Project: 6801 (Run 6018, Clone 3, Gen 9)
Atom
Post by Atom »
Edit by Mod:
Title changed from GPU client: "Error starting Folding@Home core" then sleeps
to Project: 6801 (Run 6018, Clone 3, Gen 9)
Windows 7 Ultimate 64-bit
dual GTS 450s (running at stock speeds)
latest drivers
latest GPU client
GPU client keeps failing to engage core, then tries to download a new core, then throws the same error (Corestatus = 63 (99) then repeats the process until it decides to go to sleep.
I've always had problems with stability with GTS 450s in general, but this is the first time I've encountered this problem. It's happening on two different machines, though both machines share the exact same configuration of OS, drivers, and cards.
Any idea what's causing this and how to correct it?
Thanks,
Atom
--- Opening Log file [March 26 03:06:45 UTC]
# Windows GPU Systray Edition #################################################
                       Folding@Home Client Version 6.41r2
                          http://folding.stanford.edu
Launch directory: C:\Users\David\AppData\Roaming\Folding@home-gpu
Arguments: -gpu 0 -advmethods -forcegpu nvidia_fermi
[03:06:45] - Ask before connecting: No
[03:06:45] - User name: Atom (Team 37726)
[03:06:45] - User ID: 79CAA14838267614
[03:06:45] - Machine ID: 1
[03:06:45]
[03:06:45] Gpu type=3 species=20.
[03:06:46] Loaded queue successfully.
[03:06:46] Initialization complete
[03:06:46]
[03:06:46] + Processing work unit
[03:06:46] Core required: FahCore_15.exe
[03:06:46] Core found.
[03:06:46] Working on queue slot 01 [March 26 03:06:46 UTC]
[03:06:46] + Working ...
[03:06:46]
[03:06:46] *------------------------------*
[03:06:46] Folding@Home GPU Core
[03:06:46] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:06:46]
[03:06:46] Build host: SimbiosNvdWin7
[03:06:46] Board Type: NVIDIA/CUDA
[03:06:46] Core      : x=15
[03:06:46]  Window's signal control handler registered.
[03:06:46] Preparing to commence simulation
[03:06:46] - Ensuring status. Please wait.
[03:06:55] - Looking at optimizations...
[03:06:55] - Working with standard loops on this execution.
[03:06:55] Examination of work files indicates 8 consecutive improper terminations of core.
[03:06:55] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:06:55] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[03:06:55] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[03:06:55] - Digital signature verified
[03:06:55]
[03:06:55] Project: 6801 (Run 4184, Clone 3, Gen 31)
[03:06:55]
[03:06:55] Entering M.D.
[03:06:57] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[03:06:57] Working on ALZHEIMER'S DISEASE AMYLOID
[03:06:57] Client config found, loading data.
[03:07:00] CoreStatus = 63 (99)
[03:07:00] + Error starting Folding@home core.
[03:07:05]
[03:07:05] + Processing work unit
[03:07:05] Core required: FahCore_15.exe
[03:07:05] Core found.
[03:07:05] Working on queue slot 01 [March 26 03:07:05 UTC]
[03:07:05] + Working ...
[03:07:05]
[03:07:05] *------------------------------*
[03:07:05] Folding@Home GPU Core
[03:07:05] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:07:05]
[03:07:05] Build host: SimbiosNvdWin7
[03:07:05] Board Type: NVIDIA/CUDA
[03:07:05] Core      : x=15
[03:07:05]  Window's signal control handler registered.
[03:07:05] Preparing to commence simulation
[03:07:05] - Ensuring status. Please wait.
[03:07:14] - Looking at optimizations...
[03:07:14] - Working with standard loops on this execution.
[03:07:14] Examination of work files indicates 8 consecutive improper terminations of core.
[03:07:14] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:07:14] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[03:07:14] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[03:07:14] - Digital signature verified
[03:07:14]
[03:07:14] Project: 6801 (Run 4184, Clone 3, Gen 31)
[03:07:14]
[03:07:14] Entering M.D.
[03:07:16] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[03:07:16] Working on ALZHEIMER'S DISEASE AMYLOID
[03:07:16] Client config found, loading data.
[03:07:19] CoreStatus = 63 (99)
[03:07:19] + Error starting Folding@home core.
[03:07:24]
[03:07:24] + Processing work unit
[03:07:24] Core required: FahCore_15.exe
[03:07:24] Core found.
[03:07:24] Working on queue slot 01 [March 26 03:07:24 UTC]
[03:07:24] + Working ...
[03:07:24]
[03:07:24] *------------------------------*
[03:07:24] Folding@Home GPU Core
[03:07:24] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:07:24]
[03:07:24] Build host: SimbiosNvdWin7
[03:07:24] Board Type: NVIDIA/CUDA
[03:07:24] Core      : x=15
[03:07:24]  Window's signal control handler registered.
[03:07:24] Preparing to commence simulation
[03:07:24] - Ensuring status. Please wait.
Folding@Home Client Shutdown.
--- Opening Log file [March 26 15:53:29 UTC]
[15:53:29] - Ask before connecting: No
[15:53:29] - User name: Atom (Team 37726)
[15:53:29] - User ID: 79CAA14838267614
[15:53:29] - Machine ID: 1
[15:53:29]
[15:53:29] Gpu type=3 species=20.
[15:53:29] Work directory not found. Creating...
[15:53:29] Could not open work queue, generating new queue...
[15:53:30] Initialization complete
[15:53:30] - Preparing to get new work unit...
[15:53:30] Cleaning up work directory
[15:53:30] + Attempting to get work packet
[15:53:30] Passkey found
[15:53:30] Gpu type=3 species=20.
[15:53:30] - Connecting to assignment server
[15:53:30] - Successful: assigned to (171.64.65.64).
[15:53:30] + News From Folding@Home: Welcome to Folding@Home
[15:53:30] Loaded queue successfully.
[15:53:31] + Closed connections
[15:53:31]
[15:53:31] + Processing work unit
[15:53:31] Core required: FahCore_15.exe
[15:53:31] Core not found.
[15:53:31] - Core is not present or corrupted.
[15:53:31] - Attempting to download new core...
[15:53:31] + Downloading new core: FahCore_15.exe
[15:53:31] + 10240 bytes downloaded
[15:53:32] + 20480 bytes downloaded
[15:53:32] + 30720 bytes downloaded
[15:53:32] + 40960 bytes downloaded
[15:53:32] + 51200 bytes downloaded
[15:53:32] + 61440 bytes downloaded
[15:53:32] + 71680 bytes downloaded
[15:53:32] + 81920 bytes downloaded
[15:53:32] + 92160 bytes downloaded
[15:53:32] + 102400 bytes downloaded
[15:53:32] + 112640 bytes downloaded
[15:53:32] + 122880 bytes downloaded
[15:53:32] + 133120 bytes downloaded
[15:53:32] + 143360 bytes downloaded
[15:53:32] + 153600 bytes downloaded
[15:53:33] + 163840 bytes downloaded
[15:53:33] + 174080 bytes downloaded
[15:53:33] + 184320 bytes downloaded
[15:53:33] + 194560 bytes downloaded
[15:53:33] + 204800 bytes downloaded
[15:53:33] + 215040 bytes downloaded
[15:53:33] + 225280 bytes downloaded
[15:53:33] + 235520 bytes downloaded
[15:53:33] + 245760 bytes downloaded
[15:53:33] + 256000 bytes downloaded
[15:53:33] + 266240 bytes downloaded
[15:53:33] + 276480 bytes downloaded
[15:53:33] + 286720 bytes downloaded
[15:53:33] + 296960 bytes downloaded
[15:53:34] + 307200 bytes downloaded
[15:53:34] + 317440 bytes downloaded
[15:53:34] + 327680 bytes downloaded
[15:53:34] + 337920 bytes downloaded
[15:53:34] + 348160 bytes downloaded
[15:53:34] + 358400 bytes downloaded
[15:53:34] + 368640 bytes downloaded
[15:53:34] + 378880 bytes downloaded
[15:53:34] + 389120 bytes downloaded
[15:53:34] + 399360 bytes downloaded
[15:53:34] + 409600 bytes downloaded
[15:53:34] + 419840 bytes downloaded
[15:53:34] + 430080 bytes downloaded
[15:53:34] + 440320 bytes downloaded
[15:53:34] + 450560 bytes downloaded
[15:53:34] + 460800 bytes downloaded
[15:53:34] + 471040 bytes downloaded
[15:53:34] + 481280 bytes downloaded
[15:53:34] + 491520 bytes downloaded
[15:53:35] + 501760 bytes downloaded
[15:53:35] + 512000 bytes downloaded
[15:53:35] + 522240 bytes downloaded
[15:53:35] + 532480 bytes downloaded
[15:53:35] + 542720 bytes downloaded
[15:53:35] + 552960 bytes downloaded
[15:53:35] + 563200 bytes downloaded
[15:53:35] + 573440 bytes downloaded
[15:53:35] + 583680 bytes downloaded
[15:53:35] + 593920 bytes downloaded
[15:53:35] + 604160 bytes downloaded
[15:53:35] + 614400 bytes downloaded
[15:53:35] + 624640 bytes downloaded
[15:53:35] + 634880 bytes downloaded
[15:53:35] + 645120 bytes downloaded
[15:53:35] + 655360 bytes downloaded
[15:53:35] + 665600 bytes downloaded
[15:53:35] + 675840 bytes downloaded
[15:53:35] + 686080 bytes downloaded
[15:53:35] + 696320 bytes downloaded
[15:53:35] + 706560 bytes downloaded
[15:53:35] + 716800 bytes downloaded
[15:53:35] + 727040 bytes downloaded
[15:53:35] + 737280 bytes downloaded
[15:53:35] + 747520 bytes downloaded
[15:53:35] + 757760 bytes downloaded
[15:53:35] + 768000 bytes downloaded
[15:53:36] + 778240 bytes downloaded
[15:53:36] + 788480 bytes downloaded
[15:53:36] + 798720 bytes downloaded
[15:53:36] + 808960 bytes downloaded
[15:53:36] + 819200 bytes downloaded
[15:53:36] + 829440 bytes downloaded
[15:53:36] + 839680 bytes downloaded
[15:53:36] + 849920 bytes downloaded
[15:53:36] + 860160 bytes downloaded
[15:53:36] + 870400 bytes downloaded
[15:53:36] + 880640 bytes downloaded
[15:53:36] + 890880 bytes downloaded
[15:53:36] + 901120 bytes downloaded
[15:53:36] + 911360 bytes downloaded
[15:53:36] + 921600 bytes downloaded
[15:53:36] + 931840 bytes downloaded
[15:53:36] + 942080 bytes downloaded
[15:53:36] + 952320 bytes downloaded
[15:53:36] + 962560 bytes downloaded
[15:53:36] + 972800 bytes downloaded
[15:53:36] + 983040 bytes downloaded
[15:53:36] + 993280 bytes downloaded
[15:53:36] + 1003520 bytes downloaded
[15:53:36] + 1013760 bytes downloaded
[15:53:36] + 1024000 bytes downloaded
[15:53:36] + 1034240 bytes downloaded
[15:53:36] + 1044480 bytes downloaded
[15:53:37] + 1054720 bytes downloaded
[15:53:37] + 1064960 bytes downloaded
[15:53:37] + 1075200 bytes downloaded
[15:53:37] + 1085440 bytes downloaded
[15:53:37] + 1095680 bytes downloaded
[15:53:37] + 1105920 bytes downloaded
[15:53:37] + 1116160 bytes downloaded
[15:53:37] + 1126400 bytes downloaded
[15:53:37] + 1136640 bytes downloaded
[15:53:37] + 1146880 bytes downloaded
[15:53:37] + 1157120 bytes downloaded
[15:53:37] + 1167360 bytes downloaded
[15:53:37] + 1177600 bytes downloaded
[15:53:37] + 1187840 bytes downloaded
[15:53:37] + 1198080 bytes downloaded
[15:53:37] + 1208320 bytes downloaded
[15:53:37] + 1218560 bytes downloaded
[15:53:37] + 1228800 bytes downloaded
[15:53:37] + 1239040 bytes downloaded
[15:53:37] + 1249280 bytes downloaded
[15:53:37] + 1259520 bytes downloaded
[15:53:37] + 1269760 bytes downloaded
[15:53:37] + 1280000 bytes downloaded
[15:53:37] + 1290240 bytes downloaded
[15:53:37] + 1300480 bytes downloaded
[15:53:37] + 1310720 bytes downloaded
[15:53:37] + 1320960 bytes downloaded
[15:53:37] + 1331200 bytes downloaded
[15:53:37] + 1341440 bytes downloaded
[15:53:38] + 1351680 bytes downloaded
[15:53:38] + 1361920 bytes downloaded
[15:53:38] + 1372160 bytes downloaded
[15:53:38] + 1382400 bytes downloaded
[15:53:38] + 1392640 bytes downloaded
[15:53:38] + 1402880 bytes downloaded
[15:53:38] + 1413120 bytes downloaded
[15:53:38] + 1422551 bytes downloaded
[15:53:38] Verifying core Core_15.fah...
[15:53:38] Signature is VALID
[15:53:38]
[15:53:38] Trying to unzip core FahCore_15.exe
[15:53:38] Decompressed FahCore_15.exe (3903488 bytes) successfully
[15:53:43] + Core successfully engaged
[15:53:48]
[15:53:48] + Processing work unit
[15:53:48] Core required: FahCore_15.exe
[15:53:48] Core found.
[15:53:48] Working on queue slot 01 [March 26 15:53:48 UTC]
[15:53:48] + Working ...
[15:53:49]
[15:53:49] *------------------------------*
[15:53:49] Folding@Home GPU Core
[15:53:49] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:53:49]
[15:53:49] Build host: SimbiosNvdWin7
[15:53:49] Board Type: NVIDIA/CUDA
[15:53:49] Core      : x=15
[15:53:49]  Window's signal control handler registered.
[15:53:49] Preparing to commence simulation
[15:53:49] - Looking at optimizations...
[15:53:49] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[15:53:49] - Created dyn
[15:53:49] - Files status OK
[15:53:49] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:53:49] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[15:53:49] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[15:53:49] - Digital signature verified
[15:53:49]
[15:53:49] Project: 6801 (Run 4184, Clone 3, Gen 31)
[15:53:49]
[15:53:49] Assembly optimizations on if available.
[15:53:49] Entering M.D.
[15:53:51] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[15:53:51] Working on ALZHEIMER'S DISEASE AMYLOID
[15:53:51] Client config found, loading data.
[15:53:55] CoreStatus = 63 (99)
[15:53:55] + Error starting Folding@home core.
[15:54:00]
[15:54:00] + Processing work unit
[15:54:00] Core required: FahCore_15.exe
[15:54:00] Core found.
[15:54:00] Working on queue slot 01 [March 26 15:54:00 UTC]
[15:54:00] + Working ...
[15:54:00]
[15:54:00] *------------------------------*
[15:54:00] Folding@Home GPU Core
[15:54:00] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:54:00]
[15:54:00] Build host: SimbiosNvdWin7
[15:54:00] Board Type: NVIDIA/CUDA
[15:54:00] Core      : x=15
[15:54:00]  Window's signal control handler registered.
[15:54:00] Preparing to commence simulation
[15:54:00] - Ensuring status. Please wait.
[15:54:09] - Looking at optimizations...
[15:54:09] - Working with standard loops on this execution.
[15:54:09] - Previous termination of core was improper.
[15:54:09] - Files status OK
[15:54:09] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:54:09] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[15:54:09] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[15:54:09] - Digital signature verified
[15:54:09]
[15:54:09] Project: 6801 (Run 4184, Clone 3, Gen 31)
[15:54:09]
[15:54:09] Entering M.D.
[15:54:11] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[15:54:11] Working on ALZHEIMER'S DISEASE AMYLOID
[15:54:11] Client config found, loading data.
[15:54:14] CoreStatus = 63 (99)
[15:54:14] + Error starting Folding@home core.
[15:54:19]
[15:54:19] + Processing work unit
[15:54:19] Core required: FahCore_15.exe
[15:54:19] Core found.
[15:54:19] Working on queue slot 01 [March 26 15:54:19 UTC]
[15:54:19] + Working ...
[15:54:19]
[15:54:19] *------------------------------*
[15:54:19] Folding@Home GPU Core
[15:54:19] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:54:19]
[15:54:19] Build host: SimbiosNvdWin7
[15:54:19] Board Type: NVIDIA/CUDA
[15:54:19] Core      : x=15
[15:54:19]  Window's signal control handler registered.
[15:54:19] Preparing to commence simulation
[15:54:19] - Ensuring status. Please wait.
[15:54:29] - Looking at optimizations...
[15:54:29] - Working with standard loops on this execution.
[15:54:29] - Previous termination of core was improper.
[15:54:29] - Going to use standard loops.
[15:54:29] - Files status OK
[15:54:29] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:54:29] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[15:54:29] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[15:54:29] - Digital signature verified
[15:54:29]
[15:54:29] Project: 6801 (Run 4184, Clone 3, Gen 31)
[15:54:29]
[15:54:29] Entering M.D.
[15:54:31] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[15:54:31] Working on ALZHEIMER'S DISEASE AMYLOID
[15:54:31] Client config found, loading data.
[15:54:33] CoreStatus = 63 (99)
[15:54:33] + Error starting Folding@home core.
[15:54:33] - Attempting to download new core...
