Running Multiple Clients (Intel i7 x990 12 CPUs)
Hi, I am very interested in running multiple Console versions of this client and I read as much as I could understand about how to achieve this on the FAQ but it does not seem to be reflecting on my User Statistics, it only reports 1 Client Active when I tried to have 1 GUI and 4 Console clients running.
What I did was the following:
1) Download/Install GUI Client
2) Download/Extract Console Client ( f@h_1 )
3) Download/Extract Console Client ( f@h_2 )
4) Download/Extract Console Client ( f@h_3 )
5) Download/Extract Console Client ( f@h_4 )
6) Run GUI Client - Adv. Settings ( -local and ID: 1 )
7) Run f@h_1 - Adv. Settings ( -local and ID: 2 )
8) Run f@h_2 - Adv. Settings ( -local and ID: 3 )
9) Run f@h_3 - Adv. Settings ( -local and ID: 4 )
10) Run f@h_4 - Adv. Settings ( -local and ID: 5 )
Note: All Clients are from the High Performance Clients page
At this point, I had 5 f@h clients running, 1 GUI and 4 Console. But after 2 WUs worth of completion my User Stats still only report 1 Active Client.
I could use some help, please.
My system specs are:
Intel Core i7 990X (6x 3.46GHz/12MB L3 Cache) (12 CPUs)
6 GB DDR3-1600
ATI Radeon HD 5770 - 1GB - HIS IceQ 5 Turbo - Core: 875MHz - CrossFire Mode (Dual Cards)
OS: Windows 7 Home Premium 64-bit
6 GB DDR3-1600
Re: Running Multiple Clients (Intel i7 x990 12 CPUs)
There have been two WUs returned using different MachineIDs but both WUs had errors and received no credit.
You said that you installed a single GUI Client with ID: 1 but the servers received these two GPU WUs from different Machine IDs.
Hi natedp (team 158630),
Your WU (P5734 R2 C606 G407) was added to the stats database on 2011-05-26 23:05:20 for 0 points of credit.
Your WU (P5732 R2 C591 G420) was added to the stats database on 2011-05-26 21:05:24 for 0 points of credit.
I'm not sure how the servers count clients that have only returned 0-point errors. I suggest you post the FAHlog.txt from the ones you believe have completed WUs and we can see what's going on.
I don't know why you selected -advmethods. That does increase your chances of having errors like the ones that have been reported, but the two are not necessarily related.
Logically, you may want to run two GPU clients, one for each GPU but let's leave that for a later discussion after you get something working.
Did you consider the V7 client? One of it's biggest benefits is a greatly simplified installation. Since you're new to FAH and you're trying to create a complex installation, I think you should also seriously consider scrapping what you've done with V6 client and try the V7 beta client. Most people who are running V7 don't run into any serious problems and compared to the problems that you'll probably encounter before you get everything working in V6, V7 is going to be a breeze.
You'll also benefit because you'll be able to use FahCore_16 which provides OpenCL support for the HD5xxx hardware.
Have you thought aboutr running just the one SMP client and setting it to use all your available cores? (or just 10, so you leave space for your gpu)
Alright so @ bruce,
I did change my GUI Machine ID at one point to get them in order, because it defaulted to 2 (not 1, as the FAQs suggests) and I want my GUI to be #1 and the Consoles to be IDs 2,3,4,5 respectively.
This may be why it reported 2 different Machine ID's when the WUs were returned.
For the V7, I cannot locate that. All the files I see available are all 6.something and the 1.something for PS3
@ k1wi, Would this be an overall increase to my F@H points production without killing my ability to actually do stuff while I am at my computer?
All in all, I would like to maximize my F@H production and maintain the ability to do things. I chat on IRC, browse forums and watch DVDs or play copies of my games using emulation software.
Ok, after this last update I see that I have 511 Score, 3 WUs returned and 2 Active Clients.
I am guessing 1 of my 4 Console Clients was finally working or at least contacting the server as well as my GPU client.
I have uninstalled the V6 GPU Client and deleted all but 1 Console Client folders. I will allow this current client to run while I sleep and see how things look.
I will check this thread when I get up and see about getting my hands on either this V7 Client and/or using the SMP method, provided I can figure it out with whatever information is available.
Thanks for the replies and any future help!
This is the FAHLog.txt for my only remaining client, which will remain running overnight.
--- Opening Log file [May 27 03:19:41 UTC]
Folding@Home Client Version 6.41r2
http://folding.stanford.edu
Launch directory: C:\Users\Nathan\Documents\Folding@home-Win32-GPU_XP-641
Executable: C:\Users\Nathan\Documents\Folding@home-Win32-GPU_XP-641\Folding@home-Win32-gpu.exe
[03:19:41] Gpu type=1 species=4.
[03:19:41] Configuring Folding@Home...
[03:20:47] - Ask before connecting: No
[03:20:47] - User name: natedp (Team 158630)
[03:20:47] - User ID:
[03:20:47] - Machine ID: 2
[03:20:47]
A potential conflict was detected:
Process 2096 is currently running and may also be a client with Mach. ID 2.
The program will now exit. Upon restart, this check will not be done --
You may wish to check that no client is currently running in
C:\Users\Nathan\AppData\Roaming\Folding@home-gpu before restarting.
Please press any key to exit.
--- Opening Log file [May 27 03:21:33 UTC]
[03:21:33] - Ask before connecting: No
[03:21:33] - User name: natedp (Team 158630)
[03:21:33] - User ID:
[03:21:33] - Machine ID: 2
[03:21:33]
[03:21:33] Gpu type=1 species=4.
[03:21:33] Work directory not found. Creating...
[03:21:33] Could not open work queue, generating new queue...
[03:21:33] - Preparing to get new work unit...
[03:21:33] Cleaning up work directory
[03:21:33] + Attempting to get work packet
[03:21:33] - Connecting to assignment server
[03:21:33] - Successful: assigned to (171.64.65.102).
[03:21:33] + News From Folding@Home: Welcome to Folding@Home
[03:21:33] Loaded queue successfully.
[03:21:34] + Closed connections
[03:21:34]
[03:21:34] + Processing work unit
[03:21:34] Core required: FahCore_11.exe
[03:21:34] Core not found.
[03:21:34] - Core is not present or corrupted.
[03:21:34] - Attempting to download new core...
