Having issues with GPU client
AnnmarieD
Post by AnnmarieD »
Long time member of Team Helix here but a first timer running the GPU client. I have been getting various errors since I installed the client. Not sure if this is an NVIDIA issue but I was advised to post in this forum first just in case.
If you would like to see my original thread I posted at DSLReports in the Computing Club Team Helix Forum - GPUing, lots of WUing but no return.
I post that because I put a lot of the destails there that I may miss here and I cannot post the link being a new member here. :)
Sorry if this is too much info.
I have a tri core AMD Phenom chip that is running two instances of the no nonsense F@H client. No issue there.Graphics card is an NVIDIA 8600GT.
Downloaded and did a clean install of the latest drivers as described at the NVIDIA site specificall for the card and system I have. No overclocking.
Downloaded and install this client: Folding@home-Win32-GPU-systray-641.msi
Things were wuing right along but after a while I noticed my points/production was not increasing. Checked the log files and found several errors - most notably UNSTABLE MACHINE.
Researched here, tried an uninstall of GPU and NVIDIA drivers and reinstall several times with a good cleanup in between. No luck.
Issues on and off for several days and here I am now.
Here is the last part of my log file:
[00:25:33] Timer requesting checkpoint
[00:27:14] Completed 42%
[00:32:53] Completed 43%
[00:38:30] Completed 44%
[00:40:33] Timer requesting checkpoint
[00:44:08] Completed 45%
[00:49:45] Completed 46%
[00:55:23] Completed 47%
[00:55:33] Timer requesting checkpoint
[01:01:00] Completed 48%
[01:01:08] + Working...
[01:06:37] Completed 49%
[01:10:33] Timer requesting checkpoint
[01:12:15] Completed 50%
[01:17:52] Completed 51%
[01:23:30] Completed 52%
[01:25:33] Timer requesting checkpoint
[01:29:07] Completed 53%
[01:34:44] Completed 54%
[01:40:22] Completed 55%
[01:40:33] Timer requesting checkpoint
[01:46:00] Completed 56%
[01:51:37] Completed 57%
[01:55:33] Timer requesting checkpoint
[01:57:14] Completed 58%
[02:02:52] Completed 59%
[02:08:33] Completed 60%
[02:10:33] Timer requesting checkpoint
[02:14:07] Completed 61%
[02:19:44] Completed 62%
[02:25:22] Completed 63%
[02:25:33] Timer requesting checkpoint
[02:30:59] Completed 64%
[02:36:37] Completed 65%
[02:40:33] Timer requesting checkpoint
[02:42:14] Completed 66%
[02:47:51] Completed 67%
[02:53:29] Completed 68%
[02:55:33] Timer requesting checkpoint
[02:58:02] Run: exception thrown during GuardedRun
[02:58:02] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[02:58:02] Going to send back what have done -- stepsTotalG=10000000
[02:58:02] Work fraction=0.6880 steps=10000000.
[02:58:06] logfile size=0 infoLength=0 edr=0 trr=23
[02:58:06] + Opened results file
[02:58:06] - Writing 642 bytes of core data to disk...
[02:58:06] Done: 130 -> 127 (compressed to 97.6 percent)
[02:58:06]   ... Done.
[02:58:07] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[02:58:07]
[02:58:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[02:58:11] CoreStatus = 7A (122)
[02:58:11] Sending work to server
[02:58:11] Project: 10112 (Run 587, Clone 1, Gen 85)
[02:58:11] + Attempting to send results [March 11 02:58:11 UTC]
[02:58:11] Gpu type=2 species=11.
[02:58:11] + Results successfully sent
[02:58:11] Thank you for your contribution to Folding@Home.
[02:58:15] - Preparing to get new work unit...
[02:58:15] Cleaning up work directory
[02:58:15] + Attempting to get work packet
[02:58:15] Gpu type=2 species=11.
[02:58:15] - Connecting to assignment server
[02:58:17] - Successful: assigned to (171.64.65.71).
