Project: 6541 (Run 2, Clone 15, Gen 83) EUE after 18%
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
21:21:54:Unit 01:Completed 45000 out of 250000 steps (18%)
21:32:50:Unit 01:Gromacs cannot continue further.
21:32:50:Unit 01:Going to send back what have done.
21:32:50:Unit 01:logfile size: 16584
21:32:50:Unit 01:- Writing 17120 bytes of core data to disk...
21:32:50:Unit 01:Done: 16608 -> 4372 (compressed to 26.3 percent)
21:32:50:Unit 01: ... Done.
21:32:50:Unit 01:
21:32:50:Unit 01:Folding@home Core Shutdown: EARLY_UNIT_END
21:32:50:FahCore running Unit 01 returned: BAD_WORK_UNIT (114)
21:32:50:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
Of course, the client never succeeds in closing out the partial upload, and continues to hammer the Stanford server. EDIT: killed the slot manually.
Downloaded new WU, and at 8% completion now. Project: 6507 (Run 13, Clone 240, Gen 80)
It was pretty obvious this occurred by the v7.1.21 FAHControl GUI - there was an extra line in the work queue for Sending, while the other slot was Running.
*********************** Log Started 22/May/2011-09:54:19 ***********************
09:54:19:************************* Folding@home Client *************************
09:54:19:      Website: http://folding.stanford.edu/
09:54:19:    Copyright: (c) 2009,2010 Stanford University
09:54:19:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:54:19:         Args: --lifeline 2356
09:54:19:       Config: C:/Documents and Settings/Admin/Application
09:54:19:               Data/FAHClient/config.xml
09:54:19:******************************** Build ********************************
09:54:19:      Version: 7.1.21
09:54:19:         Date: Mar 23 2011
09:54:19:         Time: 15:13:48
09:54:19:      SVN Rev: 2883
09:54:19:       Branch: fah/trunk/client
09:54:19:     Compiler: Intel(R) C++ MSVC 1500 mode 1110
09:54:19:      Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE
09:54:19:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
09:54:19:     Platform: win32 XP
09:54:19:         Bits: 32
09:54:19:         Mode: Release
09:54:19:******************************* System ********************************
09:54:19:           OS: Microsoft Windows XP Home Edition
09:54:19:          CPU: Intel(R) Pentium(R) M processor 1.73GHz
09:54:19:       CPU ID: GenuineIntel Family 6 Model 13 Stepping 8
09:54:19:         CPUs: 1
09:54:19:       Memory: 1.99GiB
09:54:19:  Free Memory: 968.25MiB
09:54:19:      Threads: WINDOWS_THREADS
09:54:19:         GPUs: 0
09:54:19:         CUDA: Not detected
09:54:19:   On Battery: false
09:54:19:   UTC offset: -7
09:54:19:          PID: 5960
09:54:19:          CWD: C:/Documents and Settings/Admin/Application Data/FAHClient
09:54:19:Win32 Service: false
09:54:19:***********************************************************************
09:54:19:<config>
09:54:19:  <service-description v='Folding@home Client'/>
09:54:19:  <service-restart v='true'/>
09:54:19:  <service-restart-delay v='5000'/>
09:54:19:
09:54:19:  <!-- Client Control -->
09:54:19:  <cycle-rate v='4'/>
09:54:19:  <cycles v='-1'/>
09:54:19:  <data-directory v='.'/>
