Project: 2685 (Run 5, Clone 17, Gen 62)
texinga
Post by texinga »
This morning, I ran across this particular 2685 that didn't seem to want to process correctly. Right after it would say "Entering MD" a Windows 7 error screen would pop-up saying "FahCore_a5.exe has stopped working". I do a lot of Bigadvs of all flavors and this is the first time I've encountered this particular problem. There have been no changes to my PC of late or new problems, so after this WU failed to process 3 times in a row (the same way), I decided to stop it and prepare to receive a new WU. I got a 6900 WU next and it processed correctly without any problems.
[11:01:55] - Ask before connecting: No
[11:01:55] - User name: texinga (Team 111065)
[11:01:55] - User ID:
[11:01:55] - Machine ID: 1
[11:01:55]
[11:01:55] Loaded queue successfully.
[11:01:55] - Preparing to get new work unit...
[11:01:55] Cleaning up work directory
[11:01:55] + Attempting to get work packet
[11:01:55] Passkey found
[11:01:55] - Connecting to assignment server
[11:01:56] - Successful: assigned to (171.67.108.22).
[11:01:56] + News From Folding@Home: Welcome to Folding@Home
[11:01:56] Loaded queue successfully.
[11:02:20] + Closed connections
[11:02:20]
[11:02:20] + Processing work unit
[11:02:20] Core required: FahCore_a5.exe
[11:02:20] Core found.
[11:02:20] Working on queue slot 08 [April 6 11:02:20 UTC]
[11:02:20] + Working ...
[11:02:20]
[11:02:20] *------------------------------*
[11:02:20] Folding@Home Gromacs SMP Core
[11:02:20] Version 2.27 (Mar 12, 2010)
[11:02:20]
[11:02:20] Preparing to commence simulation
[11:02:20] - Looking at optimizations...
[11:02:20] - Created dyn
[11:02:20] - Files status OK
[11:02:25] - Expanded 26437837 -> 32750961 (decompressed 123.8 percent)
[11:02:25] Called DecompressByteArray: compressed_data_size=26437837 data_size=32750961, decompressed_data_size=32750961 diff=0
[11:02:25] - Digital signature verified
[11:02:25]
[11:02:25] Project: 2685 (Run 5, Clone 17, Gen 62)
[11:02:25]
[11:02:26] Assembly optimizations on if available.
[11:02:26] Entering M.D.
[11:02:32] Mapping NT from 16 to 16
[11:02:34] Completed 0 out of 250000 steps  (0%)
[11:03:04] CoreStatus = C0000029 (-1073741783)
[11:03:04] Client-core communications error: ERROR 0xc0000029
[11:03:04] Deleting current work unit & continuing...
Rick
Re: Project: 2685 (Run 5, Clone 17, Gen 62)
There are two EUE reports in the DB, plus yours on the forum : I marked the WU as bad.