[02:58:17] + News From Folding@Home: Welcome to Folding@Home
[02:58:17] Loaded queue successfully.
[02:58:17] Gpu type=2 species=11.
[02:58:18] + Closed connections
[02:58:23]
[02:58:23] + Processing work unit
[02:58:23] Core required: FahCore_11.exe
[02:58:23] Core found.
[02:58:23] Working on queue slot 06 [March 11 02:58:23 UTC]
[02:58:23] + Working ...
[02:58:23]
[02:58:23] *------------------------------*
[02:58:23] Folding@Home GPU Core
[02:58:23] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[02:58:23]
[02:58:23] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[02:58:23] Build host: amoeba
[02:58:23] Board Type: Nvidia
[02:58:23] Core      :
[02:58:23] Preparing to commence simulation
[02:58:23] - Looking at optimizations...
[02:58:23] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[02:58:23] - Created dyn
[02:58:23] - Files status OK
[02:58:23] - Expanded 81825 -> 421543 (decompressed 515.1 percent)
[02:58:23] Called DecompressByteArray: compressed_data_size=81825 data_size=421543, decompressed_data_size=421543 diff=0
[02:58:23] - Digital signature verified
[02:58:23]
[02:58:23] Project: 10111 (Run 43, Clone 0, Gen 177)
[02:58:23]
[02:58:23] Assembly optimizations on if available.
[02:58:23] Entering M.D.
[02:58:30] Tpr hash work/wudata_06.tpr:  1323862141 3404692644 2922037951 3841567336 3604032537
[02:58:30]
[02:58:30] Calling fah_main args: 14 usage=100
[02:58:30]
[02:58:30] Working on 1174 p10111_ubiquitin_300K
[02:58:32] Client config found, loading data.
[02:58:33] Starting GUI Server
[03:04:03] Completed 1%
[03:09:40] Completed 2%
[03:15:18] Completed 3%
[03:20:55] Completed 4%
[03:26:33] Completed 5%
[03:32:10] Completed 6%
[03:37:47] Completed 7%
[03:43:25] Completed 8%
[03:49:02] Completed 9%
[03:54:39] Completed 10%
[04:00:17] Completed 11%
[04:05:54] Completed 12%
[04:11:32] Completed 13%
[04:17:09] Completed 14%
[04:22:46] Completed 15%
[04:28:24] Completed 16%
[04:34:01] Completed 17%
[04:39:38] Completed 18%
[04:45:16] Completed 19%
[04:50:53] Completed 20%
[04:56:31] Completed 21%
[05:02:08] Completed 22%
[05:07:46] Completed 23%
[05:13:23] Completed 24%
[05:19:00] Completed 25%
[05:24:38] Completed 26%
[05:30:15] Completed 27%
[05:35:52] Completed 28%
[05:41:30] Completed 29%
[05:47:13] Completed 30%
[05:52:45] Completed 31%
[05:58:22] Completed 32%
[06:04:00] Completed 33%
[06:09:44] Completed 34%
[06:15:26] Completed 35%
[06:21:06] Completed 36%
[06:26:46] Completed 37%
[06:32:26] Completed 38%
[06:38:06] Completed 39%
[06:43:46] Completed 40%
[06:49:26] Completed 41%
[06:55:07] Completed 42%
[07:00:47] Completed 43%
[07:01:08] + Working...
[07:06:27] Completed 44%
[07:12:06] Completed 45%
[07:17:46] Completed 46%
[07:23:26] Completed 47%
[07:29:06] Completed 48%
[07:34:46] Completed 49%
[07:40:26] Completed 50%
[07:46:05] Completed 51%
[07:51:45] Completed 52%
[07:57:25] Completed 53%
[08:03:05] Completed 54%
[08:08:45] Completed 55%
[08:14:25] Completed 56%
[08:20:05] Completed 57%
[08:25:45] Completed 58%
[08:31:24] Completed 59%
[08:37:09] Completed 60%
[08:42:44] Completed 61%
[08:48:24] Completed 62%
[08:54:04] Completed 63%
[08:59:44] Completed 64%
[09:05:24] Completed 65%
[09:11:04] Completed 66%
[09:16:44] Completed 67%
[09:22:24] Completed 68%
[09:23:39] Run: exception thrown during GuardedRun
[09:23:39] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[09:23:39] Going to send back what have done -- stepsTotalG=10000000
[09:23:39] Work fraction=0.6822 steps=10000000.
