171.64.65.64 overloaded
No Fermi units coming down or going up to 171.64.65.64. Status page shows Net Load of 719. Spike or problem?
single 1070
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Re: 171.64.65.64 overloaded
Detailed server stats showing reject since Fri May 20 11:55:10 PDT 2011. Current status:
171.64.65.64 GPU vspg2v lin5 full Reject 1.05 1096 0 0 17883 3133 6 0 112848 112848 112848 -
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
Well, good news and bad news. It can't get the p6801 WUs that have been 99% of my GPU WUs lately. But, after five attempts to get new WU from 171.64.65.64, the assignment server connected me to 171.67.108.32, where it immediately loaded a p109xx WU.
My GTX 560 Ti gets 19,000 ppd on those puppies while consuming 36 fewer watts of wall-socket power, vs the 14,378 ppd from the usual p6801s.
Luck of the draw. We just take whatever the Stanford servers throw at us.
20:23:51] + Attempting to get work packet
[20:23:51] Passkey found
[20:23:51] - Will indicate memory of 4076 MB
[20:23:51] Gpu type=3 species=21.
[20:23:51] - Connecting to assignment server
[20:23:51] Connecting to http://assign-GPU.stanford.edu:8080/
[20:23:51] Posted data.
[20:23:51] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[20:23:51] + News From Folding@Home: Welcome to Folding@Home
[20:23:51] Loaded queue successfully.
[20:23:51] Sent data
[20:23:51] Connecting to http://171.64.65.64:8080/
[20:24:12] - Couldn't send HTTP request to server
[20:24:12] + Could not connect to Work Server
[20:24:12] - Attempt #5 to get work failed, and no other work to do.
Waiting before retry.
[20:25:46] + Attempting to get work packet
[20:25:46] Passkey found
[20:25:46] - Will indicate memory of 4076 MB
[20:25:46] Gpu type=3 species=21.
[20:25:46] - Connecting to assignment server
[20:25:46] Connecting to http://assign-GPU.stanford.edu:8080/
[20:25:46] Posted data.
[20:25:46] Initial: 43AB; - Successful: assigned to (171.67.108.32).
[20:25:46] + News From Folding@Home: Welcome to Folding@Home
[20:25:46] Loaded queue successfully.
I have 2 GPU clients (GTS 450) running 24/7 but can't upload results since [May 20 08:28:03 UTC]
Here is part of the log file:
From this thread - 171.64.65.54 - Reject [Emergency downtime], I restarted one GPU client to get it going again - it was just sitting there.
[08:28:03] + Attempting to send results [May 20 08:28:03 UTC]
[08:28:03] Gpu type=3 species=21.
[08:28:04] - Couldn't send HTTP request to server
[08:28:04] + Could not connect to Work Server (results)
[08:28:04] (171.64.65.64:8080)
[08:28:04] + Retrying using alternative port
[08:28:06] - Couldn't send HTTP request to server
[08:28:06] + Could not connect to Work Server (results)
[08:28:06] (171.64.65.64:80)
[08:28:06] - Error: Could not transmit unit 07 (completed May 20) to work server.
[08:28:06] Keeping unit 07 in queue.
[08:28:06] Project: 6801 (Run 9793, Clone 2, Gen 14)
[08:28:06] - Read packet limit of 540015616... Set to 524286976.
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
Still down, I guess. Same scenario as above - assigned to 171.64.65.64 for new WU. Couldn't connect. After 5 tries, failed back to assignment server where the assignment server connected me to 171.67.108.32, where it immediately loaded a p109xx WU. Folding away now, at the expense of 17 minutes of down-time.
At least you guys have something to fold. I haven't been able to get anything. I did try to shut down the fah program and restart to no avail.
My gpu folders have been sitting idle for hours now.
*hondo*
- Hardware configuration: Geoforce 250 GTS Active for F@H
4 Core Intel not used at all for F@H - Location: England UK
WUs failing to upload
Hello folks is there a problem with the server your end, I've got 2 WUs that are failing to upload
Cheers *hondo*
Mod Edit: Merged post into appropriate thread - PantherX
Cheers *hondo*
Folding@Home Client Version 6.41r2
http://folding.stanford.edu
Launch directory: C:\Documents and Settings\hondo\Application Data\Folding@home-gpu
[22:50:42] - Ask before connecting: No
[22:50:42] - User name: *hondo* (Team 51078)
[22:50:42] - User ID: 6EBE171B7E6C885A
[22:50:42] - Machine ID: 2
[22:50:42]
[22:50:42] Gpu type=3 species=21.
