Since it is moving again, I almost didn't bother reporting it, except the errors seem remarkably similar to the errors encountered in this thread: viewtopic.php?f=66&t=18541&hilit=10121
I don't have access to post there, as it is the beta forums. I run the v7 client with SMP and a GPU slot. In the log below, I'll cut out as much of the GPU-related stuff as possible. Shortly after 1% on the SMP core, I paused both cores and rebooted my machine, so you'll notice it starts out @ 1%.
*********************** Log Started 13/May/2011-00:37:19 ***********************
00:37:19:************************* Folding@home Client *************************
00:37:19: Website: http://folding.stanford.edu/
00:37:19: Copyright: (c) 2009,2010 Stanford University
00:37:19: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:37:19: Args: --lifeline 1012 --command-port=36330
00:37:19: Config: C:/Users/Mike/AppData/Roaming/FAHClient/config.xml
00:37:19:******************************** Build ********************************
00:37:19: Version: 7.1.24
00:37:19: Date: Apr 6 2011
00:37:19: Time: 21:37:58
00:37:19: SVN Rev: 2908
00:37:19: Branch: fah/trunk/client
00:37:19: Compiler: Intel(R) C++ MSVC 1500 mode 1110
00:37:19: Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE2
00:37:19: /QaxSSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
00:37:19: Platform: win32 Vista
00:37:19: Bits: 32
00:37:19: Mode: Release
00:37:19:******************************* System ********************************
00:37:19: OS: Microsoft Windows 7 Home Premium
00:37:19: CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
00:37:19: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
00:37:19: CPUs: 4
00:37:19: Memory: 4.00GiB
00:37:19: Free Memory: 2.98GiB
00:37:19: Threads: WINDOWS_THREADS
00:37:19: GPUs: 1
00:37:19: GPU 0: NVIDIA:1 GT200 [GeForce GTX 260]
00:37:19: CUDA: 1.3
00:37:19: CUDA Driver: 4000
00:37:19: On Battery: false
00:37:19: UTC offset: -4
00:37:19: PID: 1400
00:37:19: CWD: C:/Users/Mike/AppData/Roaming/FAHClient
00:37:19:Win32 Service: false
00:37:19:***********************************************************************
00:37:20:<config>
00:37:20: <service-description v='Folding@home Client'/>
00:37:20: <service-restart v='true'/>
00:37:20: <service-restart-delay v='5000'/>
00:37:20:
00:37:20: <!-- Client Control -->
00:37:20: <cycle-rate v='4'/>
00:37:20: <cycles v='-1'/>
00:37:20: <data-directory v='.'/>
00:37:20: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
00:37:20: <exit-when-done v='false'/>
00:37:20: <max-delay v='21600'/>
00:37:20: <min-delay v='60'/>
00:37:20: <threads v='4'/>
00:37:20:
00:37:20: <!-- Configuration -->
00:37:20: <config-rotate v='true'/>
00:37:20: <config-rotate-dir v='configs'/>
00:37:20: <config-rotate-max v='16'/>
00:37:20:
00:37:20: <!-- Debugging -->
00:37:20: <assignment-servers>
00:37:20: assign3.stanford.edu:8080 assign4.stanford.edu:80
00:37:20: </assignment-servers>
00:37:20: <capture-directory v='capture'/>
00:37:20: <capture-sockets v='false'/>
00:37:20: <debug-sockets v='false'/>
00:37:20: <exception-locations v='true'/>