09:54:19:  <exec-directory v='C:\Program Files\FAHClient'/>
09:54:19:  <exit-when-done v='false'/>
09:54:19:  <max-delay v='21600'/>
09:54:19:  <min-delay v='60'/>
09:54:19:  <threads v='4'/>
09:54:19:
09:54:19:  <!-- Configuration -->
09:54:19:  <config-rotate v='true'/>
09:54:19:  <config-rotate-dir v='configs'/>
09:54:19:  <config-rotate-max v='16'/>
09:54:19:
09:54:19:  <!-- Debugging -->
09:54:19:  <assignment-servers>
09:54:19:    assign3.stanford.edu:8080 assign4.stanford.edu:80
09:54:19:  </assignment-servers>
09:54:19:  <capture-directory v='capture'/>
09:54:19:  <capture-sockets v='false'/>
09:54:19:  <debug-sockets v='false'/>
09:54:19:  <exception-locations v='true'/>
09:54:19:  <gpu-assignment-servers>
09:54:19:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
09:54:19:  </gpu-assignment-servers>
09:54:19:  <stack-traces v='false'/>
09:54:19:
09:54:19:  <!-- Error Handling -->
09:54:19:  <max-slot-errors v='5'/>
09:54:19:  <max-unit-errors v='5'/>
09:54:19:
09:54:19:  <!-- FahCore Control -->
09:54:19:  <checkpoint v='15'/>
09:54:19:  <core-dir v='cores'/>
09:54:19:  <core-priority v='idle'/>
09:54:19:  <cpu-affinity v='false'/>
09:54:19:  <cpu-usage v='100'/>
09:54:19:  <no-assembly v='false'/>
09:54:19:
09:54:19:  <!-- Folding Slot Configuration -->
09:54:19:  <client-subtype v='STDCLI'/>
09:54:19:  <client-type v='normal'/>
09:54:19:  <cpu-species v='X86_PENTIUM_II'/>
09:54:19:  <cpu-type v='X86'/>
09:54:19:  <cpus v='1'/>
09:54:19:  <extra-core-args v='-forceasm'/>
09:54:19:  <gpu v='false'/>
09:54:19:  <gpu-id v='0'/>
09:54:19:  <max-packet-size v='normal'/>
09:54:19:  <os-species v='WIN_XP'/>
09:54:19:  <os-type v='WIN32'/>
09:54:19:  <project-key v='0'/>
09:54:19:  <smp v='false'/>
09:54:19:
09:54:19:  <!-- Logging -->
09:54:19:  <log v='log.txt'/>
09:54:19:  <log-color v='false'/>
09:54:19:  <log-crlf v='true'/>
09:54:19:  <log-date v='false'/>
09:54:19:  <log-debug v='true'/>
09:54:19:  <log-domain v='false'/>
09:54:19:  <log-header v='true'/>
09:54:19:  <log-level v='true'/>
09:54:19:  <log-no-info-header v='true'/>
09:54:19:  <log-redirect v='false'/>
09:54:19:  <log-rotate v='true'/>
09:54:19:  <log-rotate-dir v='logs'/>
09:54:19:  <log-rotate-max v='16'/>
09:54:19:  <log-short-level v='false'/>
09:54:19:  <log-simple-domains v='true'/>
09:54:19:  <log-thread-id v='false'/>
09:54:19:  <log-time v='true'/>
09:54:19:  <log-to-screen v='true'/>
09:54:19:  <log-truncate v='false'/>
09:54:19:  <verbosity v='4'/>
09:54:19:
09:54:19:  <!-- Process Control -->
09:54:19:  <child v='false'/>
09:54:19:  <daemon v='false'/>
09:54:19:  <pid v='false'/>
09:54:19:  <pid-file v='Folding@home Client.pid'/>
09:54:19:  <respawn v='false'/>
09:54:19:  <service v='false'/>
09:54:19:
09:54:19:  <!-- Remote Command Server -->
09:54:19:  <command-address v='0.0.0.0'/>
09:54:19:  <command-allow v='127.0.0.1'/>
09:54:19:  <command-allow-no-pass v='127.0.0.1'/>
09:54:19:  <command-deny v='0.0.0.0/0'/>
09:54:19:  <command-deny-no-pass v='0.0.0.0/0'/>
09:54:19:  <command-port v='36330'/>
09:54:19:  <password v=''/>
09:54:19:
09:54:19:  <!-- Slot Control -->
09:54:19:  <max-shutdown-wait v='60'/>