[22:50:43] Loaded queue successfully.
[22:50:43] Initialization complete
[22:50:43]
[22:50:43] + Processing work unit
[22:50:43] Project: 6805 (Run 6308, Clone 3, Gen 24)
[22:50:43] + Attempting to send results [May 20 22:50:43 UTC]
[22:50:43] Core required: FahCore_15.exe
[22:50:43] Core found.
[22:50:43] Gpu type=3 species=21.
[22:50:43] Working on queue slot 00 [May 20 22:50:43 UTC]
[22:50:43] + Working ...
[22:50:43]
[22:50:43] *------------------------------*
[22:50:43] Folding@Home GPU Core
[22:50:43] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[22:50:43]
[22:50:43] Build host: SimbiosNvdWin7
[22:50:43] Board Type: NVIDIA/CUDA
[22:50:43] Core : x=15
[22:50:43] Window's signal control handler registered.
[22:50:43] Preparing to commence simulation
[22:50:43] - Ensuring status. Please wait.
[22:50:44] - Couldn't send HTTP request to server
[22:50:44] + Could not connect to Work Server (results)
[22:50:44] (171.64.65.64:8080)
[22:50:44] + Retrying using alternative port
[22:50:46] - Couldn't send HTTP request to server
[22:50:46] + Could not connect to Work Server (results)
[22:50:46] (171.64.65.64:80)
[22:50:46] - Error: Could not transmit unit 08 (completed May 20) to work server.
[22:50:46] + Attempting to send results [May 20 22:50:46 UTC]
[22:50:46] Gpu type=3 species=21.
[22:50:52] - Looking at optimizations...
[22:50:52] - Working with standard loops on this execution.
[22:50:52] - Previous termination of core was improper.
[22:50:52] - Going to use standard loops.
[22:50:52] - Files status OK
[22:50:52] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:50:52] - Expanded 20702 -> 77571 (decompressed 374.7 percent)
[22:50:52] Called DecompressByteArray: compressed_data_size=20702 data_size=77571, decompressed_data_size=77571 diff=0
[22:50:52] - Digital signature verified
[22:50:52]
[22:50:52] Project: 10975 (Run 2, Clone 68, Gen 17)
[22:50:52]
[22:50:52] Entering M.D.
[22:50:54] Will resume from checkpoint file work/wudata_00.ckp
[22:50:54] Tpr hash work/wudata_00.tpr: 3435825622 3030450624 4113112955 185304617 1472652184
[22:50:55] Working on 247 ProG_hpin
[22:50:55] Client config found, loading data.
[22:50:55] Starting GUI Server
[22:51:13] - Server does not have record of this unit. Will try again later.
[22:51:13] Could not transmit unit 08 to Collection server; keeping in queue.
[22:51:13] Resuming from checkpoint
[22:51:13] fcCheckPointResume: retreived and current tpr file hash:
[22:51:13] 0 3435825622 3435825622
[22:51:13] 1 3030450624 3030450624
[22:51:13] 2 4113112955 4113112955
[22:51:13] 3 185304617 185304617
[22:51:13] 4 1472652184 1472652184
[22:51:13] fcCheckPointResume: file hashes same.
[22:51:13] fcCheckPointResume: state restored.
[22:51:13] fcCheckPointResume: name work/wudata_00.log Verified work/wudata_00.log
[22:51:14] fcCheckPointResume: name work/wudata_00.trr Verified work/wudata_00.trr
[22:51:14] fcCheckPointResume: name work/wudata_00.xtc Verified work/wudata_00.xtc
[22:51:15] fcCheckPointResume: name work/wudata_00.edr Verified work/wudata_00.edr
[22:51:15] fcCheckPointResume: state restored 2
[22:51:15] Resumed from checkpoint
[22:51:15] Setting checkpoint frequency: 500000
[22:51:15] Completed 14000001 out of 50000000 steps (28%).
[22:52:06] Completed 14500000 out of 50000000 steps (29%).