00:37:20: <gpu-assignment-servers>
00:37:20: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
00:37:20: </gpu-assignment-servers>
00:37:20: <stack-traces v='false'/>
00:37:20:
00:37:20: <!-- Error Handling -->
00:37:20: <max-slot-errors v='5'/>
00:37:20: <max-unit-errors v='5'/>
00:37:20:
00:37:20: <!-- FahCore Control -->
00:37:20: <checkpoint v='15'/>
00:37:20: <core-dir v='cores'/>
00:37:20: <core-priority v='idle'/>
00:37:20: <cpu-affinity v='false'/>
00:37:20: <cpu-usage v='100'/>
00:37:20: <no-assembly v='false'/>
00:37:20:
00:37:20: <!-- Folding Slot Configuration -->
00:37:20: <client-subtype v='STDCLI'/>
00:37:20: <client-type v='advanced'/>
00:37:20: <cpu-species v='X86_PENTIUM_II'/>
00:37:20: <cpu-type v='X86'/>
00:37:20: <cpus v='4'/>
00:37:20: <gpu v='true'/>
00:37:20: <gpu-id v='0'/>
00:37:20: <max-packet-size v='big'/>
00:37:20: <os-species v='UNKNOWN'/>
00:37:20: <os-type v='WIN32'/>
00:37:20: <project-key v='0'/>
00:37:20: <smp v='true'/>
00:37:20:
00:37:20: <!-- Logging -->
00:37:20: <log v='log.txt'/>
00:37:20: <log-color v='false'/>
00:37:20: <log-crlf v='true'/>
00:37:20: <log-date v='false'/>
00:37:20: <log-debug v='true'/>
00:37:20: <log-domain v='false'/>
00:37:20: <log-header v='true'/>
00:37:20: <log-level v='true'/>
00:37:20: <log-no-info-header v='true'/>
00:37:20: <log-redirect v='false'/>
00:37:20: <log-rotate v='true'/>
00:37:20: <log-rotate-dir v='logs'/>
00:37:20: <log-rotate-max v='16'/>
00:37:20: <log-short-level v='false'/>
00:37:20: <log-simple-domains v='true'/>
00:37:20: <log-thread-id v='false'/>
00:37:20: <log-time v='true'/>
00:37:20: <log-to-screen v='true'/>
00:37:20: <log-truncate v='false'/>
00:37:20: <verbosity v='5'/>
00:37:20:
00:37:20: <!-- Network -->
00:37:20: <proxy v=':8080'/>
00:37:20: <proxy-enable v='false'/>
00:37:20: <proxy-pass v=''/>
00:37:20: <proxy-user v=''/>
00:37:20:
00:37:20: <!-- Process Control -->
00:37:20: <child v='false'/>
00:37:20: <daemon v='false'/>
00:37:20: <pid v='false'/>
00:37:20: <pid-file v='Folding@home Client.pid'/>
00:37:20: <respawn v='false'/>
00:37:20: <service v='false'/>
00:37:20:
00:37:20: <!-- Remote Command Server -->
00:37:20: <command-address v='0.0.0.0'/>
00:37:20: <command-allow v='127.0.0.1'/>
00:37:20: <command-allow-no-pass v='127.0.0.1'/>
00:37:20: <command-deny v='0.0.0.0/0'/>
00:37:20: <command-deny-no-pass v='0.0.0.0/0'/>
00:37:20: <command-port v='36330'/>
00:37:20:
00:37:20: <!-- Slot Control -->
00:37:20: <max-shutdown-wait v='60'/>
00:37:20: <pause-on-battery v='false'/>
00:37:20: <pause-on-start v='false'/>
00:37:20:
00:37:20: <!-- User Information -->
00:37:20: <machine-id v='0'/>
00:37:20: <passkey v='********************************'/>
00:37:20: <team v='111065'/>
00:37:20: <user v='AlphaWolf50'/>
00:37:20:
00:37:20: <!-- Work Unit Control -->
00:37:20: <dump-after-deadline v='true'/>
00:37:20: <max-queue v='16'/>
00:37:20: <max-units v='0'/>
00:37:20: <next-unit-percentage v='100'/>
00:37:20:
00:37:20: <!-- Folding Slots -->
00:37:20: <slot id='0' type='GPU'/>
00:37:20: <slot id='1' type='SMP'/>
00:37:20:</config>
00:37:20:Trying to access database...
