Welcome. I was in your position not too long ago.
1.- I Just installed the new beta Client Control to consolidate both clients in there, but the old clients are halfway through. Is there a way to set the Client Control to finish those too? Maybe adding them to the queue?
2.- How do I know the type of unit I'm getting? (bigadv or whatever)
3.- Where can I find my id number? I need it for the extremeoverclocking stats banner, at least I think so
.1. Set -oneunit flags in your old v6 clients. If you are running the systray v6 GPU client, it's just selecting "Pause with when done" when you right click the systray icon. On the console SMP, you need to stop the client, and restart it with the -oneunit flag
2. You will know if you are getting a "bigadv" SMP WU if you see the base point value of your WU at 8955 (currently). More accurately, look at the Stanford Project summary
http://fah-web.stanford.edu/psummary.html. The right hand column is K-factor. The Bigadv WUs have a 26.4 factor. Currently. Things could and probably will change in the future.
On your i7 2600k, you will be folding that kind of WU for over two days 24/7. You won't get the SMP bonus points until you've paid your dues and folded successfully 10 SMP work units as a user with passkey. When I first turned on my Sandy Bridge system, I started right out with two -bidadv work units. But, no bonus points. AFter I finished my second, I restarted the SMP client WITHOUT the -bigadv flag, and got the requisite number of smaller SMP WUs quickly. Then, I turned the -bigadv back on.
3. re: Extremeoverclocking banner. You won't show up in their stats for a while, but I think they use their own unique ID number. Being in Team 0, you need about 650K points or so to get into the top 2000 members of Team 0 before they will start tracking you, so you can get a sig. Once you do, your number will show up in the Stats Home/news window on the left. See User: below - I've xxx my own user number.
Stats Home/News
- All Users List
- All Teams List
|- Team: 0
|- Team Summary
|- Team Overtake
|- Team Extra Info
|- Team Users Info
|- Team Users List
|- User: xxxxx
|- User Summary
|- User Overtake
|- User Extra Info
|- User Future
Donor dazz.
Team Default (includes all those WU returned without valid team number) (0)
Score 17684 (certificate)
Donor Rank 243300 of 1540337
WU 18 (certificate)
Date of last
work unit 2011-04-23 09:09:59
