Hi there.
So I am coming back to this project now that I have more of a means to participate. I want to use the username I used before (mrkvchm), but the stats are not updating at all so far. Could this be because I have a password on the account? I dont remember setting one, but maybe now that I'm using a blank password, the stats won't update. Is there a way of reseting my account to have no password? Or a way of checking if there even is a password?
Also, when are stats supposed to update? Will they only change at the end of a WU, or would they update slowly throughout the whole process?
Also, Before, I folded for team EVGA. I now have a different team I would like to fold for. Is the change as simple as changing the team number in the clients? Because I did that, but that too has not been reflected on my account stats page.
Sorry for all the n00b questions, but thanks in advance for the help!
EDIT: So my page started updating, and I found the answer to my last question after a more thorough look at the FAQ. So I'm all good now, nothing left to see here lol. Thanks guys.
Forgot passkey. Am I screwed? - Resolved
Re: Forgot passkey. Am I screwed?
If the username is the same, there isn't any issue if you're using the passkey or not (however we strongly recommend that you use the passkey for security reasons). There are donors who are using the passkey on their SMP Client but not on their GPU Client and their stats update normally without any issue since both the clients are configured with the same username.
The official stats update every hour unless there is a server glitch or something. Third party stats follow their own schedule.
You just have to enter the correct team number and that's it. Your official Stats will show that you have contributed with more than 1 team.
BTW, can you please post your FAHlog showing that you have successfully folded and returned the WU (viewtopic.php?p=160884#p160884)?
Welcome to the forum, mrkvchm.
Passkey is not a password. There are no passwords on fah.
And if you put in the same user name and email address as last time in to the passkey request page, they'll send you the same passkey again. It's never lost.
[00:43:57] + 5171200 bytes downloaded
[00:43:57] + 5181440 bytes downloaded
[00:43:57] + 5191680 bytes downloaded
[00:43:57] + 5194559 bytes downloaded
[00:43:57] Verifying core Core_b4.fah...
[00:43:57] Signature is VALID
[00:43:57]
[00:43:57] Trying to unzip core FahCore_b4.exe
[00:44:01] Decompressed FahCore_b4.exe (16636416 bytes) successfully
[00:44:06] + Core successfully engaged
[00:44:11]
[00:44:11] + Processing work unit
[00:44:11] Core required: FahCore_b4.exe
[00:44:11] Core found.
[00:44:11] Working on queue slot 01 [March 9 00:44:11 UTC]
[00:44:11] + Working ...
[00:44:14] *********************** Log Started 09/Mar/2011 00:44:14 ***********************
[00:44:14] ************************** ProtoMol Folding@Home Core **************************
[00:44:14] Version: 25
[00:44:14] Type: 180
[00:44:14] Core: ProtoMol
[00:44:14] Website: http://folding.stanford.edu/
[00:44:14] Copyright: (c) 2009 Stanford University
[00:44:14] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[00:44:14] Args: -dir work/ -suffix 01 -nice 19 -checkpoint 15 -lifeline 4080 -version
[00:44:14] 634
[00:44:14] ************************************ Build *************************************
[00:44:14] Date: May 18 2010
[00:44:14] Time: 23:43:52
[00:44:14] Revision: 1819
[00:44:14] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[00:44:14] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[00:44:14] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[00:44:14] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[00:44:14] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[00:44:14] Platform: Windows XP
[00:44:14] Bits: 32
[00:44:14] Mode: Release
[00:44:14] ************************************ System ************************************
[00:44:14] OS: Microsoft Windows 7 Ultimate
[00:44:14] CPU: Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
[00:44:14] CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
[00:44:14] CPUs: 4 Logical, 1 Physical
[00:44:14] Memory: 6.00 GB
[00:44:14] Threads: Windows
[00:44:14] ********************************************************************************
[00:44:14] Project: 10024 (Run 30, Clone 0, Gen 123)
[00:44:14] Unit: 0x000000d00001329c4bd49b630000756b
[00:44:14] User: 0x00000000000000000000000000000000
[00:44:14] Machine: 1
[00:44:14] Reading tar file par_all27_prot_lipid.inp
[00:44:14] Reading tar file scpismQuartic.inp
[00:44:14] Reading tar file ww.pdb
[00:44:14] Reading tar file ww.psf
[00:44:14] Reading tar file checkpt
[00:44:14] Reading tar file ww.10365.pos
[00:44:14] Reading tar file ww.10365.vel
[00:44:14] Reading tar file protomol.conf
[00:44:14] Reading tar file core.xml
[00:44:14] Digital signatures verified
[00:44:15] Completed 0 out of 499375 steps (0%)
[00:59:28] Completed 5000 out of 499375 steps (1%)
[01:13:58] Completed 10000 out of 499375 steps (2%)
[01:26:56] Completed 15000 out of 499375 steps (3%)
[01:38:48] Completed 20000 out of 499375 steps (4%)
[01:53:24] Completed 25000 out of 499375 steps (5%)
[02:07:47] Completed 30000 out of 499375 steps (6%)
[02:21:08] Completed 35000 out of 499375 steps (7%)
[02:33:18] Completed 40000 out of 499375 steps (8%)
[02:45:26] Completed 45000 out of 499375 steps (9%)
[03:10:30] Completed 50000 out of 499375 steps (10%)
[03:25:02] Completed 55000 out of 499375 steps (11%)
[03:39:10] Completed 60000 out of 499375 steps (12%)
[03:51:15] Completed 65000 out of 499375 steps (13%)
[04:02:29] Completed 70000 out of 499375 steps (14%)
[04:13:28] Completed 74900 out of 499375 steps (14%)
[04:25:34] Completed 79900 out of 499375 steps (16%)
[04:37:35] Completed 84900 out of 499375 steps (17%)
[04:49:46] Completed 89900 out of 499375 steps (18%)
[05:01:25] Completed 94900 out of 499375 steps (19%)
[05:12:54] Completed 99900 out of 499375 steps (20%)
[05:24:37] Completed 104900 out of 499375 steps (21%)
[05:36:58] Completed 109900 out of 499375 steps (22%)