[22:52:57] Completed 15000000 out of 50000000 steps (30%).
[22:53:48] Completed 15500000 out of 50000000 steps (31%).
[22:54:39] Completed 16000000 out of 50000000 steps (32%).
[22:55:30] Completed 16500000 out of 50000000 steps (33%).
[22:56:21] Completed 17000000 out of 50000000 steps (34%).
[22:57:12] Completed 17500000 out of 50000000 steps (35%).
[22:58:03] Completed 18000000 out of 50000000 steps (36%).
[22:58:53] Completed 18500000 out of 50000000 steps (37%).
[22:59:44] Completed 19000000 out of 50000000 steps (38%).
[23:00:35] Completed 19500000 out of 50000000 steps (39%).
--- Opening Log file [May 20 23:02:04 UTC]
# Windows GPU Systray Edition #################################################
[23:02:04] - Ask before connecting: No
[23:02:04] - User name: *hondo* (Team 51078)
[23:02:04] - User ID: 6EBE171B7E6C885A
[23:02:04] - Machine ID: 2
[23:02:04]
[23:02:04] Gpu type=3 species=21.
[23:02:04] Loaded queue successfully.
[23:02:04] Initialization complete
[23:02:04]
[23:02:04] + Processing work unit
[23:02:04] Project: 6805 (Run 6308, Clone 3, Gen 24)
[23:02:04] + Attempting to send results [May 20 23:02:04 UTC]
[23:02:04] Core required: FahCore_15.exe
[23:02:04] Core found.
[23:02:04] Working on queue slot 00 [May 20 23:02:04 UTC]
[23:02:04] + Working ...
[23:02:04]
[23:02:04] *------------------------------*
[23:02:04] Folding@Home GPU Core
[23:02:04] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[23:02:04]
[23:02:04] Build host: SimbiosNvdWin7
[23:02:04] Board Type: NVIDIA/CUDA
[23:02:04] Core : x=15
[23:02:04] Window's signal control handler registered.
[23:02:04] Preparing to commence simulation
[23:02:04] - Ensuring status. Please wait.
[23:02:06] - Couldn't send HTTP request to server
[23:02:06] + Could not connect to Work Server (results)
[23:02:06] (171.64.65.64:8080)
[23:02:06] + Retrying using alternative port
[23:02:07] - Couldn't send HTTP request to server
[23:02:07] + Could not connect to Work Server (results)
[23:02:07] (171.64.65.64:80)
[23:02:07] - Error: Could not transmit unit 08 (completed May 20) to work server.
[23:02:07] + Attempting to send results [May 20 23:02:07 UTC]
[23:02:07] Gpu type=3 species=21.
[23:02:14] - Looking at optimizations...
[23:02:14] - Working with standard loops on this execution.
[23:02:14] - Previous termination of core was improper.
[23:02:14] - Going to use standard loops.
[23:02:14] - Files status OK
[23:02:14] sizeof(CORE_PACKET_HDR) = 512 file=<>
[23:02:14] - Expanded 20702 -> 77571 (decompressed 374.7 percent)
[23:02:14] Called DecompressByteArray: compressed_data_size=20702 data_size=77571, decompressed_data_size=77571 diff=0
[23:02:14] - Digital signature verified
[23:02:14]
[23:02:14] Project: 10975 (Run 2, Clone 68, Gen 17)
[23:02:14]
[23:02:14] Entering M.D.
[23:02:16] Will resume from checkpoint file work/wudata_00.ckp
[23:02:16] Tpr hash work/wudata_00.tpr: 3435825622 3030450624 4113112955 185304617 1472652184
[23:02:17] Working on 247 ProG_hpin
[23:02:17] Client config found, loading data.
[23:02:17] Starting GUI Server
[23:02:22] Resuming from checkpoint
[23:02:22] fcCheckPointResume: retreived and current tpr file hash:
[23:02:22] 0 3435825622 3435825622
[23:02:22] 1 3030450624 3030450624
[23:02:22] 2 4113112955 4113112955
[23:02:22] 3 185304617 185304617
[23:02:22] 4 1472652184 1472652184
[23:02:22] fcCheckPointResume: file hashes same.
[23:02:22] fcCheckPointResume: state restored.