[03:21:34] + Downloading new core: FahCore_11.exe
[03:21:34] + 10240 bytes downloaded
[03:21:34] + 20480 bytes downloaded
[03:21:34] + 30720 bytes downloaded
[03:21:34] + 40960 bytes downloaded
[03:21:34] + 51200 bytes downloaded
[03:21:34] + 61440 bytes downloaded
[03:21:34] + 71680 bytes downloaded
[03:21:34] + 81920 bytes downloaded
[03:21:34] + 92160 bytes downloaded
[03:21:34] + 102400 bytes downloaded
[03:21:34] + 112640 bytes downloaded
[03:21:34] + 122880 bytes downloaded
[03:21:34] + 133120 bytes downloaded
[03:21:34] + 143360 bytes downloaded
[03:21:34] + 153600 bytes downloaded
[03:21:34] + 163840 bytes downloaded
[03:21:34] + 174080 bytes downloaded
[03:21:34] + 184320 bytes downloaded
[03:21:35] + 194560 bytes downloaded
[03:21:35] + 204800 bytes downloaded
[03:21:35] + 215040 bytes downloaded
[03:21:35] + 225280 bytes downloaded
[03:21:35] + 235520 bytes downloaded
[03:21:35] + 245760 bytes downloaded
[03:21:35] + 256000 bytes downloaded
[03:21:35] + 266240 bytes downloaded
[03:21:35] + 276480 bytes downloaded
[03:21:35] + 286720 bytes downloaded
[03:21:35] + 296960 bytes downloaded
[03:21:35] + 307200 bytes downloaded
[03:21:35] + 317440 bytes downloaded
[03:21:35] + 327680 bytes downloaded
[03:21:35] + 337920 bytes downloaded
[03:21:35] + 348160 bytes downloaded
[03:21:35] + 358400 bytes downloaded
[03:21:35] + 368640 bytes downloaded
[03:21:35] + 378880 bytes downloaded
[03:21:35] + 389120 bytes downloaded
[03:21:35] + 399360 bytes downloaded
[03:21:35] + 409600 bytes downloaded
[03:21:35] + 419840 bytes downloaded
[03:21:35] + 430080 bytes downloaded
[03:21:35] + 440320 bytes downloaded
[03:21:35] + 450560 bytes downloaded
[03:21:35] + 460800 bytes downloaded
[03:21:35] + 471040 bytes downloaded
[03:21:35] + 481280 bytes downloaded
[03:21:35] + 491520 bytes downloaded
[03:21:35] + 501760 bytes downloaded
[03:21:35] + 512000 bytes downloaded
[03:21:35] + 522240 bytes downloaded
[03:21:35] + 532480 bytes downloaded
[03:21:35] + 542720 bytes downloaded
[03:21:35] + 552960 bytes downloaded
[03:21:35] + 563200 bytes downloaded
[03:21:35] + 573440 bytes downloaded
[03:21:35] + 583680 bytes downloaded
[03:21:35] + 593920 bytes downloaded
[03:21:35] + 604160 bytes downloaded
[03:21:35] + 614400 bytes downloaded
[03:21:35] + 624640 bytes downloaded
[03:21:35] + 634880 bytes downloaded
[03:21:35] + 645120 bytes downloaded
[03:21:35] + 655360 bytes downloaded
[03:21:35] + 665600 bytes downloaded
[03:21:35] + 675840 bytes downloaded
[03:21:35] + 686080 bytes downloaded
[03:21:35] + 696320 bytes downloaded
[03:21:35] + 706560 bytes downloaded
[03:21:35] + 716800 bytes downloaded
[03:21:35] + 727040 bytes downloaded
[03:21:35] + 737280 bytes downloaded
[03:21:35] + 747520 bytes downloaded
[03:21:35] + 757760 bytes downloaded
[03:21:35] + 768000 bytes downloaded
[03:21:35] + 778240 bytes downloaded
[03:21:35] + 788480 bytes downloaded
[03:21:35] + 798720 bytes downloaded
[03:21:35] + 808960 bytes downloaded
[03:21:35] + 819200 bytes downloaded
[03:21:35] + 829440 bytes downloaded
[03:21:35] + 839680 bytes downloaded
[03:21:35] + 849920 bytes downloaded
[03:21:35] + 860160 bytes downloaded
[03:21:35] + 870400 bytes downloaded
[03:21:35] + 880640 bytes downloaded
[03:21:35] + 890880 bytes downloaded
[03:21:35] + 901120 bytes downloaded
[03:21:35] + 911360 bytes downloaded
[03:21:35] + 921600 bytes downloaded
[03:21:35] + 931840 bytes downloaded
[03:21:35] + 942080 bytes downloaded
[03:21:35] + 952320 bytes downloaded
[03:21:35] + 962560 bytes downloaded
[03:21:35] + 972800 bytes downloaded
[03:21:35] + 983040 bytes downloaded
[03:21:35] + 993280 bytes downloaded
[03:21:35] + 1003520 bytes downloaded
[03:21:35] + 1013760 bytes downloaded
[03:21:35] + 1024000 bytes downloaded
[03:21:35] + 1034240 bytes downloaded
[03:21:35] + 1044480 bytes downloaded
[03:21:35] + 1054720 bytes downloaded
[03:21:35] + 1064960 bytes downloaded
[03:21:36] + 1075200 bytes downloaded
[03:21:36] + 1085440 bytes downloaded
[03:21:36] + 1091180 bytes downloaded
[03:21:36] Verifying core Core_11.fah...
[03:21:36] Signature is VALID
[03:21:36]
[03:21:36] Trying to unzip core FahCore_11.exe
[03:21:36] Decompressed FahCore_11.exe (3203072 bytes) successfully
[03:21:41] + Core successfully engaged
[03:21:46]
[03:21:46] + Processing work unit
[03:21:46] Core required: FahCore_11.exe
[03:21:46] Core found.
[03:21:46] Working on queue slot 01 [May 27 03:21:46 UTC]
[03:21:46] + Working ...
[03:21:46]
[03:21:46] *------------------------------*
[03:21:46] Folding@Home GPU Core - Beta
[03:21:46] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[03:21:46]
[03:21:46] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:21:46] Build host: amoeba
[03:21:46] Board Type: AMD
[03:21:46] Core :
[03:21:46] Preparing to commence simulation
[03:21:46] - Looking at optimizations...
[03:21:46] - Created dyn
[03:21:46] - Files status OK
[03:21:46] - Expanded 98700 -> 492188 (decompressed 498.6 percent)
[03:21:46] Called DecompressByteArray: compressed_data_size=98700 data_size=492188, decompressed_data_size=492188 diff=0
[03:21:46] - Digital signature verified
[03:21:46]
[03:21:46] Project: 5732 (Run 2, Clone 591, Gen 420)
[03:21:46]
[03:21:46] Assembly optimizations on if available.
[03:21:46] Entering M.D.
[03:21:53] Tpr hash work/wudata_01.tpr: 2935677777 786864377 1971191424 3513625127 49451913
[03:21:53] Working on Protein
[03:21:53] Client config found, loading data.
[03:21:53] Starting GUI Server
Folding@Home Client Shutdown.
--- Opening Log file [May 27 03:26:51 UTC]
[03:26:51] - Ask before connecting: No
[03:26:51] - User name: natedp (Team 158630)
[03:26:51] - User ID:
[03:26:51] - Machine ID: 2
[03:26:51]
[03:26:51] Gpu type=1 species=4.
[03:26:52] Loaded queue successfully.
[03:26:52]
[03:26:52] + Processing work unit
[03:26:52] Core required: FahCore_11.exe
[03:26:52] Core found.
[03:26:52] Working on queue slot 01 [May 27 03:26:52 UTC]
[03:26:52] + Working ...
[03:26:52]
[03:26:52] *------------------------------*
[03:26:52] Folding@Home GPU Core - Beta
[03:26:52] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[03:26:52]
[03:26:52] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:26:52] Build host: amoeba
[03:26:52] Board Type: AMD
[03:26:52] Core :
[03:26:52] Preparing to commence simulation
[03:26:52] - Looking at optimizations...
[03:26:52] - Files status OK
[03:26:52] - Expanded 98700 -> 492188 (decompressed 498.6 percent)
[03:26:52] Called DecompressByteArray: compressed_data_size=98700 data_size=492188, decompressed_data_size=492188 diff=0
[03:26:52] - Digital signature verified
[03:26:52]
[03:26:52] Project: 5732 (Run 2, Clone 591, Gen 420)
[03:26:52]
[03:26:52] Assembly optimizations on if available.
