- Gigabyte MA790X-UD4P mobo
- 4GB RAM
- EVGA GTS450SC
- EVGA GTS450
- 2 console clients v6.31
- HFM.net v0.4.8 rev121
- Process Lasso Pro v4.00.33
-Win7 Home Premium
I eventually got the SP1 upgrade to "stick" (after 4 or 5 tries at least) ... but it took help from some friends and a few phone calls with Microsoft support. Now the only problem is that the folding performance from the 2 GPUs is erratic ... sometimes at 99% + 99% ... and sometimes at 51% and 54% or sometimes 58% + 62%.
It the process of getting SP1 to actually complete its install, MS Support had me do an 'in place upgrade" (running Win7 install disk while in Win7 (still running)).
I had to reinstall the nVidia driver (v8.17.12.6658) after the "in place upgrade" and again after SP1 actually installed.
On my 3 machines I installed SP1 from the whole file (downloaded version from MS's site) and it was only on the AMD X4 940 machine that I had the problem. The failure would happen at the end when the machine rebooted and Sp1 was configuring ... after 2% or so it would say it had "failed" and was reverting.
I wound up (suggestion from a friend, not actually from MS Support) disabling almost everything in msconfig's StartUp and Processes tabs (except Virtual Disk). And another friend suggested temporarily disabling in Device Manager, one of my two Fermi cards ... "just in case". SP1 then stuck !
Anyway ever since, for several days, I have been getting this erratic usage of my 2 Fermi cards. Right now they are at 51% and 52%. A half hour ago they were at 99% and 99%.
Thanks for any insights !
