  <!-- Work Unit Control -->
23:30:08:  <dump-after-deadline v='true'/>
23:30:08:  <max-queue v='16'/>
23:30:08:  <max-units v='0'/>
23:30:08:  <next-unit-percentage v='99'/>
23:30:08:
23:30:08:  <!-- Folding Slots -->
23:30:08:  <slot id='0' type='UNIPROCESSOR'>
23:30:08:    <client-type v='advanced'/>
23:30:08:  </slot>
23:30:08:</config>
Snip.  Several successfully completed WUs.
01:24:20:Unit 01:Completed 232500 out of 250000 steps  (93%)
01:34:15:Unit 01:Writing local files
01:34:15:Unit 01:Completed 235000 out of 250000 steps  (94%)
01:44:08:Unit 01:Writing local files
01:44:08:Unit 01:Completed 237500 out of 250000 steps  (95%)
01:54:24:Unit 01:Writing local files
01:54:24:Unit 01:Completed 240000 out of 250000 steps  (96%)
02:04:59:Unit 01:Writing local files
02:04:59:Unit 01:Completed 242500 out of 250000 steps  (97%)
02:15:23:Unit 01:Writing local files
02:15:23:Unit 01:Completed 245000 out of 250000 steps  (98%)
02:18:29:Server connection id=19 on 0.0.0.0:36330 from 192.168.10.200:2368
02:25:08:Unit 01:Writing local files
02:25:08:Unit 01:Completed 247500 out of 250000 steps  (99%)
02:25:09:Connecting to assign3.stanford.edu:8080
02:25:11:News: Welcome to Folding@Home
02:25:11:Assigned to work server 171.64.65.62
02:25:11:Requesting new work unit for slot 00: RUNNING uniprocessor from 171.64.65.62
02:25:11:Connecting to 171.64.65.62:8080
02:25:12:Slot 00: Downloading 504.80KiB
02:25:17:Slot 00: Download complete
02:25:17:Received Unit: id:00 state:DOWNLOAD project:6503 run:16 clone:557 gen:91 core:0x78 unit:0x4a1b8bcb4de6f48d005b022d00101967
02:33:47:Server connection id=20 on 0.0.0.0:36330 from 192.168.10.200:2387
02:35:03:Unit 01:Writing local files
02:35:03:Unit 01:Completed 250000 out of 250000 steps  (100%)
02:35:03:Unit 01:Writing final coordinates.
02:35:04:Unit 01:Past main M.D. loop
02:36:04:Unit 01:
02:36:04:Unit 01:Finished Work Unit:
02:36:04:Unit 01:- Reading up to 405144 from "01/wudata_01.arc": Read 405144
02:36:04:Unit 01:- Reading up to 48672 from "01/wudata_01.xtc": Read 48672
02:36:04:Unit 01:goefile size: 0
02:36:04:Unit 01:logfile size: 28864
02:36:04:Unit 01:Leaving Run
02:36:09:Unit 01:- Writing 499020 bytes of core data to disk...
02:36:09:Unit 01:Done: 498508 -> 448537 (compressed to 89.9 percent)
02:36:09:Unit 01:  ... Done.
02:36:09:Unit 01:- Shutting down core
02:36:09:Unit 01:
02:36:09:Unit 01:Folding@home Core Shutdown: FINISHED_UNIT
02:36:10:FahCore running Unit 01 returned: FINISHED_UNIT (100)
02:36:10:Sending unit results: id:01 state:SEND project:6505 run:3 clone:352 gen:77 core:0x78 unit:0x297755284de60d21004d016000031969
02:36:10:Starting Unit 00
02:36:10:Unit 01: Uploading 438.52KiB
02:36:10:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 5868 -version 701 -checkpoint 15 -forceasm
02:36:10:Connecting to 171.64.65.62:8080
02:36:10:Started core on PID 5600
02:36:10:FahCore 0x78 started
02:36:11:Unit 00:
02:36:11:Unit 00:*------------------------------*
02:36:11:Unit 00:Folding@Home Gromacs Core
02:36:11:Unit 00:Version 1.90 (March 8, 2006)
02:36:11:Unit 00:
02:36:11:Unit 00:Preparing to commence simulation
02:36:11:Unit 00:- Assembly optimizations manually forced on.
02:36:11:Unit 00:- Not checking prior termination.
02:36:11:Unit 00:- Expanded 516403 -> 2531477 (decompressed 490.2 percent)
02:36:11:Unit 00:- Starting from initial work packet
02:36:11:Unit 00:
02:36:11:Unit 00:Project: 6503 (Run 16, Clone 557, Gen 91)
02:36:11:Unit 00:
02:36:11:Unit 00:Assembly optimizations on if available.
02:36:11:Unit 00:Entering M.D.
02:36:13:Unit 01: Upload complete
02:36:13:Server responded WORK_ACK (400)
02:36:13:Cleaning up Unit 01
02:36:17:Unit 00:Protein: TR462_B_17 in water
02:36:17:Unit 00:
02:36:17:Unit 00:Writing local files
02:36:18:Unit 00:Extra SSE boost OK.
02:36:18:Unit 00:Writing local files
02:36:18:Unit 00:Completed 0 out of 250000 steps  (0%)
02:46:10:Unit 00:Writing local files
02:46:10:Unit 00:Completed 2500 out of 250000 steps  (1%)
02:55:54:Unit 00:Writing local files
02:55:54:Unit 00:Completed 5000 out of 250000 steps  (2%)
03:05:44:Unit 00:Writing local files
03:05:44:Unit 00:Completed 7500 out of 250000 steps  (3%)
03:15:34:Unit 00:Writing local files
03:15:34:Unit 00:Completed 10000 out of 250000 steps  (4%)
03:25:28:Unit 00:Writing local files
03:25:29:Unit 00:Completed 12500 out of 250000 steps  (5%)
03:36:18:Unit 00:Writing local files
03:36:18:Unit 00:Completed 15000 out of 250000 steps  (6%)
03:46:28:Unit 00:Writing local files
03:46:28:Unit 00:Completed 17500 out of 250000 steps  (7%)
03:56:50:Unit 00:Writing local files
03:56:50:Unit 00:Completed 20000 out of 250000 steps  (8%)
04:05:47:Unit 00:
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
Re: Project: 6503 (Run 16, Clone 557, Gen 91) EUE after 8%
bump
Multiple donors had an issue with the WU:
The WU (P6503,R16,C557,G91) has been reported as a bad WU.
Thanks for your report.
