64bit Windows 7 gpu client help
fihsboy
Post by fihsboy »
I have a windows 7 64bit os with a nvideia geforce 450 gpu. I just want to run a gpu client in order to better my statistics and be more help than just the cpu client. Any help would be appreciated! I cant get the cores to startup, and sometimes it says core not found. Im just completly lost as to what im doing wrong. Thank you in advanced for any ideas or help!
                          http://folding.stanford.edu
Launch directory: C:\Users\Mike\AppData\Roaming\Folding@home-gpu
[00:41:15] - Ask before connecting: No
[00:41:15] - User name: fihsboy (Team 111065)
[00:41:15] - User ID: 71D942EB61A6A621
[00:41:15] - Machine ID: 1
[00:41:15]
[00:41:15] Loaded queue successfully.
[00:41:15] Initialization complete
[00:41:15]
[00:41:15] + Processing work unit
[00:41:15] Core required: FahCore_11.exe
[00:41:15] Core found.
[00:41:15] Working on queue slot 00 [March 24 00:41:15 UTC]
[00:41:15] + Working ...
[00:41:15]
[00:41:15] *------------------------------*
[00:41:15] Folding@Home GPU Core
[00:41:15] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[00:41:15]
[00:41:15] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:41:15] Build host: amoeba
[00:41:15] Board Type: Nvidia
[00:41:15] Core      :
[00:41:15] Preparing to commence simulation
[00:41:15] - Ensuring status. Please wait.
[00:41:25] - Looking at optimizations...
[00:41:25] - Working with standard loops on this execution.
[00:41:25] - Previous termination of core was improper.
[00:41:25] - Going to use standard loops.
[00:41:25] - Files status OK
[00:41:25] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[00:41:25] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[00:41:25] - Digital signature verified
[00:41:25]
[00:41:25] Project: 10111 (Run 285, Clone 2, Gen 210)
[00:41:25]
[00:41:25] Entering M.D.
[00:41:31] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[00:41:31]
[00:41:31] Calling fah_main args: 14 usage=100
[00:41:31]
[00:41:33] CoreStatus = 63 (99)
[00:41:33] + Error starting Folding@home core.
[00:41:38]
[00:41:38] + Processing work unit
[00:41:38] Core required: FahCore_11.exe
[00:41:38] Core found.
[00:41:39] Working on queue slot 00 [March 24 00:41:39 UTC]
[00:41:39] + Working ...
[00:41:39]
[00:41:39] *------------------------------*
[00:41:39] Folding@Home GPU Core
[00:41:39] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[00:41:39]
[00:41:39] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[00:41:39] Build host: amoeba
[00:41:39] Board Type: Nvidia
[00:41:39] Core      :
[00:41:39] Preparing to commence simulation
[00:41:39] - Ensuring status. Please wait.
[00:41:48] - Looking at optimizations...
[00:41:48] - Working with standard loops on this execution.
[00:41:48] - Previous termination of core was improper.
[00:41:48] - Going to use standard loops.
[00:41:48] - Files status OK
[00:41:48] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[00:41:48] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[00:41:48] - Digital signature verified
[00:41:48]
[00:41:48] Project: 10111 (Run 285, Clone 2, Gen 210)
[00:41:48]
[00:41:48] Entering M.D.
[00:41:54] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[00:41:54]
[00:41:54] Calling fah_main args: 14 usage=100
[00:41:54]
[00:41:57] CoreStatus = 63 (99)
[00:41:57] + Error starting Folding@home core.
Re: 64bit Windows 7 gpu client help
Welcome to the F@H Forum fihsboy,
The problem is that you are using the GPU2 Client which won't work. Please download and install the GPU3 Beta Client. However before you do that, please remove all traces of GPU2 Client from your system by doing the following:
For Console Version:
Step A: Locate the folder in which you have installed the GPU3 BETA Client
Step B: Delete it and any shortcuts you made to it
Note: Make sure that you delete the FahCore_xx, queue.dat and work folder as incorrect version\type will cause problems and won't allow your F@h GPU Client to function normally
fihsboy
Post by fihsboy »
I appreciate it! Going to go give it a shot now.
fihsboy
Post by fihsboy »
I deleted everything from my computer completly that had anything to do with the programs. F@H cpu and gpu clients as well as all the .dat files. Everything is fresh and this is the data log.
