Been folding for years and have never seen a workup with a number of steps not ending in zero. Anyone else?
Seems to be running fine btw.
Project 6075 (run 0 Clone 197 Gen263) 500008(eight) steps?
craigmdq6700
Re: Project 6075 (run 0 Clone 197 Gen263) 500008(eight) step
It happens from time to time. No explanation has been offered.
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Here's a snippet from my current GPU WU on Core 15:
[09:43:29] Completed 32000000 out of 50000000 steps (64%).
[09:44:50] Completed 32499999 out of 50000000 steps (65%).
I've been seeing this periodically. 'Doesn't seem to harm anything - the WU will catch up when it finishes.
EDIT: I added the end of the WU - interestingly enough, the last step seemed to be still off by one, but then the core shut down, the results uploaded, and the Stanford servers were happy as a clam.
[10:32:13] Completed 49999999 out of 50000000 steps (100%).
From v6 client
From v6 client
08:16:48] + Processing work unit
[08:16:48] Core required: FahCore_15.exe
[08:16:48] Core found.
[08:16:48] Working on queue slot 02 [April 16 08:16:48 UTC]
[08:16:48] + Working ...
[08:16:48] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -checkpoint 15 -verbose -lifeline 3260 -version 641'
[08:16:48]
[08:16:48] *------------------------------*
[08:16:48] Folding@Home GPU Core
[08:16:48] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[08:16:48]
[08:16:48] Build host: SimbiosNvdWin7
[08:16:48] Board Type: NVIDIA/CUDA
[08:16:48] Core : x=15
[08:16:48] Window's signal control handler registered.
[08:16:48] Preparing to commence simulation
[08:16:48] - Looking at optimizations...
[08:16:48] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[08:16:48] - Created dyn
[08:16:48] - Files status OK
[08:16:48] sizeof(CORE_PACKET_HDR) = 512 file=<>
[08:16:48] - Expanded 43758 -> 171827 (decompressed 392.6 percent)
[08:16:48] Called DecompressByteArray: compressed_data_size=43758 data_size=171827, decompressed_data_size=171827 diff=0
[08:16:48] - Digital signature verified
[08:16:48]
[08:16:48] Project: 6801 (Run 9389, Clone 3, Gen 4)
[08:16:48]
[08:16:48] Assembly optimizations on if available.
[08:16:48] Entering M.D.
[08:16:50] Tpr hash work/wudata_02.tpr: 3011143730 1635619272 650014571 3238562498 722351494
[08:16:50] Working on ALZHEIMER'S DISEASE AMYLOID
[08:16:50] Client config found, loading data.
[08:16:50] Starting GUI Server
[08:16:51] Setting checkpoint frequency: 500000
[08:18:12] Completed 500000 out of 50000000 steps (1%).
[08:19:33] Completed 1000000 out of 50000000 steps (2%).
[08:20:54] Completed 1500000 out of 50000000 steps (3%).
[08:22:16] Completed 2000000 out of 50000000 steps (4%).
[08:23:37] Completed 2500000 out of 50000000 steps (5%).
[08:24:58] Completed 3000000 out of 50000000 steps (6%).
[08:26:19] Completed 3500000 out of 50000000 steps (7%).
[08:27:40] Completed 4000000 out of 50000000 steps (8%).
[08:29:02] Completed 4500000 out of 50000000 steps (9%).
[08:30:22] Completed 5000000 out of 50000000 steps (10%).
[08:31:44] Completed 5500000 out of 50000000 steps (11%).
[08:33:05] Completed 6000000 out of 50000000 steps (12%).
[08:34:26] Completed 6500000 out of 50000000 steps (13%).
[08:35:48] Completed 7000000 out of 50000000 steps (14%).
[08:37:09] Completed 7500000 out of 50000000 steps (15%).
[08:38:30] Completed 8000000 out of 50000000 steps (16%).
[08:39:51] Completed 8500000 out of 50000000 steps (17%).
[08:41:12] Completed 9000000 out of 50000000 steps (18%).
[08:42:34] Completed 9500000 out of 50000000 steps (19%).
[08:43:55] Completed 10000000 out of 50000000 steps (20%).
[08:45:16] Completed 10500000 out of 50000000 steps (21%).
[08:46:37] Completed 11000000 out of 50000000 steps (22%).
[08:47:59] Completed 11500000 out of 50000000 steps (23%).
[08:49:20] Completed 12000000 out of 50000000 steps (24%).
[08:50:41] Completed 12500000 out of 50000000 steps (25%).
[08:52:02] Completed 13000000 out of 50000000 steps (26%).
[08:53:23] Completed 13500000 out of 50000000 steps (27%).
[08:54:45] Completed 14000000 out of 50000000 steps (28%).
[08:56:06] Completed 14500000 out of 50000000 steps (29%).
[08:57:27] Completed 15000000 out of 50000000 steps (30%).
[08:58:49] Completed 15500000 out of 50000000 steps (31%).
[09:00:09] Completed 16000000 out of 50000000 steps (32%).
[09:01:31] Completed 16500000 out of 50000000 steps (33%).
[09:02:52] Completed 17000000 out of 50000000 steps (34%).
[09:04:13] Completed 17500000 out of 50000000 steps (35%).