[15:54:33] + Downloading new core: FahCore_15.exe
[15:54:33] + 10240 bytes downloaded
[15:54:34] + 20480 bytes downloaded
[15:54:34] + 30720 bytes downloaded
[15:54:34] + 40960 bytes downloaded
[15:54:34] + 51200 bytes downloaded
[15:54:34] + 61440 bytes downloaded
[15:54:34] + 71680 bytes downloaded
[15:54:34] + 81920 bytes downloaded
[15:54:34] + 92160 bytes downloaded
[15:54:34] + 102400 bytes downloaded
[15:54:34] + 112640 bytes downloaded
[15:54:34] + 122880 bytes downloaded
[15:54:34] + 133120 bytes downloaded
[15:54:34] + 143360 bytes downloaded
[15:54:34] + 153600 bytes downloaded
[15:54:35] + 163840 bytes downloaded
[15:54:35] + 174080 bytes downloaded
[15:54:35] + 184320 bytes downloaded
[15:54:35] + 194560 bytes downloaded
[15:54:35] + 204800 bytes downloaded
[15:54:35] + 215040 bytes downloaded
[15:54:35] + 225280 bytes downloaded
[15:54:35] + 235520 bytes downloaded
[15:54:35] + 245760 bytes downloaded
[15:54:35] + 256000 bytes downloaded
[15:54:35] + 266240 bytes downloaded
[15:54:35] + 276480 bytes downloaded
[15:54:35] + 286720 bytes downloaded
[15:54:35] + 296960 bytes downloaded
[15:54:36] + 307200 bytes downloaded
[15:54:36] + 317440 bytes downloaded
[15:54:36] + 327680 bytes downloaded
[15:54:36] + 337920 bytes downloaded
[15:54:36] + 348160 bytes downloaded
[15:54:36] + 358400 bytes downloaded
[15:54:36] + 368640 bytes downloaded
[15:54:36] + 378880 bytes downloaded
[15:54:36] + 389120 bytes downloaded
[15:54:36] + 399360 bytes downloaded
[15:54:36] + 409600 bytes downloaded
[15:54:36] + 419840 bytes downloaded
[15:54:36] + 430080 bytes downloaded
[15:54:36] + 440320 bytes downloaded
[15:54:37] + 450560 bytes downloaded
[15:54:37] + 460800 bytes downloaded
[15:54:37] + 471040 bytes downloaded
[15:54:37] + 481280 bytes downloaded
[15:54:37] + 491520 bytes downloaded
[15:54:37] + 501760 bytes downloaded
[15:54:37] + 512000 bytes downloaded
[15:54:37] + 522240 bytes downloaded
[15:54:37] + 532480 bytes downloaded
[15:54:37] + 542720 bytes downloaded
[15:54:37] + 552960 bytes downloaded
[15:54:37] + 563200 bytes downloaded
[15:54:37] + 573440 bytes downloaded
[15:54:37] + 583680 bytes downloaded
[15:54:38] + 593920 bytes downloaded
[15:54:38] + 604160 bytes downloaded
[15:54:38] + 614400 bytes downloaded
[15:54:38] + 624640 bytes downloaded
[15:54:38] + 634880 bytes downloaded
[15:54:38] + 645120 bytes downloaded
[15:54:38] + 655360 bytes downloaded
[15:54:38] + 665600 bytes downloaded
[15:54:38] + 675840 bytes downloaded
[15:54:38] + 686080 bytes downloaded
[15:54:38] + 696320 bytes downloaded
[15:54:38] + 706560 bytes downloaded
[15:54:38] + 716800 bytes downloaded
[15:54:38] + 727040 bytes downloaded
[15:54:39] + 737280 bytes downloaded
[15:54:39] + 747520 bytes downloaded
[15:54:39] + 757760 bytes downloaded
[15:54:39] + 768000 bytes downloaded
[15:54:39] + 778240 bytes downloaded
[15:54:39] + 788480 bytes downloaded
[15:54:39] + 798720 bytes downloaded
[15:54:39] + 808960 bytes downloaded
[15:54:39] + 819200 bytes downloaded
[15:54:39] + 829440 bytes downloaded
[15:54:39] + 839680 bytes downloaded
[15:54:39] + 849920 bytes downloaded
[15:54:39] + 860160 bytes downloaded
[15:54:39] + 870400 bytes downloaded
[15:54:39] + 880640 bytes downloaded
[15:54:40] + 890880 bytes downloaded
[15:54:40] + 901120 bytes downloaded
[15:54:40] + 911360 bytes downloaded
[15:54:40] + 921600 bytes downloaded
[15:54:40] + 931840 bytes downloaded
[15:54:40] + 942080 bytes downloaded
[15:54:40] + 952320 bytes downloaded
[15:54:40] + 962560 bytes downloaded
[15:54:40] + 972800 bytes downloaded
[15:54:40] + 983040 bytes downloaded
[15:54:40] + 993280 bytes downloaded
[15:54:40] + 1003520 bytes downloaded
[15:54:40] + 1013760 bytes downloaded
[15:54:41] + 1024000 bytes downloaded
[15:54:41] + 1034240 bytes downloaded
[15:54:41] + 1044480 bytes downloaded
[15:54:41] + 1054720 bytes downloaded
[15:54:41] + 1064960 bytes downloaded
[15:54:41] + 1075200 bytes downloaded
[15:54:41] + 1085440 bytes downloaded
[15:54:41] + 1095680 bytes downloaded
[15:54:41] + 1105920 bytes downloaded
[15:54:41] + 1116160 bytes downloaded
[15:54:41] + 1126400 bytes downloaded
[15:54:41] + 1136640 bytes downloaded
[15:54:41] + 1146880 bytes downloaded
[15:54:41] + 1157120 bytes downloaded
[15:54:42] + 1167360 bytes downloaded
[15:54:42] + 1177600 bytes downloaded
[15:54:42] + 1187840 bytes downloaded
[15:54:42] + 1198080 bytes downloaded
[15:54:42] + 1208320 bytes downloaded
[15:54:42] + 1218560 bytes downloaded
[15:54:42] + 1228800 bytes downloaded
[15:54:42] + 1239040 bytes downloaded
[15:54:42] + 1249280 bytes downloaded
[15:54:42] + 1259520 bytes downloaded
[15:54:42] + 1269760 bytes downloaded
[15:54:42] + 1280000 bytes downloaded
[15:54:42] + 1290240 bytes downloaded
[15:54:42] + 1300480 bytes downloaded
[15:54:42] + 1310720 bytes downloaded
[15:54:43] + 1320960 bytes downloaded
[15:54:43] + 1331200 bytes downloaded
[15:54:43] + 1341440 bytes downloaded
[15:54:43] + 1351680 bytes downloaded
[15:54:43] + 1361920 bytes downloaded
[15:54:43] + 1372160 bytes downloaded
[15:54:43] + 1382400 bytes downloaded
[15:54:43] + 1392640 bytes downloaded
[15:54:43] + 1402880 bytes downloaded
[15:54:43] + 1413120 bytes downloaded
[15:54:44] + 1422551 bytes downloaded
[15:54:44] Verifying core Core_15.fah...
[15:54:44] Signature is VALID
[15:54:44]
[15:54:44] Trying to unzip core FahCore_15.exe
[15:54:44] Decompressed FahCore_15.exe (3903488 bytes) successfully
[15:54:49] + Core successfully engaged
[15:54:54]
[15:54:54] + Processing work unit
[15:54:54] Core required: FahCore_15.exe
[15:54:54] Core found.
[15:54:54] Working on queue slot 01 [March 26 15:54:54 UTC]
[15:54:54] + Working ...
[15:54:54]
[15:54:54] *------------------------------*
[15:54:54] Folding@Home GPU Core
[15:54:54] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:54:54]
[15:54:54] Build host: SimbiosNvdWin7
[15:54:54] Board Type: NVIDIA/CUDA
[15:54:54] Core      : x=15
[15:54:54]  Window's signal control handler registered.
[15:54:54] Preparing to commence simulation
[15:54:54] - Ensuring status. Please wait.
[15:55:04] - Looking at optimizations...
[15:55:04] - Working with standard loops on this execution.
[15:55:04] - Previous termination of core was improper.
[15:55:04] - Going to use standard loops.
[15:55:04] - Files status OK
[15:55:04] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:55:04] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[15:55:04] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[15:55:04] - Digital signature verified
[15:55:04]
[15:55:04] Project: 6801 (Run 4184, Clone 3, Gen 31)
[15:55:04]
[15:55:04] Entering M.D.
[15:55:06] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[15:55:06] Working on ALZHEIMER'S DISEASE AMYLOID
[15:55:06] Client config found, loading data.
[15:55:08] CoreStatus = 63 (99)
[15:55:08] + Error starting Folding@home core.
[15:55:13]
[15:55:13] + Processing work unit
[15:55:13] Core required: FahCore_15.exe
[15:55:13] Core found.
[15:55:13] Working on queue slot 01 [March 26 15:55:13 UTC]
[15:55:13] + Working ...
[15:55:13]
[15:55:13] *------------------------------*
[15:55:13] Folding@Home GPU Core
[15:55:13] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:55:13]
[15:55:13] Build host: SimbiosNvdWin7
[15:55:13] Board Type: NVIDIA/CUDA
[15:55:13] Core      : x=15
[15:55:13]  Window's signal control handler registered.
[15:55:13] Preparing to commence simulation
[15:55:13] - Ensuring status. Please wait.
[15:55:23] - Looking at optimizations...
[15:55:23] - Working with standard loops on this execution.
[15:55:23] - Previous termination of core was improper.
[15:55:23] - Going to use standard loops.
[15:55:23] - Files status OK
[15:55:23] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:55:23] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[15:55:23] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[15:55:23] - Digital signature verified
[15:55:23]
[15:55:23] Project: 6801 (Run 4184, Clone 3, Gen 31)
[15:55:23]
[15:55:23] Entering M.D.
[15:55:25] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[15:55:25] Working on ALZHEIMER'S DISEASE AMYLOID
[15:55:25] Client config found, loading data.
[15:55:28] CoreStatus = 63 (99)
[15:55:28] + Error starting Folding@home core.
--- Opening Log file [March 26 16:11:02 UTC]
[16:11:02] - Ask before connecting: No
[16:11:02] - User name: Atom (Team 37726)
[16:11:02] - User ID: 79CAA14838267614
[16:11:02] - Machine ID: 1
[16:11:02]
[16:11:02] Gpu type=3 species=20.
[16:11:02] Loaded queue successfully.
[16:11:02] Initialization complete
[16:11:02]
[16:11:02] + Processing work unit
[16:11:02] Core required: FahCore_15.exe
[16:11:02] Core found.
[16:11:02] Working on queue slot 01 [March 26 16:11:02 UTC]
[16:11:02] + Working ...
[16:11:03]
[16:11:03] *------------------------------*
[16:11:03] Folding@Home GPU Core
[16:11:03] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[16:11:03]
[16:11:03] Build host: SimbiosNvdWin7
[16:11:03] Board Type: NVIDIA/CUDA
[16:11:03] Core      : x=15
[16:11:03]  Window's signal control handler registered.
[16:11:03] Preparing to commence simulation
[16:11:03] - Ensuring status. Please wait.
[16:11:12] - Looking at optimizations...
[16:11:12] - Working with standard loops on this execution.
[16:11:12] - Previous termination of core was improper.
[16:11:12] - Going to use standard loops.
[16:11:12] - Files status OK
[16:11:12] sizeof(CORE_PACKET_HDR) = 512 file=<>
[16:11:13] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[16:11:13] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[16:11:13] - Digital signature verified
[16:11:13]
[16:11:13] Project: 6801 (Run 4184, Clone 3, Gen 31)
[16:11:13]
[16:11:13] Entering M.D.
[16:11:15] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[16:11:15] Working on ALZHEIMER'S DISEASE AMYLOID
[16:11:15] Client config found, loading data.
[16:11:15] Starting GUI Server
[16:11:19] CoreStatus = 63 (99)
[16:11:19] + Error starting Folding@home core.
[16:11:24]
[16:11:24] + Processing work unit
[16:11:24] Core required: FahCore_15.exe
[16:11:24] Core found.
[16:11:24] Working on queue slot 01 [March 26 16:11:24 UTC]
[16:11:24] + Working ...
[16:11:24]
[16:11:24] *------------------------------*
[16:11:24] Folding@Home GPU Core
[16:11:24] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[16:11:24]
[16:11:24] Build host: SimbiosNvdWin7
[16:11:24] Board Type: NVIDIA/CUDA
[16:11:24] Core      : x=15
[16:11:24]  Window's signal control handler registered.
[16:11:24] Preparing to commence simulation
[16:11:24] - Ensuring status. Please wait.
[16:11:33] - Looking at optimizations...
[16:11:33] - Working with standard loops on this execution.
[16:11:33] - Previous termination of core was improper.
[16:11:33] - Going to use standard loops.
[16:11:33] - Files status OK
[16:11:33] sizeof(CORE_PACKET_HDR) = 512 file=<>
[16:11:33] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[16:11:33] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[16:11:33] - Digital signature verified
[16:11:33]
[16:11:33] Project: 6801 (Run 4184, Clone 3, Gen 31)
[16:11:33]
[16:11:33] Entering M.D.
[16:11:35] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[16:11:35] Working on ALZHEIMER'S DISEASE AMYLOID
[16:11:35] Client config found, loading data.
[16:11:38] CoreStatus = 63 (99)
[16:11:38] + Error starting Folding@home core.
[16:11:43]
[16:11:43] + Processing work unit
[16:11:43] Core required: FahCore_15.exe
[16:11:43] Core found.
[16:11:43] Working on queue slot 01 [March 26 16:11:43 UTC]
[16:11:43] + Working ...
[16:11:43]
[16:11:43] *------------------------------*
[16:11:43] Folding@Home GPU Core
[16:11:43] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[16:11:43]
[16:11:43] Build host: SimbiosNvdWin7
[16:11:43] Board Type: NVIDIA/CUDA
[16:11:43] Core      : x=15
[16:11:43]  Window's signal control handler registered.
[16:11:43] Preparing to commence simulation
[16:11:43] - Ensuring status. Please wait.
[16:11:53] - Looking at optimizations...
[16:11:53] - Working with standard loops on this execution.
[16:11:53] - Previous termination of core was improper.
[16:11:53] - Going to use standard loops.
[16:11:53] - Files status OK
[16:11:53] sizeof(CORE_PACKET_HDR) = 512 file=<>
[16:11:53] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[16:11:53] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[16:11:53] - Digital signature verified
[16:11:53]
[16:11:53] Project: 6801 (Run 4184, Clone 3, Gen 31)
[16:11:53]
[16:11:53] Entering M.D.
[16:11:55] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[16:11:55] Working on ALZHEIMER'S DISEASE AMYLOID
[16:11:55] Client config found, loading data.
--- Opening Log file [March 26 19:12:22 UTC]
[19:12:22] - Ask before connecting: No
[19:12:22] - User name: Atom (Team 37726)
[19:12:22] - User ID: 79CAA14838267614
[19:12:22] - Machine ID: 1
[19:12:22]
[19:12:22] Gpu type=3 species=20.
[19:12:22] Work directory not found. Creating...
[19:12:22] Could not open work queue, generating new queue...
[19:12:23] Initialization complete
[19:12:23] - Preparing to get new work unit...
[19:12:23] Cleaning up work directory
[19:12:23] + Attempting to get work packet
[19:12:23] Passkey found
[19:12:23] Gpu type=3 species=20.
[19:12:23] - Connecting to assignment server
[19:12:23] - Successful: assigned to (171.64.65.64).
[19:12:23] + News From Folding@Home: Welcome to Folding@Home
[19:12:23] Loaded queue successfully.
[19:12:25] + Closed connections
[19:12:25]
[19:12:25] + Processing work unit
[19:12:25] Core required: FahCore_15.exe
[19:12:25] Core not found.
[19:12:25] - Core is not present or corrupted.
[19:12:25] - Attempting to download new core...
[19:12:25] + Downloading new core: FahCore_15.exe
[19:12:25] + 10240 bytes downloaded
[19:12:25] + 20480 bytes downloaded
[19:12:25] + 30720 bytes downloaded
[19:12:25] + 40960 bytes downloaded
[19:12:25] + 51200 bytes downloaded
[19:12:25] + 61440 bytes downloaded
[19:12:26] + 71680 bytes downloaded
[19:12:26] + 81920 bytes downloaded
[19:12:26] + 92160 bytes downloaded
[19:12:26] + 102400 bytes downloaded
[19:12:26] + 112640 bytes downloaded
[19:12:26] + 122880 bytes downloaded
[19:12:26] + 133120 bytes downloaded
[19:12:26] + 143360 bytes downloaded
[19:12:26] + 153600 bytes downloaded
[19:12:26] + 163840 bytes downloaded
[19:12:26] + 174080 bytes downloaded
[19:12:26] + 184320 bytes downloaded
[19:12:26] + 194560 bytes downloaded
[19:12:26] + 204800 bytes downloaded
[19:12:26] + 215040 bytes downloaded
[19:12:26] + 225280 bytes downloaded
[19:12:26] + 235520 bytes downloaded
[19:12:26] + 245760 bytes downloaded
[19:12:26] + 256000 bytes downloaded
[19:12:26] + 266240 bytes downloaded
[19:12:26] + 276480 bytes downloaded
[19:12:26] + 286720 bytes downloaded
[19:12:27] + 296960 bytes downloaded
[19:12:27] + 307200 bytes downloaded
[19:12:27] + 317440 bytes downloaded
[19:12:27] + 327680 bytes downloaded
[19:12:27] + 337920 bytes downloaded
[19:12:27] + 348160 bytes downloaded
[19:12:27] + 358400 bytes downloaded
[19:12:27] + 368640 bytes downloaded
[19:12:27] + 378880 bytes downloaded
[19:12:27] + 389120 bytes downloaded
[19:12:27] + 399360 bytes downloaded
[19:12:27] + 409600 bytes downloaded
[19:12:27] + 419840 bytes downloaded
[19:12:27] + 430080 bytes downloaded
[19:12:27] + 440320 bytes downloaded
[19:12:27] + 450560 bytes downloaded
[19:12:27] + 460800 bytes downloaded
[19:12:27] + 471040 bytes downloaded
[19:12:27] + 481280 bytes downloaded
[19:12:27] + 491520 bytes downloaded
[19:12:27] + 501760 bytes downloaded
[19:12:27] + 512000 bytes downloaded
[19:12:27] + 522240 bytes downloaded
[19:12:28] + 532480 bytes downloaded
[19:12:28] + 542720 bytes downloaded
[19:12:28] + 552960 bytes downloaded
[19:12:28] + 563200 bytes downloaded
[19:12:28] + 573440 bytes downloaded
[19:12:28] + 583680 bytes downloaded
[19:12:28] + 593920 bytes downloaded
[19:12:28] + 604160 bytes downloaded
[19:12:28] + 614400 bytes downloaded
[19:12:28] + 624640 bytes downloaded
[19:12:28] + 634880 bytes downloaded
[19:12:28] + 645120 bytes downloaded
[19:12:28] + 655360 bytes downloaded
[19:12:28] + 665600 bytes downloaded
[19:12:28] + 675840 bytes downloaded
[19:12:28] + 686080 bytes downloaded
[19:12:28] + 696320 bytes downloaded
[19:12:28] + 706560 bytes downloaded
[19:12:28] + 716800 bytes downloaded
[19:12:28] + 727040 bytes downloaded
[19:12:28] + 737280 bytes downloaded
[19:12:29] + 747520 bytes downloaded
[19:12:29] + 757760 bytes downloaded
[19:12:29] + 768000 bytes downloaded
[19:12:29] + 778240 bytes downloaded
[19:12:29] + 788480 bytes downloaded
[19:12:29] + 798720 bytes downloaded
[19:12:29] + 808960 bytes downloaded
[19:12:29] + 819200 bytes downloaded
[19:12:29] + 829440 bytes downloaded
[19:12:29] + 839680 bytes downloaded
[19:12:29] + 849920 bytes downloaded
[19:12:29] + 860160 bytes downloaded
[19:12:29] + 870400 bytes downloaded
[19:12:29] + 880640 bytes downloaded
[19:12:29] + 890880 bytes downloaded
[19:12:29] + 901120 bytes downloaded
[19:12:29] + 911360 bytes downloaded
[19:12:29] + 921600 bytes downloaded
[19:12:29] + 931840 bytes downloaded
[19:12:29] + 942080 bytes downloaded
[19:12:29] + 952320 bytes downloaded
[19:12:29] + 962560 bytes downloaded
[19:12:29] + 972800 bytes downloaded
[19:12:30] + 983040 bytes downloaded
[19:12:30] + 993280 bytes downloaded
[19:12:30] + 1003520 bytes downloaded
[19:12:30] + 1013760 bytes downloaded
[19:12:30] + 1024000 bytes downloaded
[19:12:30] + 1034240 bytes downloaded
[19:12:30] + 1044480 bytes downloaded
[19:12:30] + 1054720 bytes downloaded
[19:12:30] + 1064960 bytes downloaded
[19:12:30] + 1075200 bytes downloaded
[19:12:30] + 1085440 bytes downloaded
[19:12:30] + 1095680 bytes downloaded
[19:12:30] + 1105920 bytes downloaded
[19:12:30] + 1116160 bytes downloaded
[19:12:30] + 1126400 bytes downloaded
[19:12:30] + 1136640 bytes downloaded
[19:12:30] + 1146880 bytes downloaded
[19:12:30] + 1157120 bytes downloaded
[19:12:30] + 1167360 bytes downloaded
[19:12:30] + 1177600 bytes downloaded
[19:12:30] + 1187840 bytes downloaded
[19:12:30] + 1198080 bytes downloaded
[19:12:30] + 1208320 bytes downloaded
[19:12:30] + 1218560 bytes downloaded
[19:12:31] + 1228800 bytes downloaded
[19:12:31] + 1239040 bytes downloaded
[19:12:31] + 1249280 bytes downloaded
[19:12:31] + 1259520 bytes downloaded
[19:12:31] + 1269760 bytes downloaded
[19:12:31] + 1280000 bytes downloaded
[19:12:31] + 1290240 bytes downloaded
[19:12:31] + 1300480 bytes downloaded
[19:12:31] + 1310720 bytes downloaded
[19:12:31] + 1320960 bytes downloaded
[19:12:31] + 1331200 bytes downloaded
[19:12:31] + 1341440 bytes downloaded
[19:12:31] + 1351680 bytes downloaded
[19:12:31] + 1361920 bytes downloaded
[19:12:31] + 1372160 bytes downloaded
[19:12:31] + 1382400 bytes downloaded
[19:12:31] + 1392640 bytes downloaded
[19:12:31] + 1402880 bytes downloaded
[19:12:31] + 1413120 bytes downloaded
[19:12:32] + 1422551 bytes downloaded
[19:12:32] Verifying core Core_15.fah...
[19:12:32] Signature is VALID
[19:12:32]
[19:12:32] Trying to unzip core FahCore_15.exe
[19:12:32] Decompressed FahCore_15.exe (3903488 bytes) successfully
[19:12:37] + Core successfully engaged
[19:12:43]
[19:12:43] + Processing work unit
[19:12:43] Core required: FahCore_15.exe
[19:12:43] Core found.
[19:12:43] Working on queue slot 01 [March 26 19:12:43 UTC]
[19:12:43] + Working ...
[19:12:44]
[19:12:44] *------------------------------*
[19:12:44] Folding@Home GPU Core
[19:12:44] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:12:44]
[19:12:44] Build host: SimbiosNvdWin7
[19:12:44] Board Type: NVIDIA/CUDA
[19:12:44] Core      : x=15
[19:12:44]  Window's signal control handler registered.
[19:12:44] Preparing to commence simulation
[19:12:44] - Looking at optimizations...