[05:48:52] Completed 114900 out of 499375 steps (23%)
[06:02:49] Completed 119900 out of 499375 steps (24%)
[06:13:58] Completed 124900 out of 499375 steps (25%)
[06:25:11] Completed 129900 out of 499375 steps (26%)
[06:37:05] Completed 134900 out of 499375 steps (27%)
[06:49:00] Completed 139900 out of 499375 steps (28%)
[07:00:43] Completed 144800 out of 499375 steps (28%)
[07:12:23] Completed 149800 out of 499375 steps (29%)
[07:23:45] Completed 154800 out of 499375 steps (30%)
[07:35:09] Completed 159800 out of 499375 steps (32%)
[07:46:37] Completed 164800 out of 499375 steps (33%)
[07:57:48] Completed 169800 out of 499375 steps (34%)
[08:09:17] Completed 174800 out of 499375 steps (35%)
[08:20:50] Completed 179800 out of 499375 steps (36%)
[08:33:01] Completed 184800 out of 499375 steps (37%)
[08:44:19] Completed 189800 out of 499375 steps (38%)
[08:55:38] Completed 194800 out of 499375 steps (39%)
[09:07:00] Completed 199800 out of 499375 steps (40%)
[09:18:40] Completed 204800 out of 499375 steps (41%)
[09:29:54] Completed 209800 out of 499375 steps (42%)
[09:40:38] Completed 214700 out of 499375 steps (42%)
[09:52:05] Completed 219700 out of 499375 steps (43%)
[10:03:43] Completed 224700 out of 499375 steps (44%)
[10:15:23] Completed 229700 out of 499375 steps (45%)
[10:27:05] Completed 234700 out of 499375 steps (46%)
[10:38:50] Completed 239700 out of 499375 steps (48%)
[10:50:36] Completed 244700 out of 499375 steps (49%)
[11:02:02] Completed 249700 out of 499375 steps (50%)
[11:13:44] Completed 254700 out of 499375 steps (51%)
[11:25:42] Completed 259700 out of 499375 steps (52%)
[11:37:26] Completed 264700 out of 499375 steps (53%)
[11:49:05] Completed 269700 out of 499375 steps (54%)
[12:00:53] Completed 274700 out of 499375 steps (55%)
[12:12:42] Completed 279700 out of 499375 steps (56%)
[12:24:54] Completed 284700 out of 499375 steps (57%)
[12:36:41] Completed 289600 out of 499375 steps (57%)
[12:48:19] Completed 294600 out of 499375 steps (58%)
[13:00:21] Completed 299600 out of 499375 steps (59%)
[13:11:50] Completed 304600 out of 499375 steps (60%)
[13:23:36] Completed 309600 out of 499375 steps (61%)
[13:35:15] Completed 314600 out of 499375 steps (62%)
[13:47:08] Completed 319600 out of 499375 steps (64%)
[13:58:50] Completed 324600 out of 499375 steps (65%)
[14:10:34] Completed 329600 out of 499375 steps (66%)
[14:22:30] Completed 334600 out of 499375 steps (67%)
[14:34:41] Completed 339600 out of 499375 steps (68%)
[14:46:20] Completed 344600 out of 499375 steps (69%)
Folding@Home Client Shutdown.
--- Opening Log file [March 9 16:28:35 UTC]
Folding@Home Client Version 6.34
Launch directory: C:\Users\Myles\Desktop\folding\1
Executable: C:\Users\Myles\Desktop\folding\1\FAH6.34-win32-SMP.exe
[16:28:35] - Ask before connecting: No
[16:28:35] - User name: mrkvchm (Team 97103)
[16:28:35] - User ID: 2255BAFC61030934
[16:28:35] - Machine ID: 1
[16:28:35]
[16:28:35] Loaded queue successfully.
[16:28:35]
[16:28:35] + Processing work unit
[16:28:35] Core required: FahCore_b4.exe
[16:28:35] Core found.
[16:28:35] Working on queue slot 01 [March 9 16:28:35 UTC]
[16:28:35] + Working ...
[16:28:39] *********************** Log Started 09/Mar/2011 16:28:38 ***********************
[16:28:39] ************************** ProtoMol Folding@Home Core **************************
[16:28:39] Version: 25
[16:28:39] Type: 180
[16:28:39] Core: ProtoMol
[16:28:39] Website: http://folding.stanford.edu/
[16:28:39] Copyright: (c) 2009 Stanford University
[16:28:39] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[16:28:39] Args: -dir work/ -suffix 01 -nice 19 -checkpoint 15 -lifeline 3728 -version
[16:28:39] 634
[16:28:39] ************************************ Build *************************************
[16:28:39] Date: May 18 2010
[16:28:39] Time: 23:43:52
[16:28:39] Revision: 1819
[16:28:39] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[16:28:39] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[16:28:39] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[16:28:39] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[16:28:39] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[16:28:39] Platform: Windows XP
[16:28:39] Bits: 32
[16:28:39] Mode: Release
[16:28:39] ************************************ System ************************************
[16:28:39] OS: Microsoft Windows 7 Ultimate
[16:28:39] CPU: Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
[16:28:39] CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
[16:28:39] CPUs: 4 Logical, 1 Physical
[16:28:39] Memory: 6.00 GB
[16:28:39] Threads: Windows
[16:28:39] ********************************************************************************
[16:28:39] Project: 10024 (Run 30, Clone 0, Gen 123)
[16:28:39] Unit: 0x000000d00001329c4bd49b630000756b
[16:28:39] User: 0x00000000000000000000000000000000
[16:28:39] Machine: 1
[16:28:39] Digital signatures verified
[16:28:41] Completed 346300 out of 499375 steps (69%)
[16:36:17] Completed 349600 out of 499375 steps (70%)
[16:47:59] Completed 354600 out of 499375 steps (71%)
[16:59:06] Completed 359500 out of 499375 steps (71%)
[17:10:41] Completed 364500 out of 499375 steps (72%)
[17:22:32] Completed 369500 out of 499375 steps (73%)
[17:34:05] Completed 374500 out of 499375 steps (74%)
[17:46:00] Completed 379500 out of 499375 steps (75%)
[17:57:49] Completed 384500 out of 499375 steps (76%)
[18:09:44] Completed 389500 out of 499375 steps (77%)
[18:22:36] Completed 394500 out of 499375 steps (78%)
[18:35:21] Completed 399500 out of 499375 steps (80%)
[18:47:54] Completed 404500 out of 499375 steps (81%)
[18:59:39] Completed 409500 out of 499375 steps (82%)
--- Opening Log file [March 9 23:10:37 UTC]
[23:10:37] - Ask before connecting: No
[23:10:37] - User name: mrkvchm (Team 97103)
[23:10:37] - User ID: 2255BAFC61030934
[23:10:37] - Machine ID: 1
[23:10:37]
[23:10:37] Loaded queue successfully.
[23:10:37]
[23:10:37] + Processing work unit
[23:10:37] Core required: FahCore_b4.exe
[23:10:37] Core found.
[23:10:37] Working on queue slot 01 [March 9 23:10:37 UTC]
[23:10:37] + Working ...