[23:02:22] fcCheckPointResume: name work/wudata_00.log Verified work/wudata_00.log
[23:02:23] fcCheckPointResume: name work/wudata_00.trr Verified work/wudata_00.trr
[23:02:23] fcCheckPointResume: name work/wudata_00.xtc Verified work/wudata_00.xtc
[23:02:24] fcCheckPointResume: name work/wudata_00.edr Verified work/wudata_00.edr
[23:02:24] fcCheckPointResume: state restored 2
[23:02:24] Resumed from checkpoint
[23:02:24] Setting checkpoint frequency: 500000
[23:02:24] Completed 19500001 out of 50000000 steps (39%).
[23:02:34] - Server does not have record of this unit. Will try again later.
[23:02:34] Could not transmit unit 08 to Collection server; keeping in queue.
[23:03:17] Completed 20000000 out of 50000000 steps (40%).
[23:04:08] Completed 20500000 out of 50000000 steps (41%).
[23:04:59] Completed 21000000 out of 50000000 steps (42%).
[23:05:50] Completed 21500000 out of 50000000 steps (43%).
[23:06:41] Completed 22000000 out of 50000000 steps (44%).
[23:07:32] Completed 22500000 out of 50000000 steps (45%).
[23:08:24] Completed 23000000 out of 50000000 steps (46%).
[23:09:15] Completed 23500000 out of 50000000 steps (47%).
[23:10:06] Completed 24000000 out of 50000000 steps (48%).
[23:10:57] Completed 24500000 out of 50000000 steps (49%).
[23:11:48] Completed 25000000 out of 50000000 steps (50%).
[23:12:39] Completed 25500000 out of 50000000 steps (51%).
[23:13:30] Completed 26000000 out of 50000000 steps (52%).
[23:14:21] Completed 26500000 out of 50000000 steps (53%).
[23:15:12] Completed 27000000 out of 50000000 steps (54%).
[23:16:03] Completed 27500000 out of 50000000 steps (55%).
[23:16:54] Completed 28000000 out of 50000000 steps (56%).
[23:17:45] Completed 28500000 out of 50000000 steps (57%).
[23:18:36] Completed 29000000 out of 50000000 steps (58%).
[23:19:27] Completed 29500000 out of 50000000 steps (59%).
[23:20:18] Completed 30000000 out of 50000000 steps (60%).
[23:21:08] Completed 30500000 out of 50000000 steps (61%).
[23:21:59] Completed 31000000 out of 50000000 steps (62%).
[23:22:50] Completed 31500000 out of 50000000 steps (63%).
[23:23:41] Completed 32000000 out of 50000000 steps (64%).
[23:24:32] Completed 32499999 out of 50000000 steps (65%).
[23:25:23] Completed 32999999 out of 50000000 steps (66%).
[23:26:14] Completed 33499999 out of 50000000 steps (67%).
[23:27:05] Completed 33999999 out of 50000000 steps (68%).
[23:27:56] Completed 34499999 out of 50000000 steps (69%).
[23:28:48] Completed 34999999 out of 50000000 steps (70%).
[23:29:39] Completed 35499999 out of 50000000 steps (71%).
[23:30:30] Completed 35999999 out of 50000000 steps (72%).
[23:31:21] Completed 36499999 out of 50000000 steps (73%).
[23:32:12] Completed 36999999 out of 50000000 steps (74%).
[23:33:04] Completed 37499999 out of 50000000 steps (75%).
[23:33:55] Completed 37999999 out of 50000000 steps (76%).
[23:34:46] Completed 38499999 out of 50000000 steps (77%).
[23:35:37] Completed 38999999 out of 50000000 steps (78%).
[23:36:28] Completed 39499999 out of 50000000 steps (79%).
[23:37:19] Completed 39999999 out of 50000000 steps (80%).
[23:38:11] Completed 40499999 out of 50000000 steps (81%).
[23:39:02] Completed 40999999 out of 50000000 steps (82%).
[23:39:53] Completed 41499999 out of 50000000 steps (83%).
[23:40:44] Completed 41999999 out of 50000000 steps (84%).
[23:41:35] Completed 42499999 out of 50000000 steps (85%).
[23:42:27] Completed 42999999 out of 50000000 steps (86%).
[23:43:18] Completed 43499999 out of 50000000 steps (87%).