[03:26:52] Entering M.D.
[03:26:58] Will resume from checkpoint file
[03:26:58] Tpr hash work/wudata_01.tpr: 2935677777 786864377 1971191424 3513625127 49451913
[03:26:58] Working on Protein
[03:26:58] Client config found, loading data.
[03:26:58] Starting GUI Server
[03:27:00] Resuming from checkpoint
[03:27:00] fcCheckPointResume: retreived and current tpr file hash:
[03:27:00] 0 2935677777 2935677777
[03:27:00] 1 786864377 786864377
[03:27:00] 2 1971191424 1971191424
[03:27:00] 3 3513625127 3513625127
[03:27:00] 4 49451913 49451913
[03:27:00] Run: exception thrown during GuardedRun
[03:27:00] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[03:27:00] Going to send back what have done -- stepsTotalG=10000000
[03:27:00] Work fraction=0.0000 steps=10000000.
[03:27:04] logfile size=15723 infoLength=15723 edr=0 trr=23
[03:27:04] - Writing 16259 bytes of core data to disk...
[03:27:04] Done: 15747 -> 5349 (compressed to 33.9 percent)
[03:27:04] ... Done.
[03:27:04]
[03:27:04] Folding@home Core Shutdown: EARLY_UNIT_END
[03:27:10] CoreStatus = 72 (114)
[03:27:10] Sending work to server
[03:27:10] Project: 5732 (Run 2, Clone 591, Gen 420)
[03:27:10] + Attempting to send results [May 27 03:27:10 UTC]
[03:27:10] Gpu type=1 species=4.
[03:27:10] + Results successfully sent
[03:27:10] Thank you for your contribution to Folding@Home.
[03:27:15] - Preparing to get new work unit...
[03:27:15] Cleaning up work directory
[03:27:15] + Attempting to get work packet
[03:27:15] Gpu type=1 species=4.
[03:27:15] - Connecting to assignment server
[03:27:15] - Successful: assigned to (171.64.65.102).
[03:27:15] + News From Folding@Home: Welcome to Folding@Home
[03:27:15] Loaded queue successfully.
[03:27:15] + Closed connections
[03:27:20]
[03:27:20] + Processing work unit
[03:27:20] Core required: FahCore_11.exe
[03:27:20] Core found.
[03:27:20] Working on queue slot 02 [May 27 03:27:20 UTC]
[03:27:20] + Working ...
[03:27:21]
[03:27:21] *------------------------------*
[03:27:21] Folding@Home GPU Core - Beta
[03:27:21] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[03:27:21]
[03:27:21] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:27:21] Build host: amoeba
[03:27:21] Board Type: AMD
[03:27:21] Core :
[03:27:21] Preparing to commence simulation
[03:27:21] - Looking at optimizations...
[03:27:21] - Created dyn
[03:27:21] - Files status OK
[03:27:21] - Expanded 96661 -> 489152 (decompressed 506.0 percent)
[03:27:21] Called DecompressByteArray: compressed_data_size=96661 data_size=489152, decompressed_data_size=489152 diff=0
[03:27:21] - Digital signature verified
[03:27:21]
[03:27:21] Project: 5737 (Run 2, Clone 573, Gen 395)
[03:27:21]
[03:27:21] Assembly optimizations on if available.
[03:27:21] Entering M.D.
[03:27:27] Tpr hash work/wudata_02.tpr: 1226914085 2637872384 3068163440 3048951818 1079645664
[03:27:27] Working on Protein
[03:27:27] Client config found, loading data.
[03:27:27] Starting GUI Server
[03:33:38] Completed 1%
[03:39:45] Completed 2%
[03:46:20] Completed 3%
--- Opening Log file [May 27 04:13:28 UTC]
[04:13:28] - Ask before connecting: No
[04:13:28] - User name: natedp (Team 158630)
[04:13:28] - User ID:
[04:13:28] - Machine ID: 2
[04:13:28]
[04:13:28] Gpu type=1 species=4.
[04:13:28] Loaded queue successfully.
[04:13:28]
[04:13:28] + Processing work unit
[04:13:28] Core required: FahCore_11.exe
[04:13:28] Core found.
[04:13:28] Working on queue slot 02 [May 27 04:13:28 UTC]
[04:13:28] + Working ...
[04:13:28]
[04:13:28] *------------------------------*
[04:13:28] Folding@Home GPU Core - Beta
[04:13:28] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[04:13:28]
[04:13:28] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:13:28] Build host: amoeba
[04:13:28] Board Type: AMD
[04:13:28] Core :
[04:13:28] Preparing to commence simulation
[04:13:28] - Looking at optimizations...
[04:13:28] - Created dyn
[04:13:28] - Files status OK
[04:13:28] Error: Missing work file=<>
[04:13:28]
[04:13:28] Folding@home Core Shutdown: MISSING_WORK_FILES
[04:13:32] CoreStatus = 74 (116)
[04:13:32] The core could not find the work files specified. Removing from queue
[04:13:32] Deleting current work unit & continuing...
[04:13:36] - Preparing to get new work unit...
[04:13:36] Cleaning up work directory
[04:13:36] + Attempting to get work packet
[04:13:36] Gpu type=1 species=4.
[04:13:36] - Connecting to assignment server
[04:13:36] - Successful: assigned to (171.64.65.102).
[04:13:36] + News From Folding@Home: Welcome to Folding@Home
[04:13:37] Loaded queue successfully.
[04:13:37] Gpu type=1 species=4.
[04:13:37] + Closed connections
[04:13:42]
[04:13:42] + Processing work unit
[04:13:42] Core required: FahCore_11.exe
[04:13:42] Core found.
[04:13:42] Working on queue slot 03 [May 27 04:13:42 UTC]
[04:13:42] + Working ...
[04:13:42]
[04:13:42] *------------------------------*
[04:13:42] Folding@Home GPU Core - Beta
[04:13:42] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[04:13:42]
[04:13:42] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:13:42] Build host: amoeba
[04:13:42] Board Type: AMD
[04:13:42] Core :
[04:13:42] Preparing to commence simulation
[04:13:42] - Looking at optimizations...
[04:13:42] - Created dyn
[04:13:42] - Files status OK
[04:13:42] - Expanded 96661 -> 489152 (decompressed 506.0 percent)
[04:13:42] Called DecompressByteArray: compressed_data_size=96661 data_size=489152, decompressed_data_size=489152 diff=0
[04:13:42] - Digital signature verified
[04:13:42]
[04:13:42] Project: 5737 (Run 2, Clone 573, Gen 395)
[04:13:42]
[04:13:42] Assembly optimizations on if available.
[04:13:42] Entering M.D.
[04:13:48] Tpr hash work/wudata_03.tpr: 1226914085 2637872384 3068163440 3048951818 1079645664
[04:13:48] Working on Protein
[04:13:49] Client config found, loading data.
[04:13:49] Starting GUI Server
--- Opening Log file [May 27 05:54:11 UTC]
Launch directory: C:\Users\Nathan\Desktop\Folding @ Home\Folding@home-Win32-GPU_XP-641
Executable: C:\Users\Nathan\Desktop\Folding @ Home\Folding@home-Win32-GPU_XP-641\Folding@home-Win32-gpu.exe
Arguments: -local
[05:54:11] - Ask before connecting: No
[05:54:11] - User name: natedp (Team 158630)
[05:54:11] - User ID:
[05:54:11] - Machine ID: 4
[05:54:11]
[05:54:11] Gpu type=1 species=4.