09:54:19:  <pause-on-battery v='true'/>
09:54:19:  <pause-on-start v='false'/>
09:54:19:
09:54:19:  <!-- User Information -->
09:54:19:  <machine-id v='0'/>
09:54:19:  <passkey v='********************************'/>
09:54:19:  <team v='0'/>
09:54:19:  <user v='GreyWhiskers'/>
09:54:19:
09:54:19:  <!-- Work Unit Control -->
09:54:19:  <dump-after-deadline v='true'/>
09:54:19:  <max-queue v='16'/>
09:54:19:  <max-units v='0'/>
09:54:19:  <next-unit-percentage v='99'/>
09:54:19:
09:54:19:  <!-- Folding Slots -->
09:54:19:  <slot id='0' type='UNIPROCESSOR'>
09:54:19:    <client-type v='advanced'/>
09:54:19:  </slot>
09:54:19:</config>
SNIP  (7 completed WUs - it's now 29 May 2011)
17:38:02:Unit 00:Completed 245000 out of 250000 steps  (98%)
17:46:31:Unit 00:Writing local files
17:46:31:Unit 00:Completed 247500 out of 250000 steps  (99%)
17:46:32:Connecting to assign3.stanford.edu:8080
17:46:32:News: Welcome to Folding@Home
17:46:32:Assigned to work server 171.64.65.62
17:46:32:Requesting new work unit for slot 00: RUNNING uniprocessor from 171.64.65.62
17:46:32:Connecting to 171.64.65.62:8080
17:46:33:Slot 00: Downloading 579.27KiB
17:46:33:Slot 00: Download complete
17:46:33:Received Unit: id:01 state:DOWNLOAD project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
17:54:58:Unit 00:Writing local files
17:54:58:Unit 00:Completed 250000 out of 250000 steps  (100%)
17:54:58:Unit 00:Writing final coordinates.
17:54:58:Unit 00:Past main M.D. loop
17:55:58:Unit 00:
17:55:58:Unit 00:Finished Work Unit:
17:55:58:Unit 00:- Reading up to 362808 from "00/wudata_01.arc": Read 362808
17:55:58:Unit 00:- Reading up to 234480 from "00/wudata_01.xtc": Read 234480
17:55:58:Unit 00:goefile size: 0
17:55:58:Unit 00:logfile size: 59748
17:55:58:Unit 00:Leaving Run
17:56:03:Unit 00:- Writing 700708 bytes of core data to disk...
17:56:03:Unit 00:Done: 700196 -> 621593 (compressed to 88.7 percent)
17:56:03:Unit 00:  ... Done.
17:56:03:Unit 00:- Shutting down core
17:56:03:Unit 00:
17:56:03:Unit 00:Folding@home Core Shutdown: FINISHED_UNIT
17:56:04:FahCore running Unit 00 returned: FINISHED_UNIT (100)
17:56:04:Sending unit results: id:00 state:SEND project:6522 run:9 clone:92 gen:93 core:0x78 unit:0x63c861684de1a8ff005d005c0009197a
17:56:04:Starting Unit 01
17:56:04:Unit 00: Uploading 607.52KiB
17:56:04:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 01 -suffix 01 -lifeline 5960 -version 701 -checkpoint 15 -forceasm
17:56:04:Connecting to 171.64.65.62:8080
17:56:04:Started core on PID 684
17:56:04:FahCore 0x78 started
17:56:04:Unit 01:
17:56:04:Unit 01:*------------------------------*
17:56:04:Unit 01:Folding@Home Gromacs Core
17:56:04:Unit 01:Version 1.90 (March 8, 2006)
17:56:04:Unit 01:
17:56:04:Unit 01:Preparing to commence simulation
17:56:04:Unit 01:- Assembly optimizations manually forced on.
17:56:04:Unit 01:- Not checking prior termination.
17:56:05:Unit 01:- Expanded 592658 -> 2967617 (decompressed 500.7 percent)
17:56:05:Unit 01:- Starting from initial work packet
17:56:05:Unit 01:
17:56:05:Unit 01:Project: 6541 (Run 2, Clone 15, Gen 83)
17:56:05:Unit 01:
17:56:05:Unit 01:Assembly optimizations on if available.
