Project: 3907 (Run 4651, Clone 4, Gen 4) not credited
Mactin
Post by Mactin »
Project: 3907 (Run 4651, Clone 4, Gen 4) was completed (now) 8.5 hours ago.
I waited to complete another WU (from another PC) before posting.
[18:46:59] + Number of Units Completed: 19
[18:47:03] Trying to send all finished work units
[18:47:03] + No unsent completed units remaining.
[18:47:03] - Preparing to get new work unit...
[18:47:03] + Attempting to get work packet
[18:47:03] - Will indicate memory of 503 MB
[18:47:03] - Connecting to assignment server
[18:47:03] Connecting to http://assign.stanford.edu:8080/
[18:47:04] Posted data.
[18:47:04] Initial: 40AB; - Successful: assigned to (171.64.122.88).
[18:47:04] + News From Folding@Home: Welcome to Folding@Home
[18:47:04] Loaded queue successfully.
[18:47:04] Connecting to http://171.64.122.88:8080/
[18:47:05] Posted data.
[18:47:05] Initial: 0000; - Receiving payload (expected size: 345475)
[18:47:06] - Downloaded at ~337 kB/s
[18:47:06] - Averaged speed for that direction ~470 kB/s
[18:47:06] + Received work.
[18:47:06] Trying to send all finished work units
[18:47:06] + No unsent completed units remaining.
[18:47:06] + Closed connections
[18:47:06]
[18:47:06] + Processing work unit
[18:47:06] Core required: FahCore_7b.exe
[18:47:06] Core found.
[18:47:06] Working on Unit 00 [March 28 18:47:06]
[18:47:06] + Working ...
[18:47:06] - Calling 'FahCore_7b.exe -dir work/ -suffix 00 -checkpoint 10 -forceasm -verbose -lifeline 3416 -version 601'
[18:47:07]
[18:47:07] *------------------------------*
[18:47:07] Folding@Home Double Gromacs Core B
[18:47:07] Version 1.04 (Fri Aug 10 16:46:39 PDT 2007)
[18:47:07]
[18:47:07] Preparing to commence simulation
[18:47:07] - Assembly optimizations manually forced on.
[18:47:07] - Not checking prior termination.
[18:47:07] - Expanded 344963 -> 1203089 (decompressed 348.7 percent)
[18:47:07]
[18:47:07] Project: 3907 (Run 4651, Clone 4, Gen 4)
[18:47:07]
[18:47:07] Assembly optimizations on if available.
[18:47:07] Entering M.D.
[18:47:14] Working on Lig in water
[18:47:14] Completed 0 out of 500000 steps  (0)
[18:47:14] Extra SSE2 boost OK
[18:57:14] Timer requesting checkpoint
[18:58:54] Completed 5000 out of 500000 steps  (1)
[19:08:55] Timer requesting checkpoint
[19:10:37] Completed 10000 out of 500000 steps  (2)
[19:20:37] Timer requesting checkpoint
[19:22:20] Completed 15000 out of 500000 steps  (3)
[13:38:55] Completed 485000 out of 500000 steps  (97)
[13:48:55] Timer requesting checkpoint
[13:50:42] Completed 490000 out of 500000 steps  (98)
[14:00:42] Timer requesting checkpoint
[14:02:25] Completed 495000 out of 500000 steps  (99)
[14:12:25] Timer requesting checkpoint
[14:14:08] Completed 500000 out of 500000 steps  (100)
[14:15:09]
[14:15:09] Finished Work Unit:
[14:15:09] - Reading up to 7928172 from "work/wudata_00.trr": Read 7928172
[14:15:09] - Reading up to 1145480 from "work/wudata_00.xtc": Read 1145480
[14:15:09] logfile size: 25903
[14:15:09] Leaving Run
[14:15:10] - Writing 11587175 bytes of core data to disk...
[14:15:17] Done: 11586663 -> 9592222 (compressed to 82.7 percent)
[14:15:17]   ... Done.
[14:15:17] - Shutting down core
[14:15:17]
[14:15:17] Folding@home Core Shutdown: FINISHED_UNIT
[14:15:20] CoreStatus = 64 (100)
[14:15:20] Unit 0 finished with 99 percent of time to deadline remaining.
[14:15:20] Updated performance fraction: 0.984193
[14:15:20] Sending work to server
[14:15:20] - Read packet limit of 540015616... Set to 524286976.
[14:15:20] + Attempting to send results
[14:15:20] - Reading file work/wuresults_00.dat from core
[14:15:20]   (Read 9592734 bytes from disk)
[14:15:20] Connecting to http://171.64.122.88:8080/
[14:17:06] Posted data.
[14:17:06] Initial: 0000; - Uploaded at ~88 kB/s
[14:17:06] - Averaged speed for that direction ~89 kB/s
[14:17:06] + Results successfully sent
[14:17:06] Thank you for your contribution to Folding@Home.
[14:17:06] + Number of Units Completed: 20
From the log it all looks OK as does serverstat.
Thanks
anandhanju
Re: Project: 3907 (Run 4651, Clone 4, Gen 4) not credited
Post by anandhanju »
I see a 310 pointer against your name in the Kakao 0800 UTC update on the 31st; you'll have to wait until a Moderator confirms if this is the WU. Possibly related to Vijay's post here (6th reply in that thread, can't figure out how to link to a specific post :e?: )
ChelseaOilman
Post by ChelseaOilman »
Hi Mactin (team 57391),
Your WU (P3907 R4651 C4 G4) was added to the stats database on 2008-03-30 21:10:49 for 310 points of credit.