--- Opening Log file [March 24 01:15:04 UTC]
# Windows GPU Systray Edition #################################################
                       Folding@Home Client Version 6.41r2
[01:15:04] - Ask before connecting: No
[01:15:04] - User name: fihsboy (Team 111065)
[01:15:04] - User ID: 71D942EB61A6A621
[01:15:04] - Machine ID: 1
[01:15:04]
[01:15:04] Gpu type=3 species=21.
[01:15:04] Loaded queue successfully.
[01:15:04] Initialization complete
[01:15:04]
[01:15:04] + Processing work unit
[01:15:04] Core required: FahCore_11.exe
[01:15:04] Core found.
[01:15:04] Working on queue slot 00 [March 24 01:15:04 UTC]
[01:15:04] + Working ...
[01:15:04]
[01:15:04] *------------------------------*
[01:15:04] Folding@Home GPU Core
[01:15:04] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:15:04]
[01:15:04] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:15:04] Build host: amoeba
[01:15:04] Board Type: Nvidia
[01:15:04] Core      :
[01:15:04] Preparing to commence simulation
[01:15:04] - Ensuring status. Please wait.
[01:15:14] - Looking at optimizations...
[01:15:14] - Working with standard loops on this execution.
[01:15:14] Examination of work files indicates 8 consecutive improper terminations of core.
[01:15:14] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[01:15:14] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[01:15:14] - Digital signature verified
[01:15:14]
[01:15:14] Project: 10111 (Run 285, Clone 2, Gen 210)
[01:15:14]
[01:15:14] Entering M.D.
[01:15:20] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[01:15:20]
[01:15:20] Calling fah_main args: 14 usage=100
[01:15:20]
[01:15:22] CoreStatus = 63 (99)
[01:15:22] + Error starting Folding@home core.
[01:15:27]
[01:15:27] + Processing work unit
[01:15:27] Core required: FahCore_11.exe
[01:15:27] Core found.
[01:15:27] Working on queue slot 00 [March 24 01:15:27 UTC]
[01:15:27] + Working ...
[01:15:27]
[01:15:27] *------------------------------*
[01:15:27] Folding@Home GPU Core
[01:15:27] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:15:27]
[01:15:27] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:15:27] Build host: amoeba
[01:15:27] Board Type: Nvidia
[01:15:27] Core      :
[01:15:27] Preparing to commence simulation
[01:15:27] - Ensuring status. Please wait.
[01:15:37] - Looking at optimizations...
[01:15:37] - Working with standard loops on this execution.
[01:15:37] Examination of work files indicates 8 consecutive improper terminations of core.
[01:15:37] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[01:15:37] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[01:15:37] - Digital signature verified
[01:15:37]
[01:15:37] Project: 10111 (Run 285, Clone 2, Gen 210)
[01:15:37]
[01:15:37] Entering M.D.
[01:15:43] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[01:15:43]
[01:15:43] Calling fah_main args: 14 usage=100
[01:15:43]
[01:15:46] CoreStatus = 63 (99)
[01:15:46] + Error starting Folding@home core.
[01:15:51]
[01:15:51] + Processing work unit
[01:15:51] Core required: FahCore_11.exe
[01:15:51] Core found.
[01:15:51] Working on queue slot 00 [March 24 01:15:51 UTC]
[01:15:51] + Working ...
[01:15:51]
[01:15:51] *------------------------------*
[01:15:51] Folding@Home GPU Core
[01:15:51] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:15:51]
[01:15:51] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:15:51] Build host: amoeba
[01:15:51] Board Type: Nvidia
[01:15:51] Core      :
[01:15:51] Preparing to commence simulation
[01:15:51] - Ensuring status. Please wait.