Process 1100 is currently running and may also be a client with Mach. ID 4.
C:\Users\Nathan\Documents\Folding@home-Win32-GPU_XP-641-3 before restarting.
--- Opening Log file [May 27 05:54:31 UTC]
Arguments: -local
[05:54:31] - Ask before connecting: No
[05:54:31] - User name: natedp (Team 158630)
[05:54:31] - User ID:
[05:54:31] - Machine ID: 4
[05:54:31]
[05:54:31] Gpu type=1 species=4.
[05:54:31] Loaded queue successfully.
[05:54:31]
[05:54:31] + Processing work unit
[05:54:31] Core required: FahCore_11.exe
[05:54:31] Core found.
[05:54:31] Working on queue slot 03 [May 27 05:54:31 UTC]
[05:54:31] + Working ...
[05:54:31]
[05:54:31] *------------------------------*
[05:54:31] Folding@Home GPU Core - Beta
[05:54:31] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[05:54:31]
[05:54:31] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:54:31] Build host: amoeba
[05:54:31] Board Type: AMD
[05:54:31] Core :
[05:54:31] Preparing to commence simulation
[05:54:31] - Looking at optimizations...
[05:54:31] - Created dyn
[05:54:31] - Files status OK
[05:54:31] Error: Missing work file=<>
[05:54:31]
[05:54:31] Folding@home Core Shutdown: MISSING_WORK_FILES
[05:54:36] CoreStatus = 74 (116)
[05:54:36] The core could not find the work files specified. Removing from queue
[05:54:36] Deleting current work unit & continuing...
[05:54:40] - Preparing to get new work unit...
[05:54:40] Cleaning up work directory
[05:54:40] + Attempting to get work packet
[05:54:40] Gpu type=1 species=4.
[05:54:40] - Connecting to assignment server
[05:54:40] - Successful: assigned to (171.64.65.102).
[05:54:40] + News From Folding@Home: Welcome to Folding@Home
[05:54:40] Loaded queue successfully.
[05:54:41] + Closed connections
[05:54:46]
[05:54:46] + Processing work unit
[05:54:46] Core required: FahCore_11.exe
[05:54:46] Core found.
[05:54:46] Working on queue slot 04 [May 27 05:54:46 UTC]
[05:54:46] + Working ...
[05:54:46]
[05:54:46] *------------------------------*
[05:54:46] Folding@Home GPU Core - Beta
[05:54:46] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[05:54:46]
[05:54:46] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:54:46] Build host: amoeba
[05:54:46] Board Type: AMD
[05:54:46] Core :
[05:54:46] Preparing to commence simulation
[05:54:46] - Looking at optimizations...
[05:54:46] - Created dyn
[05:54:46] - Files status OK
[05:54:46] - Expanded 98755 -> 492188 (decompressed 498.3 percent)
[05:54:46] Called DecompressByteArray: compressed_data_size=98755 data_size=492188, decompressed_data_size=492188 diff=0
[05:54:46] - Digital signature verified
[05:54:46]
[05:54:46] Project: 5734 (Run 2, Clone 606, Gen 407)
[05:54:46]
[05:54:46] Assembly optimizations on if available.
[05:54:46] Entering M.D.
[05:54:52] Tpr hash work/wudata_04.tpr: 3181199704 909358215 1491427423 2999191876 3861723349
[05:55:09] Run: exception thrown during GuardedRun
[05:55:09] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[05:55:09] Going to send back what have done -- stepsTotalG=0
[05:55:09] Work fraction=0.0000 steps=0.
[05:55:13] logfile size=5061 infoLength=5061 edr=0 trr=23
[05:55:13] - Writing 5597 bytes of core data to disk...
[05:55:13] Done: 5085 -> 1916 (compressed to 37.6 percent)
[05:55:13] ... Done.
[05:55:13]
[05:55:13] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:55:16] CoreStatus = 7A (122)
[05:55:16] Sending work to server
[05:55:16] Project: 5734 (Run 2, Clone 606, Gen 407)
[05:55:16] + Attempting to send results [May 27 05:55:16 UTC]
[05:55:16] Gpu type=1 species=4.
[05:55:17] + Results successfully sent
[05:55:17] Thank you for your contribution to Folding@Home.
[05:55:21] - Preparing to get new work unit...
[05:55:21] Cleaning up work directory
[05:55:21] + Attempting to get work packet
[05:55:21] Gpu type=1 species=4.
[05:55:21] - Connecting to assignment server
[05:55:21] - Successful: assigned to (171.64.65.102).
[05:55:21] + News From Folding@Home: Welcome to Folding@Home
[05:55:21] Loaded queue successfully.
[05:55:22] + Closed connections
[05:55:27]
[05:55:27] + Processing work unit
[05:55:27] Core required: FahCore_11.exe
[05:55:27] Core found.
[05:55:27] Working on queue slot 05 [May 27 05:55:27 UTC]
[05:55:27] + Working ...
[05:55:27]
[05:55:27] *------------------------------*
[05:55:27] Folding@Home GPU Core - Beta
[05:55:27] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[05:55:27]
[05:55:27] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[05:55:27] Build host: amoeba
[05:55:27] Board Type: AMD
[05:55:27] Core :
[05:55:27] Preparing to commence simulation
[05:55:27] - Looking at optimizations...
[05:55:27] - Created dyn
[05:55:27] - Files status OK
[05:55:27] - Expanded 96733 -> 489152 (decompressed 505.6 percent)
[05:55:27] Called DecompressByteArray: compressed_data_size=96733 data_size=489152, decompressed_data_size=489152 diff=0
[05:55:27] - Digital signature verified
[05:55:27]
[05:55:27] Project: 5737 (Run 4, Clone 594, Gen 429)
[05:55:27]
[05:55:27] Assembly optimizations on if available.
[05:55:27] Entering M.D.
[05:55:33] Tpr hash work/wudata_05.tpr: 2514013199 4144680875 3605575836 3264549569 1797831773
[05:55:33] Working on Protein
[05:55:33] Client config found, loading data.
[05:55:33] Starting GUI Server
[05:58:38] Completed 1%
[06:01:42] Completed 2%
[06:04:40] Completed 3%
[06:07:39] Completed 4%
[06:10:40] Completed 5%
[06:13:42] Completed 6%
[06:16:48] Completed 7%
[06:19:51] Completed 8%
[06:22:56] Completed 9%
[06:25:57] Completed 10%
[06:28:56] Completed 11%
[06:32:00] Completed 12%
[06:35:03] Completed 13%
[06:38:03] Completed 14%
[06:41:04] Completed 15%
[06:44:05] Completed 16%
[06:47:04] Completed 17%
[06:50:09] Completed 18%
[06:53:09] Completed 19%
[06:56:08] Completed 20%
[06:59:10] Completed 21%
[07:02:08] Completed 22%
[07:05:07] Completed 23%
[07:08:06] Completed 24%
[07:11:04] Completed 25%
[07:14:04] Completed 26%
[07:17:04] Completed 27%
[07:20:04] Completed 28%
[07:23:04] Completed 29%
[07:26:02] Completed 30%
[07:29:01] Completed 31%
[07:32:01] Completed 32%
[07:34:59] Completed 33%
[07:37:58] Completed 34%
[07:40:57] Completed 35%
[07:43:55] Completed 36%
[07:46:54] Completed 37%
[07:49:54] Completed 38%
[07:52:53] Completed 39%
[07:55:52] Completed 40%
[07:58:52] Completed 41%
[08:01:51] Completed 42%
[08:04:51] Completed 43%
[08:07:51] Completed 44%
--- Opening Log file [May 27 08:11:41 UTC]
Arguments: -local
[08:11:41] - Ask before connecting: No
[08:11:41] - User name: natedp (Team 158630)
[08:11:41] - User ID:
[08:11:41] - Machine ID: 4
[08:11:41]
[08:11:41] Gpu type=1 species=4.
