[03:49:03] - Preparing to get new work unit...
[03:49:03] + Attempting to get work packet
[03:49:03] - Will indicate memory of 2048 MB
[03:49:03] - Connecting to assignment server
[03:49:03] Connecting to http://assign.stanford.edu:8080/
[03:49:04] Posted data.
[03:49:04] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[03:49:04] + News From Folding@Home: Welcome to Folding@Home
[03:49:05] Loaded queue successfully.
[03:49:05] Connecting to http://171.64.65.62:8080/
[03:49:06] Posted data.
[03:49:06] Initial: 0000; - Receiving payload (expected size: 507990)
[03:49:08] - Downloaded at ~248 kB/s
[03:49:08] - Averaged speed for that direction ~188 kB/s
[03:49:08] + Received work.
[03:49:08] Trying to send all finished work units
[03:49:08] + No unsent completed units remaining.
[03:49:08] + Closed connections
[03:49:08]
[03:49:08] + Processing work unit
[03:49:08] Core required: FahCore_78.exe
[03:49:08] Core found.
[03:49:08] Working on queue slot 02 [March 18 03:49:08 UTC]
[03:49:08] + Working ...
[03:49:08] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -nocpulock -checkpoint 30 -service -forceasm -verbose -lifeline 3276 -version 623'
[03:49:08]
[03:49:08] *------------------------------*
[03:49:08] Folding@Home Gromacs Core
[03:49:08] Version 1.90 (March 8, 2006)
[03:49:08]
[03:49:08] Preparing to commence simulation
[03:49:08] - Assembly optimizations manually forced on.
[03:49:08] - Not checking prior termination.
[03:49:09] - Expanded 507478 -> 2515965 (decompressed 495.7 percent)
[03:49:09] - Starting from initial work packet
[03:49:09]
[03:49:09] Project: 6515 (Run 2, Clone 233, Gen 33)
[03:49:09]
[03:49:09] Assembly optimizations on if available.
[03:49:09] Entering M.D.
[03:49:15] Protein: 1CFC_A_3 in water
[03:49:15]
[03:49:15] Writing local files
[03:49:15] Extra SSE boost OK.
[03:49:15] Completed 0 out of 250000 steps (0%)
[03:55:57] Gromacs cannot continue further.
[03:55:57] Going to send back what have done.
[03:55:57] logfile size: 8380
[03:55:57] - Writing 8916 bytes of core data to disk...
[03:55:57] Done: 8404 -> 3210 (compressed to 38.1 percent)
[03:55:57] ... Done.
[03:55:57]
[03:55:57] Folding@home Core Shutdown: EARLY_UNIT_END
[03:56:01] CoreStatus = 72 (114)
[03:56:01] Sending work to server
[03:56:01] Project: 6515 (Run 2, Clone 233, Gen 33)
[03:56:01] - Read packet limit of 540015616... Set to 524286976.
[03:56:01] + Attempting to send results [March 18 03:56:01 UTC]
[03:56:01] - Reading file work/wuresults_02.dat from core
[03:56:01] (Read 3722 bytes from disk)
[03:56:01] Connecting to http://171.64.65.62:8080/
[03:56:02] Posted data.
[03:56:02] Initial: 0000; - Uploaded at ~4 kB/s
[03:56:02] - Averaged speed for that direction ~27 kB/s
[03:56:02] + Results successfully sent
[03:56:02] Thank you for your contribution to Folding@Home.