[19:12:44] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[19:12:44] - Created dyn
[19:12:44] - Files status OK
[19:12:44] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:12:44] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[19:12:44] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[19:12:44] - Digital signature verified
[19:12:44]
[19:12:44] Project: 6801 (Run 4184, Clone 3, Gen 31)
[19:12:44]
[19:12:44] Assembly optimizations on if available.
[19:12:44] Entering M.D.
[19:12:46] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[19:12:46] Working on ALZHEIMER'S DISEASE AMYLOID
[19:12:46] Client config found, loading data.
[19:12:50] CoreStatus = 63 (99)
[19:12:50] + Error starting Folding@home core.
[19:12:55]
[19:12:55] + Processing work unit
[19:12:55] Core required: FahCore_15.exe
[19:12:55] Core found.
[19:12:55] Working on queue slot 01 [March 26 19:12:55 UTC]
[19:12:55] + Working ...
[19:12:55]
[19:12:55] *------------------------------*
[19:12:55] Folding@Home GPU Core
[19:12:55] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:12:55]
[19:12:55] Build host: SimbiosNvdWin7
[19:12:55] Board Type: NVIDIA/CUDA
[19:12:55] Core      : x=15
[19:12:55]  Window's signal control handler registered.
[19:12:55] Preparing to commence simulation
[19:12:55] - Ensuring status. Please wait.
[19:13:04] - Looking at optimizations...
[19:13:04] - Working with standard loops on this execution.
[19:13:04] - Previous termination of core was improper.
[19:13:04] - Files status OK
[19:13:04] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:13:04] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[19:13:04] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[19:13:04] - Digital signature verified
[19:13:04]
[19:13:04] Project: 6801 (Run 4184, Clone 3, Gen 31)
[19:13:04]
[19:13:04] Entering M.D.
[19:13:06] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[19:13:06] Working on ALZHEIMER'S DISEASE AMYLOID
[19:13:06] Client config found, loading data.
[19:13:09] CoreStatus = 63 (99)
[19:13:09] + Error starting Folding@home core.
[19:13:14]
[19:13:14] + Processing work unit
[19:13:14] Core required: FahCore_15.exe
[19:13:14] Core found.
[19:13:14] Working on queue slot 01 [March 26 19:13:14 UTC]
[19:13:14] + Working ...
[19:13:14]
[19:13:14] *------------------------------*
[19:13:14] Folding@Home GPU Core
[19:13:14] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:13:14]
[19:13:14] Build host: SimbiosNvdWin7
[19:13:14] Board Type: NVIDIA/CUDA
[19:13:14] Core      : x=15
[19:13:14]  Window's signal control handler registered.
[19:13:14] Preparing to commence simulation
[19:13:14] - Ensuring status. Please wait.
[19:13:24] - Looking at optimizations...
[19:13:24] - Working with standard loops on this execution.
[19:13:24] - Previous termination of core was improper.
[19:13:24] - Going to use standard loops.
[19:13:24] - Files status OK
[19:13:24] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:13:24] - Expanded 43565 -> 171827 (decompressed 394.4 percent)
[19:13:24] Called DecompressByteArray: compressed_data_size=43565 data_size=171827, decompressed_data_size=171827 diff=0
[19:13:24] - Digital signature verified
[19:13:24]
[19:13:24] Project: 6801 (Run 4184, Clone 3, Gen 31)
[19:13:24]
[19:13:24] Entering M.D.
[19:13:26] Tpr hash work/wudata_01.tpr:  2164606028 1151633620 97983364 724663251 58484500
[19:13:26] Working on ALZHEIMER'S DISEASE AMYLOID
[19:13:26] Client config found, loading data.
[19:13:28] CoreStatus = 63 (99)
[19:13:28] + Error starting Folding@home core.
[19:13:28] - Attempting to download new core...
[19:13:28] + Downloading new core: FahCore_15.exe
HendricksSA
Re: GPU client: "Error starting Folding@Home core" then slee
Post by HendricksSA »
Atom, welcome to the Fold. To get started, how about changing your configuration slightly. I don't know how you convey configuration options to the client (shortcut or the advance parameters tab) but lets change to: -gpu 0 -verbosity 9
The -forcegpu should not be needed with this newer version of the client and I would like to run without -advmethods for now. Then restart your client and let it run for a while. Then post a new complete log (like you did here). I did not see anything about Project: 6801 (Run 4184, Clone 3, Gen 31) in the Issues with a Specific Work Unit thread but perhaps one of the mods can check this for you.
For most GPU3 client problems I recommend the PantherX guide at: viewtopic.php?p=160068#p160068
Looking forward to your next post.
Atom
Post by Atom »
I tried removing all the existing flags and just using "-verbosity 9" but the client wouldn't start. It kept giving the error telling me my card either wasn't supported or that I needed updated drivers. (I'm running driver version 267.59.) So I added back the -forcegpu flag along with the -verbosity 9 flag. Same thing happens. I tried deleting the work folder and the queue file--same thing. Here's the log with verbose mode enabled.
--- Opening Log file [March 28 03:28:09 UTC]
Arguments: -gpu 0 -forcegpu nvidia_fermi -verbosity 9
[03:28:09] - Ask before connecting: No
[03:28:09] - User name: Atom (Team 37726)
[03:28:09] - User ID: 79CAA14838267614
[03:28:09] - Machine ID: 1
[03:28:09]
[03:28:09] Gpu type=3 species=20.
[03:28:09] Work directory not found. Creating...
[03:28:09] Could not open work queue, generating new queue...
[03:28:09] Initialization complete
[03:28:09] - Preparing to get new work unit...
[03:28:09] Cleaning up work directory
[03:28:09] - Autosending finished units... [March 28 03:28:09 UTC]
[03:28:09] Trying to send all finished work units
[03:28:09] + No unsent completed units remaining.
[03:28:09] - Autosend completed
[03:28:09] + Attempting to get work packet
[03:28:09] Passkey found
[03:28:09] - Will indicate memory of 2047 MB
[03:28:09] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 4, Stepping: 2
[03:28:09] - Connecting to assignment server
[03:28:09] Connecting to http://assign-GPU.stanford.edu:8080/
[03:28:10] Posted data.
[03:28:10] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[03:28:10] + News From Folding@Home: Welcome to Folding@Home
[03:28:10] Loaded queue successfully.
[03:28:10] Gpu type=3 species=20.
[03:28:10] Sent data
[03:28:10] Connecting to http://171.64.65.64:8080/
[03:28:11] Initial: 0000; - Receiving payload (expected size: 44070)
[03:28:11] Conversation time very short, giving reduced weight in bandwidth avg
[03:28:11] - Downloaded at ~86 kB/s
[03:28:11] - Averaged speed for that direction ~86 kB/s
[03:28:11] + Received work.
[03:28:11] + Closed connections
[03:28:11]
[03:28:11] + Processing work unit
[03:28:11] Core required: FahCore_15.exe
[03:28:11] Core found.
[03:28:11] Working on queue slot 01 [March 28 03:28:11 UTC]
[03:28:11] + Working ...
[03:28:11] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 856 -version 641'
[03:28:11]
[03:28:11] *------------------------------*
[03:28:11] Folding@Home GPU Core
[03:28:11] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:28:11]
[03:28:11] Build host: SimbiosNvdWin7
[03:28:11] Board Type: NVIDIA/CUDA
[03:28:11] Core      : x=15
[03:28:11]  Window's signal control handler registered.
[03:28:11] Preparing to commence simulation
[03:28:11] - Looking at optimizations...
[03:28:11] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[03:28:11] - Created dyn
[03:28:11] - Files status OK
[03:28:11] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:28:11] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[03:28:11] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[03:28:11] - Digital signature verified
[03:28:11]
[03:28:11] Project: 6801 (Run 1603, Clone 4, Gen 9)
[03:28:11]
[03:28:11] Assembly optimizations on if available.
[03:28:11] Entering M.D.
[03:28:13] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[03:28:13] Working on ALZHEIMER'S DISEASE AMYLOID
[03:28:13] Client config found, loading data.
[03:28:17] CoreStatus = 63 (99)
[03:28:17] + Error starting Folding@home core.
[03:28:22]
[03:28:22] + Processing work unit
[03:28:22] Core required: FahCore_15.exe
[03:28:22] Core found.
[03:28:22] Working on queue slot 01 [March 28 03:28:22 UTC]
[03:28:22] + Working ...
[03:28:22] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 856 -version 641'
[03:28:22]
[03:28:22] *------------------------------*
[03:28:22] Folding@Home GPU Core
[03:28:22] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:28:22]
[03:28:22] Build host: SimbiosNvdWin7
[03:28:22] Board Type: NVIDIA/CUDA
[03:28:22] Core      : x=15
[03:28:22]  Window's signal control handler registered.
[03:28:22] Preparing to commence simulation
[03:28:22] - Ensuring status. Please wait.
[03:28:32] - Looking at optimizations...
[03:28:32] - Working with standard loops on this execution.
[03:28:32] - Previous termination of core was improper.
[03:28:32] - Files status OK
[03:28:32] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:28:32] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[03:28:32] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[03:28:32] - Digital signature verified
[03:28:32]
[03:28:32] Project: 6801 (Run 1603, Clone 4, Gen 9)
[03:28:32]
[03:28:32] Entering M.D.
[03:28:34] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[03:28:34] Working on ALZHEIMER'S DISEASE AMYLOID
[03:28:34] Client config found, loading data.
[03:28:36] CoreStatus = 63 (99)
[03:28:36] + Error starting Folding@home core.
[03:28:41]
[03:28:41] + Processing work unit
[03:28:41] Core required: FahCore_15.exe
[03:28:41] Core found.
[03:28:41] Working on queue slot 01 [March 28 03:28:41 UTC]
[03:28:41] + Working ...
[03:28:41] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 856 -version 641'
[03:28:42]
[03:28:42] *------------------------------*
[03:28:42] Folding@Home GPU Core
[03:28:42] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:28:42]
[03:28:42] Build host: SimbiosNvdWin7
[03:28:42] Board Type: NVIDIA/CUDA
[03:28:42] Core      : x=15
[03:28:42]  Window's signal control handler registered.
[03:28:42] Preparing to commence simulation
[03:28:42] - Ensuring status. Please wait.
[03:28:51] - Looking at optimizations...
[03:28:51] - Working with standard loops on this execution.
[03:28:51] - Previous termination of core was improper.
[03:28:51] - Going to use standard loops.
[03:28:51] - Files status OK
[03:28:51] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:28:51] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[03:28:51] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[03:28:51] - Digital signature verified
[03:28:51]
[03:28:51] Project: 6801 (Run 1603, Clone 4, Gen 9)
[03:28:51]
[03:28:51] Entering M.D.
[03:28:53] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[03:28:53] Working on ALZHEIMER'S DISEASE AMYLOID
[03:28:53] Client config found, loading data.
[03:28:56] CoreStatus = 63 (99)
[03:28:56] + Error starting Folding@home core.
[03:28:56] - Attempting to download new core...
[03:28:56] + Downloading new core: FahCore_15.exe
[03:28:56] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[03:28:56] Initial: AFDE; + 10240 bytes downloaded
[03:28:56] Initial: 4A9F; + 20480 bytes downloaded
[03:28:56] Initial: 02DB; + 30720 bytes downloaded
[03:28:56] Initial: 32D2; + 40960 bytes downloaded
[03:28:56] Initial: 0664; + 51200 bytes downloaded
[03:28:56] Initial: 0400; + 61440 bytes downloaded
[03:28:56] Initial: 3AB8; + 71680 bytes downloaded
[03:28:56] Initial: F8D2; + 81920 bytes downloaded
[03:28:56] Initial: F4EE; + 92160 bytes downloaded
[03:28:57] Initial: ECE1; + 102400 bytes downloaded
[03:28:57] Initial: 9A21; + 112640 bytes downloaded
[03:28:57] Initial: 4572; + 122880 bytes downloaded
[03:28:57] Initial: A5AF; + 133120 bytes downloaded
[03:28:57] Initial: AE73; + 143360 bytes downloaded
[03:28:57] Initial: 324F; + 153600 bytes downloaded
[03:28:57] Initial: 6A97; + 163840 bytes downloaded
[03:28:57] Initial: E123; + 174080 bytes downloaded
[03:28:57] Initial: 5426; + 184320 bytes downloaded
[03:28:57] Initial: 9D76; + 194560 bytes downloaded
[03:28:57] Initial: 2226; + 204800 bytes downloaded
[03:28:57] Initial: FE64; + 215040 bytes downloaded
[03:28:57] Initial: F9F2; + 225280 bytes downloaded
[03:28:57] Initial: 4F35; + 235520 bytes downloaded
[03:28:58] Initial: D07D; + 245760 bytes downloaded
[03:28:58] Initial: 9E40; + 256000 bytes downloaded
[03:28:58] Initial: 38A2; + 266240 bytes downloaded
[03:28:58] Initial: BD94; + 276480 bytes downloaded
[03:28:58] Initial: 4BAC; + 286720 bytes downloaded
[03:28:58] Initial: D740; + 296960 bytes downloaded
[03:28:58] Initial: B43A; + 307200 bytes downloaded
[03:28:58] Initial: 4B3F; + 317440 bytes downloaded
[03:28:58] Initial: BDD0; + 327680 bytes downloaded
[03:28:59] Initial: 18EB; + 337920 bytes downloaded
[03:29:00] Initial: E612; + 348160 bytes downloaded
[03:29:00] Initial: BD4D; + 358400 bytes downloaded
[03:29:00] Initial: D804; + 368640 bytes downloaded
[03:29:00] Initial: B7D0; + 378880 bytes downloaded
[03:29:00] Initial: 6492; + 389120 bytes downloaded
[03:29:00] Initial: B390; + 399360 bytes downloaded
[03:29:00] Initial: 2ADA; + 409600 bytes downloaded
[03:29:00] Initial: BAB5; + 419840 bytes downloaded
[03:29:00] Initial: BC78; + 430080 bytes downloaded
[03:29:01] Initial: 1119; + 440320 bytes downloaded
[03:29:01] Initial: 27B1; + 450560 bytes downloaded
[03:29:01] Initial: 8A2A; + 460800 bytes downloaded
[03:29:01] Initial: 6F27; + 471040 bytes downloaded
[03:29:01] Initial: FFFF; + 481280 bytes downloaded
[03:29:01] Initial: D0B6; + 491520 bytes downloaded
[03:29:01] Initial: 0702; + 501760 bytes downloaded
[03:29:01] Initial: 08C1; + 512000 bytes downloaded
[03:29:01] Initial: E64B; + 522240 bytes downloaded
[03:29:01] Initial: F5F0; + 532480 bytes downloaded
[03:29:01] Initial: 98CB; + 542720 bytes downloaded
[03:29:01] Initial: 2477; + 552960 bytes downloaded
[03:29:01] Initial: 494C; + 563200 bytes downloaded
[03:29:01] Initial: 4D49; + 573440 bytes downloaded
[03:29:01] Initial: C6C8; + 583680 bytes downloaded
[03:29:01] Initial: 2D13; + 593920 bytes downloaded
[03:29:01] Initial: 03F9; + 604160 bytes downloaded
[03:29:01] Initial: 1315; + 614400 bytes downloaded
[03:29:01] Initial: 0887; + 624640 bytes downloaded
[03:29:01] Initial: 5BA1; + 634880 bytes downloaded
[03:29:01] Initial: E140; + 645120 bytes downloaded
[03:29:01] Initial: 1E9D; + 655360 bytes downloaded
[03:29:01] Initial: 6C1A; + 665600 bytes downloaded
[03:29:02] Initial: 8A4A; + 675840 bytes downloaded
[03:29:02] Initial: 57FD; + 686080 bytes downloaded
[03:29:02] Initial: F8E0; + 696320 bytes downloaded
[03:29:02] Initial: 0CD1; + 706560 bytes downloaded
[03:29:02] Initial: D1E2; + 716800 bytes downloaded
[03:29:02] Initial: 9CA8; + 727040 bytes downloaded
[03:29:02] Initial: 7F13; + 737280 bytes downloaded
[03:29:02] Initial: 3231; + 747520 bytes downloaded
[03:29:02] Initial: 5F16; + 757760 bytes downloaded
[03:29:02] Initial: BF95; + 768000 bytes downloaded
[03:29:02] Initial: 70A4; + 778240 bytes downloaded
[03:29:02] Initial: 6D26; + 788480 bytes downloaded
[03:29:02] Initial: 13C7; + 798720 bytes downloaded
[03:29:02] Initial: 9F26; + 808960 bytes downloaded
[03:29:02] Initial: C7B5; + 819200 bytes downloaded
[03:29:02] Initial: D5A9; + 829440 bytes downloaded
[03:29:02] Initial: F796; + 839680 bytes downloaded
[03:29:02] Initial: A004; + 849920 bytes downloaded
[03:29:02] Initial: 1011; + 860160 bytes downloaded
[03:29:02] Initial: 3F6F; + 870400 bytes downloaded
[03:29:02] Initial: B01C; + 880640 bytes downloaded
[03:29:02] Initial: E903; + 890880 bytes downloaded
[03:29:02] Initial: 29D0; + 901120 bytes downloaded
[03:29:02] Initial: 3DD6; + 911360 bytes downloaded
[03:29:02] Initial: D5BF; + 921600 bytes downloaded
[03:29:02] Initial: EC69; + 931840 bytes downloaded
[03:29:02] Initial: 1A1D; + 942080 bytes downloaded
[03:29:03] Initial: 7BC0; + 952320 bytes downloaded
[03:29:03] Initial: 9C4E; + 962560 bytes downloaded
[03:29:03] Initial: 9C59; + 972800 bytes downloaded
[03:29:03] Initial: 7BBD; + 983040 bytes downloaded
[03:29:03] Initial: D395; + 993280 bytes downloaded
[03:29:03] Initial: 5239; + 1003520 bytes downloaded
[03:29:03] Initial: BE83; + 1013760 bytes downloaded
[03:29:03] Initial: 428D; + 1024000 bytes downloaded
[03:29:03] Initial: E2EE; + 1034240 bytes downloaded
[03:29:03] Initial: 64BB; + 1044480 bytes downloaded
[03:29:03] Initial: 7200; + 1054720 bytes downloaded
[03:29:03] Initial: 71BB; + 1064960 bytes downloaded
[03:29:03] Initial: 9A20; + 1075200 bytes downloaded
[03:29:03] Initial: 1D08; + 1085440 bytes downloaded
[03:29:03] Initial: B1BD; + 1095680 bytes downloaded
[03:29:03] Initial: 4946; + 1105920 bytes downloaded
[03:29:03] Initial: 5297; + 1116160 bytes downloaded
[03:29:03] Initial: 201F; + 1126400 bytes downloaded
[03:29:03] Initial: A318; + 1136640 bytes downloaded
[03:29:03] Initial: 3ED5; + 1146880 bytes downloaded
[03:29:03] Initial: 8473; + 1157120 bytes downloaded
[03:29:03] Initial: D9B9; + 1167360 bytes downloaded
[03:29:03] Initial: 2D15; + 1177600 bytes downloaded
[03:29:03] Initial: F6A1; + 1187840 bytes downloaded
[03:29:03] Initial: 1850; + 1198080 bytes downloaded
[03:29:03] Initial: 3D3E; + 1208320 bytes downloaded
[03:29:04] Initial: 2ADB; + 1218560 bytes downloaded
[03:29:04] Initial: FF21; + 1228800 bytes downloaded
[03:29:04] Initial: 1708; + 1239040 bytes downloaded
[03:29:04] Initial: ADA8; + 1249280 bytes downloaded
[03:29:04] Initial: 8E4E; + 1259520 bytes downloaded
[03:29:04] Initial: 63C7; + 1269760 bytes downloaded
[03:29:04] Initial: 7316; + 1280000 bytes downloaded
[03:29:04] Initial: B3D8; + 1290240 bytes downloaded
[03:29:04] Initial: 2693; + 1300480 bytes downloaded
[03:29:04] Initial: 1B77; + 1310720 bytes downloaded
[03:29:04] Initial: F16F; + 1320960 bytes downloaded
[03:29:04] Initial: 45F0; + 1331200 bytes downloaded
[03:29:04] Initial: 289C; + 1341440 bytes downloaded
[03:29:04] Initial: 83F2; + 1351680 bytes downloaded
[03:29:04] Initial: 1459; + 1361920 bytes downloaded
[03:29:04] Initial: 1A62; + 1372160 bytes downloaded
[03:29:04] Initial: C408; + 1382400 bytes downloaded
[03:29:04] Initial: C561; + 1392640 bytes downloaded
[03:29:04] Initial: 8827; + 1402880 bytes downloaded
[03:29:04] Initial: 3F18; + 1413120 bytes downloaded
[03:29:04] Initial: 212C; + 1422551 bytes downloaded
[03:29:04] Verifying core Core_15.fah...