[08:11:42] Loaded queue successfully.
[08:11:42]
[08:11:42] + Processing work unit
[08:11:42] Core required: FahCore_11.exe
[08:11:42] Core found.
[08:11:42] Working on queue slot 05 [May 27 08:11:42 UTC]
[08:11:42] + Working ...
[08:11:42]
[08:11:42] *------------------------------*
[08:11:42] Folding@Home GPU Core - Beta
[08:11:42] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[08:11:42]
[08:11:42] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[08:11:42] Build host: amoeba
[08:11:42] Board Type: AMD
[08:11:42] Core :
[08:11:42] Preparing to commence simulation
[08:11:42] - Ensuring status. Please wait.
[08:11:51] - Looking at optimizations...
[08:11:51] - Working with standard loops on this execution.
[08:11:51] - Previous termination of core was improper.
[08:11:51] - Files status OK
[08:11:51] - Expanded 96733 -> 489152 (decompressed 505.6 percent)
[08:11:51] Called DecompressByteArray: compressed_data_size=96733 data_size=489152, decompressed_data_size=489152 diff=0
[08:11:51] - Digital signature verified
[08:11:51]
[08:11:51] Project: 5737 (Run 4, Clone 594, Gen 429)
[08:11:51]
[08:11:51] Entering M.D.
[08:11:58] Will resume from checkpoint file
[08:11:58] Tpr hash work/wudata_05.tpr: 2514013199 4144680875 3605575836 3264549569 1797831773
[08:11:58] Working on Protein
[08:11:58] Client config found, loading data.
[08:11:58] Starting GUI Server
[08:12:00] Resuming from checkpoint
[08:12:00] fcCheckPointResume: retreived and current tpr file hash:
[08:12:00] 0 2514013199 2514013199
[08:12:00] 1 4144680875 4144680875
[08:12:00] 2 3605575836 3605575836
[08:12:00] 3 3264549569 3264549569
[08:12:00] 4 1797831773 1797831773
[08:12:00] Verified work/wudata_05.log
[08:12:00] Verified work/wudata_05.edr
[08:12:00] Verified work/wudata_05.xtc
[08:12:00] Completed 44%
[08:14:47] Completed 45%
[08:17:37] Completed 46%
[08:20:26] Completed 47%
[08:23:14] Completed 48%
Personally I'd say your best bet would be to configure your client in SMP mode if your computer is on 24/7. Obviously you've got a really high powered machine CPU, so I would imagine that performance is important to you.
Therefore, what I'd suggest you try doing is starting off by configuring your folding client for -smp 10 and seeing whether there are any issues with your emulation gaming. I would suspect that there wouldn't be, but if you do find that there is, just drop down the -smp x value. If anything any slow down will be with your folding, but certainly not to the point where your folding performance would drop below that achieved by running multiple regular uni-processor clients. I'd recommend a 'clean' install and following the smp installation guide to the letter (including starting the client with -configonly to start with). In terms of PPD, SMP on an i7 990 will well and truly blow away any sort of multiple uni-proc clients, even if you just ran the same number of threads as you did uni-processor clients.
I know it might seem like a waste of good crunching hardware, but if you do end up running the SMP client, you'd possibly be better off stopping folding on the GPU, those ATI's aren't yet particularly efficient (although there is advancement with the new v7 client that bruce mentioned). Plus it would avoid you having to pause/resume it when you're gaming. All in all it's just a more efficient way to fold.
Make sure you're using a passkey though (this actually applies more and more for all clients) as with SMP and some uni-processor work units you will earn bonus points...
Finally, if you're overclocking at all, keep an eye on your log files/temps/general stability etc etc. FAH runs the CPU much much harder than pretty much any other app out there, even some stress testing apps, so if your machine is overclocked and even the least bit unstable, FAH will reveal it even if other apps don't!
The V7 client can be found here. I'm not pushing it ... just giving you the information you asked for.
If you're running 24x7, then a single SMP client with -smp 10 (or some other value) is much more productive and much easier to install than multiple uniprocessor clients. With dual HD 5770, you probably use your machine for gaming, and if any of the clients are going to interfere with your desired use of the machine, the GPU client(s) are more likely to be noticed than any of the CPU-based clients.
I had assumed that you had chosen multiple clients for a specific reason. We're happy to support you with whatever you choose, whether that's multiple V6 clients, the V7 client, or the SMP client and I should have asked more questions rather than simply answering the questions you asked.
Ok, so I checked in and saw that my Console version was erroring when trying to return the WU it had completed and then it couldn't retrieve a new WU to work on. So no progress was made. Removed all F@H instances from my PC and went with the SMP route.
I just completed the setup and it is now running, here is my FAHLog.txt after starting it up.
Does this look about correct?
--- Opening Log file [May 27 17:43:35 UTC]
Folding@Home Client Version 6.34
Launch directory: C:\Users\Nathan\FAH SMP
Executable: fah6
Arguments: -configonly -smp
[17:43:35] Configuring Folding@Home...
--- Opening Log file [May 27 17:45:15 UTC]
Executable: fah6
Arguments: -configonly -smp 10
[17:45:15] - Ask before connecting: No
[17:45:15] - User name: Anonymous (Team 0)
[17:45:15] - User ID: XXXXXXXXX
[17:45:15] - Machine ID: 1
[17:45:15]
[17:45:15] Configuring Folding@Home...
The program will continue in non-service mode now, working in C:\Users\Nathan\FAH SMP.
The next time the computer is starts up, you should see work automatically
continue there. Note that when this service is running, you should not try
to manually run F@H from that directory at the same time.
[17:53:28] - Ask before connecting: No
[17:53:28] - User name: natedp (Team 158630)
[17:53:28] - User ID: XXXXXXXXXXX
[17:53:28] - Machine ID: 1
[17:53:28]
[17:53:28] -configonly flag given, so exiting.
--- Opening Log file [May 27 17:55:40 UTC]
Executable: fah6
Arguments: -smp 10
[17:55:40] - Ask before connecting: No
[17:55:40] - User name: natedp (Team 158630)
[17:55:40] - User ID: XXXXXXXXXXXXXX
[17:55:40] - Machine ID: 1
[17:55:40]
[17:55:40] Work directory not found. Creating...
[17:55:40] Could not open work queue, generating new queue...
[17:55:40] - Preparing to get new work unit...
[17:55:40] Cleaning up work directory
[17:55:40] + Attempting to get work packet
[17:55:40] Passkey found
[17:55:40] - Connecting to assignment server
[17:55:40] - Successful: assigned to (171.64.65.54).
[17:55:40] + News From Folding@Home: Welcome to Folding@Home
[17:55:41] Loaded queue successfully.