[09:23:43] logfile size=0 infoLength=0 edr=0 trr=23
[09:23:43] + Opened results file
[09:23:43] - Writing 642 bytes of core data to disk...
[09:23:43] Done: 130 -> 127 (compressed to 97.6 percent)
[09:23:43]   ... Done.
[09:23:43] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[09:23:43]
[09:23:43] Folding@home Core Shutdown: EARLY_UNIT_END
[09:23:48] CoreStatus = 72 (114)
[09:23:48] Sending work to server
[09:23:48] Project: 10111 (Run 43, Clone 0, Gen 177)
[09:23:48] + Attempting to send results [March 11 09:23:48 UTC]
[09:23:48] Gpu type=2 species=11.
[09:23:48] + Results successfully sent
[09:23:48] Thank you for your contribution to Folding@Home.
[09:23:52] - Preparing to get new work unit...
[09:23:52] Cleaning up work directory
[09:23:52] + Attempting to get work packet
[09:23:52] Gpu type=2 species=11.
[09:23:52] - Connecting to assignment server
[09:23:53] - Successful: assigned to (171.64.65.71).
[09:23:53] + News From Folding@Home: Welcome to Folding@Home
[09:23:53] Loaded queue successfully.
[09:23:53] Gpu type=2 species=11.
[09:23:54] + Closed connections
[09:23:59]
[09:23:59] + Processing work unit
[09:23:59] Core required: FahCore_11.exe
[09:23:59] Core found.
[09:23:59] Working on queue slot 07 [March 11 09:23:59 UTC]
[09:23:59] + Working ...
[09:23:59]
[09:23:59] *------------------------------*
[09:23:59] Folding@Home GPU Core
[09:23:59] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[09:23:59]
[09:23:59] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:23:59] Build host: amoeba
[09:23:59] Board Type: Nvidia
[09:23:59] Core      :
[09:23:59] Preparing to commence simulation
[09:23:59] - Looking at optimizations...
[09:23:59] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[09:23:59] - Created dyn
[09:23:59] - Files status OK
[09:23:59] - Expanded 81887 -> 421543 (decompressed 514.7 percent)
[09:23:59] Called DecompressByteArray: compressed_data_size=81887 data_size=421543, decompressed_data_size=421543 diff=0
[09:23:59] - Digital signature verified
[09:23:59]
[09:23:59] Project: 10117 (Run 188, Clone 1, Gen 10)
[09:23:59]
[09:23:59] Assembly optimizations on if available.
[09:23:59] Entering M.D.
[09:24:05] Tpr hash work/wudata_07.tpr:  2701880875 2579153593 3431504761 3381814208 3505570294
[09:24:05]
[09:24:05] Calling fah_main args: 14 usage=100
[09:24:05]
[09:24:06] Working on 1174 p10117_ubiquitin_300K
[09:24:06] mdrun_gpu returned
[09:24:06] Going to send back what have done -- stepsTotalG=0
[09:24:06] Work fraction=0.0000 steps=0.
[09:24:10] logfile size=0 infoLength=0 edr=0 trr=25
[09:24:10] + Opened results file
[09:24:10] - Writing 637 bytes of core data to disk...
[09:24:10] Done: 125 -> 124 (compressed to 99.2 percent)
[09:24:10]   ... Done.