[03:29:04] Signature is VALID
[03:29:04]
[03:29:04] Trying to unzip core FahCore_15.exe
[03:29:05] Decompressed FahCore_15.exe (3903488 bytes) successfully
[03:29:10] + Core successfully engaged
[03:29:15]
[03:29:15] + Processing work unit
[03:29:15] Core required: FahCore_15.exe
[03:29:15] Core found.
[03:29:15] Working on queue slot 01 [March 28 03:29:15 UTC]
[03:29:15] + Working ...
[03:29:15] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 856 -version 641'
[03:29:15]
[03:29:15] *------------------------------*
[03:29:15] Folding@Home GPU Core
[03:29:15] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:29:15]
[03:29:15] Build host: SimbiosNvdWin7
[03:29:15] Board Type: NVIDIA/CUDA
[03:29:15] Core      : x=15
[03:29:15]  Window's signal control handler registered.
[03:29:15] Preparing to commence simulation
[03:29:15] - Ensuring status. Please wait.
[03:29:24] - Looking at optimizations...
[03:29:24] - Working with standard loops on this execution.
[03:29:24] - Previous termination of core was improper.
[03:29:24] - Going to use standard loops.
[03:29:24] - Files status OK
[03:29:24] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:29:24] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[03:29:24] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[03:29:24] - Digital signature verified
[03:29:24]
[03:29:24] Project: 6801 (Run 1603, Clone 4, Gen 9)
[03:29:24]
[03:29:24] Entering M.D.
[03:29:26] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[03:29:26] Working on ALZHEIMER'S DISEASE AMYLOID
[03:29:26] Client config found, loading data.
[03:29:29] CoreStatus = 63 (99)
[03:29:29] + Error starting Folding@home core.
[03:29:34]
[03:29:34] + Processing work unit
[03:29:34] Core required: FahCore_15.exe
[03:29:34] Core found.
[03:29:34] Working on queue slot 01 [March 28 03:29:34 UTC]
[03:29:34] + Working ...
[03:29:34] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 856 -version 641'
[03:29:34]
[03:29:34] *------------------------------*
[03:29:34] Folding@Home GPU Core
[03:29:34] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:29:34]
[03:29:34] Build host: SimbiosNvdWin7
[03:29:34] Board Type: NVIDIA/CUDA
[03:29:34] Core      : x=15
[03:29:34]  Window's signal control handler registered.
[03:29:34] Preparing to commence simulation
[03:29:34] - Ensuring status. Please wait.
[03:29:44] - Looking at optimizations...
[03:29:44] - Working with standard loops on this execution.
[03:29:44] - Previous termination of core was improper.
[03:29:44] - Going to use standard loops.
[03:29:44] - Files status OK
[03:29:44] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:29:44] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[03:29:44] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[03:29:44] - Digital signature verified
[03:29:44]
[03:29:44] Project: 6801 (Run 1603, Clone 4, Gen 9)
[03:29:44]
[03:29:44] Entering M.D.
[03:29:46] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[03:29:46] Working on ALZHEIMER'S DISEASE AMYLOID
[03:29:46] Client config found, loading data.
[03:29:48] CoreStatus = 63 (99)
[03:29:48] + Error starting Folding@home core.
[03:29:53]
[03:29:53] + Processing work unit
[03:29:53] Core required: FahCore_15.exe
[03:29:53] Core found.
[03:29:53] Working on queue slot 01 [March 28 03:29:53 UTC]
[03:29:53] + Working ...
[03:29:53] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 856 -version 641'
[03:29:53]
[03:29:53] *------------------------------*
[03:29:53] Folding@Home GPU Core
[03:29:53] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:29:53]
[03:29:53] Build host: SimbiosNvdWin7
[03:29:53] Board Type: NVIDIA/CUDA
[03:29:53] Core      : x=15
[03:29:53]  Window's signal control handler registered.
[03:29:53] Preparing to commence simulation
[03:29:53] - Ensuring status. Please wait.
[03:29:58] ***** Got a SIGTERM signal (2)
[03:29:58] Killing all core threads
HendricksSA
Ok, lets try to fall back to a previous graphics driver. The PantherX guide I refer to recommends 258.96. I have to admit I'm running a newer version, but this is a case where the latest drivers can cause problems with the scientific results. I know others are running with 266.xx. I would also suggest a clean sweep and reinstall of the drivers. You should not need the -forcegpu flag so please try removing it again. Then delete the work directory, queue.dat file and core 15. On the restart the client will recreate these and download the needed core. Please consult the PantherX guide for install and sweeping help: viewtopic.php?p=158850#p158850
Looking forward to updated and successful log.
Atom
Post by Atom »
Thanks for the help Hendricks, but no joy.
I looked at the 258.96 driver, but it doesn't say that it supports the 450 cards. Instead I did a clean install with the 260.89 driver. I deleted the work folder and the core and queue files, rebooted and still no luck. I have the GPU clients set to load upon Windows startup, and when they first attempt to startup, I get two error messages that I either don't have a supported card, or that I need updated drivers. Once I dismiss those errors, I can manually start both GPU client without error (though I still need the -forcegpu arguments to make them work.
I have two GTS 250 clients running fine, a GTX 260 which runs fine, a three-way 450 that is running fine now (after a bit of flakiness earlier), and a dual GTX 460 machine that has been rock steady for months. It seems (from my personal experience and from reading this and ther forums, that there's something weird that's specific to the 450 cards.)
What, specifically, does a Corestatus = 63 (99) error indicate?
Here's the log:
[15:25:14] - Ask before connecting: No
[15:25:14] - User name: Atom (Team 37726)
[15:25:14] - User ID: 79CAA14838267614
[15:25:14] - Machine ID: 1
[15:25:14]
[15:25:14] Gpu type=3 species=20.
[15:25:14] Work directory not found. Creating...
[15:25:14] Could not open work queue, generating new queue...
[15:25:14] Initialization complete
[15:25:14] - Preparing to get new work unit...
[15:25:14] - Autosending finished units... [March 28 15:25:14 UTC]
[15:25:14] Cleaning up work directory
[15:25:14] Trying to send all finished work units
[15:25:14] + No unsent completed units remaining.
[15:25:14] - Autosend completed
[15:25:14] + Attempting to get work packet
[15:25:14] Passkey found
[15:25:14] - Will indicate memory of 2047 MB
[15:25:14] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 4, Stepping: 2
[15:25:14] - Connecting to assignment server
[15:25:14] Connecting to http://assign-GPU.stanford.edu:8080/
[15:25:15] Posted data.
[15:25:15] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[15:25:15] + News From Folding@Home: Welcome to Folding@Home
[15:25:15] Loaded queue successfully.
[15:25:15] Gpu type=3 species=20.
[15:25:15] Sent data
[15:25:15] Connecting to http://171.64.65.64:8080/
[15:25:15] Initial: 0000; - Receiving payload (expected size: 44070)
[15:25:16] - Downloaded at ~43 kB/s
[15:25:16] - Averaged speed for that direction ~43 kB/s
[15:25:16] + Received work.
[15:25:16] + Closed connections
[15:25:16]
[15:25:16] + Processing work unit
[15:25:16] Core required: FahCore_15.exe
[15:25:16] Core not found.
[15:25:16] - Core is not present or corrupted.
[15:25:16] - Attempting to download new core...
[15:25:16] + Downloading new core: FahCore_15.exe
[15:25:16] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[15:25:16] Initial: AFDE; + 10240 bytes downloaded
[15:25:16] Initial: 4A9F; + 20480 bytes downloaded
[15:25:16] Initial: 02DB; + 30720 bytes downloaded
[15:25:16] Initial: 32D2; + 40960 bytes downloaded
[15:25:16] Initial: 0664; + 51200 bytes downloaded
[15:25:16] Initial: 0400; + 61440 bytes downloaded
[15:25:17] Initial: 3AB8; + 71680 bytes downloaded
[15:25:17] Initial: F8D2; + 81920 bytes downloaded
[15:25:17] Initial: F4EE; + 92160 bytes downloaded
[15:25:17] Initial: ECE1; + 102400 bytes downloaded
[15:25:17] Initial: 9A21; + 112640 bytes downloaded
[15:25:17] Initial: 4572; + 122880 bytes downloaded
[15:25:17] Initial: A5AF; + 133120 bytes downloaded
[15:25:17] Initial: AE73; + 143360 bytes downloaded
[15:25:17] Initial: 324F; + 153600 bytes downloaded
[15:25:17] Initial: 6A97; + 163840 bytes downloaded
[15:25:17] Initial: E123; + 174080 bytes downloaded
[15:25:17] Initial: 5426; + 184320 bytes downloaded
[15:25:17] Initial: 9D76; + 194560 bytes downloaded
[15:25:17] Initial: 2226; + 204800 bytes downloaded
[15:25:17] Initial: FE64; + 215040 bytes downloaded
[15:25:18] Initial: F9F2; + 225280 bytes downloaded
[15:25:18] Initial: 4F35; + 235520 bytes downloaded
[15:25:18] Initial: D07D; + 245760 bytes downloaded
[15:25:18] Initial: 9E40; + 256000 bytes downloaded
[15:25:18] Initial: 38A2; + 266240 bytes downloaded
[15:25:18] Initial: BD94; + 276480 bytes downloaded
[15:25:18] Initial: 4BAC; + 286720 bytes downloaded
[15:25:18] Initial: D740; + 296960 bytes downloaded
[15:25:18] Initial: B43A; + 307200 bytes downloaded
[15:25:18] Initial: 4B3F; + 317440 bytes downloaded
[15:25:18] Initial: BDD0; + 327680 bytes downloaded
[15:25:18] Initial: 18EB; + 337920 bytes downloaded
[15:25:18] Initial: E612; + 348160 bytes downloaded
[15:25:18] Initial: BD4D; + 358400 bytes downloaded
[15:25:18] Initial: D804; + 368640 bytes downloaded
[15:25:18] Initial: B7D0; + 378880 bytes downloaded
[15:25:18] Initial: 6492; + 389120 bytes downloaded
[15:25:19] Initial: B390; + 399360 bytes downloaded
[15:25:19] Initial: 2ADA; + 409600 bytes downloaded
[15:25:19] Initial: BAB5; + 419840 bytes downloaded
[15:25:19] Initial: BC78; + 430080 bytes downloaded
[15:25:19] Initial: 1119; + 440320 bytes downloaded
[15:25:19] Initial: 27B1; + 450560 bytes downloaded
[15:25:19] Initial: 8A2A; + 460800 bytes downloaded
[15:25:19] Initial: 6F27; + 471040 bytes downloaded
[15:25:19] Initial: FFFF; + 481280 bytes downloaded
[15:25:19] Initial: D0B6; + 491520 bytes downloaded
[15:25:19] Initial: 0702; + 501760 bytes downloaded
[15:25:19] Initial: 08C1; + 512000 bytes downloaded
[15:25:19] Initial: E64B; + 522240 bytes downloaded
[15:25:19] Initial: F5F0; + 532480 bytes downloaded
[15:25:19] Initial: 98CB; + 542720 bytes downloaded
[15:25:19] Initial: 2477; + 552960 bytes downloaded
[15:25:19] Initial: 494C; + 563200 bytes downloaded
[15:25:20] Initial: 4D49; + 573440 bytes downloaded
[15:25:20] Initial: C6C8; + 583680 bytes downloaded
[15:25:20] Initial: 2D13; + 593920 bytes downloaded
[15:25:20] Initial: 03F9; + 604160 bytes downloaded
[15:25:20] Initial: 1315; + 614400 bytes downloaded
[15:25:20] Initial: 0887; + 624640 bytes downloaded
[15:25:20] Initial: 5BA1; + 634880 bytes downloaded
[15:25:20] Initial: E140; + 645120 bytes downloaded
[15:25:20] Initial: 1E9D; + 655360 bytes downloaded
[15:25:20] Initial: 6C1A; + 665600 bytes downloaded
[15:25:20] Initial: 8A4A; + 675840 bytes downloaded
[15:25:20] Initial: 57FD; + 686080 bytes downloaded
[15:25:20] Initial: F8E0; + 696320 bytes downloaded
[15:25:20] Initial: 0CD1; + 706560 bytes downloaded
[15:25:20] Initial: D1E2; + 716800 bytes downloaded
[15:25:20] Initial: 9CA8; + 727040 bytes downloaded
[15:25:21] Initial: 7F13; + 737280 bytes downloaded
[15:25:21] Initial: 3231; + 747520 bytes downloaded
[15:25:21] Initial: 5F16; + 757760 bytes downloaded
[15:25:21] Initial: BF95; + 768000 bytes downloaded
[15:25:21] Initial: 70A4; + 778240 bytes downloaded
[15:25:21] Initial: 6D26; + 788480 bytes downloaded
[15:25:21] Initial: 13C7; + 798720 bytes downloaded
[15:25:21] Initial: 9F26; + 808960 bytes downloaded
[15:25:21] Initial: C7B5; + 819200 bytes downloaded
[15:25:21] Initial: D5A9; + 829440 bytes downloaded
[15:25:21] Initial: F796; + 839680 bytes downloaded
[15:25:21] Initial: A004; + 849920 bytes downloaded
[15:25:21] Initial: 1011; + 860160 bytes downloaded
[15:25:21] Initial: 3F6F; + 870400 bytes downloaded
[15:25:21] Initial: B01C; + 880640 bytes downloaded
[15:25:22] Initial: E903; + 890880 bytes downloaded
[15:25:22] Initial: 29D0; + 901120 bytes downloaded
[15:25:22] Initial: 3DD6; + 911360 bytes downloaded
[15:25:22] Initial: D5BF; + 921600 bytes downloaded
[15:25:22] Initial: EC69; + 931840 bytes downloaded
[15:25:22] Initial: 1A1D; + 942080 bytes downloaded
[15:25:22] Initial: 7BC0; + 952320 bytes downloaded
[15:25:22] Initial: 9C4E; + 962560 bytes downloaded
[15:25:22] Initial: 9C59; + 972800 bytes downloaded
[15:25:22] Initial: 7BBD; + 983040 bytes downloaded
[15:25:22] Initial: D395; + 993280 bytes downloaded
[15:25:22] Initial: 5239; + 1003520 bytes downloaded
[15:25:22] Initial: BE83; + 1013760 bytes downloaded
[15:25:22] Initial: 428D; + 1024000 bytes downloaded
[15:25:22] Initial: E2EE; + 1034240 bytes downloaded
[15:25:22] Initial: 64BB; + 1044480 bytes downloaded
[15:25:23] Initial: 7200; + 1054720 bytes downloaded
[15:25:23] Initial: 71BB; + 1064960 bytes downloaded
[15:25:23] Initial: 9A20; + 1075200 bytes downloaded
[15:25:23] Initial: 1D08; + 1085440 bytes downloaded
[15:25:23] Initial: B1BD; + 1095680 bytes downloaded
[15:25:23] Initial: 4946; + 1105920 bytes downloaded
[15:25:23] Initial: 5297; + 1116160 bytes downloaded
[15:25:23] Initial: 201F; + 1126400 bytes downloaded
[15:25:23] Initial: A318; + 1136640 bytes downloaded
[15:25:23] Initial: 3ED5; + 1146880 bytes downloaded
[15:25:23] Initial: 8473; + 1157120 bytes downloaded
[15:25:23] Initial: D9B9; + 1167360 bytes downloaded
[15:25:23] Initial: 2D15; + 1177600 bytes downloaded
[15:25:23] Initial: F6A1; + 1187840 bytes downloaded
[15:25:23] Initial: 1850; + 1198080 bytes downloaded
[15:25:23] Initial: 3D3E; + 1208320 bytes downloaded
[15:25:23] Initial: 2ADB; + 1218560 bytes downloaded
[15:25:23] Initial: FF21; + 1228800 bytes downloaded
[15:25:23] Initial: 1708; + 1239040 bytes downloaded
[15:25:23] Initial: ADA8; + 1249280 bytes downloaded
[15:25:23] Initial: 8E4E; + 1259520 bytes downloaded
[15:25:23] Initial: 63C7; + 1269760 bytes downloaded
[15:25:23] Initial: 7316; + 1280000 bytes downloaded
[15:25:23] Initial: B3D8; + 1290240 bytes downloaded
[15:25:23] Initial: 2693; + 1300480 bytes downloaded
[15:25:23] Initial: 1B77; + 1310720 bytes downloaded
[15:25:23] Initial: F16F; + 1320960 bytes downloaded
[15:25:23] Initial: 45F0; + 1331200 bytes downloaded
[15:25:24] Initial: 289C; + 1341440 bytes downloaded
[15:25:24] Initial: 83F2; + 1351680 bytes downloaded
[15:25:24] Initial: 1459; + 1361920 bytes downloaded
[15:25:24] Initial: 1A62; + 1372160 bytes downloaded
[15:25:24] Initial: C408; + 1382400 bytes downloaded
[15:25:24] Initial: C561; + 1392640 bytes downloaded
[15:25:24] Initial: 8827; + 1402880 bytes downloaded
[15:25:24] Initial: 3F18; + 1413120 bytes downloaded
[15:25:24] Initial: 212C; + 1422551 bytes downloaded
[15:25:24] Verifying core Core_15.fah...
[15:25:24] Signature is VALID
[15:25:24]
[15:25:24] Trying to unzip core FahCore_15.exe
[15:25:25] Decompressed FahCore_15.exe (3903488 bytes) successfully
[15:25:30] + Core successfully engaged
[15:25:35]
[15:25:35] + Processing work unit
[15:25:35] Core required: FahCore_15.exe
[15:25:35] Core found.
[15:25:35] Working on queue slot 01 [March 28 15:25:35 UTC]
[15:25:35] + Working ...
[15:25:35] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 3904 -version 641'
[15:25:35]
[15:25:35] *------------------------------*
[15:25:35] Folding@Home GPU Core
[15:25:35] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:25:35]
[15:25:35] Build host: SimbiosNvdWin7
[15:25:35] Board Type: NVIDIA/CUDA
[15:25:35] Core      : x=15
[15:25:35]  Window's signal control handler registered.
[15:25:35] Preparing to commence simulation
[15:25:35] - Looking at optimizations...
[15:25:35] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[15:25:35] - Created dyn
[15:25:35] - Files status OK
[15:25:35] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:25:35] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[15:25:35] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[15:25:35] - Digital signature verified
[15:25:35]
[15:25:35] Project: 6801 (Run 1603, Clone 4, Gen 9)
[15:25:35]
[15:25:35] Assembly optimizations on if available.
[15:25:35] Entering M.D.
[15:25:37] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[15:25:37] Working on ALZHEIMER'S DISEASE AMYLOID
[15:25:37] Client config found, loading data.
[15:25:41] CoreStatus = 63 (99)
[15:25:41] + Error starting Folding@home core.
[15:25:46]
[15:25:46] + Processing work unit
[15:25:46] Core required: FahCore_15.exe
[15:25:46] Core found.
[15:25:46] Working on queue slot 01 [March 28 15:25:46 UTC]
[15:25:46] + Working ...
[15:25:46] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 3904 -version 641'
[15:25:46]
[15:25:46] *------------------------------*
[15:25:46] Folding@Home GPU Core
[15:25:46] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:25:46]
[15:25:46] Build host: SimbiosNvdWin7
[15:25:46] Board Type: NVIDIA/CUDA
[15:25:46] Core      : x=15
[15:25:46]  Window's signal control handler registered.
[15:25:46] Preparing to commence simulation
[15:25:46] - Ensuring status. Please wait.
[15:25:56] - Looking at optimizations...
[15:25:56] - Working with standard loops on this execution.
[15:25:56] - Previous termination of core was improper.
[15:25:56] - Files status OK
[15:25:56] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:25:56] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[15:25:56] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[15:25:56] - Digital signature verified
[15:25:56]
[15:25:56] Project: 6801 (Run 1603, Clone 4, Gen 9)
[15:25:56]
[15:25:56] Entering M.D.
[15:25:58] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[15:25:58] Working on ALZHEIMER'S DISEASE AMYLOID
[15:25:58] Client config found, loading data.
[15:26:00] CoreStatus = 63 (99)
[15:26:00] + Error starting Folding@home core.
[15:26:05]
[15:26:05] + Processing work unit
[15:26:05] Core required: FahCore_15.exe
[15:26:05] Core found.
[15:26:05] Working on queue slot 01 [March 28 15:26:05 UTC]
[15:26:05] + Working ...