[23:44:09] Completed 43999999 out of 50000000 steps (88%).
--- Opening Log file [May 20 23:46:09 UTC]
[23:46:09] - Ask before connecting: No
[23:46:09] - User name: *hondo* (Team 51078)
[23:46:09] - User ID: 6EBE171B7E6C885A
[23:46:09] - Machine ID: 2
[23:46:09]
[23:46:09] Gpu type=3 species=21.
[23:46:09] Loaded queue successfully.
[23:46:09] Initialization complete
[23:46:09]
[23:46:09] + Processing work unit
[23:46:09] Project: 6805 (Run 6308, Clone 3, Gen 24)
[23:46:09] + Attempting to send results [May 20 23:46:09 UTC]
[23:46:09] Core required: FahCore_15.exe
[23:46:09] Core found.
[23:46:09] Working on queue slot 00 [May 20 23:46:09 UTC]
[23:46:09] + Working ...
[23:46:09]
[23:46:09] *------------------------------*
[23:46:09] Folding@Home GPU Core
[23:46:09] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[23:46:09]
[23:46:09] Build host: SimbiosNvdWin7
[23:46:09] Board Type: NVIDIA/CUDA
[23:46:09] Core : x=15
[23:46:09] Window's signal control handler registered.
[23:46:09] Preparing to commence simulation
[23:46:09] - Ensuring status. Please wait.
[23:46:10] - Couldn't send HTTP request to server
[23:46:10] + Could not connect to Work Server (results)
[23:46:10] (171.64.65.64:8080)
[23:46:10] + Retrying using alternative port
[23:46:12] - Couldn't send HTTP request to server
[23:46:12] + Could not connect to Work Server (results)
[23:46:12] (171.64.65.64:80)
[23:46:12] - Error: Could not transmit unit 08 (completed May 20) to work server.
[23:46:12] + Attempting to send results [May 20 23:46:12 UTC]
[23:46:12] Gpu type=3 species=21.
[23:46:19] - Looking at optimizations...
[23:46:19] - Working with standard loops on this execution.
[23:46:19] - Previous termination of core was improper.
[23:46:19] - Going to use standard loops.
[23:46:19] - Files status OK
[23:46:19] sizeof(CORE_PACKET_HDR) = 512 file=<>
[23:46:19] - Expanded 20702 -> 77571 (decompressed 374.7 percent)
[23:46:19] Called DecompressByteArray: compressed_data_size=20702 data_size=77571, decompressed_data_size=77571 diff=0
[23:46:19] - Digital signature verified
[23:46:19]
[23:46:19] Project: 10975 (Run 2, Clone 68, Gen 17)
[23:46:19]
[23:46:19] Entering M.D.
[23:46:21] Will resume from checkpoint file work/wudata_00.ckp
[23:46:21] Tpr hash work/wudata_00.tpr: 3435825622 3030450624 4113112955 185304617 1472652184
[23:46:22] Working on 247 ProG_hpin
[23:46:22] Client config found, loading data.
[23:46:22] Starting GUI Server
[23:46:24] Resuming from checkpoint
[23:46:24] fcCheckPointResume: retreived and current tpr file hash:
[23:46:24] 0 3435825622 3435825622
[23:46:24] 1 3030450624 3030450624
[23:46:24] 2 4113112955 4113112955
[23:46:24] 3 185304617 185304617
[23:46:24] 4 1472652184 1472652184
[23:46:24] fcCheckPointResume: file hashes same.
[23:46:24] fcCheckPointResume: state restored.
[23:46:24] fcCheckPointResume: name work/wudata_00.log Verified work/wudata_00.log
[23:46:26] fcCheckPointResume: name work/wudata_00.trr Verified work/wudata_00.trr
[23:46:26] fcCheckPointResume: name work/wudata_00.xtc Verified work/wudata_00.xtc
[23:46:28] fcCheckPointResume: name work/wudata_00.edr Verified work/wudata_00.edr
[23:46:28] fcCheckPointResume: state restored 2
[23:46:28] Resumed from checkpoint
[23:46:28] Setting checkpoint frequency: 500000
[23:46:28] Completed 44000001 out of 50000000 steps (88%).
[23:47:19] Completed 44499999 out of 50000000 steps (89%).