[01:16:00] - Looking at optimizations...
[01:16:00] - Working with standard loops on this execution.
[01:16:00] Examination of work files indicates 8 consecutive improper terminations of core.
[01:16:00] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[01:16:00] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[01:16:00] - Digital signature verified
[01:16:00]
[01:16:00] Project: 10111 (Run 285, Clone 2, Gen 210)
[01:16:00]
[01:16:00] Entering M.D.
[01:16:06] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[01:16:06]
[01:16:06] Calling fah_main args: 14 usage=100
[01:16:06]
[01:16:09] CoreStatus = 63 (99)
[01:16:09] + Error starting Folding@home core.
[01:16:09] - Attempting to download new core...
[01:16:09] + Downloading new core: FahCore_11.exe
[01:16:10] + 10240 bytes downloaded
[01:16:11] + 20480 bytes downloaded
[01:16:12] + 30720 bytes downloaded
[01:16:12] + 40960 bytes downloaded
[01:16:13] + 51200 bytes downloaded
[01:16:14] + 61440 bytes downloaded
[01:16:15] + 71680 bytes downloaded
[01:16:15] + 81920 bytes downloaded
[01:16:15] + 92160 bytes downloaded
[01:16:15] + 102400 bytes downloaded
[01:16:18] + 112640 bytes downloaded
[01:16:19] + 122880 bytes downloaded
[01:16:20] + 133120 bytes downloaded
[01:16:20] + 143360 bytes downloaded
[01:16:21] + 153600 bytes downloaded
[01:16:22] + 163840 bytes downloaded
[01:16:22] + 174080 bytes downloaded
[01:16:22] + 184320 bytes downloaded
[01:16:22] + 194560 bytes downloaded
[01:16:23] + 204800 bytes downloaded
[01:16:24] + 215040 bytes downloaded
[01:16:24] + 225280 bytes downloaded
[01:16:26] + 235520 bytes downloaded
[01:16:26] + 245760 bytes downloaded
[01:16:27] + 256000 bytes downloaded
[01:16:28] + 266240 bytes downloaded
[01:16:28] + 276480 bytes downloaded
[01:16:29] + 286720 bytes downloaded
[01:16:30] + 296960 bytes downloaded
[01:16:30] + 307200 bytes downloaded
[01:16:31] + 317440 bytes downloaded
[01:16:32] + 327680 bytes downloaded
[01:16:33] + 337920 bytes downloaded
[01:16:33] + 348160 bytes downloaded
[01:16:34] + 358400 bytes downloaded
[01:16:34] + 368640 bytes downloaded
[01:16:35] + 378880 bytes downloaded
[01:16:36] + 389120 bytes downloaded
[01:16:36] + 399360 bytes downloaded
[01:16:37] + 409600 bytes downloaded
[01:16:38] + 419840 bytes downloaded
[01:16:39] + 430080 bytes downloaded
[01:16:41] + 440320 bytes downloaded
[01:16:42] + 450560 bytes downloaded
[01:16:43] + 460800 bytes downloaded
[01:16:43] + 471040 bytes downloaded
[01:16:43] + 481280 bytes downloaded
[01:16:44] + 491520 bytes downloaded
[01:16:44] + 501760 bytes downloaded
[01:16:47] + 512000 bytes downloaded
[01:16:47] + 522240 bytes downloaded
[01:16:48] + 532480 bytes downloaded
[01:16:48] + 542720 bytes downloaded
[01:16:49] + 552960 bytes downloaded
[01:16:50] + 563200 bytes downloaded
[01:16:51] + 573440 bytes downloaded
[01:16:51] + 583680 bytes downloaded
[01:16:52] + 593920 bytes downloaded
[01:16:52] + 604160 bytes downloaded
[01:16:53] + 614400 bytes downloaded
[01:16:54] + 624640 bytes downloaded
[01:16:55] + 634880 bytes downloaded
[01:16:56] + 645120 bytes downloaded
[01:16:56] + 655360 bytes downloaded
[01:16:58] + 665067 bytes downloaded
[01:16:58] Verifying core Core_11.fah...
