60 failed uploads of this unit.
Mactin
Post by Mactin »
This is probably a lost cause but here it is :
[11:40:15] - Read packet limit of 540015616... Set to 524286976.
[11:40:15] + Attempting to send results [March 29 11:40:15 UTC]
[11:40:15] - Reading file work/wuresults_01.dat from core
[11:40:15]   (Read 118176 bytes from disk)
[11:40:15] Gpu type=2 species=11.
[11:40:15] Connecting to http://171.67.108.26:8080/
[11:40:16] Posted data.
[11:40:16] Initial: 0000; - Uploaded at ~116 kB/s
[11:40:16] - Averaged speed for that direction ~103 kB/s
[11:40:16] - Server does not have record of this unit. Will try again later.
[11:40:16]   Could not transmit unit 01 to Collection server; keeping in queue.
[11:40:16] + Sent 0 of 1 completed units to the server
[11:40:16] - Preparing to get new work unit...
[11:40:16] Cleaning up work directory
[11:40:16] + Attempting to get work packet
[11:40:16] Passkey found
[11:40:16] - Will indicate memory of 2048 MB
[11:40:16] Gpu type=2 species=11.
[11:40:16] - Connecting to assignment server
[11:40:16] Connecting to http://assign-GPU.stanford.edu:8080/
[11:40:17] Posted data.
[11:40:17] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[11:40:17] + News From Folding@Home: Welcome to Folding@Home
[11:40:17] Loaded queue successfully.
[11:40:17] Gpu type=2 species=11.
[11:40:17] Sent data
[11:40:17] Connecting to http://171.67.108.11:8080/
[11:40:18] Posted data.
[11:40:18] Initial: 0000; - Receiving payload (expected size: 47179)
[11:40:18] Conversation time very short, giving reduced weight in bandwidth avg
[11:40:18] - Downloaded at ~92 kB/s
[11:40:18] - Averaged speed for that direction ~63 kB/s
[11:40:18] + Received work.
[11:40:18] Trying to send all finished work units
[11:40:18] Project: 10117 (Run 7595, Clone 1, Gen 5)
[11:40:18] - Read packet limit of 540015616... Set to 524286976.
[11:40:18] + Attempting to send results [March 29 11:40:18 UTC]
[11:40:18] - Reading file work/wuresults_01.dat from core
[11:40:18]   (Read 118176 bytes from disk)
[11:40:18] Gpu type=2 species=11.
[11:40:18] Connecting to http://171.64.65.71:8080/
[11:40:20] Posted data.
[11:40:20] Initial: 0000; - Uploaded at ~58 kB/s
[11:40:20] - Averaged speed for that direction ~94 kB/s
[11:40:20] - Server does not have record of this unit. Will try again later.
[11:40:20] - Error: Could not transmit unit 01 (completed March 27) to work server.
[11:40:20] - 60 failed uploads of this unit.
HendricksSA
Re: 60 failed uploads of this unit.
Post by HendricksSA »
Maclin, your 10117 has a 2 day preferred deadline. I don't know when it first downloaded, but you are probably past that now. It shows completion on Mar 27. Once it passed the preferred deadline it would have been reassigned. The final deadline is 3 days so the client should automatically delete it from the queue. Probably no points for it in your future.
Your WU (P10117 R7595 C1 G5) was added to the stats database on 2011-03-26 09:05:11 for 494 points of credit.
Apparently the server accepted it but the confirmation message back to the client was lost/blocked/??? so the client never deleted the WU. After that, the messages that the WU had already been received were, in fact, correct.