[17:55:43] + Closed connections
[17:55:43]
[17:55:43] + Processing work unit
[17:55:43] Core required: FahCore_a3.exe
[17:55:43] Core not found.
[17:55:43] - Core is not present or corrupted.
[17:55:43] - Attempting to download new core...
[17:55:43] + Downloading new core: FahCore_a3.exe
[17:55:43] + 10240 bytes downloaded
[17:55:43] + 20480 bytes downloaded
[17:55:43] + 30720 bytes downloaded
[17:55:43] + 40960 bytes downloaded
[17:55:43] + 51200 bytes downloaded
[17:55:43] + 61440 bytes downloaded
[17:55:43] + 71680 bytes downloaded
[17:55:43] + 81920 bytes downloaded
[17:55:43] + 92160 bytes downloaded
[17:55:43] + 102400 bytes downloaded
[17:55:43] + 112640 bytes downloaded
[17:55:43] + 122880 bytes downloaded
[17:55:43] + 133120 bytes downloaded
[17:55:43] + 143360 bytes downloaded
[17:55:43] + 153600 bytes downloaded
[17:55:43] + 163840 bytes downloaded
[17:55:43] + 174080 bytes downloaded
[17:55:43] + 184320 bytes downloaded
[17:55:43] + 194560 bytes downloaded
[17:55:43] + 204800 bytes downloaded
[17:55:43] + 215040 bytes downloaded
[17:55:43] + 225280 bytes downloaded
[17:55:43] + 235520 bytes downloaded
[17:55:43] + 245760 bytes downloaded
[17:55:43] + 256000 bytes downloaded
[17:55:43] + 266240 bytes downloaded
[17:55:43] + 276480 bytes downloaded
[17:55:43] + 286720 bytes downloaded
[17:55:43] + 296960 bytes downloaded
[17:55:43] + 307200 bytes downloaded
[17:55:43] + 317440 bytes downloaded
[17:55:43] + 327680 bytes downloaded
[17:55:43] + 337920 bytes downloaded
[17:55:44] + 348160 bytes downloaded
[17:55:44] + 358400 bytes downloaded
[17:55:44] + 368640 bytes downloaded
[17:55:44] + 378880 bytes downloaded
[17:55:44] + 389120 bytes downloaded
[17:55:44] + 399360 bytes downloaded
[17:55:44] + 409600 bytes downloaded
[17:55:44] + 419840 bytes downloaded
[17:55:44] + 430080 bytes downloaded
[17:55:44] + 440320 bytes downloaded
[17:55:44] + 450560 bytes downloaded
[17:55:44] + 460800 bytes downloaded
[17:55:44] + 471040 bytes downloaded
[17:55:44] + 481280 bytes downloaded
[17:55:44] + 491520 bytes downloaded
[17:55:44] + 501760 bytes downloaded
[17:55:44] + 512000 bytes downloaded
[17:55:44] + 522240 bytes downloaded
[17:55:44] + 532480 bytes downloaded
[17:55:44] + 542720 bytes downloaded
[17:55:44] + 552960 bytes downloaded
[17:55:44] + 563200 bytes downloaded
[17:55:44] + 573440 bytes downloaded
[17:55:44] + 583680 bytes downloaded
[17:55:44] + 593920 bytes downloaded
[17:55:44] + 604160 bytes downloaded
[17:55:44] + 614400 bytes downloaded
[17:55:44] + 624640 bytes downloaded
[17:55:44] + 634880 bytes downloaded
[17:55:44] + 645120 bytes downloaded
[17:55:44] + 655360 bytes downloaded
[17:55:44] + 665600 bytes downloaded
[17:55:44] + 675840 bytes downloaded
[17:55:44] + 686080 bytes downloaded
[17:55:44] + 696320 bytes downloaded
[17:55:44] + 706560 bytes downloaded
[17:55:44] + 716800 bytes downloaded
[17:55:44] + 727040 bytes downloaded
[17:55:44] + 737280 bytes downloaded
[17:55:44] + 747520 bytes downloaded
[17:55:44] + 757760 bytes downloaded
[17:55:44] + 768000 bytes downloaded
[17:55:44] + 778240 bytes downloaded
[17:55:44] + 788480 bytes downloaded
[17:55:44] + 798720 bytes downloaded
[17:55:44] + 808960 bytes downloaded
[17:55:44] + 819200 bytes downloaded
[17:55:44] + 829440 bytes downloaded
[17:55:44] + 839680 bytes downloaded
[17:55:44] + 849920 bytes downloaded
[17:55:44] + 860160 bytes downloaded
[17:55:44] + 870400 bytes downloaded
[17:55:44] + 880640 bytes downloaded
[17:55:44] + 890880 bytes downloaded
[17:55:44] + 901120 bytes downloaded
[17:55:44] + 911360 bytes downloaded
[17:55:44] + 921600 bytes downloaded
[17:55:44] + 931840 bytes downloaded
[17:55:44] + 942080 bytes downloaded
[17:55:44] + 952320 bytes downloaded
[17:55:44] + 962560 bytes downloaded
[17:55:44] + 972800 bytes downloaded
[17:55:44] + 983040 bytes downloaded
[17:55:44] + 993280 bytes downloaded
[17:55:44] + 1003520 bytes downloaded
[17:55:44] + 1013760 bytes downloaded
[17:55:44] + 1024000 bytes downloaded
[17:55:44] + 1034240 bytes downloaded
[17:55:44] + 1044480 bytes downloaded
[17:55:44] + 1054720 bytes downloaded
[17:55:44] + 1064960 bytes downloaded
[17:55:44] + 1075200 bytes downloaded
[17:55:44] + 1085440 bytes downloaded
[17:55:44] + 1095680 bytes downloaded
[17:55:44] + 1105920 bytes downloaded
[17:55:44] + 1116160 bytes downloaded
[17:55:44] + 1126400 bytes downloaded
[17:55:44] + 1136640 bytes downloaded
[17:55:44] + 1146880 bytes downloaded
[17:55:44] + 1157120 bytes downloaded
[17:55:44] + 1167360 bytes downloaded
[17:55:44] + 1177600 bytes downloaded
[17:55:44] + 1187840 bytes downloaded
[17:55:44] + 1198080 bytes downloaded
[17:55:44] + 1208320 bytes downloaded
[17:55:44] + 1218560 bytes downloaded
[17:55:44] + 1228800 bytes downloaded
[17:55:44] + 1239040 bytes downloaded
[17:55:44] + 1249280 bytes downloaded
[17:55:44] + 1259520 bytes downloaded
[17:55:44] + 1269760 bytes downloaded
[17:55:44] + 1280000 bytes downloaded
[17:55:44] + 1290240 bytes downloaded
[17:55:44] + 1300480 bytes downloaded
[17:55:44] + 1310720 bytes downloaded
[17:55:44] + 1320960 bytes downloaded
[17:55:44] + 1331200 bytes downloaded
[17:55:44] + 1341440 bytes downloaded
[17:55:44] + 1351680 bytes downloaded
[17:55:44] + 1361920 bytes downloaded
[17:55:44] + 1372160 bytes downloaded
[17:55:44] + 1382400 bytes downloaded
[17:55:45] + 1392640 bytes downloaded
[17:55:45] + 1402880 bytes downloaded
[17:55:45] + 1413120 bytes downloaded
[17:55:45] + 1423360 bytes downloaded
[17:55:45] + 1433600 bytes downloaded
[17:55:45] + 1443840 bytes downloaded
[17:55:45] + 1454080 bytes downloaded
[17:55:45] + 1464320 bytes downloaded
[17:55:45] + 1474560 bytes downloaded
[17:55:45] + 1484800 bytes downloaded
[17:55:45] + 1495040 bytes downloaded