[23:10:41] *********************** Log Started 09/Mar/2011 23:10:41 ***********************
[23:10:41] ************************** ProtoMol Folding@Home Core **************************
[23:10:41] Version: 25
[23:10:41] Type: 180
[23:10:41] Core: ProtoMol
[23:10:41] Website: http://folding.stanford.edu/
[23:10:41] Copyright: (c) 2009 Stanford University
[23:10:41] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[23:10:41] Args: -dir work/ -suffix 01 -nice 19 -checkpoint 15 -lifeline 5048 -version
[23:10:41] 634
[23:10:41] ************************************ Build *************************************
[23:10:41] Date: May 18 2010
[23:10:41] Time: 23:43:52
[23:10:41] Revision: 1819
[23:10:41] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[23:10:41] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[23:10:41] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[23:10:41] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[23:10:41] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[23:10:41] Platform: Windows XP
[23:10:41] Bits: 32
[23:10:41] Mode: Release
[23:10:41] ************************************ System ************************************
[23:10:41] OS: Microsoft Windows 7 Ultimate
[23:10:41] CPU: Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
[23:10:41] CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
[23:10:41] CPUs: 4 Logical, 1 Physical
[23:10:41] Memory: 6.00 GB
[23:10:41] Threads: Windows
[23:10:41] ********************************************************************************
[23:10:41] Project: 10024 (Run 30, Clone 0, Gen 123)
[23:10:41] Unit: 0x000000d00001329c4bd49b630000756b
[23:10:41] User: 0x00000000000000000000000000000000
[23:10:41] Machine: 1
[23:10:41] Digital signatures verified
[23:10:44] Completed 403400 out of 499375 steps (80%)
[23:13:28] Completed 404500 out of 499375 steps (81%)
--- Opening Log file [March 8 23:46:25 UTC]
Launch directory: C:\Users\Myles\Desktop\folding\2
Executable: C:\Users\Myles\Desktop\folding\2\FAH6.34-win32-SMP.exe
[23:46:25] Configuring Folding@Home...
[23:47:08] - Ask before connecting: No
[23:47:08] - User name: mrkvchm (Team 97103)
[23:47:08] - User ID: 2255BAFC61030934
[23:47:08] - Machine ID: 2
[23:47:08]
[23:47:08] Work directory not found. Creating...
[23:47:08] Could not open work queue, generating new queue...
[23:47:08] - Preparing to get new work unit...
[23:47:08] Cleaning up work directory
[23:47:08] + Attempting to get work packet
[23:47:08] - Connecting to assignment server
[23:47:09] - Successful: assigned to (171.67.108.33).
[23:47:09] + News From Folding@Home: Welcome to Folding@Home
[23:47:09] Loaded queue successfully.
[23:48:12] + Could not get Work unit data from Work Server
[23:48:12] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[23:48:28] + Attempting to get work packet
[23:48:28] - Connecting to assignment server
[23:48:29] - Successful: assigned to (171.67.108.33).
[23:48:29] + News From Folding@Home: Welcome to Folding@Home
[23:48:29] Loaded queue successfully.
[23:49:32] + Could not get Work unit data from Work Server
[23:49:32] - Attempt #2 to get work failed, and no other work to do.
[23:49:48] + Attempting to get work packet
[23:49:48] - Connecting to assignment server
[23:50:09] - Couldn't send HTTP request to server
[23:50:09] + Could not connect to Assignment Server
[23:50:10] - Successful: assigned to (171.67.108.33).
[23:50:10] + News From Folding@Home: Welcome to Folding@Home
[23:50:10] Loaded queue successfully.
[23:51:25] + Could not get Work unit data from Work Server
[23:51:25] - Attempt #3 to get work failed, and no other work to do.
[23:51:50] + Attempting to get work packet
[23:51:50] - Connecting to assignment server
[23:51:50] + Could not connect to Assignment Server
[23:51:50] + Could not connect to Assignment Server 2
[23:51:50] + Couldn't get work instructions.
[23:51:50] - Attempt #4 to get work failed, and no other work to do.
--- Opening Log file [March 8 23:53:08 UTC]
[23:53:08] - Ask before connecting: No
[23:53:08] - User name: mrkvchm (Team 97103)
[23:53:08] - User ID: 2255BAFC61030934
[23:53:08] - Machine ID: 2
[23:53:08]
[23:53:08] Loaded queue successfully.
[23:53:08] - Preparing to get new work unit...
[23:53:08] Cleaning up work directory
[23:53:08] + Attempting to get work packet
[23:53:08] - Connecting to assignment server
[23:53:09] - Successful: assigned to (171.67.108.33).
[23:53:09] + News From Folding@Home: Welcome to Folding@Home
[23:53:09] Loaded queue successfully.
[23:54:13] + Could not get Work unit data from Work Server
[23:54:13] - Attempt #1 to get work failed, and no other work to do.
--- Opening Log file [March 9 00:43:47 UTC]
[00:43:47] - Ask before connecting: No
[00:43:47] - User name: mrkvchm (Team 97103)
[00:43:47] - User ID: 2255BAFC61030934
[00:43:47] - Machine ID: 2
[00:43:47]
A potential conflict was detected:
Process 3836 is currently running and may also be a client with Mach. ID 2.
The program will now exit. Upon restart, this check will not be done --
You may wish to check that no client is currently running in
C:\Users\Myles\AppData\Roaming\Folding@home-gpu before restarting.
Please press any key to exit.
--- Opening Log file [March 9 00:44:07 UTC]
[00:44:07] - Ask before connecting: No
[00:44:07] - User name: mrkvchm (Team 97103)
[00:44:07] - User ID: 2255BAFC61030934
[00:44:07] - Machine ID: 2
[00:44:07]
[00:44:07] Loaded queue successfully.
[00:44:07] - Preparing to get new work unit...
[00:44:07] Cleaning up work directory
[00:44:07] + Attempting to get work packet
[00:44:07] - Connecting to assignment server
[00:44:08] - Successful: assigned to (129.74.85.15).
[00:44:08] + News From Folding@Home: Welcome to Folding@Home
[00:44:08] Loaded queue successfully.
[00:44:09] + Closed connections
[00:44:09]
[00:44:09] + Processing work unit
[00:44:09] Core required: FahCore_b4.exe
[00:44:09] Core not found.
[00:44:09] - Core is not present or corrupted.
[00:44:09] - Attempting to download new core...