[15:26:05] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 3904 -version 641'
[15:26:05]
[15:26:05] *------------------------------*
[15:26:05] Folding@Home GPU Core
[15:26:05] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:26:05]
[15:26:05] Build host: SimbiosNvdWin7
[15:26:05] Board Type: NVIDIA/CUDA
[15:26:05] Core      : x=15
[15:26:05]  Window's signal control handler registered.
[15:26:05] Preparing to commence simulation
[15:26:05] - Ensuring status. Please wait.
[15:26:15] - Looking at optimizations...
[15:26:15] - Working with standard loops on this execution.
[15:26:15] - Previous termination of core was improper.
[15:26:15] - Going to use standard loops.
[15:26:15] - Files status OK
[15:26:15] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:26:15] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[15:26:15] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[15:26:15] - Digital signature verified
[15:26:15]
[15:26:15] Project: 6801 (Run 1603, Clone 4, Gen 9)
[15:26:15]
[15:26:15] Entering M.D.
[15:26:17] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[15:26:17] Working on ALZHEIMER'S DISEASE AMYLOID
[15:26:17] Client config found, loading data.
[15:26:19] CoreStatus = 63 (99)
[15:26:19] + Error starting Folding@home core.
[15:26:19] - Attempting to download new core...
[15:26:19] + Downloading new core: FahCore_15.exe
[15:26:19] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[15:26:20] Initial: AFDE; + 10240 bytes downloaded
[15:26:20] Initial: 4A9F; + 20480 bytes downloaded
[15:26:20] Initial: 02DB; + 30720 bytes downloaded
[15:26:20] Initial: 32D2; + 40960 bytes downloaded
[15:26:20] Initial: 0664; + 51200 bytes downloaded
[15:26:20] Initial: 0400; + 61440 bytes downloaded
[15:26:20] Initial: 3AB8; + 71680 bytes downloaded
[15:26:20] Initial: F8D2; + 81920 bytes downloaded
[15:26:20] Initial: F4EE; + 92160 bytes downloaded
[15:26:20] Initial: ECE1; + 102400 bytes downloaded
[15:26:20] Initial: 9A21; + 112640 bytes downloaded
[15:26:20] Initial: 4572; + 122880 bytes downloaded
[15:26:20] Initial: A5AF; + 133120 bytes downloaded
[15:26:20] Initial: AE73; + 143360 bytes downloaded
[15:26:20] Initial: 324F; + 153600 bytes downloaded
[15:26:20] Initial: 6A97; + 163840 bytes downloaded
[15:26:21] Initial: E123; + 174080 bytes downloaded
[15:26:21] Initial: 5426; + 184320 bytes downloaded
[15:26:21] Initial: 9D76; + 194560 bytes downloaded
[15:26:21] Initial: 2226; + 204800 bytes downloaded
[15:26:21] Initial: FE64; + 215040 bytes downloaded
[15:26:21] Initial: F9F2; + 225280 bytes downloaded
[15:26:21] Initial: 4F35; + 235520 bytes downloaded
[15:26:21] Initial: D07D; + 245760 bytes downloaded
[15:26:21] Initial: 9E40; + 256000 bytes downloaded
[15:26:21] Initial: 38A2; + 266240 bytes downloaded
[15:26:21] Initial: BD94; + 276480 bytes downloaded
[15:26:21] Initial: 4BAC; + 286720 bytes downloaded
[15:26:21] Initial: D740; + 296960 bytes downloaded
[15:26:21] Initial: B43A; + 307200 bytes downloaded
[15:26:21] Initial: 4B3F; + 317440 bytes downloaded
[15:26:21] Initial: BDD0; + 327680 bytes downloaded
[15:26:22] Initial: 18EB; + 337920 bytes downloaded
[15:26:22] Initial: E612; + 348160 bytes downloaded
[15:26:22] Initial: BD4D; + 358400 bytes downloaded
[15:26:22] Initial: D804; + 368640 bytes downloaded
[15:26:22] Initial: B7D0; + 378880 bytes downloaded
[15:26:22] Initial: 6492; + 389120 bytes downloaded
[15:26:22] Initial: B390; + 399360 bytes downloaded
[15:26:22] Initial: 2ADA; + 409600 bytes downloaded
[15:26:22] Initial: BAB5; + 419840 bytes downloaded
[15:26:22] Initial: BC78; + 430080 bytes downloaded
[15:26:22] Initial: 1119; + 440320 bytes downloaded
[15:26:22] Initial: 27B1; + 450560 bytes downloaded
[15:26:22] Initial: 8A2A; + 460800 bytes downloaded
[15:26:22] Initial: 6F27; + 471040 bytes downloaded
[15:26:22] Initial: FFFF; + 481280 bytes downloaded
[15:26:22] Initial: D0B6; + 491520 bytes downloaded
[15:26:23] Initial: 0702; + 501760 bytes downloaded
[15:26:23] Initial: 08C1; + 512000 bytes downloaded
[15:26:23] Initial: E64B; + 522240 bytes downloaded
[15:26:23] Initial: F5F0; + 532480 bytes downloaded
[15:26:23] Initial: 98CB; + 542720 bytes downloaded
[15:26:23] Initial: 2477; + 552960 bytes downloaded
[15:26:23] Initial: 494C; + 563200 bytes downloaded
[15:26:23] Initial: 4D49; + 573440 bytes downloaded
[15:26:23] Initial: C6C8; + 583680 bytes downloaded
[15:26:23] Initial: 2D13; + 593920 bytes downloaded
[15:26:23] Initial: 03F9; + 604160 bytes downloaded
[15:26:23] Initial: 1315; + 614400 bytes downloaded
[15:26:23] Initial: 0887; + 624640 bytes downloaded
[15:26:23] Initial: 5BA1; + 634880 bytes downloaded
[15:26:23] Initial: E140; + 645120 bytes downloaded
[15:26:23] Initial: 1E9D; + 655360 bytes downloaded
[15:26:24] Initial: 6C1A; + 665600 bytes downloaded
[15:26:24] Initial: 8A4A; + 675840 bytes downloaded
[15:26:24] Initial: 57FD; + 686080 bytes downloaded
[15:26:24] Initial: F8E0; + 696320 bytes downloaded
[15:26:24] Initial: 0CD1; + 706560 bytes downloaded
[15:26:24] Initial: D1E2; + 716800 bytes downloaded
[15:26:24] Initial: 9CA8; + 727040 bytes downloaded
[15:26:24] Initial: 7F13; + 737280 bytes downloaded
[15:26:24] Initial: 3231; + 747520 bytes downloaded
[15:26:24] Initial: 5F16; + 757760 bytes downloaded
[15:26:24] Initial: BF95; + 768000 bytes downloaded
[15:26:24] Initial: 70A4; + 778240 bytes downloaded
[15:26:24] Initial: 6D26; + 788480 bytes downloaded
[15:26:24] Initial: 13C7; + 798720 bytes downloaded
[15:26:24] Initial: 9F26; + 808960 bytes downloaded
[15:26:24] Initial: C7B5; + 819200 bytes downloaded
[15:26:24] Initial: D5A9; + 829440 bytes downloaded
[15:26:25] Initial: F796; + 839680 bytes downloaded
[15:26:25] Initial: A004; + 849920 bytes downloaded
[15:26:25] Initial: 1011; + 860160 bytes downloaded
[15:26:25] Initial: 3F6F; + 870400 bytes downloaded
[15:26:25] Initial: B01C; + 880640 bytes downloaded
[15:26:25] Initial: E903; + 890880 bytes downloaded
[15:26:25] Initial: 29D0; + 901120 bytes downloaded
[15:26:25] Initial: 3DD6; + 911360 bytes downloaded
[15:26:25] Initial: D5BF; + 921600 bytes downloaded
[15:26:25] Initial: EC69; + 931840 bytes downloaded
[15:26:25] Initial: 1A1D; + 942080 bytes downloaded
[15:26:25] Initial: 7BC0; + 952320 bytes downloaded
[15:26:25] Initial: 9C4E; + 962560 bytes downloaded
[15:26:25] Initial: 9C59; + 972800 bytes downloaded
[15:26:25] Initial: 7BBD; + 983040 bytes downloaded
[15:26:25] Initial: D395; + 993280 bytes downloaded
[15:26:25] Initial: 5239; + 1003520 bytes downloaded
[15:26:25] Initial: BE83; + 1013760 bytes downloaded
[15:26:25] Initial: 428D; + 1024000 bytes downloaded
[15:26:25] Initial: E2EE; + 1034240 bytes downloaded
[15:26:26] Initial: 64BB; + 1044480 bytes downloaded
[15:26:26] Initial: 7200; + 1054720 bytes downloaded
[15:26:26] Initial: 71BB; + 1064960 bytes downloaded
[15:26:26] Initial: 9A20; + 1075200 bytes downloaded
[15:26:26] Initial: 1D08; + 1085440 bytes downloaded
[15:26:26] Initial: B1BD; + 1095680 bytes downloaded
[15:26:26] Initial: 4946; + 1105920 bytes downloaded
[15:26:26] Initial: 5297; + 1116160 bytes downloaded
[15:26:26] Initial: 201F; + 1126400 bytes downloaded
[15:26:26] Initial: A318; + 1136640 bytes downloaded
[15:26:26] Initial: 3ED5; + 1146880 bytes downloaded
[15:26:26] Initial: 8473; + 1157120 bytes downloaded
[15:26:26] Initial: D9B9; + 1167360 bytes downloaded
[15:26:26] Initial: 2D15; + 1177600 bytes downloaded
[15:26:26] Initial: F6A1; + 1187840 bytes downloaded
[15:26:26] Initial: 1850; + 1198080 bytes downloaded
[15:26:26] Initial: 3D3E; + 1208320 bytes downloaded
[15:26:26] Initial: 2ADB; + 1218560 bytes downloaded
[15:26:26] Initial: FF21; + 1228800 bytes downloaded
[15:26:26] Initial: 1708; + 1239040 bytes downloaded
[15:26:26] Initial: ADA8; + 1249280 bytes downloaded
[15:26:26] Initial: 8E4E; + 1259520 bytes downloaded
[15:26:26] Initial: 63C7; + 1269760 bytes downloaded
[15:26:26] Initial: 7316; + 1280000 bytes downloaded
[15:26:26] Initial: B3D8; + 1290240 bytes downloaded
[15:26:26] Initial: 2693; + 1300480 bytes downloaded
[15:26:27] Initial: 1B77; + 1310720 bytes downloaded
[15:26:27] Initial: F16F; + 1320960 bytes downloaded
[15:26:27] Initial: 45F0; + 1331200 bytes downloaded
[15:26:27] Initial: 289C; + 1341440 bytes downloaded
[15:26:27] Initial: 83F2; + 1351680 bytes downloaded
[15:26:27] Initial: 1459; + 1361920 bytes downloaded
[15:26:27] Initial: 1A62; + 1372160 bytes downloaded
[15:26:27] Initial: C408; + 1382400 bytes downloaded
[15:26:27] Initial: C561; + 1392640 bytes downloaded
[15:26:27] Initial: 8827; + 1402880 bytes downloaded
[15:26:27] Initial: 3F18; + 1413120 bytes downloaded
[15:26:27] Initial: 212C; + 1422551 bytes downloaded
[15:26:27] Verifying core Core_15.fah...
[15:26:27] Signature is VALID
[15:26:27]
[15:26:27] Trying to unzip core FahCore_15.exe
[15:26:27] Decompressed FahCore_15.exe (3903488 bytes) successfully
[15:26:32] + Core successfully engaged
[15:26:37]
[15:26:37] + Processing work unit
[15:26:37] Core required: FahCore_15.exe
[15:26:37] Core found.
[15:26:37] Working on queue slot 01 [March 28 15:26:37 UTC]
[15:26:37] + Working ...
[15:26:37] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 3904 -version 641'
[15:26:38]
[15:26:38] *------------------------------*
[15:26:38] Folding@Home GPU Core
[15:26:38] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:26:38]
[15:26:38] Build host: SimbiosNvdWin7
[15:26:38] Board Type: NVIDIA/CUDA
[15:26:38] Core      : x=15
[15:26:38]  Window's signal control handler registered.
[15:26:38] Preparing to commence simulation
[15:26:38] - Ensuring status. Please wait.
[15:26:47] - Looking at optimizations...
[15:26:47] - Working with standard loops on this execution.
[15:26:47] - Previous termination of core was improper.
[15:26:47] - Going to use standard loops.
[15:26:47] - Files status OK
[15:26:47] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:26:47] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[15:26:47] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[15:26:47] - Digital signature verified
[15:26:47]
[15:26:47] Project: 6801 (Run 1603, Clone 4, Gen 9)
[15:26:47]
[15:26:47] Entering M.D.
[15:26:49] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[15:26:49] Working on ALZHEIMER'S DISEASE AMYLOID
[15:26:49] Client config found, loading data.
[15:26:52] CoreStatus = 63 (99)
[15:26:52] + Error starting Folding@home core.
[15:26:57]
[15:26:57] + Processing work unit
[15:26:57] Core required: FahCore_15.exe
[15:26:57] Core found.
[15:26:57] Working on queue slot 01 [March 28 15:26:57 UTC]
[15:26:57] + Working ...
[15:26:57] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 3904 -version 641'
[15:26:57]
[15:26:57] *------------------------------*
[15:26:57] Folding@Home GPU Core
[15:26:57] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:26:57]
[15:26:57] Build host: SimbiosNvdWin7
[15:26:57] Board Type: NVIDIA/CUDA
[15:26:57] Core      : x=15
[15:26:57]  Window's signal control handler registered.
[15:26:57] Preparing to commence simulation
[15:26:57] - Ensuring status. Please wait.
[15:27:06] - Looking at optimizations...
[15:27:06] - Working with standard loops on this execution.
[15:27:06] - Previous termination of core was improper.
[15:27:06] - Going to use standard loops.
[15:27:06] - Files status OK
[15:27:06] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:27:06] - Expanded 43558 -> 171827 (decompressed 394.4 percent)
[15:27:06] Called DecompressByteArray: compressed_data_size=43558 data_size=171827, decompressed_data_size=171827 diff=0
[15:27:06] - Digital signature verified
[15:27:06]
[15:27:06] Project: 6801 (Run 1603, Clone 4, Gen 9)
[15:27:06]
[15:27:06] Entering M.D.
[15:27:08] Tpr hash work/wudata_01.tpr:  205250502 945025059 2756098960 180343172 3727591976
[15:27:08] Working on ALZHEIMER'S DISEASE AMYLOID
[15:27:08] Client config found, loading data.
[15:27:11] CoreStatus = 63 (99)
[15:27:11] + Error starting Folding@home core.
[15:27:16]
[15:27:16] + Processing work unit
[15:27:16] Core required: FahCore_15.exe
[15:27:16] Core found.
[15:27:16] Working on queue slot 01 [March 28 15:27:16 UTC]
[15:27:16] + Working ...
[15:27:16] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 3904 -version 641'
[15:27:16]
[15:27:16] *------------------------------*
[15:27:16] Folding@Home GPU Core
[15:27:16] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:27:16]
[15:27:16] Build host: SimbiosNvdWin7
[15:27:16] Board Type: NVIDIA/CUDA
[15:27:16] Core      : x=15
[15:27:16]  Window's signal control handler registered.
[15:27:16] Preparing to commence simulation
[15:27:16] - Ensuring status. Please wait.
[15:27:23] ***** Got a SIGTERM signal (2)
[15:27:23] Killing all core threads
Folding@Home Client Shutdown.
Atom
May have solved it
Post by Atom »
I was thinking about the differences between this machine and the three-way 450 rig that has been working pretty well, and the one big difference I could think of was clock speed. The cards giving me trouble are MSI N450GTS cards that are "factory overclocked" to 850 MHz. I underclocked them to 796 MHz and they stopped throwing errors (at least initially.) I'll see if they remain stable at this speed.
Do you have more than one GPU in that system?
Atom
Underclocking didn't fix it
Post by Atom »
After underclocking the shaders to 796 MHz and memory to 1798 I could get it to run for a while at least. I just saw that it went to sleep again after downloading and failing to get 5 cores to complete a work unit. I've included an excerpt from the log (since all 5 downloads will run over the max # characters for this post.)
So now I have 4 of these 450s that are sitting idle--wasting what could be 32-26K PPD. Can anyone else think of anything to adjust to get these working?
-------log excerpt picks up after the download of yet another core--------
[19:55:03] Trying to unzip core FahCore_15.exe
[19:55:03] Decompressed FahCore_15.exe (3903488 bytes) successfully
[19:55:08] + Core successfully engaged
[19:55:13]
[19:55:13] + Processing work unit
[19:55:13] Core required: FahCore_15.exe
[19:55:13] Core found.
[19:55:13] Working on queue slot 02 [March 28 19:55:13 UTC]
[19:55:13] + Working ...
[19:55:13] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:55:13]
[19:55:13] *------------------------------*
[19:55:13] Folding@Home GPU Core
[19:55:13] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:55:13]
[19:55:13] Build host: SimbiosNvdWin7
[19:55:13] Board Type: NVIDIA/CUDA
[19:55:13] Core      : x=15
[19:55:13]  Window's signal control handler registered.
[19:55:13] Preparing to commence simulation
[19:55:13] - Ensuring status. Please wait.
[19:55:23] - Looking at optimizations...
[19:55:23] - Working with standard loops on this execution.
[19:55:23] - Previous termination of core was improper.
[19:55:23] - Going to use standard loops.
[19:55:23] - Files status OK
[19:55:23] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:55:23] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:55:23] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:55:23] - Digital signature verified
[19:55:23]
[19:55:23] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:55:23]
[19:55:23] Entering M.D.
[19:55:25] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:55:25] Working on ALZHEIMER'S DISEASE AMYLOID
[19:55:25] Client config found, loading data.
[19:55:27] CoreStatus = 63 (99)
[19:55:27] + Error starting Folding@home core.
[19:55:32]
[19:55:32] + Processing work unit
[19:55:32] Core required: FahCore_15.exe
[19:55:32] Core found.
[19:55:32] Working on queue slot 02 [March 28 19:55:32 UTC]
[19:55:32] + Working ...
[19:55:32] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:55:32]
[19:55:32] *------------------------------*
[19:55:32] Folding@Home GPU Core
[19:55:32] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:55:32]
[19:55:32] Build host: SimbiosNvdWin7
[19:55:32] Board Type: NVIDIA/CUDA
[19:55:32] Core      : x=15
[19:55:32]  Window's signal control handler registered.
[19:55:32] Preparing to commence simulation
[19:55:32] - Ensuring status. Please wait.
[19:55:42] - Looking at optimizations...
[19:55:42] - Working with standard loops on this execution.
[19:55:42] - Previous termination of core was improper.
[19:55:42] - Going to use standard loops.
[19:55:42] - Files status OK
[19:55:42] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:55:42] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:55:42] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:55:42] - Digital signature verified
[19:55:42]
[19:55:42] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:55:42]
[19:55:42] Entering M.D.
[19:55:44] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:55:44] Working on ALZHEIMER'S DISEASE AMYLOID
[19:55:44] Client config found, loading data.
[19:55:47] CoreStatus = 63 (99)
[19:55:47] + Error starting Folding@home core.
[19:55:52]
[19:55:52] + Processing work unit
[19:55:52] Core required: FahCore_15.exe
[19:55:52] Core found.
[19:55:52] Working on queue slot 02 [March 28 19:55:52 UTC]
[19:55:52] + Working ...
[19:55:52] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:55:52]
[19:55:52] *------------------------------*
[19:55:52] Folding@Home GPU Core
[19:55:52] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:55:52]
[19:55:52] Build host: SimbiosNvdWin7
[19:55:52] Board Type: NVIDIA/CUDA
[19:55:52] Core      : x=15
[19:55:52]  Window's signal control handler registered.
[19:55:52] Preparing to commence simulation
[19:55:52] - Ensuring status. Please wait.
[19:56:01] - Looking at optimizations...
[19:56:01] - Working with standard loops on this execution.
[19:56:01] - Previous termination of core was improper.
[19:56:01] - Going to use standard loops.
[19:56:01] - Files status OK
[19:56:01] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:56:01] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:56:01] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:56:01] - Digital signature verified
[19:56:01]
[19:56:01] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:56:01]
[19:56:01] Entering M.D.
[19:56:03] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:56:03] Working on ALZHEIMER'S DISEASE AMYLOID
[19:56:03] Client config found, loading data.
[19:56:06] CoreStatus = 63 (99)
[19:56:06] + Error starting Folding@home core.
[19:56:06] - Attempting to download new core...