[09:24:10] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[09:24:10]
[09:24:10] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:24:13] CoreStatus = 7A (122)
[09:24:13] Sending work to server
[09:24:13] Project: 10117 (Run 188, Clone 1, Gen 10)
[09:24:13] + Attempting to send results [March 11 09:24:13 UTC]
[09:24:13] Gpu type=2 species=11.
[09:24:14] + Results successfully sent
[09:24:14] Thank you for your contribution to Folding@Home.
[09:24:18] - Preparing to get new work unit...
[09:24:18] Cleaning up work directory
[09:24:18] + Attempting to get work packet
[09:24:18] Gpu type=2 species=11.
[09:24:18] - Connecting to assignment server
[09:24:18] - Successful: assigned to (171.64.65.71).
[09:24:18] + News From Folding@Home: Welcome to Folding@Home
[09:24:19] Loaded queue successfully.
[09:24:19] Gpu type=2 species=11.
[09:24:19] + Closed connections
[09:24:24]
[09:24:24] + Processing work unit
[09:24:24] Core required: FahCore_11.exe
[09:24:24] Core found.
[09:24:24] Working on queue slot 08 [March 11 09:24:24 UTC]
[09:24:24] + Working ...
[09:24:25]
[09:24:25] *------------------------------*
[09:24:25] Folding@Home GPU Core
[09:24:25] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[09:24:25]
[09:24:25] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:24:25] Build host: amoeba
[09:24:25] Board Type: Nvidia
[09:24:25] Core      :
[09:24:25] Preparing to commence simulation
[09:24:25] - Looking at optimizations...
[09:24:25] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[09:24:25] - Created dyn
[09:24:25] - Files status OK
[09:24:25] - Expanded 81854 -> 421543 (decompressed 514.9 percent)
[09:24:25] Called DecompressByteArray: compressed_data_size=81854 data_size=421543, decompressed_data_size=421543 diff=0
[09:24:25] - Digital signature verified
[09:24:25]
[09:24:25] Project: 10111 (Run 493, Clone 0, Gen 170)
[09:24:25]
[09:24:25] Assembly optimizations on if available.
[09:24:25] Entering M.D.
[09:24:31] Tpr hash work/wudata_08.tpr:  4071360819 2319094084 2743999039 1087348469 114873146
[09:24:31]
[09:24:31] Calling fah_main args: 14 usage=100
[09:24:31]
[09:24:31] Working on 1174 p10111_ubiquitin_300K
[09:24:31] mdrun_gpu returned
[09:24:31] Going to send back what have done -- stepsTotalG=0
[09:24:31] Work fraction=0.0000 steps=0.
[09:24:35] logfile size=0 infoLength=0 edr=0 trr=25
[09:24:35] + Opened results file
[09:24:35] - Writing 637 bytes of core data to disk...
[09:24:35] Done: 125 -> 124 (compressed to 99.2 percent)
[09:24:35]   ... Done.
[09:24:35] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[09:24:35]
[09:24:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:24:39] CoreStatus = 7A (122)
[09:24:39] Sending work to server
[09:24:39] Project: 10111 (Run 493, Clone 0, Gen 170)
[09:24:39] + Attempting to send results [March 11 09:24:39 UTC]
[09:24:39] Gpu type=2 species=11.
[09:24:39] + Results successfully sent
[09:24:39] Thank you for your contribution to Folding@Home.
[09:24:43] - Preparing to get new work unit...
[09:24:43] Cleaning up work directory
[09:24:43] + Attempting to get work packet
[09:24:43] Gpu type=2 species=11.
[09:24:43] - Connecting to assignment server
[09:24:44] - Successful: assigned to (171.64.65.71).
[09:24:44] + News From Folding@Home: Welcome to Folding@Home
[09:24:44] Loaded queue successfully.
[09:24:44] Gpu type=2 species=11.
[09:24:45] + Closed connections
[09:24:50]
[09:24:50] + Processing work unit
[09:24:50] Core required: FahCore_11.exe
[09:24:50] Core found.