00:37:21:Database locked
00:37:21:Enabled folding slot 00: READY gpu:0:"GT200 [GeForce GTX 260]"
00:37:21:Enabled folding slot 01: READY smp:4
00:37:21:Started thread 6 on PID 1400
00:37:21:Started thread 5 on PID 1400
00:37:21:Started thread 4 on PID 1400
00:37:21:Started thread 1 on PID 1400
00:37:21:Started thread 3 on PID 1400
00:37:21:Starting Unit 01
00:37:21:Running core: C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -lifeline 1400 -version 701 -checkpoint 15 -np 4
00:37:21:Started core on PID 760
00:37:21:FahCore 0xa3 started
00:37:21:Started thread 7 on PID 1400
00:37:21:Connecting to assign-GPU.stanford.edu:80
00:37:21:News: Welcome to Folding@Home
00:37:21:Assigned to work server 171.64.65.61
00:37:21:Requesting new work unit for slot 00: READY gpu:0:"GT200 [GeForce GTX 260]" from 171.64.65.61
00:37:21:Connecting to 171.64.65.61:8080
00:37:21:Unit 01:
00:37:21:Unit 01:*------------------------------*
00:37:21:Unit 01:Folding@Home Gromacs SMP Core
00:37:21:Unit 01:Version 2.27 (Dec. 15, 2010)
00:37:21:Unit 01:
00:37:21:Unit 01:Preparing to commence simulation
00:37:21:Unit 01:- Ensuring status. Please wait.
00:37:22:Slot 00: Downloading 72.65KiB
00:37:23:Slot 00: Download complete
00:37:23:Received Unit: id:00 state:DOWNLOAD project:6605 run:6 clone:266 gen:845 core:0x11 unit:0x2a827cbc4dcc7d54034d010a000619cd
00:37:23:Starting Unit 00
00:37:23:Running core: C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -lifeline 1400 -version 701 -checkpoint 15 -gpu 0
00:37:23:Started core on PID 1672
00:37:23:FahCore 0x11 started
00:37:23:Started thread 8 on PID 1400
00:37:23:Unit 00:
00:37:23:Unit 00:*------------------------------*
00:37:23:Unit 00:Folding@Home GPU Core
00:37:23:Unit 00:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
00:37:23:Unit 00:
00:37:23:Unit 00:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
00:37:23:Unit 00:Build host: amoeba
00:37:23:Unit 00:Board Type: Nvidia
00:37:23:Unit 00:Core :
00:37:23:Unit 00:Preparing to commence simulation
00:37:23:Unit 00:- Looking at optimizations...
00:37:23:Unit 00:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
00:37:23:Unit 00:- Created dyn
00:37:23:Unit 00:- Files status OK
00:37:23:Unit 00:- Expanded 73880 -> 383588 (decompressed 519.2 percent)
00:37:23:Unit 00:Called DecompressByteArray: compressed_data_size=73880 data_size=383588, decompressed_data_size=383588 diff=0
00:37:23:Unit 00:- Digital signature verified
00:37:23:Unit 00:
00:37:23:Unit 00:Project: 6605 (Run 6, Clone 266, Gen 845)
00:37:23:Unit 00:
00:37:23:Unit 00:Assembly optimizations on if available.
00:37:23:Unit 00:Entering M.D.
00:37:24:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
00:37:24:Started thread 9 on PID 1400
00:37:29:Unit 00:Tpr hash 00/wudata_01.tpr: 1589591875 2638857951 2393670717 2413450958 1367645381
00:37:29:Unit 00:
00:37:29:Unit 00:Calling fah_main args: 14 usage=100
00:37:29:Unit 00:
00:37:29:Unit 00:Working on Protein
00:37:30:Unit 00:Client config unavailable.
00:37:31:Unit 01:- Looking at optimizations...
00:37:31:Unit 01:- Working with standard loops on this execution.
00:37:31:Unit 01:- Previous termination of core was improper.
00:37:31:Unit 01:- Files status OK
00:37:31:Unit 01:- Expanded 809277 -> 2075428 (decompressed 256.4 percent)
00:37:31:Unit 01:Called DecompressByteArray: compressed_data_size=809277 data_size=2075428, decompressed_data_size=2075428 diff=0
00:37:31:Unit 01:- Digital signature verified
00:37:31:Unit 01:
00:37:31:Unit 01:Project: 10121 (Run 2, Clone 392, Gen 0)
00:37:31:Unit 01:
00:37:31:Unit 01:Entering M.D.