[01:16:58] Signature is VALID
[01:16:58]
[01:16:58] Trying to unzip core FahCore_11.exe
[01:16:58] Decompressed FahCore_11.exe (1908736 bytes) successfully
[01:17:03] + Core successfully engaged
[01:17:08]
[01:17:08] + Processing work unit
[01:17:08] Core required: FahCore_11.exe
[01:17:08] Core found.
[01:17:08] Working on queue slot 00 [March 24 01:17:08 UTC]
[01:17:08] + Working ...
[01:17:08]
[01:17:08] *------------------------------*
[01:17:08] Folding@Home GPU Core
[01:17:08] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:17:08]
[01:17:08] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:17:08] Build host: amoeba
[01:17:08] Board Type: Nvidia
[01:17:08] Core      :
[01:17:08] Preparing to commence simulation
[01:17:08] - Ensuring status. Please wait.
[01:17:18] - Looking at optimizations...
[01:17:18] - Working with standard loops on this execution.
[01:17:18] Examination of work files indicates 8 consecutive improper terminations of core.
[01:17:18] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[01:17:18] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[01:17:18] - Digital signature verified
[01:17:18]
[01:17:18] Project: 10111 (Run 285, Clone 2, Gen 210)
[01:17:18]
[01:17:18] Entering M.D.
[01:17:24] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[01:17:24]
[01:17:24] Calling fah_main args: 14 usage=100
[01:17:24]
[01:17:26] CoreStatus = 63 (99)
[01:17:26] + Error starting Folding@home core.
[01:17:31]
[01:17:31] + Processing work unit
[01:17:31] Core required: FahCore_11.exe
[01:17:31] Core found.
[01:17:31] Working on queue slot 00 [March 24 01:17:31 UTC]
[01:17:31] + Working ...
[01:17:31]
[01:17:31] *------------------------------*
[01:17:31] Folding@Home GPU Core
[01:17:31] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:17:31]
[01:17:31] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:17:31] Build host: amoeba
[01:17:31] Board Type: Nvidia
[01:17:31] Core      :
[01:17:31] Preparing to commence simulation
[01:17:31] - Ensuring status. Please wait.
[01:17:41] - Looking at optimizations...
[01:17:41] - Working with standard loops on this execution.
[01:17:41] Examination of work files indicates 8 consecutive improper terminations of core.
[01:17:41] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[01:17:41] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[01:17:41] - Digital signature verified
[01:17:41]
[01:17:41] Project: 10111 (Run 285, Clone 2, Gen 210)
[01:17:41]
[01:17:41] Entering M.D.
[01:17:47] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[01:17:47]
[01:17:47] Calling fah_main args: 14 usage=100
[01:17:47]
[01:17:49] CoreStatus = 63 (99)
[01:17:49] + Error starting Folding@home core.
[01:17:54]
[01:17:54] + Processing work unit
[01:17:54] Core required: FahCore_11.exe
[01:17:54] Core found.
[01:17:54] Working on queue slot 00 [March 24 01:17:54 UTC]
[01:17:54] + Working ...
[01:17:55]
[01:17:55] *------------------------------*
[01:17:55] Folding@Home GPU Core
[01:17:55] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:17:55]
[01:17:55] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:17:55] Build host: amoeba
[01:17:55] Board Type: Nvidia
[01:17:55] Core      :
[01:17:55] Preparing to commence simulation
[01:17:55] - Ensuring status. Please wait.
[01:18:04] - Looking at optimizations...
[01:18:04] - Working with standard loops on this execution.
[01:18:04] Examination of work files indicates 8 consecutive improper terminations of core.
[01:18:04] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[01:18:04] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[01:18:04] - Digital signature verified
[01:18:04]
[01:18:04] Project: 10111 (Run 285, Clone 2, Gen 210)
[01:18:04]
[01:18:04] Entering M.D.