[09:24:50] Working on queue slot 09 [March 11 09:24:50 UTC]
[09:24:50] + Working ...
[09:24:50]
[09:24:50] *------------------------------*
[09:24:50] Folding@Home GPU Core
[09:24:50] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[09:24:50]
[09:24:50] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:24:50] Build host: amoeba
[09:24:50] Board Type: Nvidia
[09:24:50] Core      :
[09:24:50] Preparing to commence simulation
[09:24:50] - Looking at optimizations...
[09:24:50] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[09:24:50] - Created dyn
[09:24:50] - Files status OK
[09:24:50] - Expanded 82008 -> 425170 (decompressed 518.4 percent)
[09:24:50] Called DecompressByteArray: compressed_data_size=82008 data_size=425170, decompressed_data_size=425170 diff=0
[09:24:50] - Digital signature verified
[09:24:50]
[09:24:50] Project: 10112 (Run 384, Clone 0, Gen 145)
[09:24:50]
[09:24:50] Assembly optimizations on if available.
[09:24:50] Entering M.D.
[09:24:56] Tpr hash work/wudata_09.tpr:  3176219875 4095425337 1319317224 1700102026 2458015174
[09:24:56]
[09:24:56] Calling fah_main args: 14 usage=100
[09:24:56]
[09:24:57] Working on 1174 p10112_ubiquitin_300K
[09:24:57] mdrun_gpu returned
[09:24:57] Going to send back what have done -- stepsTotalG=0
[09:24:57] Work fraction=0.0000 steps=0.
[09:25:01] logfile size=0 infoLength=0 edr=0 trr=25
[09:25:01] + Opened results file
[09:25:01] - Writing 637 bytes of core data to disk...
[09:25:01] Done: 125 -> 124 (compressed to 99.2 percent)
[09:25:01]   ... Done.
[09:25:01] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[09:25:01]
[09:25:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:25:05] CoreStatus = 7A (122)
[09:25:05] Sending work to server
[09:25:05] Project: 10112 (Run 384, Clone 0, Gen 145)
[09:25:05] + Attempting to send results [March 11 09:25:05 UTC]
[09:25:05] Gpu type=2 species=11.
[09:25:05] + Results successfully sent
[09:25:05] Thank you for your contribution to Folding@Home.
[09:25:09] - Preparing to get new work unit...
[09:25:09] Cleaning up work directory
[09:25:09] + Attempting to get work packet
[09:25:09] Gpu type=2 species=11.
[09:25:09] - Connecting to assignment server
[09:25:10] - Successful: assigned to (171.64.65.71).
[09:25:10] + News From Folding@Home: Welcome to Folding@Home
[09:25:10] Loaded queue successfully.
[09:25:10] Gpu type=2 species=11.
[09:25:11] + Closed connections
[09:25:16]
[09:25:16] + Processing work unit
[09:25:16] Core required: FahCore_11.exe
[09:25:16] Core found.
[09:25:16] Working on queue slot 00 [March 11 09:25:16 UTC]
[09:25:16] + Working ...
[09:25:16]
[09:25:16] *------------------------------*
[09:25:16] Folding@Home GPU Core
[09:25:16] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[09:25:16]
[09:25:16] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[09:25:16] Build host: amoeba
[09:25:16] Board Type: Nvidia
[09:25:16] Core      :
[09:25:16] Preparing to commence simulation
[09:25:16] - Looking at optimizations...
[09:25:16] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[09:25:16] - Created dyn
[09:25:16] - Files status OK
[09:25:16] - Expanded 81914 -> 425170 (decompressed 519.0 percent)
[09:25:16] Called DecompressByteArray: compressed_data_size=81914 data_size=425170, decompressed_data_size=425170 diff=0
[09:25:16] - Digital signature verified
[09:25:16]
[09:25:16] Project: 10112 (Run 5, Clone 0, Gen 152)
[09:25:16]
[09:25:16] Assembly optimizations on if available.