[17:55:45] + 1505280 bytes downloaded
[17:55:45] + 1515520 bytes downloaded
[17:55:45] + 1525760 bytes downloaded
[17:55:45] + 1536000 bytes downloaded
[17:55:45] + 1546240 bytes downloaded
[17:55:45] + 1556480 bytes downloaded
[17:55:45] + 1566720 bytes downloaded
[17:55:45] + 1576960 bytes downloaded
[17:55:45] + 1587200 bytes downloaded
[17:55:45] + 1597440 bytes downloaded
[17:55:45] + 1607680 bytes downloaded
[17:55:45] + 1617920 bytes downloaded
[17:55:45] + 1628160 bytes downloaded
[17:55:45] + 1638400 bytes downloaded
[17:55:45] + 1648640 bytes downloaded
[17:55:45] + 1658880 bytes downloaded
[17:55:45] + 1669120 bytes downloaded
[17:55:45] + 1679360 bytes downloaded
[17:55:45] + 1689600 bytes downloaded
[17:55:45] + 1699840 bytes downloaded
[17:55:45] + 1710080 bytes downloaded
[17:55:45] + 1720320 bytes downloaded
[17:55:45] + 1730560 bytes downloaded
[17:55:45] + 1740800 bytes downloaded
[17:55:45] + 1751040 bytes downloaded
[17:55:45] + 1761280 bytes downloaded
[17:55:45] + 1771520 bytes downloaded
[17:55:45] + 1781760 bytes downloaded
[17:55:45] + 1792000 bytes downloaded
[17:55:45] + 1802240 bytes downloaded
[17:55:45] + 1812480 bytes downloaded
[17:55:45] + 1822720 bytes downloaded
[17:55:45] + 1832960 bytes downloaded
[17:55:45] + 1843200 bytes downloaded
[17:55:45] + 1853440 bytes downloaded
[17:55:45] + 1863680 bytes downloaded
[17:55:45] + 1873920 bytes downloaded
[17:55:45] + 1884160 bytes downloaded
[17:55:45] + 1894400 bytes downloaded
[17:55:45] + 1904640 bytes downloaded
[17:55:45] + 1914880 bytes downloaded
[17:55:45] + 1925120 bytes downloaded
[17:55:45] + 1935360 bytes downloaded
[17:55:45] + 1945600 bytes downloaded
[17:55:45] + 1955840 bytes downloaded
[17:55:45] + 1966080 bytes downloaded
[17:55:45] + 1976320 bytes downloaded
[17:55:45] + 1986560 bytes downloaded
[17:55:45] + 1996800 bytes downloaded
[17:55:45] + 2007040 bytes downloaded
[17:55:45] + 2017280 bytes downloaded
[17:55:45] + 2027520 bytes downloaded
[17:55:45] + 2037760 bytes downloaded
[17:55:45] + 2048000 bytes downloaded
[17:55:45] + 2058240 bytes downloaded
[17:55:45] + 2068480 bytes downloaded
[17:55:45] + 2078720 bytes downloaded
[17:55:45] + 2088960 bytes downloaded
[17:55:45] + 2099200 bytes downloaded
[17:55:45] + 2109440 bytes downloaded
[17:55:45] + 2119680 bytes downloaded
[17:55:45] + 2129920 bytes downloaded
[17:55:45] + 2140160 bytes downloaded
[17:55:45] + 2150400 bytes downloaded
[17:55:45] + 2160640 bytes downloaded
[17:55:45] + 2170880 bytes downloaded
[17:55:45] + 2181120 bytes downloaded
[17:55:45] + 2191360 bytes downloaded
[17:55:45] + 2201600 bytes downloaded
[17:55:45] + 2211840 bytes downloaded
[17:55:45] + 2222080 bytes downloaded
[17:55:45] + 2232320 bytes downloaded
[17:55:45] + 2242560 bytes downloaded
[17:55:45] + 2252800 bytes downloaded
[17:55:45] + 2263040 bytes downloaded
[17:55:45] + 2273280 bytes downloaded
[17:55:45] + 2283520 bytes downloaded
[17:55:45] + 2293760 bytes downloaded
[17:55:45] + 2304000 bytes downloaded
[17:55:45] + 2314240 bytes downloaded
[17:55:45] + 2324480 bytes downloaded
[17:55:45] + 2334720 bytes downloaded
[17:55:45] + 2344960 bytes downloaded
[17:55:45] + 2355200 bytes downloaded
[17:55:45] + 2365440 bytes downloaded
[17:55:45] + 2375680 bytes downloaded
[17:55:45] + 2385920 bytes downloaded
[17:55:45] + 2396160 bytes downloaded
[17:55:45] + 2406400 bytes downloaded
[17:55:45] + 2416640 bytes downloaded
[17:55:45] + 2426880 bytes downloaded
[17:55:45] + 2437120 bytes downloaded
[17:55:45] + 2447360 bytes downloaded
[17:55:45] + 2457600 bytes downloaded
[17:55:45] + 2467840 bytes downloaded
[17:55:45] + 2478080 bytes downloaded
[17:55:46] + 2488320 bytes downloaded
[17:55:46] + 2498560 bytes downloaded
[17:55:46] + 2508800 bytes downloaded
[17:55:46] + 2519040 bytes downloaded
[17:55:46] + 2529280 bytes downloaded
[17:55:46] + 2539520 bytes downloaded
[17:55:46] + 2549760 bytes downloaded
[17:55:46] + 2560000 bytes downloaded
[17:55:46] + 2570240 bytes downloaded
[17:55:46] + 2580480 bytes downloaded
[17:55:46] + 2590720 bytes downloaded
[17:55:46] + 2600960 bytes downloaded
[17:55:46] + 2611200 bytes downloaded
[17:55:46] + 2621440 bytes downloaded
[17:55:46] + 2631680 bytes downloaded
[17:55:46] + 2641920 bytes downloaded
[17:55:46] + 2652160 bytes downloaded
[17:55:46] + 2662400 bytes downloaded
[17:55:46] + 2672640 bytes downloaded
[17:55:46] + 2682880 bytes downloaded
[17:55:46] + 2693120 bytes downloaded
[17:55:46] + 2703360 bytes downloaded
[17:55:46] + 2713600 bytes downloaded
[17:55:46] + 2723840 bytes downloaded
[17:55:46] + 2734080 bytes downloaded
[17:55:46] + 2744320 bytes downloaded
[17:55:46] + 2754560 bytes downloaded
[17:55:46] + 2764800 bytes downloaded
[17:55:46] + 2775040 bytes downloaded
[17:55:46] + 2785280 bytes downloaded
[17:55:46] + 2795520 bytes downloaded
[17:55:46] + 2805760 bytes downloaded
[17:55:46] + 2816000 bytes downloaded
[17:55:46] + 2826240 bytes downloaded
[17:55:46] + 2836480 bytes downloaded
[17:55:46] + 2846720 bytes downloaded
[17:55:46] + 2856960 bytes downloaded
[17:55:46] + 2867200 bytes downloaded
[17:55:46] + 2877440 bytes downloaded
[17:55:46] + 2887680 bytes downloaded
[17:55:46] + 2897920 bytes downloaded
[17:55:46] + 2908160 bytes downloaded
[17:55:46] + 2918400 bytes downloaded
[17:55:46] + 2928640 bytes downloaded
[17:55:46] + 2938880 bytes downloaded
[17:55:46] + 2949120 bytes downloaded
[17:55:46] + 2959360 bytes downloaded
[17:55:46] + 2969600 bytes downloaded
[17:55:46] + 2979840 bytes downloaded
[17:55:46] + 2990080 bytes downloaded
[17:55:46] + 3000320 bytes downloaded
[17:55:46] + 3010560 bytes downloaded
[17:55:46] + 3020800 bytes downloaded
[17:55:46] + 3028785 bytes downloaded
[17:55:46] Verifying core Core_a3.fah...