[00:44:09] + Downloading new core: FahCore_b4.exe
[00:44:09] + 10240 bytes downloaded
[00:44:10] + 20480 bytes downloaded
[00:44:10] + 30720 bytes downloaded
[00:44:10] + 40960 bytes downloaded
[00:44:10] + 51200 bytes downloaded
[00:44:10] + 61440 bytes downloaded
[00:44:10] + 71680 bytes downloaded
[00:44:10] + 81920 bytes downloaded
[00:44:10] + 92160 bytes downloaded
[00:44:10] + 102400 bytes downloaded
[00:44:10] + 112640 bytes downloaded
[00:44:10] + 122880 bytes downloaded
[00:44:10] + 133120 bytes downloaded
[00:44:10] + 143360 bytes downloaded
[00:44:10] + 153600 bytes downloaded
[00:44:10] + 163840 bytes downloaded
[00:44:10] + 174080 bytes downloaded
[00:44:11] + 184320 bytes downloaded
[00:44:11] + 194560 bytes downloaded
[00:44:11] + 204800 bytes downloaded
[00:44:11] + 215040 bytes downloaded
[00:44:11] + 225280 bytes downloaded
[00:44:11] + 235520 bytes downloaded
[00:44:11] + 245760 bytes downloaded
[00:44:11] + 256000 bytes downloaded
[00:44:11] + 266240 bytes downloaded
[00:44:11] + 276480 bytes downloaded
[00:44:11] + 286720 bytes downloaded
[00:44:11] + 296960 bytes downloaded
[00:44:11] + 307200 bytes downloaded
[00:44:11] + 317440 bytes downloaded
[00:44:11] + 327680 bytes downloaded
[00:44:11] + 337920 bytes downloaded
[00:44:11] + 348160 bytes downloaded
[00:44:11] + 358400 bytes downloaded
[00:44:11] + 368640 bytes downloaded
[00:44:11] + 378880 bytes downloaded
[00:44:11] + 389120 bytes downloaded
[00:44:11] + 399360 bytes downloaded
[00:44:11] + 409600 bytes downloaded
[00:44:11] + 419840 bytes downloaded
[00:44:11] + 430080 bytes downloaded
[00:44:11] + 440320 bytes downloaded
[00:44:11] + 450560 bytes downloaded
[00:44:11] + 460800 bytes downloaded
[00:44:11] + 471040 bytes downloaded
[00:44:11] + 481280 bytes downloaded
[00:44:11] + 491520 bytes downloaded
[00:44:12] + 501760 bytes downloaded
[00:44:12] + 512000 bytes downloaded
[00:44:12] + 522240 bytes downloaded
[00:44:12] + 532480 bytes downloaded
[00:44:12] + 542720 bytes downloaded
[00:44:12] + 552960 bytes downloaded
[00:44:12] + 563200 bytes downloaded
[00:44:12] + 573440 bytes downloaded
[00:44:12] + 583680 bytes downloaded
[00:44:12] + 593920 bytes downloaded
[00:44:12] + 604160 bytes downloaded
[00:44:12] + 614400 bytes downloaded
[00:44:12] + 624640 bytes downloaded
[00:44:12] + 634880 bytes downloaded
[00:44:12] + 645120 bytes downloaded
[00:44:12] + 655360 bytes downloaded
[00:44:12] + 665600 bytes downloaded
[00:44:12] + 675840 bytes downloaded
[00:44:12] + 686080 bytes downloaded
[00:44:12] + 696320 bytes downloaded
[00:44:12] + 706560 bytes downloaded
[00:44:12] + 716800 bytes downloaded
[00:44:12] + 727040 bytes downloaded
[00:44:12] + 737280 bytes downloaded
[00:44:12] + 747520 bytes downloaded
[00:44:12] + 757760 bytes downloaded
[00:44:12] + 768000 bytes downloaded
[00:44:12] + 778240 bytes downloaded
[00:44:12] + 788480 bytes downloaded
[00:44:12] + 798720 bytes downloaded
[00:44:12] + 808960 bytes downloaded
[00:44:13] + 819200 bytes downloaded
[00:44:13] + 829440 bytes downloaded
[00:44:13] + 839680 bytes downloaded
[00:44:13] + 849920 bytes downloaded
[00:44:13] + 860160 bytes downloaded
[00:44:13] + 870400 bytes downloaded
[00:44:13] + 880640 bytes downloaded
[00:44:13] + 890880 bytes downloaded
[00:44:13] + 901120 bytes downloaded
[00:44:13] + 911360 bytes downloaded
[00:44:13] + 921600 bytes downloaded
[00:44:13] + 931840 bytes downloaded
[00:44:13] + 942080 bytes downloaded
[00:44:13] + 952320 bytes downloaded
[00:44:13] + 962560 bytes downloaded
[00:44:13] + 972800 bytes downloaded
[00:44:13] + 983040 bytes downloaded
[00:44:13] + 993280 bytes downloaded
[00:44:13] + 1003520 bytes downloaded
[00:44:13] + 1013760 bytes downloaded
[00:44:13] + 1024000 bytes downloaded
[00:44:13] + 1034240 bytes downloaded
[00:44:13] + 1044480 bytes downloaded
[00:44:13] + 1054720 bytes downloaded
[00:44:13] + 1064960 bytes downloaded
[00:44:13] + 1075200 bytes downloaded
[00:44:13] + 1085440 bytes downloaded
[00:44:13] + 1095680 bytes downloaded
[00:44:13] + 1105920 bytes downloaded
[00:44:13] + 1116160 bytes downloaded
[00:44:13] + 1126400 bytes downloaded
[00:44:14] + 1136640 bytes downloaded
[00:44:14] + 1146880 bytes downloaded
[00:44:14] + 1157120 bytes downloaded
[00:44:14] + 1167360 bytes downloaded
[00:44:14] + 1177600 bytes downloaded
[00:44:14] + 1187840 bytes downloaded
[00:44:14] + 1198080 bytes downloaded
[00:44:14] + 1208320 bytes downloaded
[00:44:14] + 1218560 bytes downloaded
[00:44:14] + 1228800 bytes downloaded
[00:44:14] + 1239040 bytes downloaded
[00:44:14] + 1249280 bytes downloaded
[00:44:14] + 1259520 bytes downloaded
[00:44:14] + 1269760 bytes downloaded
[00:44:14] + 1280000 bytes downloaded
[00:44:14] + 1290240 bytes downloaded
[00:44:14] + 1300480 bytes downloaded
[00:44:14] + 1310720 bytes downloaded
[00:44:14] + 1320960 bytes downloaded
[00:44:14] + 1331200 bytes downloaded
[00:44:14] + 1341440 bytes downloaded
[00:44:14] + 1351680 bytes downloaded
[00:44:14] + 1361920 bytes downloaded
[00:44:14] + 1372160 bytes downloaded
[00:44:14] + 1382400 bytes downloaded
[00:44:14] + 1392640 bytes downloaded
[00:44:14] + 1402880 bytes downloaded
[00:44:14] + 1413120 bytes downloaded
[00:44:14] + 1423360 bytes downloaded
[00:44:14] + 1433600 bytes downloaded
[00:44:14] + 1443840 bytes downloaded
[00:44:15] + 1454080 bytes downloaded
[00:44:15] + 1464320 bytes downloaded
[00:44:15] + 1474560 bytes downloaded
[00:44:15] + 1484800 bytes downloaded
[00:44:15] + 1495040 bytes downloaded
[00:44:15] + 1505280 bytes downloaded
[00:44:15] + 1515520 bytes downloaded
[00:44:15] + 1525760 bytes downloaded
[00:44:15] + 1536000 bytes downloaded
[00:44:15] + 1546240 bytes downloaded
[00:44:15] + 1556480 bytes downloaded