[19:56:06] + Downloading new core: FahCore_15.exe
[19:56:06] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[19:56:06] Initial: AFDE; + 10240 bytes downloaded
[19:56:06] Initial: 4A9F; + 20480 bytes downloaded
[19:56:06] Initial: 02DB; + 30720 bytes downloaded
[19:56:06] Initial: 32D2; + 40960 bytes downloaded
[19:56:07] Initial: 0664; + 51200 bytes downloaded
[19:56:07] Initial: 0400; + 61440 bytes downloaded
[19:56:07] Initial: 3AB8; + 71680 bytes downloaded
[19:56:07] Initial: F8D2; + 81920 bytes downloaded
[19:56:07] Initial: F4EE; + 92160 bytes downloaded
[19:56:07] Initial: ECE1; + 102400 bytes downloaded
[19:56:07] Initial: 9A21; + 112640 bytes downloaded
[19:56:07] Initial: 4572; + 122880 bytes downloaded
[19:56:07] Initial: A5AF; + 133120 bytes downloaded
[19:56:07] Initial: AE73; + 143360 bytes downloaded
[19:56:07] Initial: 324F; + 153600 bytes downloaded
[19:56:07] Initial: 6A97; + 163840 bytes downloaded
[19:56:07] Initial: E123; + 174080 bytes downloaded
[19:56:07] Initial: 5426; + 184320 bytes downloaded
[19:56:07] Initial: 9D76; + 194560 bytes downloaded
[19:56:07] Initial: 2226; + 204800 bytes downloaded
[19:56:07] Initial: FE64; + 215040 bytes downloaded
[19:56:07] Initial: F9F2; + 225280 bytes downloaded
[19:56:07] Initial: 4F35; + 235520 bytes downloaded
[19:56:07] Initial: D07D; + 245760 bytes downloaded
[19:56:07] Initial: 9E40; + 256000 bytes downloaded
[19:56:07] Initial: 38A2; + 266240 bytes downloaded
[19:56:07] Initial: BD94; + 276480 bytes downloaded
[19:56:07] Initial: 4BAC; + 286720 bytes downloaded
[19:56:07] Initial: D740; + 296960 bytes downloaded
[19:56:07] Initial: B43A; + 307200 bytes downloaded
[19:56:08] Initial: 4B3F; + 317440 bytes downloaded
[19:56:08] Initial: BDD0; + 327680 bytes downloaded
[19:56:08] Initial: 18EB; + 337920 bytes downloaded
[19:56:08] Initial: E612; + 348160 bytes downloaded
[19:56:08] Initial: BD4D; + 358400 bytes downloaded
[19:56:08] Initial: D804; + 368640 bytes downloaded
[19:56:08] Initial: B7D0; + 378880 bytes downloaded
[19:56:08] Initial: 6492; + 389120 bytes downloaded
[19:56:08] Initial: B390; + 399360 bytes downloaded
[19:56:08] Initial: 2ADA; + 409600 bytes downloaded
[19:56:08] Initial: BAB5; + 419840 bytes downloaded
[19:56:08] Initial: BC78; + 430080 bytes downloaded
[19:56:08] Initial: 1119; + 440320 bytes downloaded
[19:56:08] Initial: 27B1; + 450560 bytes downloaded
[19:56:08] Initial: 8A2A; + 460800 bytes downloaded
[19:56:08] Initial: 6F27; + 471040 bytes downloaded
[19:56:08] Initial: FFFF; + 481280 bytes downloaded
[19:56:08] Initial: D0B6; + 491520 bytes downloaded
[19:56:08] Initial: 0702; + 501760 bytes downloaded
[19:56:08] Initial: 08C1; + 512000 bytes downloaded
[19:56:08] Initial: E64B; + 522240 bytes downloaded
[19:56:08] Initial: F5F0; + 532480 bytes downloaded
[19:56:08] Initial: 98CB; + 542720 bytes downloaded
[19:56:08] Initial: 2477; + 552960 bytes downloaded
[19:56:08] Initial: 494C; + 563200 bytes downloaded
[19:56:08] Initial: 4D49; + 573440 bytes downloaded
[19:56:08] Initial: C6C8; + 583680 bytes downloaded
[19:56:09] Initial: 2D13; + 593920 bytes downloaded
[19:56:09] Initial: 03F9; + 604160 bytes downloaded
[19:56:09] Initial: 1315; + 614400 bytes downloaded
[19:56:09] Initial: 0887; + 624640 bytes downloaded
[19:56:09] Initial: 5BA1; + 634880 bytes downloaded
[19:56:09] Initial: E140; + 645120 bytes downloaded
[19:56:09] Initial: 1E9D; + 655360 bytes downloaded
[19:56:09] Initial: 6C1A; + 665600 bytes downloaded
[19:56:09] Initial: 8A4A; + 675840 bytes downloaded
[19:56:09] Initial: 57FD; + 686080 bytes downloaded
[19:56:09] Initial: F8E0; + 696320 bytes downloaded
[19:56:09] Initial: 0CD1; + 706560 bytes downloaded
[19:56:09] Initial: D1E2; + 716800 bytes downloaded
[19:56:09] Initial: 9CA8; + 727040 bytes downloaded
[19:56:09] Initial: 7F13; + 737280 bytes downloaded
[19:56:09] Initial: 3231; + 747520 bytes downloaded
[19:56:09] Initial: 5F16; + 757760 bytes downloaded
[19:56:09] Initial: BF95; + 768000 bytes downloaded
[19:56:09] Initial: 70A4; + 778240 bytes downloaded
[19:56:09] Initial: 6D26; + 788480 bytes downloaded
[19:56:09] Initial: 13C7; + 798720 bytes downloaded
[19:56:09] Initial: 9F26; + 808960 bytes downloaded
[19:56:09] Initial: C7B5; + 819200 bytes downloaded
[19:56:09] Initial: D5A9; + 829440 bytes downloaded
[19:56:09] Initial: F796; + 839680 bytes downloaded
[19:56:09] Initial: A004; + 849920 bytes downloaded
[19:56:09] Initial: 1011; + 860160 bytes downloaded
[19:56:09] Initial: 3F6F; + 870400 bytes downloaded
[19:56:09] Initial: B01C; + 880640 bytes downloaded
[19:56:10] Initial: E903; + 890880 bytes downloaded
[19:56:10] Initial: 29D0; + 901120 bytes downloaded
[19:56:10] Initial: 3DD6; + 911360 bytes downloaded
[19:56:10] Initial: D5BF; + 921600 bytes downloaded
[19:56:10] Initial: EC69; + 931840 bytes downloaded
[19:56:10] Initial: 1A1D; + 942080 bytes downloaded
[19:56:10] Initial: 7BC0; + 952320 bytes downloaded
[19:56:10] Initial: 9C4E; + 962560 bytes downloaded
[19:56:10] Initial: 9C59; + 972800 bytes downloaded
[19:56:10] Initial: 7BBD; + 983040 bytes downloaded
[19:56:10] Initial: D395; + 993280 bytes downloaded
[19:56:10] Initial: 5239; + 1003520 bytes downloaded
[19:56:10] Initial: BE83; + 1013760 bytes downloaded
[19:56:10] Initial: 428D; + 1024000 bytes downloaded
[19:56:10] Initial: E2EE; + 1034240 bytes downloaded
[19:56:10] Initial: 64BB; + 1044480 bytes downloaded
[19:56:10] Initial: 7200; + 1054720 bytes downloaded
[19:56:10] Initial: 71BB; + 1064960 bytes downloaded
[19:56:10] Initial: 9A20; + 1075200 bytes downloaded
[19:56:10] Initial: 1D08; + 1085440 bytes downloaded
[19:56:10] Initial: B1BD; + 1095680 bytes downloaded
[19:56:10] Initial: 4946; + 1105920 bytes downloaded
[19:56:10] Initial: 5297; + 1116160 bytes downloaded
[19:56:10] Initial: 201F; + 1126400 bytes downloaded
[19:56:10] Initial: A318; + 1136640 bytes downloaded
[19:56:10] Initial: 3ED5; + 1146880 bytes downloaded
[19:56:10] Initial: 8473; + 1157120 bytes downloaded
[19:56:10] Initial: D9B9; + 1167360 bytes downloaded
[19:56:11] Initial: 2D15; + 1177600 bytes downloaded
[19:56:11] Initial: F6A1; + 1187840 bytes downloaded
[19:56:11] Initial: 1850; + 1198080 bytes downloaded
[19:56:11] Initial: 3D3E; + 1208320 bytes downloaded
[19:56:11] Initial: 2ADB; + 1218560 bytes downloaded
[19:56:11] Initial: FF21; + 1228800 bytes downloaded
[19:56:11] Initial: 1708; + 1239040 bytes downloaded
[19:56:11] Initial: ADA8; + 1249280 bytes downloaded
[19:56:11] Initial: 8E4E; + 1259520 bytes downloaded
[19:56:11] Initial: 63C7; + 1269760 bytes downloaded
[19:56:11] Initial: 7316; + 1280000 bytes downloaded
[19:56:11] Initial: B3D8; + 1290240 bytes downloaded
[19:56:11] Initial: 2693; + 1300480 bytes downloaded
[19:56:11] Initial: 1B77; + 1310720 bytes downloaded
[19:56:11] Initial: F16F; + 1320960 bytes downloaded
[19:56:11] Initial: 45F0; + 1331200 bytes downloaded
[19:56:11] Initial: 289C; + 1341440 bytes downloaded
[19:56:11] Initial: 83F2; + 1351680 bytes downloaded
[19:56:11] Initial: 1459; + 1361920 bytes downloaded
[19:56:11] Initial: 1A62; + 1372160 bytes downloaded
[19:56:11] Initial: C408; + 1382400 bytes downloaded
[19:56:11] Initial: C561; + 1392640 bytes downloaded
[19:56:11] Initial: 8827; + 1402880 bytes downloaded
[19:56:11] Initial: 3F18; + 1413120 bytes downloaded
[19:56:11] Initial: 212C; + 1422551 bytes downloaded
[19:56:11] Verifying core Core_15.fah...
[19:56:12] Signature is VALID
[19:56:12]
[19:56:12] Trying to unzip core FahCore_15.exe
[19:56:12] Decompressed FahCore_15.exe (3903488 bytes) successfully
[19:56:17] + Core successfully engaged
[19:56:22]
[19:56:22] + Processing work unit
[19:56:22] Core required: FahCore_15.exe
[19:56:22] Core found.
[19:56:22] Working on queue slot 02 [March 28 19:56:22 UTC]
[19:56:22] + Working ...
[19:56:22] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:56:22]
[19:56:22] *------------------------------*
[19:56:22] Folding@Home GPU Core
[19:56:22] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:56:22]
[19:56:22] Build host: SimbiosNvdWin7
[19:56:22] Board Type: NVIDIA/CUDA
[19:56:22] Core      : x=15
[19:56:22]  Window's signal control handler registered.
[19:56:22] Preparing to commence simulation
[19:56:22] - Ensuring status. Please wait.
[19:56:32] - Looking at optimizations...
[19:56:32] - Working with standard loops on this execution.
[19:56:32] - Previous termination of core was improper.
[19:56:32] - Going to use standard loops.
[19:56:32] - Files status OK
[19:56:32] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:56:32] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:56:32] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:56:32] - Digital signature verified
[19:56:32]
[19:56:32] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:56:32]
[19:56:32] Entering M.D.
[19:56:34] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:56:34] Working on ALZHEIMER'S DISEASE AMYLOID
[19:56:34] Client config found, loading data.
[19:56:36] CoreStatus = 63 (99)
[19:56:36] + Error starting Folding@home core.
[19:56:41]
[19:56:41] + Processing work unit
[19:56:41] Core required: FahCore_15.exe
[19:56:41] Core found.
[19:56:41] Working on queue slot 02 [March 28 19:56:41 UTC]
[19:56:41] + Working ...
[19:56:41] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:56:41]
[19:56:41] *------------------------------*
[19:56:41] Folding@Home GPU Core
[19:56:41] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:56:41]
[19:56:41] Build host: SimbiosNvdWin7
[19:56:41] Board Type: NVIDIA/CUDA
[19:56:41] Core      : x=15
[19:56:41]  Window's signal control handler registered.
[19:56:41] Preparing to commence simulation
[19:56:41] - Ensuring status. Please wait.
[19:56:51] - Looking at optimizations...
[19:56:51] - Working with standard loops on this execution.
[19:56:51] - Previous termination of core was improper.
[19:56:51] - Going to use standard loops.
[19:56:51] - Files status OK
[19:56:51] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:56:51] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:56:51] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:56:51] - Digital signature verified
[19:56:51]
[19:56:51] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:56:51]
[19:56:51] Entering M.D.
[19:56:53] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:56:53] Working on ALZHEIMER'S DISEASE AMYLOID
[19:56:53] Client config found, loading data.
[19:56:56] CoreStatus = 63 (99)
[19:56:56] + Error starting Folding@home core.
[19:57:01]
[19:57:01] + Processing work unit
[19:57:01] Core required: FahCore_15.exe
[19:57:01] Core found.
[19:57:01] Working on queue slot 02 [March 28 19:57:01 UTC]
[19:57:01] + Working ...
[19:57:01] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:57:01]
[19:57:01] *------------------------------*
[19:57:01] Folding@Home GPU Core
[19:57:01] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:57:01]
[19:57:01] Build host: SimbiosNvdWin7
[19:57:01] Board Type: NVIDIA/CUDA
[19:57:01] Core      : x=15
[19:57:01]  Window's signal control handler registered.
[19:57:01] Preparing to commence simulation
[19:57:01] - Ensuring status. Please wait.
[19:57:10] - Looking at optimizations...
[19:57:10] - Working with standard loops on this execution.
[19:57:10] Examination of work files indicates 8 consecutive improper terminations of core.
[19:57:10] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:57:10] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:57:10] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:57:10] - Digital signature verified
[19:57:10]
[19:57:10] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:57:10]
[19:57:10] Entering M.D.
[19:57:12] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:57:12] Working on ALZHEIMER'S DISEASE AMYLOID
[19:57:12] Client config found, loading data.
[19:57:15] CoreStatus = 63 (99)
[19:57:15] + Error starting Folding@home core.
[19:57:15] - Attempting to download new core...
[19:57:15] + Downloading new core: FahCore_15.exe
[19:57:15] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[19:57:15] Initial: AFDE; + 10240 bytes downloaded
[19:57:15] Initial: 4A9F; + 20480 bytes downloaded
[19:57:15] Initial: 02DB; + 30720 bytes downloaded
[19:57:15] Initial: 32D2; + 40960 bytes downloaded
[19:57:15] Initial: 0664; + 51200 bytes downloaded
[19:57:15] Initial: 0400; + 61440 bytes downloaded
[19:57:15] Initial: 3AB8; + 71680 bytes downloaded
[19:57:15] Initial: F8D2; + 81920 bytes downloaded
[19:57:15] Initial: F4EE; + 92160 bytes downloaded
[19:57:16] Initial: ECE1; + 102400 bytes downloaded
[19:57:16] Initial: 9A21; + 112640 bytes downloaded
[19:57:16] Initial: 4572; + 122880 bytes downloaded
[19:57:16] Initial: A5AF; + 133120 bytes downloaded
[19:57:16] Initial: AE73; + 143360 bytes downloaded
[19:57:16] Initial: 324F; + 153600 bytes downloaded
[19:57:16] Initial: 6A97; + 163840 bytes downloaded
[19:57:16] Initial: E123; + 174080 bytes downloaded
[19:57:16] Initial: 5426; + 184320 bytes downloaded
[19:57:16] Initial: 9D76; + 194560 bytes downloaded
[19:57:16] Initial: 2226; + 204800 bytes downloaded
[19:57:16] Initial: FE64; + 215040 bytes downloaded
[19:57:16] Initial: F9F2; + 225280 bytes downloaded
[19:57:16] Initial: 4F35; + 235520 bytes downloaded
[19:57:17] Initial: D07D; + 245760 bytes downloaded
[19:57:17] Initial: 9E40; + 256000 bytes downloaded
[19:57:17] Initial: 38A2; + 266240 bytes downloaded
[19:57:17] Initial: BD94; + 276480 bytes downloaded
[19:57:17] Initial: 4BAC; + 286720 bytes downloaded
[19:57:17] Initial: D740; + 296960 bytes downloaded
[19:57:17] Initial: B43A; + 307200 bytes downloaded
[19:57:17] Initial: 4B3F; + 317440 bytes downloaded
[19:57:17] Initial: BDD0; + 327680 bytes downloaded
[19:57:17] Initial: 18EB; + 337920 bytes downloaded
[19:57:17] Initial: E612; + 348160 bytes downloaded
[19:57:17] Initial: BD4D; + 358400 bytes downloaded
[19:57:17] Initial: D804; + 368640 bytes downloaded
[19:57:17] Initial: B7D0; + 378880 bytes downloaded
[19:57:17] Initial: 6492; + 389120 bytes downloaded
[19:57:18] Initial: B390; + 399360 bytes downloaded
[19:57:18] Initial: 2ADA; + 409600 bytes downloaded
[19:57:18] Initial: BAB5; + 419840 bytes downloaded
[19:57:18] Initial: BC78; + 430080 bytes downloaded
[19:57:18] Initial: 1119; + 440320 bytes downloaded
[19:57:18] Initial: 27B1; + 450560 bytes downloaded
[19:57:18] Initial: 8A2A; + 460800 bytes downloaded
[19:57:18] Initial: 6F27; + 471040 bytes downloaded
[19:57:18] Initial: FFFF; + 481280 bytes downloaded
[19:57:18] Initial: D0B6; + 491520 bytes downloaded
[19:57:18] Initial: 0702; + 501760 bytes downloaded
[19:57:18] Initial: 08C1; + 512000 bytes downloaded
[19:57:18] Initial: E64B; + 522240 bytes downloaded
[19:57:18] Initial: F5F0; + 532480 bytes downloaded
[19:57:19] Initial: 98CB; + 542720 bytes downloaded
[19:57:19] Initial: 2477; + 552960 bytes downloaded
[19:57:19] Initial: 494C; + 563200 bytes downloaded
[19:57:19] Initial: 4D49; + 573440 bytes downloaded
[19:57:19] Initial: C6C8; + 583680 bytes downloaded
[19:57:19] Initial: 2D13; + 593920 bytes downloaded
[19:57:19] Initial: 03F9; + 604160 bytes downloaded
[19:57:19] Initial: 1315; + 614400 bytes downloaded
[19:57:19] Initial: 0887; + 624640 bytes downloaded
[19:57:19] Initial: 5BA1; + 634880 bytes downloaded
[19:57:19] Initial: E140; + 645120 bytes downloaded
[19:57:19] Initial: 1E9D; + 655360 bytes downloaded
[19:57:19] Initial: 6C1A; + 665600 bytes downloaded
[19:57:19] Initial: 8A4A; + 675840 bytes downloaded
[19:57:19] Initial: 57FD; + 686080 bytes downloaded
[19:57:20] Initial: F8E0; + 696320 bytes downloaded
[19:57:20] Initial: 0CD1; + 706560 bytes downloaded
[19:57:20] Initial: D1E2; + 716800 bytes downloaded
[19:57:20] Initial: 9CA8; + 727040 bytes downloaded
[19:57:20] Initial: 7F13; + 737280 bytes downloaded
[19:57:20] Initial: 3231; + 747520 bytes downloaded
[19:57:20] Initial: 5F16; + 757760 bytes downloaded
[19:57:20] Initial: BF95; + 768000 bytes downloaded
[19:57:20] Initial: 70A4; + 778240 bytes downloaded
[19:57:20] Initial: 6D26; + 788480 bytes downloaded
[19:57:20] Initial: 13C7; + 798720 bytes downloaded
[19:57:20] Initial: 9F26; + 808960 bytes downloaded
[19:57:20] Initial: C7B5; + 819200 bytes downloaded
[19:57:20] Initial: D5A9; + 829440 bytes downloaded
[19:57:21] Initial: F796; + 839680 bytes downloaded
[19:57:21] Initial: A004; + 849920 bytes downloaded
[19:57:21] Initial: 1011; + 860160 bytes downloaded
[19:57:21] Initial: 3F6F; + 870400 bytes downloaded
[19:57:21] Initial: B01C; + 880640 bytes downloaded
[19:57:21] Initial: E903; + 890880 bytes downloaded
[19:57:21] Initial: 29D0; + 901120 bytes downloaded
[19:57:21] Initial: 3DD6; + 911360 bytes downloaded
[19:57:21] Initial: D5BF; + 921600 bytes downloaded
[19:57:21] Initial: EC69; + 931840 bytes downloaded
[19:57:21] Initial: 1A1D; + 942080 bytes downloaded
[19:57:21] Initial: 7BC0; + 952320 bytes downloaded
[19:57:21] Initial: 9C4E; + 962560 bytes downloaded
[19:57:21] Initial: 9C59; + 972800 bytes downloaded
[19:57:21] Initial: 7BBD; + 983040 bytes downloaded
[19:57:22] Initial: D395; + 993280 bytes downloaded
[19:57:22] Initial: 5239; + 1003520 bytes downloaded
[19:57:22] Initial: BE83; + 1013760 bytes downloaded
[19:57:22] Initial: 428D; + 1024000 bytes downloaded
[19:57:22] Initial: E2EE; + 1034240 bytes downloaded
[19:57:22] Initial: 64BB; + 1044480 bytes downloaded
[19:57:22] Initial: 7200; + 1054720 bytes downloaded
[19:57:22] Initial: 71BB; + 1064960 bytes downloaded
[19:57:22] Initial: 9A20; + 1075200 bytes downloaded
[19:57:22] Initial: 1D08; + 1085440 bytes downloaded
[19:57:22] Initial: B1BD; + 1095680 bytes downloaded
[19:57:22] Initial: 4946; + 1105920 bytes downloaded
[19:57:22] Initial: 5297; + 1116160 bytes downloaded
[19:57:23] Initial: 201F; + 1126400 bytes downloaded
[19:57:23] Initial: A318; + 1136640 bytes downloaded
[19:57:23] Initial: 3ED5; + 1146880 bytes downloaded
[19:57:23] Initial: 8473; + 1157120 bytes downloaded
[19:57:23] Initial: D9B9; + 1167360 bytes downloaded
[19:57:23] Initial: 2D15; + 1177600 bytes downloaded
[19:57:23] Initial: F6A1; + 1187840 bytes downloaded
[19:57:23] Initial: 1850; + 1198080 bytes downloaded
[19:57:23] Initial: 3D3E; + 1208320 bytes downloaded
[19:57:23] Initial: 2ADB; + 1218560 bytes downloaded
[19:57:23] Initial: FF21; + 1228800 bytes downloaded
[19:57:23] Initial: 1708; + 1239040 bytes downloaded
[19:57:23] Initial: ADA8; + 1249280 bytes downloaded
[19:57:23] Initial: 8E4E; + 1259520 bytes downloaded
[19:57:24] Initial: 63C7; + 1269760 bytes downloaded
[19:57:24] Initial: 7316; + 1280000 bytes downloaded
[19:57:24] Initial: B3D8; + 1290240 bytes downloaded
[19:57:24] Initial: 2693; + 1300480 bytes downloaded
[19:57:24] Initial: 1B77; + 1310720 bytes downloaded
[19:57:24] Initial: F16F; + 1320960 bytes downloaded
[19:57:24] Initial: 45F0; + 1331200 bytes downloaded
[19:57:24] Initial: 289C; + 1341440 bytes downloaded
[19:57:24] Initial: 83F2; + 1351680 bytes downloaded
[19:57:24] Initial: 1459; + 1361920 bytes downloaded
[19:57:24] Initial: 1A62; + 1372160 bytes downloaded
[19:57:24] Initial: C408; + 1382400 bytes downloaded
[19:57:24] Initial: C561; + 1392640 bytes downloaded
[19:57:24] Initial: 8827; + 1402880 bytes downloaded
[19:57:24] Initial: 3F18; + 1413120 bytes downloaded
[19:57:25] Initial: 212C; + 1422551 bytes downloaded
[19:57:25] Verifying core Core_15.fah...