[09:05:35] Completed 18000000 out of 50000000 steps (36%).
[09:06:56] Completed 18500000 out of 50000000 steps (37%).
[09:08:17] Completed 19000000 out of 50000000 steps (38%).
[09:09:38] Completed 19500000 out of 50000000 steps (39%).
[09:10:59] Completed 20000000 out of 50000000 steps (40%).
[09:12:21] Completed 20500000 out of 50000000 steps (41%).
[09:13:42] Completed 21000000 out of 50000000 steps (42%).
[09:15:03] Completed 21500000 out of 50000000 steps (43%).
[09:16:25] Completed 22000000 out of 50000000 steps (44%).
[09:17:45] Completed 22500000 out of 50000000 steps (45%).
[09:19:07] Completed 23000000 out of 50000000 steps (46%).
[09:20:28] Completed 23500000 out of 50000000 steps (47%).
[09:21:49] Completed 24000000 out of 50000000 steps (48%).
[09:23:11] Completed 24500000 out of 50000000 steps (49%).
[09:24:32] Completed 25000000 out of 50000000 steps (50%).
[09:25:53] Completed 25500000 out of 50000000 steps (51%).
[09:27:14] Completed 26000000 out of 50000000 steps (52%).
[09:28:35] Completed 26500000 out of 50000000 steps (53%).
[09:29:57] Completed 27000000 out of 50000000 steps (54%).
[09:31:18] Completed 27500000 out of 50000000 steps (55%).
[09:32:39] Completed 28000000 out of 50000000 steps (56%).
[09:34:00] Completed 28500000 out of 50000000 steps (57%).
[09:35:22] Completed 29000000 out of 50000000 steps (58%).
[09:36:43] Completed 29500000 out of 50000000 steps (59%).
[09:38:04] Completed 30000000 out of 50000000 steps (60%).
[09:39:25] Completed 30500000 out of 50000000 steps (61%).
[09:40:47] Completed 31000000 out of 50000000 steps (62%).
[09:42:08] Completed 31500000 out of 50000000 steps (63%).
[09:46:12] Completed 32999999 out of 50000000 steps (66%).
[09:47:33] Completed 33499999 out of 50000000 steps (67%).
[09:48:54] Completed 33999999 out of 50000000 steps (68%).
[09:50:15] Completed 34499999 out of 50000000 steps (69%).
[09:51:36] Completed 34999999 out of 50000000 steps (70%).
[09:52:58] Completed 35499999 out of 50000000 steps (71%).
SNIP
[10:30:52] Completed 49499999 out of 50000000 steps (99%).
[10:32:14] Finished fah_main
[10:32:14]
[10:32:14] Successful run
[10:32:14] DynamicWrapper: Finished Work Unit: sleep=10000
[10:32:24] Reserved 2481276 bytes for xtc file; Cosm status=0
[10:32:24] Allocated 2481276 bytes for xtc file
[10:32:24] - Reading up to 2481276 from "work/wudata_02.xtc": Read 2481276
[10:32:24] Read 2481276 bytes from xtc file; available packet space=783949188
[10:32:24] xtc file hash check passed.
[10:32:24] Reserved 76680 76680 783949188 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[10:32:24] Allocated 76680 bytes for arc file
[10:32:24] - Reading up to 76680 from "work/wudata_02.trr": Read 76680
[10:32:24] Read 76680 bytes from arc file; available packet space=783872508
[10:32:24] trr file hash check passed.
[10:32:24] Allocated 544 bytes for edr file
[10:32:24] Read bedfile
[10:32:24] edr file hash check passed.
[10:32:24] Allocated 120134 bytes for logfile
[10:32:24] Read logfile
[10:32:24] GuardedRun: success in DynamicWrapper
[10:32:24] GuardedRun: done
[10:32:24] Run: GuardedRun completed.
[10:32:26] + Opened results file
[10:32:26] - Writing 2679146 bytes of core data to disk...
[10:32:26] Done: 2678634 -> 2521791 (compressed to 94.1 percent)
[10:32:26] ... Done.
[10:32:26] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[10:32:27] Shutting down core
[10:32:27]
[10:32:27] Folding@home Core Shutdown: FINISHED_UNIT
[10:32:31] CoreStatus = 64 (100)
[10:32:31] Unit 2 finished with 99 percent of time to deadline remaining.
[10:32:31] Updated performance fraction: 0.990392
[10:32:31] Sending work to server
[10:32:31] Project: 6801 (Run 9389, Clone 3, Gen 4)
[10:32:31] - Read packet limit of 540015616... Set to 524286976.
[10:32:31] + Attempting to send results [April 16 10:32:31 UTC]
[10:32:31] - Reading file work/wuresults_02.dat from core
[10:32:31] (Read 2522303 bytes from disk)
[10:32:31] Gpu type=3 species=21.
[10:32:31] Connecting to http://171.64.65.64:8080/
[10:32:36] Posted data.
[10:32:36] Initial: 0000; - Uploaded at ~492 kB/s
[10:32:36] - Averaged speed for that direction ~436 kB/s
[10:32:36] + Results successfully sent
[10:32:36] Thank you for your contribution to Folding@Home.
[10:32:36] + Number of Units Completed: 215