17:56:05:Unit 01:Entering M.D.
17:56:08:Unit 00: Upload complete
17:56:08:Server responded WORK_ACK (400)
17:56:08:Cleaning up Unit 00
17:56:11:Unit 01:Protein: ubiq_3 in water
17:56:11:Unit 01:
17:56:11:Unit 01:Writing local files
17:56:12:Unit 01:Extra SSE boost OK.
17:56:12:Unit 01:Writing local files
17:56:12:Unit 01:Completed 0 out of 250000 steps  (0%)
18:07:22:Unit 01:Writing local files
18:07:22:Unit 01:Completed 2500 out of 250000 steps  (1%)
18:18:35:Unit 01:Writing local files
18:18:35:Unit 01:Completed 5000 out of 250000 steps  (2%)
18:29:47:Unit 01:Writing local files
18:29:47:Unit 01:Completed 7500 out of 250000 steps  (3%)
18:40:59:Unit 01:Writing local files
18:40:59:Unit 01:Completed 10000 out of 250000 steps  (4%)
18:52:09:Unit 01:Writing local files
18:52:09:Unit 01:Completed 12500 out of 250000 steps  (5%)
19:03:24:Unit 01:Writing local files
19:03:24:Unit 01:Completed 15000 out of 250000 steps  (6%)
19:14:21:Server connection id=45 on 0.0.0.0:36330 from 192.168.10.200:1907
19:15:15:Unit 01:Writing local files
19:15:16:Unit 01:Completed 17500 out of 250000 steps  (7%)
19:26:30:Unit 01:Writing local files
19:26:30:Unit 01:Completed 20000 out of 250000 steps  (8%)
19:30:37:Server connection id=46 on 0.0.0.0:36330 from 192.168.10.200:1920
19:37:41:Unit 01:Writing local files
19:37:41:Unit 01:Completed 22500 out of 250000 steps  (9%)
19:49:23:Unit 01:Writing local files
19:49:23:Unit 01:Completed 25000 out of 250000 steps  (10%)
20:00:54:Unit 01:Writing local files
20:00:54:Unit 01:Completed 27500 out of 250000 steps  (11%)
20:12:33:Unit 01:Writing local files
20:12:33:Unit 01:Completed 30000 out of 250000 steps  (12%)
20:24:05:Unit 01:Writing local files
20:24:05:Unit 01:Completed 32500 out of 250000 steps  (13%)
20:35:38:Unit 01:Writing local files
20:35:38:Unit 01:Completed 35000 out of 250000 steps  (14%)
20:47:12:Unit 01:Writing local files
20:47:12:Unit 01:Completed 37500 out of 250000 steps  (15%)
20:58:47:Unit 01:Writing local files
20:58:47:Unit 01:Completed 40000 out of 250000 steps  (16%)
21:10:17:Unit 01:Writing local files
21:10:17:Unit 01:Completed 42500 out of 250000 steps  (17%)
21:21:54:Unit 01:Writing local files
21:32:50:Unit 01:
21:32:50:Connecting to assign3.stanford.edu:8080
21:32:50:Unit 01: Uploading 4.77KiB
21:32:50:Connecting to 171.64.65.62:8080
21:32:51:WARNING: Exception: Failed to send results to work server: Failed to read response packet
21:32:51:Trying to send results to collection server
21:32:51:News: Welcome to Folding@Home
21:32:51:Unit 01: Uploading 4.77KiB
21:32:51:Assigned to work server 171.64.65.62
21:32:51:Connecting to 171.67.108.25:8080
21:32:51:Requesting new work unit for slot 00: READY uniprocessor from 171.64.65.62
21:32:51:Connecting to 171.64.65.62:8080
21:32:51:Slot 00: Downloading 612.32KiB
21:32:52:WARNING: WorkServer connection failed on port 8080 trying 80
21:32:52:Connecting to 171.67.108.25:80
21:32:52:Slot 00: Download complete
21:32:52:Received Unit: id:00 state:DOWNLOAD project:6507 run:13 clone:240 gen:80 core:0x78 unit:0x316b968b4de2bb86005000f0000d196b
21:32:52:Starting Unit 00
21:32:52:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 5960 -version 701 -checkpoint 15 -forceasm
21:32:53:Started core on PID 3616
21:32:53:FahCore 0x78 started
21:32:53:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
21:32:53:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