[01:18:10] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[01:18:10]
[01:18:10] Calling fah_main args: 14 usage=100
[01:18:10]
[01:18:13] CoreStatus = 63 (99)
[01:18:13] + Error starting Folding@home core.
[01:18:13] - Attempting to download new core...
[01:18:13] + Downloading new core: FahCore_11.exe
[01:18:14] + 10240 bytes downloaded
[01:18:15] + 20480 bytes downloaded
[01:18:16] + 30720 bytes downloaded
[01:18:17] + 40960 bytes downloaded
[01:18:18] + 51200 bytes downloaded
[01:18:18] + 61440 bytes downloaded
[01:18:19] + 71680 bytes downloaded
[01:18:20] + 81920 bytes downloaded
[01:18:21] + 92160 bytes downloaded
[01:18:21] + 102400 bytes downloaded
[01:18:21] + 112640 bytes downloaded
[01:18:21] + 122880 bytes downloaded
[01:18:23] + 133120 bytes downloaded
[01:18:24] + 143360 bytes downloaded
[01:18:25] + 153600 bytes downloaded
[01:18:25] + 163840 bytes downloaded
[01:18:25] + 174080 bytes downloaded
[01:18:26] + 184320 bytes downloaded
[01:18:26] + 194560 bytes downloaded
[01:18:28] + 204800 bytes downloaded
[01:18:29] + 215040 bytes downloaded
[01:18:31] + 225280 bytes downloaded
[01:18:33] + 235520 bytes downloaded
[01:18:33] + 245760 bytes downloaded
[01:18:35] + 256000 bytes downloaded
[01:18:36] + 266240 bytes downloaded
[01:18:37] + 276480 bytes downloaded
[01:18:37] + 286720 bytes downloaded
[01:18:38] + 296960 bytes downloaded
[01:18:40] + 307200 bytes downloaded
[01:18:40] + 317440 bytes downloaded
[01:18:41] + 327680 bytes downloaded
[01:18:42] + 337920 bytes downloaded
[01:18:43] + 348160 bytes downloaded
[01:18:44] + 358400 bytes downloaded
[01:18:44] + 368640 bytes downloaded
[01:18:45] + 378880 bytes downloaded
[01:18:47] + 389120 bytes downloaded
[01:18:48] + 399360 bytes downloaded
[01:18:49] + 409600 bytes downloaded
[01:18:50] + 419840 bytes downloaded
[01:18:50] + 430080 bytes downloaded
[01:18:51] + 440320 bytes downloaded
[01:18:52] + 450560 bytes downloaded
[01:18:53] + 460800 bytes downloaded
[01:18:54] + 471040 bytes downloaded
[01:18:54] + 481280 bytes downloaded
[01:18:54] + 491520 bytes downloaded
[01:18:54] + 501760 bytes downloaded
[01:18:55] + 512000 bytes downloaded
[01:18:56] + 522240 bytes downloaded
[01:18:56] + 532480 bytes downloaded
[01:18:57] + 542720 bytes downloaded
[01:18:58] + 552960 bytes downloaded
[01:18:58] + 563200 bytes downloaded
[01:19:00] + 573440 bytes downloaded
[01:19:01] + 583680 bytes downloaded
[01:19:01] + 593920 bytes downloaded
[01:19:01] + 604160 bytes downloaded
[01:19:03] + 614400 bytes downloaded
[01:19:05] + 624640 bytes downloaded
[01:19:05] + 634880 bytes downloaded
[01:19:06] + 645120 bytes downloaded
[01:19:07] + 655360 bytes downloaded
[01:19:09] + 665067 bytes downloaded
[01:19:09] Verifying core Core_11.fah...
[01:19:09] Signature is VALID
[01:19:09]
[01:19:09] Trying to unzip core FahCore_11.exe
[01:19:09] Decompressed FahCore_11.exe (1908736 bytes) successfully
[01:19:14] + Core successfully engaged
[01:19:19]
[01:19:19] + Processing work unit
[01:19:19] Core required: FahCore_11.exe
[01:19:19] Core found.
