Project: 6900 (Run 32, Clone 11, Gen 40)
RoomateoYo
Hardware configuration: i7-2600k @ 4.4 GHz
GTX780
i7-2630QM
GT555M
Post by RoomateoYo »
This unit caused the a5 core to immediately crash several times. I think I downloaded the same unit 3 times.
Zagen30
Re: Project: 6900 (Run 32, Clone 11, Gen 40)
Post by Zagen30 »
I'm getting the same thing.
DrSpalding
Hardware configuration: Dell Studio 425 MTS-Core i7-920 c0 stock
evga SLI 3x o/c Core i7-920 d0 @ 3.9GHz + nVidia GTX275
Dell 5150 + nVidia 9800GT
Post by DrSpalding »
As am I. Here is a relevant excerpt of the log:
[00:11:46] - Preparing to get new work unit...
[00:11:46] Cleaning up work directory
[00:11:48] + Attempting to get work packet
[00:11:48] Passkey found
[00:11:48] - Connecting to assignment server
[00:11:48] - Successful: assigned to (130.237.232.141).
[00:11:48] + News From Folding@Home: Welcome to Folding@Home
[00:11:48] Loaded queue successfully.
[00:12:21] + Closed connections
[00:12:21]
[00:12:21] + Processing work unit
[00:12:21] Core required: FahCore_a5.exe
[00:12:21] Core found.
[00:12:21] Working on queue slot 02 [April 23 00:12:21 UTC]
[00:12:21] + Working ...
[00:12:21]
[00:12:21] *------------------------------*
[00:12:21] Folding@Home Gromacs SMP Core
[00:12:21] Version 2.27 (Mar 12, 2010)
[00:12:21]
[00:12:21] Preparing to commence simulation
[00:12:21] - Looking at optimizations...
[00:12:21] - Created dyn
[00:12:21] - Files status OK
[00:12:26] - Expanded 24867174 -> 30796293 (decompressed 123.8 percent)
[00:12:26] Called DecompressByteArray: compressed_data_size=24867174 data_size=30796293, decompressed_data_size=30796293 diff=0
[00:12:26] - Digital signature verified
[00:12:26]
[00:12:26] Project: 6900 (Run 32, Clone 11, Gen 40)
[00:12:26]
[00:12:26] Assembly optimizations on if available.
[00:12:26] Entering M.D.
[00:12:32] Mapping NT from 8 to 8
[00:12:35] Completed 0 out of 250000 steps  (0%)
[00:12:45] CoreStatus = C0000029 (-1073741783)
[00:12:45] Client-core communications error: ERROR 0xc0000029
[00:12:45] Deleting current work unit & continuing...
[00:12:59] - Preparing to get new work unit...
[00:12:59] Cleaning up work directory
[00:13:00] + Attempting to get work packet
[00:13:00] Passkey found
[00:13:00] - Connecting to assignment server
[00:13:01] - Successful: assigned to (130.237.232.141).
[00:13:01] + News From Folding@Home: Welcome to Folding@Home
[00:13:01] Loaded queue successfully.
[00:13:41] + Closed connections
In addition, it caused the client to try to redownload the core exe again and again as well and was unable to connect to the work server many times. Something is rotten; perhaps the WU data is corrupted?
For now, I switched from -bigadv to -advmethods to get a non-bigadv WU and then restarted with -bigadv to do something besides download the same WU over and over again until it gets to a 24 hour EUE pause.
Not a real doctor, I just play one on the 'net!
Thanks for the reports.
The WU (P6900,R32,C11,G40) has been reported as a bad WU.