21:32:53:Unit 01: Uploading 4.77KiB
21:32:53:Connecting to 171.64.65.62:8080
21:32:53:WARNING: Exception: Failed to send results to work server: Failed to read response packet
21:32:53:Trying to send results to collection server
21:32:53:Unit 00:
21:32:53:Unit 00:*------------------------------*
21:32:53:Unit 00:Folding@Home Gromacs Core
21:32:53:Unit 00:Version 1.90 (March 8, 2006)
21:32:53:Unit 00:
21:32:53:Unit 00:Preparing to commence simulation
21:32:53:Unit 00:- Assembly optimizations manually forced on.
21:32:53:Unit 00:- Not checking prior termination.
21:32:53:Unit 00:- Expanded 626501 -> 3099845 (decompressed 494.7 percent)
21:32:53:Unit 00:- Starting from initial work packet
21:32:53:Unit 00:
21:32:53:Unit 00:Project: 6507 (Run 13, Clone 240, Gen 80)
21:32:53:Unit 00:
21:32:53:Connecting to 171.67.108.25:8080
21:32:53:Unit 00:Assembly optimizations on if available.
21:32:53:Unit 00:Entering M.D.
21:32:54:WARNING: WorkServer connection failed on port 8080 trying 80
21:32:54:Connecting to 171.67.108.25:80
21:32:55:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
21:33:00:Unit 00:Protein: 1CFC_B_14 in water
21:33:00:Unit 00:
21:33:00:Unit 00:Writing local files
21:33:00:Unit 00:Extra SSE boost OK.
21:33:00:Unit 00:Completed 0 out of 250000 steps  (0%)
21:33:53:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
21:33:53:Unit 01: Uploading 4.77KiB
21:33:53:Connecting to 171.64.65.62:8080
21:33:53:WARNING: Exception: Failed to send results to work server: Failed to read response packet
21:33:53:Trying to send results to collection server
21:33:53:Connecting to 171.67.108.25:8080
21:33:54:WARNING: WorkServer connection failed on port 8080 trying 80
21:33:54:Connecting to 171.67.108.25:80
21:33:55:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
21:35:30:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
21:35:31:Unit 01: Uploading 4.77KiB
21:35:31:Connecting to 171.64.65.62:8080
21:35:32:WARNING: Exception: Failed to send results to work server: Failed to read response packet
21:35:32:Trying to send results to collection server
21:35:32:Unit 01: Uploading 4.77KiB
21:35:32:Connecting to 171.67.108.25:8080
21:35:33:WARNING: WorkServer connection failed on port 8080 trying 80
21:35:33:Connecting to 171.67.108.25:80
21:35:34:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
21:38:07:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
21:38:08:Unit 01: Uploading 4.77KiB
21:38:08:Connecting to 171.64.65.62:8080
21:38:08:WARNING: Exception: Failed to send results to work server: Failed to read response packet
21:38:08:Trying to send results to collection server
21:38:08:Connecting to 171.67.108.25:8080
21:38:09:WARNING: WorkServer connection failed on port 8080 trying 80
21:38:09:Connecting to 171.67.108.25:80
21:38:10:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
21:42:22:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
21:42:22:Unit 01: Uploading 4.77KiB
21:42:22:Connecting to 171.64.65.62:8080
21:42:22:WARNING: Exception: Failed to send results to work server: Failed to read response packet
21:42:22:Trying to send results to collection server
21:42:23:Unit 01: Uploading 4.77KiB
21:42:23:Connecting to 171.67.108.25:8080
21:42:24:WARNING: WorkServer connection failed on port 8080 trying 80
21:42:24:Connecting to 171.67.108.25:80
21:42:25:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
21:45:06:Unit 00:Writing local files