[01:19:19] Working on queue slot 00 [March 24 01:19:19 UTC]
[01:19:19] + Working ...
[01:19:19]
[01:19:19] *------------------------------*
[01:19:19] Folding@Home GPU Core
[01:19:19] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:19:19]
[01:19:19] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:19:19] Build host: amoeba
[01:19:19] Board Type: Nvidia
[01:19:19] Core      :
[01:19:19] Preparing to commence simulation
[01:19:19] - Ensuring status. Please wait.
[01:19:29] - Looking at optimizations...
[01:19:29] - Working with standard loops on this execution.
[01:19:29] Examination of work files indicates 8 consecutive improper terminations of core.
[01:19:29] - Expanded 81841 -> 421543 (decompressed 515.0 percent)
[01:19:29] Called DecompressByteArray: compressed_data_size=81841 data_size=421543, decompressed_data_size=421543 diff=0
[01:19:29] - Digital signature verified
[01:19:29]
[01:19:29] Project: 10111 (Run 285, Clone 2, Gen 210)
[01:19:29]
[01:19:29] Entering M.D.
[01:19:35] Tpr hash work/wudata_00.tpr:  349696724 1839411771 821656865 376101288 2769193569
[01:19:35]
[01:19:35] Calling fah_main args: 14 usage=100
[01:19:35]
[01:19:37] CoreStatus = 63 (99)
[01:19:37] + Error starting Folding@home core.
[01:19:42]
[01:19:42] + Processing work unit
[01:19:42] Core required: FahCore_11.exe
[01:19:42] Core found.
[01:19:42] Working on queue slot 00 [March 24 01:19:42 UTC]
[01:19:42] + Working ...
[01:19:42]
[01:19:42] *------------------------------*
[01:19:42] Folding@Home GPU Core
[01:19:42] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[01:19:42]
[01:19:42] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:19:42] Build host: amoeba
[01:19:42] Board Type: Nvidia
[01:19:42] Core      :
[01:19:42] Preparing to commence simulation
[01:19:42] - Ensuring status. Please wait.
Unfortunately, you didn't since you have the queue.dat file:
Can you do this:
For Systray Version:
Step A: Press Windows Key + R to open Run window
Step B: Type this %APPDATA% (with the % sign) and press enter
Step C: A window will appear (C:\Users\[username]\AppData\Roaming\ OR C:\Documents and Settings\[username]\Application Data\) and there you have to delete a folder called "Folding@Home-gpu"
Step D: Delete any shortcuts you have made
Hopefully, you will be able to delete the previous queue.dat file. Since your GPU is a Fermi one, it will only use FahCore_15
Haitch
Post by Haitch »
fihsboy,
It doesn't look like you deleted the queue.dat and work files - the client is loading the existing queue and work files.
Stop the client, from the Start menu go to FAH@Home folder, then select "Folding@home data files - expert only". From the Explorer window that opens, delete queue.dat and the work directory.
Restart the client.
H.
fihsboy
Post by fihsboy »
Well, that did it! Thank you! Running like a champ. I appreciate all the help!!
fihsboy
Post by fihsboy »
Last question, can I run the GPU client and the CPU client at the same time? Without hindering performance from either?
You can run them both at the same time but they will compete with each other to an unknown extent. It actually depends on your configuration and to some extent on the WUs being assigned. I'm willing to guess that running both at the same time will net more points than running either one alone, especially with the GTX460 GPU (It tends to steal very little from the CPU client but you need to set it to a higher priority than the CPU client.)
justjohn
Post by justjohn »
fihsboy, you do know about the SMP client, right? Odds are that you have multiple CPU cores, that will use them all just running one program.
fihsboy
Post by fihsboy »
It works, I just jumped from 244000 to 190000 donor rank in one day. 23 hours...works nicely. Now I just need to up the ante and hook up the rest of the computers in my house.