[09:25:16] Entering M.D.
[09:25:22] Tpr hash work/wudata_00.tpr:  2046641682 2269639626 633751165 2078774851 1032361568
[09:25:22]
[09:25:22] Calling fah_main args: 14 usage=100
[09:25:22]
[09:25:22] Working on 1174 p10112_ubiquitin_300K
[09:25:22] mdrun_gpu returned
[09:25:22] Going to send back what have done -- stepsTotalG=0
[09:25:22] Work fraction=0.0000 steps=0.
[09:25:27] logfile size=0 infoLength=0 edr=0 trr=25
[09:25:27] + Opened results file
[09:25:27] - Writing 637 bytes of core data to disk...
[09:25:27] Done: 125 -> 123 (compressed to 98.4 percent)
[09:25:27]   ... Done.
[09:25:27] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[09:25:27]
[09:25:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[09:25:30] CoreStatus = 7A (122)
[09:25:30] Sending work to server
[09:25:30] Project: 10112 (Run 5, Clone 0, Gen 152)
[09:25:30] + Attempting to send results [March 11 09:25:30 UTC]
[09:25:30] Gpu type=2 species=11.
[09:25:31] + Results successfully sent
[09:25:31] Thank you for your contribution to Folding@Home.
[09:25:35] EUE limit exceeded. Pausing 24 hours.
I have paused the client.
Re: Project: 10112 (Run 229, Clone 1, Gen 119) - Missing Poi
Pausing the client is the right thing to do until we figure this out. You're earning few, if any points, and you're not producing any useful science.
One likely candidate is bad hardware. Have you run MemtestG80 on that GPU? See http://folding.stanford.edu/English/DownloadUtils
One of my favorite Mods hangs out over there and she's probably helped you with a lot of things I might suggest.
AnnmarieD
Post by AnnmarieD »
Running MemtestG80right now. So far no errors up to iteration 12. Will post back upon completion.
sortofageek
Post by sortofageek »
I don't even know what a GPU looks like yet, Bruce. Someday, maybe, but I really can't be much help with this if my economy ever smiles on me again.
I directed her to this section because I thought I saw one she completed and sent home successfully, couldn't see the result in the database. I was rushing through the forum so quickly I missed the part about the server having a problem with the WU.
Sorry, Annmarie, but you're in excellent hands here.
AnnmarieD
Post by AnnmarieD »
As long as you say it's OK sorto - I don't want to tick you off being a Mod here and all. ;-)
Anyway - the mem test completed and the screen flicked off - no errors found but I have no log of that to post.
Welcome to the F@H Forum AnnmarieD,
Have you read the troubleshooting post (viewtopic.php?f=59&t=15196&start=15#p160068)? Also, can you please tell us what OS you're using and Drivers?
sortofageek
Re: Having issues with GPU client
You couldn't tick me off if you tried, AM. This is great! PantherX is on it! :D
I'll just go sweep up around some posts now, look busy. :wink:
AnnmarieD
Post by AnnmarieD »
266.58 whql driver for the graphics card from the NVIDIA website after choosing all the specific details for that card.
I am reading through the troubleshooting guide but am running out of time here in NY. I will have to rerun the memory tests again in the morning.
That troubleshooting guide is for the GPU3 Beta. I am running the GPU2 if that makes a difference.
I have read your thread on the other Forum (http://www.dslreports.com/forum/r255890 ... -no-return).
The GPU Client that you're using is actually GPU3 v6.41r2 (from the FAHlog that you have posted in this and the other thread) while the GPU2 Client is v6.23 so what is the current Client that you're running (or want to run)? For your GPU, you can use either one.
For the GPU to fold, you only need the Nvidia Driver to be installed. There isn't any need to download the CUDA toolkit or anything. Since you have been experimenting with different drivers, I would suggest that you download and install Driver Sweeper (links and instructions in my Guide) and install the latest Drivers. If you want, you can install the 258.96 WHQL Drivers which is recommended by the developers.