[23:47:42] - Couldn't send HTTP request to server
[23:47:42] + Could not connect to Work Server (results)
[23:47:42] (171.67.108.26:8080)
[23:47:42] + Retrying using alternative port
[23:47:44] - Couldn't send HTTP request to server
[23:47:44] + Could not connect to Work Server (results)
[23:47:44] (171.67.108.26:80)
[23:47:44] Could not transmit unit 08 to Collection server; keeping in queue.
[23:48:10] Completed 44999999 out of 50000000 steps (90%).
[23:49:01] Completed 45499999 out of 50000000 steps (91%).
I installed GPU systray client. I just quit it and restart it from shortcut found at Start / Startup.
I pinged YSL, a PG researcher, about her server.
thanks7im wrote:I pinged YSL, a PG researcher, about her server.
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
server stats show it is still down - and that in the last update, they dried up the server - the WU, WUs AVAIL, WUs to go, WUs WAIT are all zero'ed out.
171.64.65.64 GPU vspg2v lin5 full Reject 2.32 761 2 3 17883 3122 -1 0 0 0 0
I know that I have one WU from 171.64.65.64 that is still waiting to go back to the server. In v6, it's in queue slot 5. These p109xx that I'm receiving are clocking over in just over an hour - and that I'm about to overrun slot 5 in a couple of hours. I guess that this is just an, "Oh Well", and if it's overrun so be it.
Seems it's back online
- Fri May 20 20:30:10 PDT 2011 171.64.65.64 GPU vspg2v lin5 full Accepting
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
My old WU just uploaded, but it seems that the server is still showing zero WU, WUs Avail, etc.
Xavier Zepherious
I also seem to have this issue
Please fix this
It's annoying...can't upload and can't get new WU's
Please fix this
[16:07:09] Folding@home Core Shutdown: FINISHED_UNIT
[16:07:12] CoreStatus = 64 (100)
[16:07:12] Unit 1 finished with 99 percent of time to deadline remaining.
[16:07:12] Updated performance fraction: 0.991337
[16:07:12] Sending work to server
[16:07:12] Project: 6801 (Run 1154, Clone 4, Gen 14)
[16:07:12] - Read packet limit of 540015616... Set to 524286976.
[16:07:12] + Attempting to send results [May 21 16:07:12 UTC]
[16:07:12] - Reading file work/wuresults_01.dat from core
[16:07:12] (Read 2509092 bytes from disk)
[16:07:12] Gpu type=3 species=30.
[16:07:12] Connecting to http://171.64.65.64:8080/
[16:07:13] - Couldn't send HTTP request to server
[16:07:13] + Could not connect to Work Server (results)
[16:07:13] (171.64.65.64:8080)
[16:07:13] + Retrying using alternative port
[16:07:13] Connecting to http://171.64.65.64:80/
[16:07:14] - Couldn't send HTTP request to server
[16:07:14] + Could not connect to Work Server (results)
[16:07:14] (171.64.65.64:80)
[16:07:14] - Error: Could not transmit unit 01 (completed May 21) to work server.
[16:07:14] - 1 failed uploads of this unit.
[16:07:14] Keeping unit 01 in queue.
[16:07:14] Trying to send all finished work units
[16:07:14] Project: 6801 (Run 1154, Clone 4, Gen 14)
[16:07:14] - Read packet limit of 540015616... Set to 524286976.
[16:07:14] + Attempting to send results [May 21 16:07:14 UTC]
[16:07:14] - Reading file work/wuresults_01.dat from core
[16:07:14] (Read 2509092 bytes from disk)
[16:07:14] Gpu type=3 species=30.
[16:07:14] Connecting to http://171.64.65.64:8080/
[16:07:15] - Couldn't send HTTP request to server
[16:07:15] + Could not connect to Work Server (results)
[16:07:15] (171.64.65.64:8080)
[16:07:15] + Retrying using alternative port
[16:07:15] Connecting to http://171.64.65.64:80/
[16:07:17] - Couldn't send HTTP request to server
[16:07:17] + Could not connect to Work Server (results)
[16:07:17] (171.64.65.64:80)
[16:07:17] - Error: Could not transmit unit 01 (completed May 21) to work server.
[16:07:17] - 2 failed uploads of this unit.