[00:44:15] + 1566720 bytes downloaded
[00:44:15] + 1576960 bytes downloaded
[00:44:15] + 1587200 bytes downloaded
[00:44:15] + 1597440 bytes downloaded
[00:44:15] + 1607680 bytes downloaded
[00:44:15] + 1617920 bytes downloaded
[00:44:15] + 1628160 bytes downloaded
[00:44:15] + 1638400 bytes downloaded
[00:44:15] + 1648640 bytes downloaded
[00:44:15] + 1658880 bytes downloaded
[00:44:15] + 1669120 bytes downloaded
[00:44:15] + 1679360 bytes downloaded
[00:44:15] + 1689600 bytes downloaded
[00:44:15] + 1699840 bytes downloaded
[00:44:15] + 1710080 bytes downloaded
[00:44:15] + 1720320 bytes downloaded
[00:44:15] + 1730560 bytes downloaded
[00:44:15] + 1740800 bytes downloaded
[00:44:15] + 1751040 bytes downloaded
[00:44:15] + 1761280 bytes downloaded
[00:44:16] + 1771520 bytes downloaded
[00:44:16] + 1781760 bytes downloaded
[00:44:16] + 1792000 bytes downloaded
[00:44:16] + 1802240 bytes downloaded
[00:44:16] + 1812480 bytes downloaded
[00:44:16] + 1822720 bytes downloaded
[00:44:16] + 1832960 bytes downloaded
[00:44:16] + 1843200 bytes downloaded
[00:44:16] + 1853440 bytes downloaded
[00:44:16] + 1863680 bytes downloaded
[00:44:16] + 1873920 bytes downloaded
[00:44:16] + 1884160 bytes downloaded
[00:44:16] + 1894400 bytes downloaded
[00:44:16] + 1904640 bytes downloaded
[00:44:16] + 1914880 bytes downloaded
[00:44:16] + 1925120 bytes downloaded
[00:44:16] + 1935360 bytes downloaded
[00:44:16] + 1945600 bytes downloaded
[00:44:16] + 1955840 bytes downloaded
[00:44:16] + 1966080 bytes downloaded
[00:44:16] + 1976320 bytes downloaded
[00:44:16] + 1986560 bytes downloaded
[00:44:16] + 1996800 bytes downloaded
[00:44:16] + 2007040 bytes downloaded
[00:44:16] + 2017280 bytes downloaded
[00:44:16] + 2027520 bytes downloaded
[00:44:16] + 2037760 bytes downloaded
[00:44:16] + 2048000 bytes downloaded
[00:44:16] + 2058240 bytes downloaded
[00:44:16] + 2068480 bytes downloaded
[00:44:16] + 2078720 bytes downloaded
[00:44:16] + 2088960 bytes downloaded
[00:44:17] + 2099200 bytes downloaded
[00:44:17] + 2109440 bytes downloaded
[00:44:17] + 2119680 bytes downloaded
[00:44:17] + 2129920 bytes downloaded
[00:44:17] + 2140160 bytes downloaded
[00:44:17] + 2150400 bytes downloaded
[00:44:17] + 2160640 bytes downloaded
[00:44:17] + 2170880 bytes downloaded
[00:44:17] + 2181120 bytes downloaded
[00:44:17] + 2191360 bytes downloaded
[00:44:17] + 2201600 bytes downloaded
[00:44:17] + 2211840 bytes downloaded
[00:44:17] + 2222080 bytes downloaded
[00:44:17] + 2232320 bytes downloaded
[00:44:17] + 2242560 bytes downloaded
[00:44:17] + 2252800 bytes downloaded
[00:44:17] + 2263040 bytes downloaded
[00:44:17] + 2273280 bytes downloaded
[00:44:17] + 2283520 bytes downloaded
[00:44:17] + 2293760 bytes downloaded
[00:44:17] + 2304000 bytes downloaded
[00:44:17] + 2314240 bytes downloaded
[00:44:17] + 2324480 bytes downloaded
[00:44:17] + 2334720 bytes downloaded
[00:44:17] + 2344960 bytes downloaded
[00:44:17] + 2355200 bytes downloaded
[00:44:17] + 2365440 bytes downloaded
[00:44:17] + 2375680 bytes downloaded
[00:44:17] + 2385920 bytes downloaded
[00:44:17] + 2396160 bytes downloaded
[00:44:17] + 2406400 bytes downloaded
[00:44:18] + 2416640 bytes downloaded
[00:44:18] + 2426880 bytes downloaded
[00:44:18] + 2437120 bytes downloaded
[00:44:18] + 2447360 bytes downloaded
[00:44:18] + 2457600 bytes downloaded
[00:44:18] + 2467840 bytes downloaded
[00:44:18] + 2478080 bytes downloaded
[00:44:18] + 2488320 bytes downloaded
[00:44:18] + 2498560 bytes downloaded
[00:44:18] + 2508800 bytes downloaded
[00:44:18] + 2519040 bytes downloaded
[00:44:18] + 2529280 bytes downloaded
[00:44:18] + 2539520 bytes downloaded
[00:44:18] + 2549760 bytes downloaded
[00:44:18] + 2560000 bytes downloaded
[00:44:18] + 2570240 bytes downloaded
[00:44:18] + 2580480 bytes downloaded
[00:44:18] + 2590720 bytes downloaded
[00:44:18] + 2600960 bytes downloaded
[00:44:18] + 2611200 bytes downloaded
[00:44:18] + 2621440 bytes downloaded
[00:44:18] + 2631680 bytes downloaded
[00:44:18] + 2641920 bytes downloaded
[00:44:18] + 2652160 bytes downloaded
[00:44:18] + 2662400 bytes downloaded
[00:44:18] + 2672640 bytes downloaded
[00:44:18] + 2682880 bytes downloaded
[00:44:18] + 2693120 bytes downloaded
[00:44:18] + 2703360 bytes downloaded
[00:44:18] + 2713600 bytes downloaded
[00:44:18] + 2723840 bytes downloaded
[00:44:18] + 2734080 bytes downloaded
[00:44:19] + 2744320 bytes downloaded
[00:44:19] + 2754560 bytes downloaded
[00:44:19] + 2764800 bytes downloaded
[00:44:19] + 2775040 bytes downloaded
[00:44:19] + 2785280 bytes downloaded
[00:44:19] + 2795520 bytes downloaded
[00:44:19] + 2805760 bytes downloaded
[00:44:19] + 2816000 bytes downloaded
[00:44:19] + 2826240 bytes downloaded
[00:44:19] + 2836480 bytes downloaded
[00:44:19] + 2846720 bytes downloaded
[00:44:19] + 2856960 bytes downloaded
[00:44:19] + 2867200 bytes downloaded
[00:44:19] + 2877440 bytes downloaded
[00:44:19] + 2887680 bytes downloaded
[00:44:19] + 2897920 bytes downloaded
[00:44:19] + 2908160 bytes downloaded
[00:44:19] + 2918400 bytes downloaded
[00:44:19] + 2928640 bytes downloaded
[00:44:19] + 2938880 bytes downloaded
[00:44:19] + 2949120 bytes downloaded
[00:44:19] + 2959360 bytes downloaded
[00:44:19] + 2969600 bytes downloaded
[00:44:19] + 2979840 bytes downloaded
[00:44:19] + 2990080 bytes downloaded
[00:44:19] + 3000320 bytes downloaded
[00:44:19] + 3010560 bytes downloaded
[00:44:19] + 3020800 bytes downloaded
[00:44:19] + 3031040 bytes downloaded
[00:44:19] + 3041280 bytes downloaded
[00:44:19] + 3051520 bytes downloaded
[00:44:19] + 3061760 bytes downloaded
[00:44:19] + 3072000 bytes downloaded
[00:44:20] + 3082240 bytes downloaded
[00:44:20] + 3092480 bytes downloaded
