Project: 6501 (Run 14, Clone 385, Gen 95) EUE after 52%
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
Upload still hammering server. I'll clean that up next. Processing next WU. Core 78.
16:38:02:Unit 01:Gromacs cannot continue further.
16:38:02:Unit 01:Going to send back what have done.
16:38:02:Unit 01:logfile size: 34797
16:38:02:Unit 01:- Writing 35333 bytes of core data to disk...
16:38:02:Unit 01:Done: 34821 -> 5804 (compressed to 16.6 percent)
16:38:02:Unit 01: ... Done.
16:38:02:Unit 01:
16:38:02:Unit 01:Folding@home Core Shutdown: EARLY_UNIT_END
16:38:03:FahCore running Unit 01 returned: BAD_WORK_UNIT (114)
*********************** Log Started 10/May/2011-15:47:15 ***********************
15:47:15:************************* Folding@home Client *************************
15:47:15:      Website: http://folding.stanford.edu/
15:47:15:    Copyright: (c) 2009,2010 Stanford University
15:47:15:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:47:15:         Args: --lifeline 3864
15:47:15:       Config: C:/Documents and Settings/Admin/Application
15:47:15:               Data/FAHClient/config.xml
15:47:15:******************************** Build ********************************
15:47:15:      Version: 7.1.21
15:47:15:         Date: Mar 23 2011
15:47:15:         Time: 15:13:48
15:47:15:      SVN Rev: 2883
15:47:15:       Branch: fah/trunk/client
15:47:15:     Compiler: Intel(R) C++ MSVC 1500 mode 1110
15:47:15:      Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE
15:47:15:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
15:47:15:     Platform: win32 XP
15:47:15:         Bits: 32
15:47:15:         Mode: Release
15:47:15:******************************* System ********************************
15:47:15:           OS: Microsoft Windows XP Home Edition
15:47:15:          CPU: Intel(R) Pentium(R) M processor 1.73GHz
15:47:15:       CPU ID: GenuineIntel Family 6 Model 13 Stepping 8
15:47:15:         CPUs: 1
15:47:15:       Memory: 1.99GiB
15:47:15:  Free Memory: 1.17GiB
15:47:15:      Threads: WINDOWS_THREADS
15:47:15:         GPUs: 0
15:47:15:         CUDA: Not detected
15:47:15:   On Battery: false
15:47:15:   UTC offset: -7
15:47:15:          PID: 2576
15:47:15:          CWD: C:/Documents and Settings/Admin/Application Data/FAHClient
15:47:15:Win32 Service: false
15:47:15:***********************************************************************
15:47:15:<config>
15:47:15:  <service-description v='Folding@home Client'/>
15:47:15:  <service-restart v='true'/>
15:47:15:  <service-restart-delay v='5000'/>
15:47:15:
15:47:15:  <!-- Client Control -->
15:47:15:  <cycle-rate v='4'/>
15:47:15:  <cycles v='-1'/>
15:47:15:  <data-directory v='.'/>
15:47:15:  <exec-directory v='C:\Program Files\FAHClient'/>
15:47:15:  <exit-when-done v='false'/>
15:47:15:  <max-delay v='21600'/>
15:47:15:  <min-delay v='60'/>
15:47:15:  <threads v='4'/>
15:47:15:
15:47:15:  <!-- Configuration -->
15:47:15:  <config-rotate v='true'/>
15:47:15:  <config-rotate-dir v='configs'/>
15:47:15:  <config-rotate-max v='16'/>
15:47:15:
15:47:15:  <!-- Debugging -->
15:47:15:  <assignment-servers>
15:47:15:    assign3.stanford.edu:8080 assign4.stanford.edu:80
15:47:15:  </assignment-servers>
15:47:15:  <capture-directory v='capture'/>
15:47:15:  <capture-sockets v='false'/>
15:47:15:  <debug-sockets v='false'/>
15:47:15:  <exception-locations v='true'/>
15:47:15:  <gpu-assignment-servers>
15:47:15:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
15:47:15:  </gpu-assignment-servers>
15:47:15:  <stack-traces v='false'/>
15:47:15:
15:47:15:  <!-- Error Handling -->
15:47:15:  <max-slot-errors v='5'/>
15:47:15:  <max-unit-errors v='5'/>
15:47:15:
15:47:15:  <!-- FahCore Control -->
15:47:15:  <checkpoint v='15'/>
15:47:15:  <core-dir v='cores'/>
15:47:15:  <core-priority v='idle'/>
15:47:15:  <cpu-affinity v='false'/>
15:47:15:  <cpu-usage v='100'/>
15:47:15:  <no-assembly v='false'/>
