Project: 10425 (Run 35822, Clone 0, Gen 37)
Abraham54
Post by Abraham54 »
My hardware specification first:
Dell Studio XPS M1645 - i7 , 8GB Ram, Seagate 320 Hybride-harddisk.
Windows 7 x64 with NIS2011
Since I use this notebook, every work-unit completed gave te following error when finished for uploading:
Server reports problem with unit..
I use Folding@Home Client Version 6.23".
Location of "Folding@Home": C:\Users\Abraham54\AppData\Local\Folding@home
This fact makes me unhappy, so at the moment all folding work is stopped.
Example:
[06:54:26] Project: 10425 (Run 35822, Clone 0, Gen 37)
[06:54:26]
[06:54:27] Entering M.D.
[06:54:33] Using Gromacs checkpoints
[06:54:34] Mapping NT from 1 to 1
[06:54:34] Resuming from checkpoint
[06:54:34] Verified work/wudata_01.log
[06:54:34] Verified work/wudata_01.trr
[06:54:34] Verified work/wudata_01.xtc
[06:54:34] Verified work/wudata_01.edr
[06:54:34] Completed 1945290 out of 2000000 steps  (97%)
[07:25:35] Completed 1960000 out of 2000000 steps  (98%)
[08:06:46] Completed 1980000 out of 2000000 steps  (99%)
[08:46:59] Completed 2000000 out of 2000000 steps  (100%)
[08:46:59] DynamicWrapper: Finished Work Unit: sleep=10000
[08:47:09]
[08:47:09] Finished Work Unit:
[08:47:09] - Reading up to 233640 from "work/wudata_01.trr": Read 233640
[08:47:09] trr file hash check passed.
[08:47:09] - Reading up to 1414180 from "work/wudata_01.xtc": Read 1414180
[08:47:09] xtc file hash check passed.
[08:47:09] edr file hash check passed.
[08:47:09] logfile size: 68213
[08:47:09] Leaving Run
[08:47:09] - Writing 1739297 bytes of core data to disk...
[08:47:10] Done: 1738785 -> 1686651 (compressed to 97.0 percent)
[08:47:10]   ... Done.
[08:47:10] - Shutting down core
[08:47:10]
[08:47:10] Folding@home Core Shutdown: FINISHED_UNIT
[08:47:13] CoreStatus = 64 (100)
[08:47:13] Sending work to server
[08:47:13] Project: 10425 (Run 35822, Clone 0, Gen 37)
[08:47:13] - Read packet limit of 540015616... Set to 524286976.
[08:47:13] + Attempting to send results [May 4 08:47:13 UTC]
[08:47:18] - Server reports problem with unit.
[08:47:18] - Preparing to get new work unit...
[08:47:18] + Attempting to get work packet
[08:47:18] - Connecting to assignment server
[08:47:19] - Successful: assigned to (171.64.65.84).
[08:47:19] + News From Folding@Home: Welcome to Folding@Home
[08:47:19] Loaded queue successfully.
[08:47:22] + Closed connections
John_Weatherman
Re: Server reports problem with unit
Post by John_Weatherman »
I've never seen a run number that high! I think you have a bad WU - maybe a kind Mod can check it out ... Have you been doing the same work over and over again? (have a look in the log file to see)
There's no record of the WU being returned yet. Like John, I don't remember seeing numbers that high but it does look like they're valid. I see that P10425 R35822 C0 G36 was added to the stats database on 2011-04-28 15:10:21 PDT and Gen 37 is created when Gen 36 is completed so it's perfectly reasonable that you received that WU soon after that.
The "server reports problem with unit" message generally means that the data is corrupt (which might have happened on your system or during the upload process) or when the WU has already been received (which apparently is NOT the case). Let it attempt to upload a few more times before you panic. ;)
You said you had troubles with other WUs. Please post a copy of the log from download through attempted upload.
Re: Project: 10425 (Run 35822, Clone 0, Gen 37)
The WU isn't a bad one since it was completed successfully by another Donor:
Your WU (P10425 R35822 C0 G37) was added to the stats database on 2011-05-27 06:05:32 for 194 points of credit.