[00:44:20] + 3102720 bytes downloaded
[00:44:20] + 3112960 bytes downloaded
[00:44:20] + 3123200 bytes downloaded
[00:44:20] + 3133440 bytes downloaded
[00:44:20] + 3143680 bytes downloaded
[00:44:20] + 3153920 bytes downloaded
[00:44:20] + 3164160 bytes downloaded
[00:44:20] + 3174400 bytes downloaded
[00:44:20] + 3184640 bytes downloaded
[00:44:20] + 3194880 bytes downloaded
[00:44:20] + 3205120 bytes downloaded
[00:44:20] + 3215360 bytes downloaded
[00:44:20] + 3225600 bytes downloaded
[00:44:20] + 3235840 bytes downloaded
[00:44:20] + 3246080 bytes downloaded
[00:44:20] + 3256320 bytes downloaded
[00:44:20] + 3266560 bytes downloaded
[00:44:20] + 3276800 bytes downloaded
[00:44:20] + 3287040 bytes downloaded
[00:44:20] + 3297280 bytes downloaded
[00:44:20] + 3307520 bytes downloaded
[00:44:20] + 3317760 bytes downloaded
[00:44:20] + 3328000 bytes downloaded
[00:44:20] + 3338240 bytes downloaded
[00:44:20] + 3348480 bytes downloaded
[00:44:20] + 3358720 bytes downloaded
[00:44:20] + 3368960 bytes downloaded
[00:44:20] + 3379200 bytes downloaded
[00:44:20] + 3389440 bytes downloaded
[00:44:21] + 3399680 bytes downloaded
[00:44:21] + 3409920 bytes downloaded
[00:44:21] + 3420160 bytes downloaded
[00:44:21] + 3430400 bytes downloaded
[00:44:21] + 3440640 bytes downloaded
[00:44:21] + 3450880 bytes downloaded
[00:44:21] + 3461120 bytes downloaded
[00:44:21] + 3471360 bytes downloaded
[00:44:21] + 3481600 bytes downloaded
[00:44:21] + 3491840 bytes downloaded
[00:44:21] + 3502080 bytes downloaded
[00:44:21] + 3512320 bytes downloaded
[00:44:21] + 3522560 bytes downloaded
[00:44:21] + 3532800 bytes downloaded
[00:44:21] + 3543040 bytes downloaded
[00:44:21] + 3553280 bytes downloaded
[00:44:21] + 3563520 bytes downloaded
[00:44:21] + 3573760 bytes downloaded
[00:44:21] + 3584000 bytes downloaded
[00:44:21] + 3594240 bytes downloaded
[00:44:21] + 3604480 bytes downloaded
[00:44:21] + 3614720 bytes downloaded
[00:44:21] + 3624960 bytes downloaded
[00:44:21] + 3635200 bytes downloaded
[00:44:21] + 3645440 bytes downloaded
[00:44:21] + 3655680 bytes downloaded
[00:44:21] + 3665920 bytes downloaded
[00:44:21] + 3676160 bytes downloaded
[00:44:22] + 3686400 bytes downloaded
[00:44:22] + 3696640 bytes downloaded
[00:44:22] + 3706880 bytes downloaded
[00:44:22] + 3717120 bytes downloaded
[00:44:22] + 3727360 bytes downloaded
[00:44:22] + 3737600 bytes downloaded
[00:44:22] + 3747840 bytes downloaded
[00:44:22] + 3758080 bytes downloaded
[00:44:22] + 3768320 bytes downloaded
[00:44:22] + 3778560 bytes downloaded
[00:44:22] + 3788800 bytes downloaded
[00:44:22] + 3799040 bytes downloaded
[00:44:22] + 3809280 bytes downloaded
[00:44:22] + 3819520 bytes downloaded
[00:44:22] + 3829760 bytes downloaded
[00:44:22] + 3840000 bytes downloaded
[00:44:22] + 3850240 bytes downloaded
[00:44:22] + 3860480 bytes downloaded
[00:44:22] + 3870720 bytes downloaded
[00:44:22] + 3880960 bytes downloaded
[00:44:22] + 3891200 bytes downloaded
[00:44:22] + 3901440 bytes downloaded
[00:44:22] + 3911680 bytes downloaded
[00:44:22] + 3921920 bytes downloaded
[00:44:22] + 3932160 bytes downloaded
[00:44:22] + 3942400 bytes downloaded
[00:44:22] + 3952640 bytes downloaded
[00:44:22] + 3962880 bytes downloaded
[00:44:22] + 3973120 bytes downloaded
[00:44:22] + 3983360 bytes downloaded
[00:44:23] + 3993600 bytes downloaded
[00:44:23] + 4003840 bytes downloaded
[00:44:23] + 4014080 bytes downloaded
[00:44:23] + 4024320 bytes downloaded
[00:44:23] + 4034560 bytes downloaded
[00:44:23] + 4044800 bytes downloaded
[00:44:23] + 4055040 bytes downloaded
[00:44:23] + 4065280 bytes downloaded
[00:44:23] + 4075520 bytes downloaded
[00:44:23] + 4085760 bytes downloaded
[00:44:23] + 4096000 bytes downloaded
[00:44:23] + 4106240 bytes downloaded
[00:44:23] + 4116480 bytes downloaded
[00:44:23] + 4126720 bytes downloaded
[00:44:23] + 4136960 bytes downloaded
[00:44:23] + 4147200 bytes downloaded
[00:44:23] + 4157440 bytes downloaded
[00:44:23] + 4167680 bytes downloaded
[00:44:23] + 4177920 bytes downloaded
[00:44:23] + 4188160 bytes downloaded
[00:44:23] + 4198400 bytes downloaded
[00:44:23] + 4208640 bytes downloaded
[00:44:23] + 4218880 bytes downloaded
[00:44:23] + 4229120 bytes downloaded
[00:44:23] + 4239360 bytes downloaded
[00:44:23] + 4249600 bytes downloaded
[00:44:23] + 4259840 bytes downloaded
[00:44:23] + 4270080 bytes downloaded
[00:44:23] + 4280320 bytes downloaded
[00:44:23] + 4290560 bytes downloaded
[00:44:23] + 4300800 bytes downloaded
[00:44:24] + 4311040 bytes downloaded
[00:44:24] + 4321280 bytes downloaded
[00:44:24] + 4331520 bytes downloaded
[00:44:24] + 4341760 bytes downloaded
[00:44:24] + 4352000 bytes downloaded
[00:44:24] + 4362240 bytes downloaded
[00:44:24] + 4372480 bytes downloaded
[00:44:24] + 4382720 bytes downloaded
[00:44:24] + 4392960 bytes downloaded
[00:44:24] + 4403200 bytes downloaded
[00:44:24] + 4413440 bytes downloaded
[00:44:24] + 4423680 bytes downloaded
[00:44:24] + 4433920 bytes downloaded
[00:44:24] + 4444160 bytes downloaded
[00:44:24] + 4454400 bytes downloaded
[00:44:24] + 4464640 bytes downloaded
[00:44:24] + 4474880 bytes downloaded
[00:44:24] + 4485120 bytes downloaded
[00:44:24] + 4495360 bytes downloaded
[00:44:24] + 4505600 bytes downloaded
[00:44:24] + 4515840 bytes downloaded
[00:44:24] + 4526080 bytes downloaded
[00:44:24] + 4536320 bytes downloaded
[00:44:24] + 4546560 bytes downloaded
[00:44:24] + 4556800 bytes downloaded
[00:44:24] + 4567040 bytes downloaded
[00:44:24] + 4577280 bytes downloaded
[00:44:24] + 4587520 bytes downloaded
[00:44:24] + 4597760 bytes downloaded
[00:44:24] + 4608000 bytes downloaded
[00:44:24] + 4618240 bytes downloaded
[00:44:25] + 4628480 bytes downloaded