00:37:31:Unit 00:Starting GUI Server
00:37:37:Unit 01:Using Gromacs checkpoints
00:37:37:Unit 01:Mapping NT from 4 to 4
00:37:38:Unit 01:Resuming from checkpoint
00:37:38:Unit 01:Verified 01/wudata_01.log
00:37:38:Unit 01:Verified 01/wudata_01.trr
00:37:38:Unit 01:Verified 01/wudata_01.xtc
00:37:38:Unit 01:Verified 01/wudata_01.edr
00:37:38:Unit 01:Completed 30444 out of 2500000 steps (1%)
01:06:38:Unit 01:Completed 50000 out of 2500000 steps (2%)
01:43:00:Unit 01:Completed 75000 out of 2500000 steps (3%)
02:18:31:Unit 01:Completed 100000 out of 2500000 steps (4%)
02:54:50:Unit 01:Completed 125000 out of 2500000 steps (5%)
03:31:38:Unit 01:Completed 150000 out of 2500000 steps (6%)
04:07:56:Unit 01:Completed 175000 out of 2500000 steps (7%)
04:44:39:Unit 01:Completed 200000 out of 2500000 steps (8%)
05:20:37:Unit 01:Completed 225000 out of 2500000 steps (9%)
09:30:48:FahCore, running Unit 01, returned: UNKNOWN_ENUM (-1073741819)
09:30:48:Starting Unit 01
09:30:48:Running core: C:/Users/Mike/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -lifeline 1400 -version 701 -checkpoint 15 -np 4
09:30:48:Started core on PID 3924
09:30:48:FahCore 0xa3 started
09:30:48:Started thread 15 on PID 1400
09:30:48:Unit 01:
09:30:48:Unit 01:*------------------------------*
09:30:48:Unit 01:Folding@Home Gromacs SMP Core
09:30:48:Unit 01:Version 2.27 (Dec. 15, 2010)
09:30:48:Unit 01:
09:30:48:Unit 01:Preparing to commence simulation
09:30:48:Unit 01:- Ensuring status. Please wait.
09:30:54:Unit 02:Completed 57%
09:30:58:Unit 01:- Looking at optimizations...
09:30:58:Unit 01:- Working with standard loops on this execution.
09:30:58:Unit 01:- Previous termination of core was improper.
09:30:58:Unit 01:- Going to use standard loops.
09:30:58:Unit 01:- Files status OK
09:30:58:Unit 01:- Expanded 809277 -> 2075428 (decompressed 256.4 percent)
09:30:58:Unit 01:Called DecompressByteArray: compressed_data_size=809277 data_size=2075428, decompressed_data_size=2075428 diff=0
09:30:58:Unit 01:- Digital signature verified
09:30:58:Unit 01:
09:30:58:Unit 01:Project: 10121 (Run 2, Clone 392, Gen 0)
09:30:58:Unit 01:
09:30:58:Unit 01:Entering M.D.
09:31:04:Unit 01:Using Gromacs checkpoints
09:31:04:Unit 01:Mapping NT from 4 to 4
09:31:04:Unit 01:Resuming from checkpoint
09:31:04:Unit 01:Verified 01/wudata_01.log
09:31:04:Unit 01:Verified 01/wudata_01.trr
09:31:04:Unit 01:Verified 01/wudata_01.xtc
09:31:04:Unit 01:Verified 01/wudata_01.edr
09:31:04:Unit 01:Completed 235928 out of 2500000 steps (9%)
09:51:40:Unit 01:Completed 250000 out of 2500000 steps (10%)
Faulting application name: FahCore_a3.exe, version: 0.0.0.0, time stamp: 0x4d4720af
Faulting module name: FahCore_a3.exe, version: 0.0.0.0, time stamp: 0x4d4720af
Exception code: 0xc0000005
Fault offset: 0x0026efdb
Faulting process id: 0x2f8
Faulting application start time: 0x01cc1105ebaa938a
Faulting application path: C:\Users\Mike\AppData\Roaming\FAHClient\cores\www.stanford.edu\~pande\Win32\x86\Core_a3.fah\FahCore_a3.exe
Faulting module path: C:\Users\Mike\AppData\Roaming\FAHClient\cores\www.stanford.edu\~pande\Win32\x86\Core_a3.fah\FahCore_a3.exe