15:47:15:
15:47:15:  <!-- Folding Slot Configuration -->
15:47:15:  <client-subtype v='STDCLI'/>
15:47:15:  <client-type v='normal'/>
15:47:15:  <cpu-species v='X86_PENTIUM_II'/>
15:47:15:  <cpu-type v='X86'/>
15:47:15:  <cpus v='1'/>
15:47:15:  <extra-core-args v='-forceasm'/>
15:47:15:  <gpu v='false'/>
15:47:15:  <gpu-id v='0'/>
15:47:15:  <max-packet-size v='normal'/>
15:47:15:  <os-species v='WIN_XP'/>
15:47:15:  <os-type v='WIN32'/>
15:47:15:  <project-key v='0'/>
15:47:15:  <smp v='false'/>
15:47:15:
15:47:15:  <!-- Logging -->
15:47:15:  <log v='log.txt'/>
15:47:15:  <log-color v='false'/>
15:47:15:  <log-crlf v='true'/>
15:47:15:  <log-date v='false'/>
15:47:15:  <log-debug v='true'/>
15:47:15:  <log-domain v='false'/>
15:47:15:  <log-header v='true'/>
15:47:15:  <log-level v='true'/>
15:47:15:  <log-no-info-header v='true'/>
15:47:15:  <log-redirect v='false'/>
15:47:15:  <log-rotate v='true'/>
15:47:15:  <log-rotate-dir v='logs'/>
15:47:15:  <log-rotate-max v='16'/>
15:47:15:  <log-short-level v='false'/>
15:47:15:  <log-simple-domains v='true'/>
15:47:15:  <log-thread-id v='false'/>
15:47:15:  <log-time v='true'/>
15:47:15:  <log-to-screen v='true'/>
15:47:15:  <log-truncate v='false'/>
15:47:15:  <verbosity v='5'/>
15:47:15:
15:47:15:  <!-- Process Control -->
15:47:15:  <child v='false'/>
15:47:15:  <daemon v='false'/>
15:47:15:  <pid v='false'/>
15:47:15:  <pid-file v='Folding@home Client.pid'/>
15:47:15:  <respawn v='false'/>
15:47:15:  <service v='false'/>
15:47:15:
15:47:15:  <!-- Remote Command Server -->
15:47:15:  <command-address v='0.0.0.0'/>
15:47:15:  <command-allow v='127.0.0.1'/>
15:47:15:  <command-allow-no-pass v='127.0.0.1'/>
15:47:15:  <command-deny v='0.0.0.0/0'/>
15:47:15:  <command-deny-no-pass v='0.0.0.0/0'/>
15:47:15:  <command-port v='36330'/>
15:47:15:  <password v=''/>
15:47:15:
15:47:15:  <!-- Slot Control -->
15:47:15:  <max-shutdown-wait v='60'/>
15:47:15:  <pause-on-battery v='true'/>
15:47:15:  <pause-on-start v='false'/>
15:47:15:
15:47:15:  <!-- User Information -->
15:47:15:  <machine-id v='0'/>
15:47:15:  <passkey v='********************************'/>
15:47:15:  <team v='0'/>
15:47:15:  <user v='GreyWhiskers'/>
15:47:15:
15:47:15:  <!-- Work Unit Control -->
15:47:15:  <dump-after-deadline v='true'/>
15:47:15:  <max-queue v='16'/>
15:47:15:  <max-units v='0'/>
15:47:15:  <next-unit-percentage v='99'/>
15:47:15:
15:47:15:  <!-- Folding Slots -->
15:47:15:  <slot id='0' type='UNIPROCESSOR'>
15:47:15:    <client-type v='advanced'/>
15:47:15:  </slot>
15:47:15:</config>
SNIP
19:37:29:Saving configuration to config.xml
19:37:29:<config>
19:37:29:  <!-- Folding Slot Configuration -->
19:37:29:  <extra-core-args v='-forceasm'/>
19:37:29:  <smp v='false'/>
19:37:29:
19:37:29:  <!-- Logging -->
19:37:29:  <verbosity v='4'/>
19:37:29:
19:37:29:  <!-- Remote Command Server -->
19:37:29:  <password v=''/>
19:37:29:
19:37:29:  <!-- Slot Control -->
19:37:29:  <pause-on-battery v='true'/>
19:37:29:
19:37:29:  <!-- User Information -->
19:37:29:  <passkey v='********************************'/>
19:37:29:  <user v='GreyWhiskers'/>
19:37:29:
19:37:29:  <!-- Folding Slots -->
19:37:29:  <slot id='0' type='UNIPROCESSOR'>
19:37:29:    <client-type v='advanced'/>
19:37:29:  </slot>
19:37:29:</config>
SNIP
03:22:11:Connecting to assign3.stanford.edu:8080
03:22:11:News: Welcome to Folding@Home
03:22:11:Assigned to work server 171.64.65.62
03:22:11:Requesting new work unit for slot 00: RUNNING uniprocessor from 171.64.65.62
03:22:11:Connecting to 171.64.65.62:8080
03:22:12:Slot 00: Downloading 729.85KiB
03:22:13:Slot 00: Download complete
03:22:13:Received Unit: id:01 state:DOWNLOAD project:6501 run:14 clone:385 gen:95 core:0x78 unit:0x548963064dcf46e5005f0181000e1965
03:31:27:Unit 00:Writing local files
03:31:27:Unit 00:Completed 250000 out of 250000 steps  (100%)
03:31:27:Unit 00:Writing final coordinates.