I believe that you're running the Systray version. Since you are already running the Console version, I would suggest that you get the Console version of GPU3 (or GPU2 if you want) and run that. However, I have heard that the latest Console for GPU3 is a drop-in replacement so you can download the older one (link in my GPU Guide) and then replace the .exe file with the latest one.
Also, can you tell us what temperature does your GPU reach while folding? Is the intake vent and fan clean or is it clogged up from dust?
HendricksSA
Post by HendricksSA »
AnnmarieD, welcome to the Fold. I can see one problem that could be stopping you. I don't know nVida architectures, but the 8600 is probably a compute capability 1.0 card. With the 6.41r2 client, you're showing compute capability 1.1 (species 11). There is a new flag to be used with your card and the new version of the client. If you can read through this topic, it should help you out. Check out viewtopic.php?f=50&t=17879
I'm afraid it has bad news if my conclusion is right but the seniors here have the final call. I don't think your card will be able to process the 1011x work units. Again, I'm not an expert on card power vs atoms. Bruce or PantherX is that sort of person!
HendricksSA wrote:AnnmarieD, welcome to the Fold. I can see one problem that could be stopping you. I don't know nVida architectures, but the 8600 is probably a compute capability 1.0 card. With the 6.41r2 client, you're showing compute capability 1.1 (species 11). There is a new flag to be used with your card and the new version of the client. If you can read through this topic, it should help you out. Check out viewtopic.php?f=50&t=17879
Actually, the 8600GT is Compute Capability 1.1 (http://en.wikipedia.org/wiki/CUDA#Supported_GPUs) so in theory it should be able to fold FahCore_15 WUs. However, since the WU is FahCore_11 (according to the FAHlogs) which is giving errors, it is weird. It could be due to leftover driver files or something.
BTW, most troubleshooting steps work regardless of the GPU3 or GPU2 Client. If you have any doubts of a particular step, feel free to ask and we will clarify it for you.
Fahrenheit451
Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB
Post by Fahrenheit451 »
You should give the GPU2 6.23 console client a try. For my 8800GTS 512 (G92) it's the the only client which runs stable.
Or your 8600 GT (G84) is defective (see http://www.tomshardware.com/news/nvidia ... ,6121.html and http://en.wikipedia.org/wiki/GeForce_8_Series).
HendricksSA
Fahrenheit451, are you able to process 1011x work units? If so, do you have any idea about the shader count on your card vs. AnnmarieD's? I usually just assume the 8xxx series cards are older cards and therefore compute 1.0 devices. However, I've got PantherX to keep me honest and I will have to do my homework in the future. I'm wondering if the 8xxx series cards are having problems with the bigger work units?
AnnmarieD
Post by AnnmarieD »
I am having a heck of a time replying here even with no long or links.
Going to try this again.
AnnmarieD
Post by AnnmarieD »
OK here is my real reply. Let me see if it will post
I am going to attempt to reconstruct what I did AFTER I noticed things were going wrong:
In the Control Panel Add/Remove Programs I uninstalled the CUDA Toolkit and Folding@Home Win32 gpu.
I rebooted.
I ran CCLeaner several times in there to pick up any bits and pieces and I did run the DriveSweeper_210 after I uninstalled the toolkit.
I downloaded and installed 266.58 whql driver for the graphics card from the NVIDIA website using there "how to find what driver is right for my card page".
I rebooted.
I downloaded, installed and configured Folding@Home -Win32 GPU systray 641 simply adding my name and team number - no flags - just plain vanilla.
My fans and intake are quite clean but I cannot tell you the temp of my CPU when folding since I quit. I will restart folding and post back.
In the mean time - is there a step by step that I can follow? I am getting a bit confused as to what to uninstall, install, try and not.
I confuse easily. :)
I would like to clean out everything and start from scratch.
Also, when I uninstall a driver how the heck to I stop Windows from installing a new driver upon boot up?
