[16:49:24] + Attempting to get work packet
[16:49:24] Passkey found
[16:49:24] - Will indicate memory of 2048 MB
[16:49:24] - Connecting to assignment server
[16:49:24] Connecting to http://assign.stanford.edu:8080/
[16:49:25] Posted data.
[16:49:25] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[16:49:25] + News From Folding@Home: Welcome to Folding@Home
[16:49:26] Loaded queue successfully.
[16:49:26] Sent data
[16:49:26] Connecting to http://171.64.65.62:8080/
[16:49:26] Posted data.
[16:49:26] Initial: 0000; - Receiving payload (expected size: 475311)
[16:49:29] - Downloaded at ~154 kB/s
[16:49:29] - Averaged speed for that direction ~128 kB/s
[16:49:29] + Received work.
[16:49:29] Trying to send all finished work units
[16:49:29] + No unsent completed units remaining.
[16:49:29] + Closed connections
[16:49:29]
[16:49:29] + Processing work unit
[16:49:29] Core required: FahCore_78.exe
[16:49:29] Core found.
[16:49:29] Working on queue slot 09 [March 26 16:49:29 UTC]
[16:49:29] + Working ...
[16:49:29] - Calling '.\FahCore_78.exe -dir work/ -suffix 09 -nice 19 -cpu 96 -nocpulock -checkpoint 30 -service -forceasm -verbose -lifeline 3296 -version 634'
[16:49:29]
[16:49:29] *------------------------------*
[16:49:29] Folding@Home Gromacs Core
[16:49:29] Version 1.90 (March 8, 2006)
[16:49:29]
[16:49:29] Preparing to commence simulation
[16:49:29] - Assembly optimizations manually forced on.
[16:49:29] - Not checking prior termination.
[16:49:30] - Expanded 474799 -> 2361141 (decompressed 497.2 percent)
[16:49:30] - Starting from initial work packet
[16:49:30]
[16:49:30] Project: 6518 (Run 4, Clone 216, Gen 18)
[16:49:30]
[16:49:30] Assembly optimizations on if available.
[16:49:30] Entering M.D.
[16:49:36] Protein: proG_5 in water
[16:49:36]
[16:49:36] Writing local files
[16:49:36] Extra SSE boost OK.
[16:49:36] Completed 0 out of 250000 steps (0%)
[16:55:50] Writing local files
[16:55:50] Completed 2500 out of 250000 steps (1%)
[17:02:03] Writing local files
[17:02:03] Completed 5000 out of 250000 steps (2%)
[17:08:16] Writing local files
[17:08:16] Completed 7500 out of 250000 steps (3%)
[17:14:27] Writing local files
[17:14:27] Completed 10000 out of 250000 steps (4%)
[17:20:40] Writing local files
[17:20:41] Completed 12500 out of 250000 steps (5%)
[17:26:54] Writing local files
[17:26:54] Completed 15000 out of 250000 steps (6%)
[17:33:05] Writing local files
[17:33:05] Completed 17500 out of 250000 steps (7%)
[17:39:15] Writing local files
[17:39:15] Completed 20000 out of 250000 steps (8%)
[17:45:29] Writing local files
[17:45:29] Completed 22500 out of 250000 steps (9%)
[17:51:41] Writing local files
[17:51:41] Completed 25000 out of 250000 steps (10%)
[17:57:52] Writing local files
[17:57:52] Completed 27500 out of 250000 steps (11%)
[18:04:02] Writing local files
[18:04:02] Completed 30000 out of 250000 steps (12%)
[18:10:15] Writing local files
[18:10:15] Completed 32500 out of 250000 steps (13%)
[18:16:27] Writing local files
[18:16:27] Completed 35000 out of 250000 steps (14%)
[18:22:40] Writing local files
[18:22:40] Completed 37500 out of 250000 steps (15%)
[18:28:53] Writing local files
[18:28:53] Completed 40000 out of 250000 steps (16%)
[18:35:04] Writing local files
[18:35:04] Completed 42500 out of 250000 steps (17%)
[18:41:14] Writing local files
[18:41:14] Completed 45000 out of 250000 steps (18%)
[18:47:27] Writing local files
[18:47:27] Completed 47500 out of 250000 steps (19%)
[18:53:21] Gromacs cannot continue further.
[18:53:21] Going to send back what have done.
[18:53:21] logfile size: 8309
[18:53:21] - Writing 8845 bytes of core data to disk...
[18:53:21] Done: 8333 -> 3179 (compressed to 38.1 percent)
[18:53:21] ... Done.
[18:53:21]
[18:53:21] Folding@home Core Shutdown: EARLY_UNIT_END
[18:53:24] CoreStatus = 72 (114)
[18:53:24] Sending work to server
[18:53:24] Project: 6518 (Run 4, Clone 216, Gen 18)
[18:53:24] - Read packet limit of 540015616... Set to 524286976.
[18:53:24] + Attempting to send results [March 26 18:53:24 UTC]
[18:53:24] - Reading file work/wuresults_09.dat from core
[18:53:24] (Read 3691 bytes from disk)
[18:53:24] Connecting to http://171.64.65.62:8080/
[18:53:25] Posted data.
[18:53:25] Initial: 0000; - Uploaded at ~4 kB/s
[18:53:25] - Averaged speed for that direction ~19 kB/s
[18:53:25] + Results successfully sent
[18:53:25] Thank you for your contribution to Folding@Home.