[19:57:25] Signature is VALID
[19:57:25]
[19:57:25] Trying to unzip core FahCore_15.exe
[19:57:25] Decompressed FahCore_15.exe (3903488 bytes) successfully
[19:57:30] + Core successfully engaged
[19:57:35]
[19:57:35] + Processing work unit
[19:57:35] Core required: FahCore_15.exe
[19:57:35] Core found.
[19:57:35] Working on queue slot 02 [March 28 19:57:35 UTC]
[19:57:35] + Working ...
[19:57:35] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:57:35]
[19:57:35] *------------------------------*
[19:57:35] Folding@Home GPU Core
[19:57:35] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:57:35]
[19:57:35] Build host: SimbiosNvdWin7
[19:57:35] Board Type: NVIDIA/CUDA
[19:57:35] Core      : x=15
[19:57:35]  Window's signal control handler registered.
[19:57:35] Preparing to commence simulation
[19:57:35] - Ensuring status. Please wait.
[19:57:45] - Looking at optimizations...
[19:57:45] - Working with standard loops on this execution.
[19:57:45] Examination of work files indicates 8 consecutive improper terminations of core.
[19:57:45] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:57:45] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:57:45] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:57:45] - Digital signature verified
[19:57:45]
[19:57:45] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:57:45]
[19:57:45] Entering M.D.
[19:57:47] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:57:47] Working on ALZHEIMER'S DISEASE AMYLOID
[19:57:47] Client config found, loading data.
[19:57:50] CoreStatus = 63 (99)
[19:57:50] + Error starting Folding@home core.
[19:57:55]
[19:57:55] + Processing work unit
[19:57:55] Core required: FahCore_15.exe
[19:57:55] Core found.
[19:57:55] Working on queue slot 02 [March 28 19:57:55 UTC]
[19:57:55] + Working ...
[19:57:55] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:57:55]
[19:57:55] *------------------------------*
[19:57:55] Folding@Home GPU Core
[19:57:55] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:57:55]
[19:57:55] Build host: SimbiosNvdWin7
[19:57:55] Board Type: NVIDIA/CUDA
[19:57:55] Core      : x=15
[19:57:55]  Window's signal control handler registered.
[19:57:55] Preparing to commence simulation
[19:57:55] - Ensuring status. Please wait.
[19:58:04] - Looking at optimizations...
[19:58:04] - Working with standard loops on this execution.
[19:58:04] Examination of work files indicates 8 consecutive improper terminations of core.
[19:58:04] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:58:04] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:58:04] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:58:04] - Digital signature verified
[19:58:04]
[19:58:04] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:58:04]
[19:58:04] Entering M.D.
[19:58:06] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:58:06] Working on ALZHEIMER'S DISEASE AMYLOID
[19:58:06] Client config found, loading data.
[19:58:09] CoreStatus = 63 (99)
[19:58:09] + Error starting Folding@home core.
[19:58:14]
[19:58:14] + Processing work unit
[19:58:14] Core required: FahCore_15.exe
[19:58:14] Core found.
[19:58:14] Working on queue slot 02 [March 28 19:58:14 UTC]
[19:58:14] + Working ...
[19:58:14] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:58:14]
[19:58:14] *------------------------------*
[19:58:14] Folding@Home GPU Core
[19:58:14] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:58:14]
[19:58:14] Build host: SimbiosNvdWin7
[19:58:14] Board Type: NVIDIA/CUDA
[19:58:14] Core      : x=15
[19:58:14]  Window's signal control handler registered.
[19:58:14] Preparing to commence simulation
[19:58:14] - Ensuring status. Please wait.
[19:58:24] - Looking at optimizations...
[19:58:24] - Working with standard loops on this execution.
[19:58:24] Examination of work files indicates 8 consecutive improper terminations of core.
[19:58:24] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:58:24] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:58:24] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:58:24] - Digital signature verified
[19:58:24]
[19:58:24] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:58:24]
[19:58:24] Entering M.D.
[19:58:26] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:58:26] Working on ALZHEIMER'S DISEASE AMYLOID
[19:58:26] Client config found, loading data.
[19:58:28] CoreStatus = 63 (99)
[19:58:28] + Error starting Folding@home core.
[19:58:28] - Attempting to download new core...
[19:58:28] + Downloading new core: FahCore_15.exe
[19:58:28] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[19:58:29] Initial: AFDE; + 10240 bytes downloaded
[19:58:29] Initial: 4A9F; + 20480 bytes downloaded
[19:58:29] Initial: 02DB; + 30720 bytes downloaded
[19:58:29] Initial: 32D2; + 40960 bytes downloaded
[19:58:29] Initial: 0664; + 51200 bytes downloaded
[19:58:29] Initial: 0400; + 61440 bytes downloaded
[19:58:29] Initial: 3AB8; + 71680 bytes downloaded
[19:58:29] Initial: F8D2; + 81920 bytes downloaded
[19:58:29] Initial: F4EE; + 92160 bytes downloaded
[19:58:29] Initial: ECE1; + 102400 bytes downloaded
[19:58:29] Initial: 9A21; + 112640 bytes downloaded
[19:58:29] Initial: 4572; + 122880 bytes downloaded
[19:58:29] Initial: A5AF; + 133120 bytes downloaded
[19:58:29] Initial: AE73; + 143360 bytes downloaded
[19:58:29] Initial: 324F; + 153600 bytes downloaded
[19:58:29] Initial: 6A97; + 163840 bytes downloaded
[19:58:29] Initial: E123; + 174080 bytes downloaded
[19:58:29] Initial: 5426; + 184320 bytes downloaded
[19:58:30] Initial: 9D76; + 194560 bytes downloaded
[19:58:30] Initial: 2226; + 204800 bytes downloaded
[19:58:30] Initial: FE64; + 215040 bytes downloaded
[19:58:30] Initial: F9F2; + 225280 bytes downloaded
[19:58:30] Initial: 4F35; + 235520 bytes downloaded
[19:58:30] Initial: D07D; + 245760 bytes downloaded
[19:58:30] Initial: 9E40; + 256000 bytes downloaded
[19:58:30] Initial: 38A2; + 266240 bytes downloaded
[19:58:30] Initial: BD94; + 276480 bytes downloaded
[19:58:30] Initial: 4BAC; + 286720 bytes downloaded
[19:58:30] Initial: D740; + 296960 bytes downloaded
[19:58:30] Initial: B43A; + 307200 bytes downloaded
[19:58:30] Initial: 4B3F; + 317440 bytes downloaded
[19:58:30] Initial: BDD0; + 327680 bytes downloaded
[19:58:30] Initial: 18EB; + 337920 bytes downloaded
[19:58:30] Initial: E612; + 348160 bytes downloaded
[19:58:30] Initial: BD4D; + 358400 bytes downloaded
[19:58:30] Initial: D804; + 368640 bytes downloaded
[19:58:30] Initial: B7D0; + 378880 bytes downloaded
[19:58:30] Initial: 6492; + 389120 bytes downloaded
[19:58:30] Initial: B390; + 399360 bytes downloaded
[19:58:30] Initial: 2ADA; + 409600 bytes downloaded
[19:58:30] Initial: BAB5; + 419840 bytes downloaded
[19:58:30] Initial: BC78; + 430080 bytes downloaded
[19:58:30] Initial: 1119; + 440320 bytes downloaded
[19:58:30] Initial: 27B1; + 450560 bytes downloaded
[19:58:30] Initial: 8A2A; + 460800 bytes downloaded
[19:58:30] Initial: 6F27; + 471040 bytes downloaded
[19:58:30] Initial: FFFF; + 481280 bytes downloaded
[19:58:30] Initial: D0B6; + 491520 bytes downloaded
[19:58:31] Initial: 0702; + 501760 bytes downloaded
[19:58:31] Initial: 08C1; + 512000 bytes downloaded
[19:58:31] Initial: E64B; + 522240 bytes downloaded
[19:58:31] Initial: F5F0; + 532480 bytes downloaded
[19:58:31] Initial: 98CB; + 542720 bytes downloaded
[19:58:31] Initial: 2477; + 552960 bytes downloaded
[19:58:31] Initial: 494C; + 563200 bytes downloaded
[19:58:31] Initial: 4D49; + 573440 bytes downloaded
[19:58:31] Initial: C6C8; + 583680 bytes downloaded
[19:58:31] Initial: 2D13; + 593920 bytes downloaded
[19:58:31] Initial: 03F9; + 604160 bytes downloaded
[19:58:31] Initial: 1315; + 614400 bytes downloaded
[19:58:31] Initial: 0887; + 624640 bytes downloaded
[19:58:31] Initial: 5BA1; + 634880 bytes downloaded
[19:58:31] Initial: E140; + 645120 bytes downloaded
[19:58:31] Initial: 1E9D; + 655360 bytes downloaded
[19:58:31] Initial: 6C1A; + 665600 bytes downloaded
[19:58:31] Initial: 8A4A; + 675840 bytes downloaded
[19:58:31] Initial: 57FD; + 686080 bytes downloaded
[19:58:31] Initial: F8E0; + 696320 bytes downloaded
[19:58:31] Initial: 0CD1; + 706560 bytes downloaded
[19:58:31] Initial: D1E2; + 716800 bytes downloaded
[19:58:31] Initial: 9CA8; + 727040 bytes downloaded
[19:58:31] Initial: 7F13; + 737280 bytes downloaded
[19:58:31] Initial: 3231; + 747520 bytes downloaded
[19:58:31] Initial: 5F16; + 757760 bytes downloaded
[19:58:32] Initial: BF95; + 768000 bytes downloaded
[19:58:32] Initial: 70A4; + 778240 bytes downloaded
[19:58:32] Initial: 6D26; + 788480 bytes downloaded
[19:58:32] Initial: 13C7; + 798720 bytes downloaded
[19:58:32] Initial: 9F26; + 808960 bytes downloaded
[19:58:32] Initial: C7B5; + 819200 bytes downloaded
[19:58:32] Initial: D5A9; + 829440 bytes downloaded
[19:58:32] Initial: F796; + 839680 bytes downloaded
[19:58:32] Initial: A004; + 849920 bytes downloaded
[19:58:32] Initial: 1011; + 860160 bytes downloaded
[19:58:32] Initial: 3F6F; + 870400 bytes downloaded
[19:58:32] Initial: B01C; + 880640 bytes downloaded
[19:58:32] Initial: E903; + 890880 bytes downloaded
[19:58:32] Initial: 29D0; + 901120 bytes downloaded
[19:58:32] Initial: 3DD6; + 911360 bytes downloaded
[19:58:32] Initial: D5BF; + 921600 bytes downloaded
[19:58:32] Initial: EC69; + 931840 bytes downloaded
[19:58:32] Initial: 1A1D; + 942080 bytes downloaded
[19:58:32] Initial: 7BC0; + 952320 bytes downloaded
[19:58:32] Initial: 9C4E; + 962560 bytes downloaded
[19:58:32] Initial: 9C59; + 972800 bytes downloaded
[19:58:32] Initial: 7BBD; + 983040 bytes downloaded
[19:58:32] Initial: D395; + 993280 bytes downloaded
[19:58:32] Initial: 5239; + 1003520 bytes downloaded
[19:58:32] Initial: BE83; + 1013760 bytes downloaded
[19:58:32] Initial: 428D; + 1024000 bytes downloaded
[19:58:32] Initial: E2EE; + 1034240 bytes downloaded
[19:58:32] Initial: 64BB; + 1044480 bytes downloaded
[19:58:32] Initial: 7200; + 1054720 bytes downloaded
[19:58:32] Initial: 71BB; + 1064960 bytes downloaded
[19:58:33] Initial: 9A20; + 1075200 bytes downloaded
[19:58:33] Initial: 1D08; + 1085440 bytes downloaded
[19:58:33] Initial: B1BD; + 1095680 bytes downloaded
[19:58:33] Initial: 4946; + 1105920 bytes downloaded
[19:58:33] Initial: 5297; + 1116160 bytes downloaded
[19:58:33] Initial: 201F; + 1126400 bytes downloaded
[19:58:33] Initial: A318; + 1136640 bytes downloaded
[19:58:33] Initial: 3ED5; + 1146880 bytes downloaded
[19:58:33] Initial: 8473; + 1157120 bytes downloaded
[19:58:33] Initial: D9B9; + 1167360 bytes downloaded
[19:58:33] Initial: 2D15; + 1177600 bytes downloaded
[19:58:33] Initial: F6A1; + 1187840 bytes downloaded
[19:58:33] Initial: 1850; + 1198080 bytes downloaded
[19:58:33] Initial: 3D3E; + 1208320 bytes downloaded
[19:58:33] Initial: 2ADB; + 1218560 bytes downloaded
[19:58:33] Initial: FF21; + 1228800 bytes downloaded
[19:58:33] Initial: 1708; + 1239040 bytes downloaded
[19:58:33] Initial: ADA8; + 1249280 bytes downloaded
[19:58:33] Initial: 8E4E; + 1259520 bytes downloaded
[19:58:33] Initial: 63C7; + 1269760 bytes downloaded
[19:58:33] Initial: 7316; + 1280000 bytes downloaded
[19:58:33] Initial: B3D8; + 1290240 bytes downloaded
[19:58:33] Initial: 2693; + 1300480 bytes downloaded
[19:58:33] Initial: 1B77; + 1310720 bytes downloaded
[19:58:33] Initial: F16F; + 1320960 bytes downloaded
[19:58:33] Initial: 45F0; + 1331200 bytes downloaded
[19:58:33] Initial: 289C; + 1341440 bytes downloaded
[19:58:34] Initial: 83F2; + 1351680 bytes downloaded
[19:58:34] Initial: 1459; + 1361920 bytes downloaded
[19:58:34] Initial: 1A62; + 1372160 bytes downloaded
[19:58:34] Initial: C408; + 1382400 bytes downloaded
[19:58:34] Initial: C561; + 1392640 bytes downloaded
[19:58:34] Initial: 8827; + 1402880 bytes downloaded
[19:58:34] Initial: 3F18; + 1413120 bytes downloaded
[19:58:34] Initial: 212C; + 1422551 bytes downloaded
[19:58:34] Verifying core Core_15.fah...
[19:58:34] Signature is VALID
[19:58:34]
[19:58:34] Trying to unzip core FahCore_15.exe
[19:58:34] Decompressed FahCore_15.exe (3903488 bytes) successfully
[19:58:39] + Core successfully engaged
[19:58:44]
[19:58:44] + Processing work unit
[19:58:44] Core required: FahCore_15.exe
[19:58:44] Core found.
[19:58:44] Working on queue slot 02 [March 28 19:58:44 UTC]
[19:58:44] + Working ...
[19:58:44] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:58:45]
[19:58:45] *------------------------------*
[19:58:45] Folding@Home GPU Core
[19:58:45] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:58:45]
[19:58:45] Build host: SimbiosNvdWin7
[19:58:45] Board Type: NVIDIA/CUDA
[19:58:45] Core      : x=15
[19:58:45]  Window's signal control handler registered.
[19:58:45] Preparing to commence simulation
[19:58:45] - Ensuring status. Please wait.
[19:58:54] - Looking at optimizations...
[19:58:54] - Working with standard loops on this execution.
[19:58:54] Examination of work files indicates 8 consecutive improper terminations of core.
[19:58:54] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:58:54] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:58:54] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:58:54] - Digital signature verified
[19:58:54]
[19:58:54] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:58:54]
[19:58:54] Entering M.D.
[19:58:56] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:58:56] Working on ALZHEIMER'S DISEASE AMYLOID
[19:58:56] Client config found, loading data.
[19:58:59] CoreStatus = 63 (99)
[19:58:59] + Error starting Folding@home core.
[19:59:04]
[19:59:04] + Processing work unit
[19:59:04] Core required: FahCore_15.exe
[19:59:04] Core found.
[19:59:04] Working on queue slot 02 [March 28 19:59:04 UTC]
[19:59:04] + Working ...
[19:59:04] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:59:04]
[19:59:04] *------------------------------*
[19:59:04] Folding@Home GPU Core
[19:59:04] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:59:04]
[19:59:04] Build host: SimbiosNvdWin7
[19:59:04] Board Type: NVIDIA/CUDA
[19:59:04] Core      : x=15
[19:59:04]  Window's signal control handler registered.
[19:59:04] Preparing to commence simulation
[19:59:04] - Ensuring status. Please wait.
[19:59:13] - Looking at optimizations...
[19:59:13] - Working with standard loops on this execution.
[19:59:13] Examination of work files indicates 8 consecutive improper terminations of core.
[19:59:13] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:59:13] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:59:13] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:59:13] - Digital signature verified
[19:59:13]
[19:59:13] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:59:13]
[19:59:13] Entering M.D.
[19:59:15] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:59:15] Working on ALZHEIMER'S DISEASE AMYLOID
[19:59:15] Client config found, loading data.
[19:59:18] CoreStatus = 63 (99)
[19:59:18] + Error starting Folding@home core.
[19:59:23]
[19:59:23] + Processing work unit
[19:59:23] Core required: FahCore_15.exe
[19:59:23] Core found.
[19:59:23] Working on queue slot 02 [March 28 19:59:23 UTC]
[19:59:23] + Working ...