21:45:06:Unit 00:Completed 2500 out of 250000 steps  (1%)
21:49:13:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
21:49:13:Unit 01: Uploading 4.77KiB
21:49:13:Connecting to 171.64.65.62:8080
21:49:13:WARNING: Exception: Failed to send results to work server: Failed to read response packet
21:49:13:Trying to send results to collection server
21:49:13:Connecting to 171.67.108.25:8080
21:49:14:WARNING: WorkServer connection failed on port 8080 trying 80
21:49:14:Connecting to 171.67.108.25:80
21:49:15:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
21:57:13:Unit 00:Writing local files
21:57:14:Unit 00:Completed 5000 out of 250000 steps  (2%)
22:00:19:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
22:00:19:Unit 01: Uploading 4.77KiB
22:00:19:Connecting to 171.64.65.62:8080
22:00:19:WARNING: Exception: Failed to send results to work server: Failed to read response packet
22:00:19:Trying to send results to collection server
22:00:19:Connecting to 171.67.108.25:8080
22:00:20:WARNING: WorkServer connection failed on port 8080 trying 80
22:00:20:Connecting to 171.67.108.25:80
22:00:21:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
22:09:19:Unit 00:Writing local files
22:09:19:Unit 00:Completed 7500 out of 250000 steps  (3%)
22:18:15:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
22:18:15:Unit 01: Uploading 4.77KiB
22:18:15:Connecting to 171.64.65.62:8080
22:18:15:WARNING: Exception: Failed to send results to work server: Failed to read response packet
22:18:15:Trying to send results to collection server
22:18:16:Unit 01: Uploading 4.77KiB
22:18:16:Connecting to 171.67.108.25:8080
22:18:17:WARNING: WorkServer connection failed on port 8080 trying 80
22:18:17:Connecting to 171.67.108.25:80
22:18:18:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
22:21:25:Unit 00:Writing local files
22:21:25:Unit 00:Completed 10000 out of 250000 steps  (4%)
22:33:30:Unit 00:Writing local files
22:33:30:Unit 00:Completed 12500 out of 250000 steps  (5%)
22:45:42:Unit 00:Writing local files
22:45:42:Unit 00:Completed 15000 out of 250000 steps  (6%)
22:47:17:Sending unit results: id:01 state:SEND project:6541 run:2 clone:15 gen:83 core:0x78 unit:0x764e71354de2867b0053000f0002198d
22:47:18:Unit 01: Uploading 4.77KiB
22:47:18:Connecting to 171.64.65.62:8080
22:47:18:WARNING: Exception: Failed to send results to work server: Failed to read response packet
22:47:18:Trying to send results to collection server
22:47:18:Connecting to 171.67.108.25:8080
22:47:19:WARNING: WorkServer connection failed on port 8080 trying 80
22:47:19:Connecting to 171.67.108.25:80
22:47:20:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
EUE on my tertiary computer - 2005-era Toshiba laptop CPU: Intel(R) Pentium(R) M processor 1.73GHz running single slot 24/7 for 11 months +. This laptop gets about 110 ppd out of my total.
sortofageek
Re: Project: 6541 (Run 2, Clone 15, Gen 83) EUE after 18%
Post by sortofageek »
I did check Project: 6541 (Run 2, Clone 15, Gen 83), but no data back yet.
GreyWhiskers wrote:...It was pretty obvious this occurred by the v7.1.21 FAHControl GUI...
Is there a reason that you haven't upgraded to V7.1.24?
See Ticket #615
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
Some inertia - some initial difficulty making my two computers running v7 connect via remote. So, I ended up just staying with v7.1.21 until the next beta.
