Project: 6508 (Run 14, Clone 278, Gen 32)
OEOTS
Hardware configuration: Main PC: Intel E6400 @ 3.0 Ghz, 4GB RAM, EN7900GS, Win XP SP3
Post by OEOTS »
I've found a EUE on one of the laptops running here, it's a bone stock Lattitude D820 with a T2400 rated a 1.83 Ghz.
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@home\Folding@home-x86
Arguments: -verbosity 9 -advmethods
[10:57:37] - Ask before connecting: No
[10:57:37] - User name: OEOTS (Team 195604)
[10:57:37] - User ID: *********************
[10:57:37] - Machine ID: 1
[10:57:37]
[10:57:37] Loaded queue successfully.
[10:57:37] Initialization complete
[10:57:37]
[10:57:37] + Processing work unit
[10:57:37] - Autosending finished units... [April 6 10:57:37 UTC]
[10:57:37] Trying to send all finished work units
[10:57:37] + No unsent completed units remaining.
[10:57:37] - Autosend completed
[10:57:37] Core required: FahCore_78.exe
[10:57:37] Core found.
[10:57:38] Working on queue slot 04 [April 6 10:57:38 UTC]
[10:57:38] + Working ...
[10:57:42] - Calling '.\FahCore_78.exe -dir work/ -suffix 04 -checkpoint 15 -verbose -lifeline 728 -version 623'
[10:57:42]
[10:57:42] *------------------------------*
[10:57:42] Folding@Home Gromacs Core
[10:57:42] Version 1.90 (March 8, 2006)
[10:57:42]
[10:57:42] Preparing to commence simulation
[10:57:42] - Looking at optimizations...
[10:57:42] - Files status OK
[10:57:42] - Expanded 479859 -> 2353061 (decompressed 490.3 percent)
[10:57:43]
[10:57:43] Project: 6508 (Run 14, Clone 278, Gen 32)
[10:57:43]
[10:57:43] Assembly optimizations on if available.
[10:57:43] Entering M.D.
[10:58:04] (Starting from checkpoint)
[10:58:04] Protein: proG_15 in water
[10:58:04]
[10:58:04] Writing local files
[10:58:04] Completed 30000 out of 250000 steps  (12%)
[10:58:04] Extra SSE boost OK.
[11:07:33] Writing local files
[11:07:33]
[15:30:49] Completed 112500 out of 250000 steps  (45%)
[15:39:02] Writing local files
[15:39:02] Completed 115000 out of 250000 steps  (46%)
[15:47:14] Writing local files
[15:47:14] Completed 117500 out of 250000 steps  (47%)
[15:50:03] Gromacs cannot continue further.
[15:50:03] Going to send back what have done.
[15:50:03] logfile size: 22487
[15:50:03] - Writing 23023 bytes of core data to disk...
[15:50:03] Done: 22511 -> 4683 (compressed to 20.8 percent)
[15:50:03]   ... Done.
[15:50:03]
[15:50:03] Folding@home Core Shutdown: EARLY_UNIT_END
[15:50:07] CoreStatus = 72 (114)
[15:50:07] Sending work to server
[15:50:07] Project: 6508 (Run 14, Clone 278, Gen 32)
[15:50:07] - Read packet limit of 540015616... Set to 524286976.
Re: Project: 6508 (Run 14, Clone 278, Gen 32)
Hi OEOTS (team 195604),
Your WU (P6508 R14 C278 G32) was added to the stats database on 2011-04-06 09:03:06 for 34.08 points of credit.
There are 3 other reports of EUE in the db, so I marked the WU as bad.
