Project: 2692 (Run 1, Clone 27, Gen 79) faulting
sfield
Post by sfield »
Faulted at 0%. Non-overclocked system with ECC memory. Unfortunately, I didn't capture the WU for diagnostics before clicking OK to dismiss the dialog. Client didn't try to pull this WU again (over a day passed before I noticed this).
[07:35:09] Project: 2692 (Run 1, Clone 27, Gen 79)
[07:35:09]
[07:35:09] Assembly optimizations on if available.
[07:35:09] Entering M.D.
[07:35:21] Completed 0 out of 250000 steps  (0%)
[17:09:05] CoreStatus = C0000029 (-1073741783)
[17:09:05] Client-core communications error: ERROR 0xc0000029
[17:09:05] Deleting current work unit & continuing...
Re: Project: 2692 (Run 1, Clone 27, Gen 79) faulting
No data in the WU Database yet so I have marked it for a follow-up.
When you make a report like that, be sure to include the header information containing the Core title and version number.
The WU folded successfully:
Your WU (P2692 R1 C27 G79) was added to the stats database on 2011-03-19 09:10:49 for 61494 points of credit.