[19:59:23] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:59:23]
[19:59:23] *------------------------------*
[19:59:23] Folding@Home GPU Core
[19:59:23] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:59:23]
[19:59:23] Build host: SimbiosNvdWin7
[19:59:23] Board Type: NVIDIA/CUDA
[19:59:23] Core      : x=15
[19:59:23]  Window's signal control handler registered.
[19:59:23] Preparing to commence simulation
[19:59:23] - Ensuring status. Please wait.
[19:59:33] - Looking at optimizations...
[19:59:33] - Working with standard loops on this execution.
[19:59:33] Examination of work files indicates 8 consecutive improper terminations of core.
[19:59:33] sizeof(CORE_PACKET_HDR) = 512 file=<>
[19:59:33] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[19:59:33] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[19:59:33] - Digital signature verified
[19:59:33]
[19:59:33] Project: 6801 (Run 4756, Clone 3, Gen 31)
[19:59:33]
[19:59:33] Entering M.D.
[19:59:35] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[19:59:35] Working on ALZHEIMER'S DISEASE AMYLOID
[19:59:35] Client config found, loading data.
[19:59:37] CoreStatus = 63 (99)
[19:59:37] + Error starting Folding@home core.
[19:59:37] - Attempting to download new core...
[19:59:37] + Downloading new core: FahCore_15.exe
[19:59:37] Downloading core (/~pande/Win32/x86/NVIDIA/Fermi/Core_15.fah from www.stanford.edu)
[19:59:37] Initial: AFDE; + 10240 bytes downloaded
[19:59:37] Initial: 4A9F; + 20480 bytes downloaded
[19:59:38] Initial: 02DB; + 30720 bytes downloaded
[19:59:38] Initial: 32D2; + 40960 bytes downloaded
[19:59:38] Initial: 0664; + 51200 bytes downloaded
[19:59:38] Initial: 0400; + 61440 bytes downloaded
[19:59:38] Initial: 3AB8; + 71680 bytes downloaded
[19:59:38] Initial: F8D2; + 81920 bytes downloaded
[19:59:38] Initial: F4EE; + 92160 bytes downloaded
[19:59:38] Initial: ECE1; + 102400 bytes downloaded
[19:59:38] Initial: 9A21; + 112640 bytes downloaded
[19:59:38] Initial: 4572; + 122880 bytes downloaded
[19:59:38] Initial: A5AF; + 133120 bytes downloaded
[19:59:38] Initial: AE73; + 143360 bytes downloaded
[19:59:38] Initial: 324F; + 153600 bytes downloaded
[19:59:38] Initial: 6A97; + 163840 bytes downloaded
[19:59:39] Initial: E123; + 174080 bytes downloaded
[19:59:39] Initial: 5426; + 184320 bytes downloaded
[19:59:39] Initial: 9D76; + 194560 bytes downloaded
[19:59:39] Initial: 2226; + 204800 bytes downloaded
[19:59:39] Initial: FE64; + 215040 bytes downloaded
[19:59:39] Initial: F9F2; + 225280 bytes downloaded
[19:59:39] Initial: 4F35; + 235520 bytes downloaded
[19:59:39] Initial: D07D; + 245760 bytes downloaded
[19:59:39] Initial: 9E40; + 256000 bytes downloaded
[19:59:39] Initial: 38A2; + 266240 bytes downloaded
[19:59:39] Initial: BD94; + 276480 bytes downloaded
[19:59:39] Initial: 4BAC; + 286720 bytes downloaded
[19:59:39] Initial: D740; + 296960 bytes downloaded
[19:59:39] Initial: B43A; + 307200 bytes downloaded
[19:59:40] Initial: 4B3F; + 317440 bytes downloaded
[19:59:40] Initial: BDD0; + 327680 bytes downloaded
[19:59:40] Initial: 18EB; + 337920 bytes downloaded
[19:59:40] Initial: E612; + 348160 bytes downloaded
[19:59:40] Initial: BD4D; + 358400 bytes downloaded
[19:59:40] Initial: D804; + 368640 bytes downloaded
[19:59:40] Initial: B7D0; + 378880 bytes downloaded
[19:59:40] Initial: 6492; + 389120 bytes downloaded
[19:59:40] Initial: B390; + 399360 bytes downloaded
[19:59:40] Initial: 2ADA; + 409600 bytes downloaded
[19:59:40] Initial: BAB5; + 419840 bytes downloaded
[19:59:40] Initial: BC78; + 430080 bytes downloaded
[19:59:40] Initial: 1119; + 440320 bytes downloaded
[19:59:40] Initial: 27B1; + 450560 bytes downloaded
[19:59:40] Initial: 8A2A; + 460800 bytes downloaded
[19:59:41] Initial: 6F27; + 471040 bytes downloaded
[19:59:41] Initial: FFFF; + 481280 bytes downloaded
[19:59:41] Initial: D0B6; + 491520 bytes downloaded
[19:59:41] Initial: 0702; + 501760 bytes downloaded
[19:59:41] Initial: 08C1; + 512000 bytes downloaded
[19:59:41] Initial: E64B; + 522240 bytes downloaded
[19:59:41] Initial: F5F0; + 532480 bytes downloaded
[19:59:41] Initial: 98CB; + 542720 bytes downloaded
[19:59:41] Initial: 2477; + 552960 bytes downloaded
[19:59:41] Initial: 494C; + 563200 bytes downloaded
[19:59:41] Initial: 4D49; + 573440 bytes downloaded
[19:59:41] Initial: C6C8; + 583680 bytes downloaded
[19:59:41] Initial: 2D13; + 593920 bytes downloaded
[19:59:41] Initial: 03F9; + 604160 bytes downloaded
[19:59:42] Initial: 1315; + 614400 bytes downloaded
[19:59:42] Initial: 0887; + 624640 bytes downloaded
[19:59:42] Initial: 5BA1; + 634880 bytes downloaded
[19:59:42] Initial: E140; + 645120 bytes downloaded
[19:59:42] Initial: 1E9D; + 655360 bytes downloaded
[19:59:42] Initial: 6C1A; + 665600 bytes downloaded
[19:59:42] Initial: 8A4A; + 675840 bytes downloaded
[19:59:42] Initial: 57FD; + 686080 bytes downloaded
[19:59:42] Initial: F8E0; + 696320 bytes downloaded
[19:59:42] Initial: 0CD1; + 706560 bytes downloaded
[19:59:42] Initial: D1E2; + 716800 bytes downloaded
[19:59:42] Initial: 9CA8; + 727040 bytes downloaded
[19:59:42] Initial: 7F13; + 737280 bytes downloaded
[19:59:43] Initial: 3231; + 747520 bytes downloaded
[19:59:43] Initial: 5F16; + 757760 bytes downloaded
[19:59:43] Initial: BF95; + 768000 bytes downloaded
[19:59:43] Initial: 70A4; + 778240 bytes downloaded
[19:59:43] Initial: 6D26; + 788480 bytes downloaded
[19:59:43] Initial: 13C7; + 798720 bytes downloaded
[19:59:43] Initial: 9F26; + 808960 bytes downloaded
[19:59:43] Initial: C7B5; + 819200 bytes downloaded
[19:59:43] Initial: D5A9; + 829440 bytes downloaded
[19:59:43] Initial: F796; + 839680 bytes downloaded
[19:59:43] Initial: A004; + 849920 bytes downloaded
[19:59:43] Initial: 1011; + 860160 bytes downloaded
[19:59:43] Initial: 3F6F; + 870400 bytes downloaded
[19:59:43] Initial: B01C; + 880640 bytes downloaded
[19:59:43] Initial: E903; + 890880 bytes downloaded
[19:59:44] Initial: 29D0; + 901120 bytes downloaded
[19:59:44] Initial: 3DD6; + 911360 bytes downloaded
[19:59:44] Initial: D5BF; + 921600 bytes downloaded
[19:59:44] Initial: EC69; + 931840 bytes downloaded
[19:59:44] Initial: 1A1D; + 942080 bytes downloaded
[19:59:44] Initial: 7BC0; + 952320 bytes downloaded
[19:59:44] Initial: 9C4E; + 962560 bytes downloaded
[19:59:44] Initial: 9C59; + 972800 bytes downloaded
[19:59:44] Initial: 7BBD; + 983040 bytes downloaded
[19:59:44] Initial: D395; + 993280 bytes downloaded
[19:59:44] Initial: 5239; + 1003520 bytes downloaded
[19:59:44] Initial: BE83; + 1013760 bytes downloaded
[19:59:44] Initial: 428D; + 1024000 bytes downloaded
[19:59:44] Initial: E2EE; + 1034240 bytes downloaded
[19:59:44] Initial: 64BB; + 1044480 bytes downloaded
[19:59:45] Initial: 7200; + 1054720 bytes downloaded
[19:59:45] Initial: 71BB; + 1064960 bytes downloaded
[19:59:45] Initial: 9A20; + 1075200 bytes downloaded
[19:59:45] Initial: 1D08; + 1085440 bytes downloaded
[19:59:45] Initial: B1BD; + 1095680 bytes downloaded
[19:59:45] Initial: 4946; + 1105920 bytes downloaded
[19:59:45] Initial: 5297; + 1116160 bytes downloaded
[19:59:45] Initial: 201F; + 1126400 bytes downloaded
[19:59:45] Initial: A318; + 1136640 bytes downloaded
[19:59:45] Initial: 3ED5; + 1146880 bytes downloaded
[19:59:45] Initial: 8473; + 1157120 bytes downloaded
[19:59:45] Initial: D9B9; + 1167360 bytes downloaded
[19:59:45] Initial: 2D15; + 1177600 bytes downloaded
[19:59:45] Initial: F6A1; + 1187840 bytes downloaded
[19:59:46] Initial: 1850; + 1198080 bytes downloaded
[19:59:46] Initial: 3D3E; + 1208320 bytes downloaded
[19:59:46] Initial: 2ADB; + 1218560 bytes downloaded
[19:59:46] Initial: FF21; + 1228800 bytes downloaded
[19:59:46] Initial: 1708; + 1239040 bytes downloaded
[19:59:46] Initial: ADA8; + 1249280 bytes downloaded
[19:59:46] Initial: 8E4E; + 1259520 bytes downloaded
[19:59:46] Initial: 63C7; + 1269760 bytes downloaded
[19:59:46] Initial: 7316; + 1280000 bytes downloaded
[19:59:46] Initial: B3D8; + 1290240 bytes downloaded
[19:59:46] Initial: 2693; + 1300480 bytes downloaded
[19:59:46] Initial: 1B77; + 1310720 bytes downloaded
[19:59:46] Initial: F16F; + 1320960 bytes downloaded
[19:59:46] Initial: 45F0; + 1331200 bytes downloaded
[19:59:47] Initial: 289C; + 1341440 bytes downloaded
[19:59:47] Initial: 83F2; + 1351680 bytes downloaded
[19:59:47] Initial: 1459; + 1361920 bytes downloaded
[19:59:47] Initial: 1A62; + 1372160 bytes downloaded
[19:59:47] Initial: C408; + 1382400 bytes downloaded
[19:59:47] Initial: C561; + 1392640 bytes downloaded
[19:59:47] Initial: 8827; + 1402880 bytes downloaded
[19:59:47] Initial: 3F18; + 1413120 bytes downloaded
[19:59:47] Initial: 212C; + 1422551 bytes downloaded
[19:59:47] Verifying core Core_15.fah...
[19:59:47] Signature is VALID
[19:59:47]
[19:59:47] Trying to unzip core FahCore_15.exe
[19:59:48] Decompressed FahCore_15.exe (3903488 bytes) successfully
[19:59:53] + Core successfully engaged
[19:59:58]
[19:59:58] + Processing work unit
[19:59:58] Core required: FahCore_15.exe
[19:59:58] Core found.
[19:59:58] Working on queue slot 02 [March 28 19:59:58 UTC]
[19:59:58] + Working ...
[19:59:58] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[19:59:58]
[19:59:58] *------------------------------*
[19:59:58] Folding@Home GPU Core
[19:59:58] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[19:59:58]
[19:59:58] Build host: SimbiosNvdWin7
[19:59:58] Board Type: NVIDIA/CUDA
[19:59:58] Core      : x=15
[19:59:58]  Window's signal control handler registered.
[19:59:58] Preparing to commence simulation
[19:59:58] - Ensuring status. Please wait.
[20:00:07] - Looking at optimizations...
[20:00:07] - Working with standard loops on this execution.
[20:00:07] Examination of work files indicates 8 consecutive improper terminations of core.
[20:00:07] sizeof(CORE_PACKET_HDR) = 512 file=<>
[20:00:07] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[20:00:07] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[20:00:07] - Digital signature verified
[20:00:07]
[20:00:07] Project: 6801 (Run 4756, Clone 3, Gen 31)
[20:00:07]
[20:00:07] Entering M.D.
[20:00:09] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[20:00:09] Working on ALZHEIMER'S DISEASE AMYLOID
[20:00:09] Client config found, loading data.
[20:00:12] CoreStatus = 63 (99)
[20:00:12] + Error starting Folding@home core.
[20:00:17]
[20:00:17] + Processing work unit
[20:00:17] Core required: FahCore_15.exe
[20:00:17] Core found.
[20:00:17] Working on queue slot 02 [March 28 20:00:17 UTC]
[20:00:17] + Working ...
[20:00:17] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[20:00:17]
[20:00:17] *------------------------------*
[20:00:17] Folding@Home GPU Core
[20:00:17] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[20:00:17]
[20:00:17] Build host: SimbiosNvdWin7
[20:00:17] Board Type: NVIDIA/CUDA
[20:00:17] Core      : x=15
[20:00:17]  Window's signal control handler registered.
[20:00:17] Preparing to commence simulation
[20:00:17] - Ensuring status. Please wait.
[20:00:27] - Looking at optimizations...
[20:00:27] - Working with standard loops on this execution.
[20:00:27] Examination of work files indicates 8 consecutive improper terminations of core.
[20:00:27] sizeof(CORE_PACKET_HDR) = 512 file=<>
[20:00:27] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[20:00:27] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[20:00:27] - Digital signature verified
[20:00:27]
[20:00:27] Project: 6801 (Run 4756, Clone 3, Gen 31)
[20:00:27]
[20:00:27] Entering M.D.
[20:00:29] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[20:00:29] Working on ALZHEIMER'S DISEASE AMYLOID
[20:00:29] Client config found, loading data.
[20:00:31] CoreStatus = 63 (99)
[20:00:31] + Error starting Folding@home core.
[20:00:36]
[20:00:36] + Processing work unit
[20:00:36] Core required: FahCore_15.exe
[20:00:36] Core found.
[20:00:36] Working on queue slot 02 [March 28 20:00:36 UTC]
[20:00:36] + Working ...
[20:00:36] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -nocpulock -checkpoint 15 -verbose -lifeline 4068 -version 641'
[20:00:37]
[20:00:37] *------------------------------*
[20:00:37] Folding@Home GPU Core
[20:00:37] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[20:00:37]
[20:00:37] Build host: SimbiosNvdWin7
[20:00:37] Board Type: NVIDIA/CUDA
[20:00:37] Core      : x=15
[20:00:37]  Window's signal control handler registered.
[20:00:37] Preparing to commence simulation
[20:00:37] - Ensuring status. Please wait.
[20:00:46] - Looking at optimizations...
[20:00:46] - Working with standard loops on this execution.
[20:00:46] Examination of work files indicates 8 consecutive improper terminations of core.
[20:00:46] sizeof(CORE_PACKET_HDR) = 512 file=<>
[20:00:46] - Expanded 44343 -> 171827 (decompressed 387.4 percent)
[20:00:46] Called DecompressByteArray: compressed_data_size=44343 data_size=171827, decompressed_data_size=171827 diff=0
[20:00:46] - Digital signature verified
[20:00:46]
[20:00:46] Project: 6801 (Run 4756, Clone 3, Gen 31)
[20:00:46]
[20:00:46] Entering M.D.
[20:00:48] Tpr hash work/wudata_02.tpr:  3516492143 2967914013 3107581907 2895976157 1595940273
[20:00:48] Working on ALZHEIMER'S DISEASE AMYLOID
[20:00:48] Client config found, loading data.
[20:00:51] CoreStatus = 63 (99)
[20:00:51] + Error starting Folding@home core.
[20:00:51]
Folding@Home will go to sleep for 1 day as there have been 5 consecutive Cores executed which failed to complete a work unit.
[20:00:51] (To wake it up early, quit the application and restart it.)
[20:00:51] If problems persist, please visit our website at http://folding.stanford.edu for help.
[20:00:51] + Sleeping...
Atom
Re: GPU client: "Error starting Folding@Home core" then slee
Post by Atom »
bruce wrote:Do you have more than one GPU in that system?
Yes, the second piece of info in my orig post is that this is part of a dual-GPU system.
When something runs for "a little while" that means it's probably heat-related. Are your GPUs 2-slot affairs that push the hot air out the back, or 1-slot types that just recirculate it inside the case? How much cool air can get between the two GPUs or do they just keep each other warm?
Is your power supply able to deliver enough power to the GPUs?
HendricksSA
Post by HendricksSA »
Atom, tell us more about the "load upon Windows startup". I don't see evidence of a service launch in the log so I'm guessing you are putting a shortcut in your Startup Folder. Error 63 (99) is associated with a failure to meet some initial startup requirement. I'm guessing the obvious thing here - the need for the forcegpu flag and not recognizing the cards must be at the root of the problem. How to fix it has me stumped since this happened on two machines. Let me check that as well - is the other 450 machine running stable now? Is this problem on only this one machine?
Following what Bruce said, had this machine been running stable for some time and then just started with the error 63?
What version of Windows do you have? If you actually are trying to run a GPU client as a service, that cannot be done in Vista/Win7 due to a Microsoft security patch.
Atom
Post by Atom »
bruce wrote:When something runs for "a little while" that means it's probably heat-related. Are your GPUs 2-slot affairs that push the hot air out the back, or 1-slot types that just recirculate it inside the case? How much cool air can get between the two GPUs or do they just keep each other warm?
"Running for a little while" meant that it completed one work unit before throwing the error again. (I should have been more specific.) The cards are two-slot cards, and there's lots of space (an empty slot) between them. Still, the MSI fan shroud lets lots of air recirculate back into the cabinet. To address that, there's a fan blowing outside air on them, and I have good ventilation overall on these PCs. When folding, they maintain constant temps in the mid 70s (C). I really don't think it's an overheating issue.
Power supply is an OCZ StealthXstream2 600 Watt unit. It's a high-current PSU that puts out 72 Amps total on its four 12 Volt lines. That's plenty of power to run two 450s. Nvidia claims they max out at 106W. (By way of comparison, I have a dual GTX 460 folding rig running the same PSU with rock solid reliability , and my 3-way 450 folding rig has the 700 Watt version of this PSU, which puts out exactly the same 72 Amps on the 12 Volt rails.) Power shouldn't be a problem.
Atom
Post by Atom »
HendricksSA wrote:Atom, tell us more about the "load upon Windows startup". I don't see evidence of a service launch in the log so I'm guessing you are putting a shortcut in your Startup Folder. Error 63 (99) is associated with a failure to meet some initial startup requirement. I'm guessing the obvious thing here - the need for the forcegpu flag and not recognizing the cards must be at the root of the problem. How to fix it has me stumped since this happened on two machines. Let me check that as well - is the other 450 machine running stable now? Is this problem on only this one machine?
You're right, I simply placed shortcuts in the Startup folder. These are dedicated folding machines. They're located in my office, about 45 minutes from home. I'm almost never in my office, so it's handy to have the GPU client start automatically if the machine reboots for any reason. I can't tell you if the other dual 450 folding machine is working correctly now or not. I clicked "shut down" instead of "Restart" over the weekend by mistake when I was remotely connected and I need to get someone in the office to manually start the machine for me (I'm not going in to the office for a while.) But before I shut it down, it was experiencing the same "Corestatus = 63" problem.
I do have a third machine that's running three 450s, and they're running fine. None of the three cards in that machine are MSI cards, so that's one notable difference. Otherwise they're all running Windows 7 Ultimate 64-bit, with the same drivers and f@h client versions. They also had the same Windows patches applied (I do them all at the same time.)
I built these machines fairly recently. I tested them at home for a while to gauge stability before moving them to my office. They ran fine at home for a week or so. Once I moved them to my office they started these chronic error messages. I'll try to get the other machine started tomorrow and give you an update after I underclock those cards, too. I can also try throttling these cards back even more to see if that helps.
Atom
Post by Atom »
bruce wrote:What version of Windows do you have? If you actually are trying to run a GPU client as a service, that cannot be done in Vista/Win7 due to a Microsoft security patch.
The very first piece of info in my orig post says it's Windows 7 Ultimate 64-bit