[17:55:46] Signature is VALID
[17:55:46]
[17:55:46] Trying to unzip core FahCore_a3.exe
[17:55:47] Decompressed FahCore_a3.exe (10057216 bytes) successfully
[17:55:52] + Core successfully engaged
[17:55:57]
[17:55:57] + Processing work unit
[17:55:57] Core required: FahCore_a3.exe
[17:55:57] Core found.
[17:55:57] Working on queue slot 01 [May 27 17:55:57 UTC]
[17:55:57] + Working ...
[17:55:57]
[17:55:57] *------------------------------*
[17:55:57] Folding@Home Gromacs SMP Core
[17:55:57] Version 2.27 (Dec. 15, 2010)
[17:55:57]
[17:55:57] Preparing to commence simulation
[17:55:57] - Looking at optimizations...
[17:55:57] - Created dyn
[17:55:57] - Files status OK
[17:55:58] - Expanded 1764704 -> 2253729 (decompressed 127.7 percent)
[17:55:58] Called DecompressByteArray: compressed_data_size=1764704 data_size=2253729, decompressed_data_size=2253729 diff=0
[17:55:58] - Digital signature verified
[17:55:58]
[17:55:58] Project: 6053 (Run 0, Clone 28, Gen 319)
[17:55:58]
[17:55:58] Assembly optimizations on if available.
[17:55:58] Entering M.D.
[17:56:03] Mapping NT from 10 to 10
[17:56:04] Completed 0 out of 500000 steps (0%)
yes.
Grandpa_01
- Hardware configuration: 3 - Supermicro H8QGi-F AMD MC 6174=144 cores 2.5Ghz, 96GB G.Skill DDR3 1333Mhz Ubuntu 10.10
Yes it is correct but if you are not going to run the GPU client's then you can run just -smp which will default to -smp 12. If you are gaming while folding then the -smp 10 is a better choice any way after you complete your 10 smp WU's and qualify for the bonus points you may want to consider running bigadv but that is a decision to make latter.
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
How do I run bigadv? I set the small/normal/big setting to Big when configuring my client.
Add the -bigadv flag in extra parameters or in the start string. You must have answered no to advanced methods during configuration.
I am afraid I do not recall that option or at least I don't recall seeing BIGADV specifically. I do know that I was prompted to choose Small, Normal, or Big file-sizes and I did input Big.
The following is from the SMP Install Guide that I followed to the letter...
Acceptable size of work assignment and work result packets (bigger units
may have large memory demands) -- 'small' is <5MB, 'normal' is <10MB, and
'big' is >10MB (small/normal/big) [normal]?
This option states a preference for the size of work units downloaded and uploaded to the project servers. Note that all SMP WUs are large in size, so big is the required setting. Bigger units will also have bigger memory requirements. If you run on a slower broadband or dialup internet connection, small is the recommended setting to ease your bandwidth usage and you may want to switch to the CPU client instead.
Change advanced options (yes/no) [no]? yes
If you want to change the advanced options, enter yes. It is not mandatory but is recommended for SMP installs.
Core Priority (idle/low) [idle]?
This adjusts the FAH client priority level. This is similar to, but not the same as the Windows priority setting. In most cases, the default idle setting is recommended.
Note: For better performance when mixing CPU or SMP clients with GPU clients, raise the priority of the GPU clients by selecting the low priority setting. Do NOT change the Windows priority settings for the client or fahcore.
CPU usage requested (5-100) [100]?
This will adjust the percentage of CPU usage. The FAH client only uses spare CPU cycles not used by other programs, so reducing this setting is not typically necessary. However, if you want to lower system temperatures, or reserve CPU cycles for more intensive computer tasks, enter a number below 100.In the SMP client, changing this setting does not reduce CPU usage.
Disable highly optimized assembly code (no/yes) [no]?
If you are having issues running the client, disable this. For 99.9% of the users, leave this at the default setting since this reduces the client performance a lot.
Pause if battery power is being used (useful for laptops) (no/yes) [no]?
If you run a laptop, set this to yes to pause if the laptop is not plugged on the wall. This will avoid the client draining the battery.(if name WinSMP*:)In the SMP client, this setting may not behave as expected.(if name WinGPU*:)In the GPU client, this setting may not behave as expected.
Interval, in minutes, between checkpoints (3-30) [15]?
Number of minutes between each checkpoint where the client is writing the client progress to disk in case of unexpected interruption. 15 is the recommended setting.
Memory, in MB, to indicate (1013 available) [1013]?
Sets the amount of memory seen by the work servers. By default, it shows the full system memory amount. Note that reducing this setting does not reserve more memory for other programs. However, reducing this setting will prevent the client from downloading memory intensive work units. A setting too low may prevent the client from getting any new work. (if name WinSMP*:)In the SMP client, .5 GB per CPU core is the minimum, while 1 GB per core is recommended.
Set -advmethods flag always, requesting new advanced
scientific cores and/or work units if available (no/yes) [no]?
This is the same as using the -advmethods command line flag, except -advmethods will not appear on the arguments line in the fahlog. This option states a preference to request late stage beta work units, which may be less stable than regular work units. May cause work unit size and PPD to increase, decrease, or not change.
Ignore any deadline information (mainly useful if
system clock frequently has errors) (no/yes) [no]?
Only set this to yes if your local computer clock is having issues keeping the correct date and time.
Machine ID (1-16) [1]?
This is the Machine Number of the client. If you are running more than one client under the same operating system, you need to have a different Machine ID for each client on that machine. If you are installing a single client on multiple computers, you do not need to change this since this is only for installing multiple clients on the same computer.
Launch automatically, install as a service in this directory (yes/no) [no]?
If you want the client to run as a service, say yes and it will install a new entry in the services list. The next time you restart the computer, the service will start automatically and run in the background. SMP as a service is only supported in v6.30 and newer.
Note: The current Windows user account must have Administrator privileges to install FAH as a service. And rebooting the computer to start the client running as a service is required.
The following options require you to restart the client before they take effect
Disable CPU affinity lock (no/yes) [no]?
Not useful for SMP since it use all cores.
Additional client parameters []?
You can enter the client flags here so you don't have to type the flag each time you run the client. We strongly suggest you enter the -smp Do NOT enter -config or -configonly'' or any single-use flag in this field to avoid problems.
IP address to bind core to (for viewer) []?
For future use when the Viewer is working better. Specifies the IP address of the machine of which the viewer should display the client output.-
Grandpa_01
It goes in the Additional client parameters []?
Additional client parameters []? -smp -bigadv
Alright, I see now. Thanks!