[00:44:25] + 4638720 bytes downloaded
[00:44:25] + 4648960 bytes downloaded
[00:44:25] + 4659200 bytes downloaded
[00:44:25] + 4669440 bytes downloaded
[00:44:25] + 4679680 bytes downloaded
[00:44:25] + 4689920 bytes downloaded
[00:44:25] + 4700160 bytes downloaded
[00:44:25] + 4710400 bytes downloaded
[00:44:25] + 4720640 bytes downloaded
[00:44:25] + 4730880 bytes downloaded
[00:44:25] + 4741120 bytes downloaded
[00:44:25] + 4751360 bytes downloaded
[00:44:25] + 4761600 bytes downloaded
[00:44:25] + 4771840 bytes downloaded
[00:44:25] + 4782080 bytes downloaded
[00:44:25] + 4792320 bytes downloaded
[00:44:25] + 4802560 bytes downloaded
[00:44:25] + 4812800 bytes downloaded
[00:44:25] + 4823040 bytes downloaded
[00:44:25] + 4833280 bytes downloaded
[00:44:25] + 4843520 bytes downloaded
[00:44:25] + 4853760 bytes downloaded
[00:44:25] + 4864000 bytes downloaded
[00:44:25] + 4874240 bytes downloaded
[00:44:25] + 4884480 bytes downloaded
[00:44:25] + 4894720 bytes downloaded
[00:44:25] + 4904960 bytes downloaded
[00:44:25] + 4915200 bytes downloaded
[00:44:25] + 4925440 bytes downloaded
[00:44:25] + 4935680 bytes downloaded
[00:44:25] + 4945920 bytes downloaded
[00:44:26] + 4956160 bytes downloaded
[00:44:26] + 4966400 bytes downloaded
[00:44:26] + 4976640 bytes downloaded
[00:44:26] + 4986880 bytes downloaded
[00:44:26] + 4997120 bytes downloaded
[00:44:26] + 5007360 bytes downloaded
[00:44:26] + 5017600 bytes downloaded
[00:44:26] + 5027840 bytes downloaded
[00:44:26] + 5038080 bytes downloaded
[00:44:26] + 5048320 bytes downloaded
[00:44:26] + 5058560 bytes downloaded
[00:44:26] + 5068800 bytes downloaded
[00:44:26] + 5079040 bytes downloaded
[00:44:26] + 5089280 bytes downloaded
[00:44:26] + 5099520 bytes downloaded
[00:44:26] + 5109760 bytes downloaded
[00:44:26] + 5120000 bytes downloaded
[00:44:26] + 5130240 bytes downloaded
[00:44:26] + 5140480 bytes downloaded
[00:44:26] + 5150720 bytes downloaded
[00:44:26] + 5160960 bytes downloaded
[00:44:26] + 5171200 bytes downloaded
[00:44:26] + 5181440 bytes downloaded
[00:44:26] + 5191680 bytes downloaded
[00:44:26] + 5194559 bytes downloaded
[00:44:26] Verifying core Core_b4.fah...
[00:44:26] Signature is VALID
[00:44:26]
[00:44:26] Trying to unzip core FahCore_b4.exe
[00:44:30] Decompressed FahCore_b4.exe (16636416 bytes) successfully
[00:44:35] + Core successfully engaged
[00:44:41]
[00:44:41] + Processing work unit
[00:44:41] Core required: FahCore_b4.exe
[00:44:41] Core found.
[00:44:41] Working on queue slot 01 [March 9 00:44:41 UTC]
[00:44:41] + Working ...
[00:44:45] *********************** Log Started 09/Mar/2011 00:44:45 ***********************
[00:44:45] ************************** ProtoMol Folding@Home Core **************************
[00:44:45] Version: 25
[00:44:45] Type: 180
[00:44:45] Core: ProtoMol
[00:44:45] Website: http://folding.stanford.edu/
[00:44:45] Copyright: (c) 2009 Stanford University
[00:44:45] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[00:44:45] Args: -dir work/ -suffix 01 -nice 19 -checkpoint 15 -lifeline 2304 -version
[00:44:45] 634
[00:44:45] ************************************ Build *************************************
[00:44:45] Date: May 18 2010
[00:44:45] Time: 23:43:52
[00:44:45] Revision: 1819
[00:44:45] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[00:44:45] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[00:44:45] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[00:44:45] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[00:44:45] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[00:44:45] Platform: Windows XP
[00:44:45] Bits: 32
[00:44:45] Mode: Release
[00:44:45] ************************************ System ************************************
[00:44:45] OS: Microsoft Windows 7 Ultimate
[00:44:45] CPU: Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
[00:44:45] CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
[00:44:45] CPUs: 4 Logical, 1 Physical
[00:44:45] Memory: 6.00 GB
[00:44:45] Threads: Windows
[00:44:45] ********************************************************************************
[00:44:45] Project: 10034 (Run 450, Clone 0, Gen 97)
[00:44:45] Unit: 0x000000970001329c4bd49e7500016310
[00:44:45] User: 0x00000000000000000000000000000000
[00:44:45] Machine: 2
[00:44:45] Reading tar file par_all27_prot_lipid.inp
[00:44:45] Reading tar file scpismQuartic.inp
[00:44:45] Reading tar file ww.pdb
[00:44:45] Reading tar file ww.psf
[00:44:45] Reading tar file checkpt
[00:44:45] Reading tar file ww.8628.pos
[00:44:45] Reading tar file ww.8628.vel
[00:44:45] Reading tar file protomol.conf
[00:44:45] Reading tar file core.xml
[00:44:45] Digital signatures verified
[00:44:45] Completed 0 out of 499375 steps (0%)
[00:44:45] WARNING: Exception: 0: Could not bind socket to 127.0.0.1:52753: No error
[00:55:49] Completed 5000 out of 499375 steps (1%)
[01:16:00] Completed 10000 out of 499375 steps (2%)
[01:26:44] Completed 15000 out of 499375 steps (3%)
[01:45:35] Completed 20000 out of 499375 steps (4%)
[01:56:24] Completed 25000 out of 499375 steps (5%)
[02:09:37] Completed 30000 out of 499375 steps (6%)
[02:30:20] Completed 35000 out of 499375 steps (7%)
[02:40:55] Completed 40000 out of 499375 steps (8%)
[02:56:35] Completed 45000 out of 499375 steps (9%)
[03:11:02] Completed 50000 out of 499375 steps (10%)
[03:21:53] Completed 55000 out of 499375 steps (11%)
[03:36:27] Completed 60000 out of 499375 steps (12%)
[03:46:57] Completed 65000 out of 499375 steps (13%)
[03:56:55] Completed 70000 out of 499375 steps (14%)
[04:06:43] Completed 74900 out of 499375 steps (14%)
[04:16:39] Completed 79900 out of 499375 steps (16%)
[04:28:11] Completed 84900 out of 499375 steps (17%)