Report Id: 68fa72fb-7d24-11e0-b1bf-00241d27e46bCode: Select all
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: FahCore_a3.exe
P2: 0.0.0.0
P3: 4d4720af
P4: FahCore_a3.exe
P5: 0.0.0.0
P6: 4d4720af
P7: c0000005
P8: 0026efdb
P9:
P10:
These files may be available here:
C:\Users\Mike\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_FahCore_a3.exe_57e4de819812533b867c78bfed1814e9be031da_0f2a7519
Analysis symbol:
Rechecking for solution: 0
Report Status: 0Code: Select all
Version=1
EventType=APPCRASH
EventTime=129497392165901437
ReportType=2
Consent=1
ReportIdentifier=68fa72fc-7d24-11e0-b1bf-00241d27e46b
IntegratorReportIdentifier=68fa72fb-7d24-11e0-b1bf-00241d27e46b
WOW64=1
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=FahCore_a3.exe
Sig[1].Name=Application Version
Sig[1].Value=0.0.0.0
Sig[2].Name=Application Timestamp
Sig[2].Value=4d4720af
Sig[3].Name=Fault Module Name
Sig[3].Value=FahCore_a3.exe
Sig[4].Name=Fault Module Version
Sig[4].Value=0.0.0.0
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=4d4720af
Sig[6].Name=Exception Code
Sig[6].Value=c0000005
Sig[7].Name=Exception Offset
Sig[7].Value=0026efdb
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.768.3
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=0a9e
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=0a9e372d3b4ad19135b953a78882e789
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=0a9e
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=0a9e372d3b4ad19135b953a78882e789
UI[2]=C:\Users\Mike\AppData\Roaming\FAHClient\cores\www.stanford.edu\~pande\Win32\x86\Core_a3.fah\FahCore_a3.exe
UI[3]=FahCore_a3.exe has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Users\Mike\AppData\Roaming\FAHClient\cores\www.stanford.edu\~pande\Win32\x86\Core_a3.fah\FahCore_a3.exe
LoadedModule[1]=C:\Windows\SysWOW64\ntdll.dll
LoadedModule[2]=C:\Windows\syswow64\kernel32.dll
LoadedModule[3]=C:\Windows\syswow64\KERNELBASE.dll
LoadedModule[4]=C:\Program Files\AVAST Software\Avast\snxhk.dll
LoadedModule[5]=C:\Windows\system32\IPHLPAPI.DLL
LoadedModule[6]=C:\Windows\syswow64\msvcrt.dll
LoadedModule[7]=C:\Windows\syswow64\NSI.dll
LoadedModule[8]=C:\Windows\system32\WINNSI.DLL
LoadedModule[9]=C:\Windows\syswow64\RPCRT4.dll
LoadedModule[10]=C:\Windows\syswow64\SspiCli.dll
LoadedModule[11]=C:\Windows\syswow64\CRYPTBASE.dll
LoadedModule[12]=C:\Windows\SysWOW64\sechost.dll
LoadedModule[13]=C:\Windows\system32\WSOCK32.dll
LoadedModule[14]=C:\Windows\syswow64\WS2_32.dll
LoadedModule[15]=C:\Windows\syswow64\ADVAPI32.dll
LoadedModule[16]=C:\Windows\syswow64\SHELL32.dll
LoadedModule[17]=C:\Windows\syswow64\SHLWAPI.dll
LoadedModule[18]=C:\Windows\syswow64\GDI32.dll
LoadedModule[19]=C:\Windows\syswow64\USER32.dll
LoadedModule[20]=C:\Windows\syswow64\LPK.dll
LoadedModule[21]=C:\Windows\syswow64\USP10.dll
LoadedModule[22]=C:\Windows\system32\IMM32.DLL
LoadedModule[23]=C:\Windows\syswow64\MSCTF.dll
FriendlyEventName=Stopped working
ConsentKey=APPCRASH
AppName=FahCore_a3.exe
AppPath=C:\Users\Mike\AppData\Roaming\FAHClient\cores\www.stanford.edu\~pande\Win32\x86\Core_a3.fah\FahCore_a3.exe