03:31:28:Unit 00:Past main M.D. loop
03:32:28:Unit 00:
03:32:28:Unit 00:Finished Work Unit:
03:32:28:Unit 00:- Reading up to 384912 from "00/wudata_01.arc": Read 384912
03:32:28:Unit 00:- Reading up to 36372 from "00/wudata_01.xtc": Read 36372
03:32:28:Unit 00:goefile size: 0
03:32:28:Unit 00:logfile size: 27046
03:32:28:Unit 00:Leaving Run
03:32:30:Unit 00:- Writing 458538 bytes of core data to disk...
03:32:30:Unit 00:Done: 458026 -> 414095 (compressed to 90.4 percent)
03:32:30:Unit 00:  ... Done.
03:32:30:Unit 00:- Shutting down core
03:32:30:Unit 00:
03:32:30:Unit 00:Folding@home Core Shutdown: FINISHED_UNIT
03:32:30:FahCore running Unit 00 returned: FINISHED_UNIT (100)
03:32:30:Sending unit results: id:00 state:SEND project:6508 run:2 clone:240 gen:94 core:0x78 unit:0x0b3082f04dce66ab005e00f00002196c
03:32:30:Unit 00: Uploading 404.89KiB
03:32:30:Connecting to 171.64.65.62:8080
03:32:31:Starting Unit 01
03:32:31:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 01 -suffix 01 -lifeline 2576 -version 701 -checkpoint 15 -forceasm
03:32:31:Started core on PID 4804
03:32:31:FahCore 0x78 started
03:32:31:Unit 01:
03:32:31:Unit 01:*------------------------------*
03:32:31:Unit 01:Folding@Home Gromacs Core
03:32:31:Unit 01:Version 1.90 (March 8, 2006)
03:32:31:Unit 01:
03:32:31:Unit 01:Preparing to commence simulation
03:32:31:Unit 01:- Assembly optimizations manually forced on.
03:32:31:Unit 01:- Not checking prior termination.
03:32:32:Unit 01:- Expanded 746857 -> 3748137 (decompressed 501.8 percent)
03:32:32:Unit 01:- Starting from initial work packet
03:32:32:Unit 01:
03:32:32:Unit 01:Project: 6501 (Run 14, Clone 385, Gen 95)
03:32:32:Unit 01:
03:32:32:Unit 01:Assembly optimizations on if available.
03:32:32:Unit 01:Entering M.D.
03:32:34:Unit 00: Upload complete
03:32:34:Server responded WORK_ACK (400)
03:32:34:Cleaning up Unit 00
03:32:39:Unit 01:Protein: UBIQUITIN MODEL3750 in water
03:32:39:Unit 01:
03:32:39:Unit 01:Writing local files
03:32:39:Unit 01:Extra SSE boost OK.
03:32:40:Unit 01:Writing local files
03:32:40:Unit 01:Completed 0 out of 250000 steps  (0%)
03:47:50:Unit 01:Writing local files
03:47:50:Unit 01:Completed 2500 out of 250000 steps  (1%)
04:03:58:Unit 01:Writing local files
04:03:58:Unit 01:Completed 5000 out of 250000 steps  (2%)
04:20:35:Unit 01:Writing local files
04:20:35:Unit 01:Completed 7500 out of 250000 steps  (3%)
SNIP
16:22:46:Unit 01:Writing local files
16:22:46:Unit 01:Completed 127500 out of 250000 steps  (51%)
16:37:48:Unit 01:Writing local files
16:37:48:Unit 01:Completed 130000 out of 250000 steps  (52%)
16:38:02:Unit 01:
Re: Project: 6501 (Run 14, Clone 385, Gen 95) EUE after 52%
There were 3 failures in the WU Database so I have marked it as a bad WU:
The WU (P6501,R14,C385,G95) has been reported as a bad WU.
Thanks for your report.