[04:38:51] Completed 89900 out of 499375 steps (18%)
[04:49:45] Completed 94900 out of 499375 steps (19%)
[05:00:39] Completed 99900 out of 499375 steps (20%)
[05:11:12] Completed 104900 out of 499375 steps (21%)
[05:21:07] Completed 109900 out of 499375 steps (22%)
[05:31:37] Completed 114900 out of 499375 steps (23%)
[05:41:49] Completed 119900 out of 499375 steps (24%)
[05:52:06] Completed 124900 out of 499375 steps (25%)
[06:02:27] Completed 129900 out of 499375 steps (26%)
[06:12:41] Completed 134900 out of 499375 steps (27%)
[06:22:49] Completed 139900 out of 499375 steps (28%)
[06:33:02] Completed 144800 out of 499375 steps (28%)
[06:44:13] Completed 149800 out of 499375 steps (29%)
[06:55:07] Completed 154800 out of 499375 steps (30%)
[07:05:59] Completed 159800 out of 499375 steps (32%)
[07:16:34] Completed 164800 out of 499375 steps (33%)
[07:26:45] Completed 169800 out of 499375 steps (34%)
[07:37:40] Completed 174800 out of 499375 steps (35%)
[07:48:08] Completed 179800 out of 499375 steps (36%)
[07:58:12] Completed 184800 out of 499375 steps (37%)
[08:08:02] Completed 189800 out of 499375 steps (38%)
[08:17:39] Completed 194800 out of 499375 steps (39%)
[08:27:59] Completed 199800 out of 499375 steps (40%)
[08:38:10] Completed 204800 out of 499375 steps (41%)
[08:48:03] Completed 209800 out of 499375 steps (42%)
[08:58:10] Completed 214700 out of 499375 steps (42%)
[09:08:22] Completed 219700 out of 499375 steps (43%)
[09:18:06] Completed 224700 out of 499375 steps (44%)
[09:27:34] Completed 229700 out of 499375 steps (45%)
[09:37:06] Completed 234700 out of 499375 steps (46%)
[09:49:23] Completed 239700 out of 499375 steps (48%)
[09:59:16] Completed 244700 out of 499375 steps (49%)
[10:10:11] Completed 249700 out of 499375 steps (50%)
[10:20:21] Completed 254700 out of 499375 steps (51%)
[10:30:29] Completed 259700 out of 499375 steps (52%)
[10:40:25] Completed 264700 out of 499375 steps (53%)
[10:49:24] Completed 269700 out of 499375 steps (54%)
[10:58:23] Completed 274700 out of 499375 steps (55%)
[11:07:56] Completed 279700 out of 499375 steps (56%)
[11:17:42] Completed 284700 out of 499375 steps (57%)
[11:27:44] Completed 289600 out of 499375 steps (57%)
[11:37:48] Completed 294600 out of 499375 steps (58%)
[11:47:37] Completed 299600 out of 499375 steps (59%)
[11:58:00] Completed 304600 out of 499375 steps (60%)
[12:07:58] Completed 309600 out of 499375 steps (61%)
[12:17:39] Completed 314600 out of 499375 steps (62%)
[12:28:00] Completed 319600 out of 499375 steps (64%)
[12:37:59] Completed 324600 out of 499375 steps (65%)
[12:48:08] Completed 329600 out of 499375 steps (66%)
[12:58:37] Completed 334600 out of 499375 steps (67%)
[13:09:12] Completed 339600 out of 499375 steps (68%)
[13:19:32] Completed 344600 out of 499375 steps (69%)
[13:30:03] Completed 349600 out of 499375 steps (70%)
[13:40:07] Completed 354600 out of 499375 steps (71%)
[13:50:53] Completed 359500 out of 499375 steps (71%)
[14:01:30] Completed 364500 out of 499375 steps (72%)
[14:11:37] Completed 369500 out of 499375 steps (73%)
[14:21:35] Completed 374500 out of 499375 steps (74%)
[14:31:50] Completed 379500 out of 499375 steps (75%)
[14:42:07] Completed 384500 out of 499375 steps (76%)
[14:52:23] Completed 389500 out of 499375 steps (77%)
--- Opening Log file [March 9 16:28:40 UTC]
[16:28:40] - Ask before connecting: No
[16:28:40] - User name: mrkvchm (Team 97103)
[16:28:40] - User ID: 2255BAFC61030934
[16:28:40] - Machine ID: 2
[16:28:40]
Process 3264 is currently running and may also be a client with Mach. ID 2.
--- Opening Log file [March 9 16:28:46 UTC]
[16:28:46] - Ask before connecting: No
[16:28:46] - User name: mrkvchm (Team 97103)
[16:28:46] - User ID: 2255BAFC61030934
[16:28:46] - Machine ID: 2
[16:28:46]
[16:28:46] Loaded queue successfully.
[16:28:46]
[16:28:46] + Processing work unit
[16:28:46] Core required: FahCore_b4.exe
[16:28:46] Core found.
[16:28:46] Working on queue slot 01 [March 9 16:28:46 UTC]
[16:28:46] + Working ...
[16:28:49] *********************** Log Started 09/Mar/2011 16:28:49 ***********************
[16:28:49] ************************** ProtoMol Folding@Home Core **************************
[16:28:49] Version: 25
[16:28:49] Type: 180
[16:28:49] Core: ProtoMol
[16:28:49] Website: http://folding.stanford.edu/
[16:28:49] Copyright: (c) 2009 Stanford University
[16:28:49] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[16:28:49] Args: -dir work/ -suffix 01 -nice 19 -checkpoint 15 -lifeline 3448 -version
[16:28:49] 634
[16:28:49] ************************************ Build *************************************
[16:28:49] Date: May 18 2010
[16:28:49] Time: 23:43:52
[16:28:49] Revision: 1819
[16:28:49] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[16:28:49] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[16:28:49] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[16:28:49] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[16:28:49] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[16:28:49] Platform: Windows XP
[16:28:49] Bits: 32
[16:28:49] Mode: Release
[16:28:49] ************************************ System ************************************
[16:28:49] OS: Microsoft Windows 7 Ultimate
[16:28:49] CPU: Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
[16:28:49] CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
[16:28:49] CPUs: 4 Logical, 1 Physical
[16:28:49] Memory: 6.00 GB
[16:28:49] Threads: Windows
[16:28:49] ********************************************************************************
[16:28:49] Project: 10034 (Run 450, Clone 0, Gen 97)
[16:28:49] Unit: 0x000000970001329c4bd49e7500016310
[16:28:49] User: 0x00000000000000000000000000000000
[16:28:49] Machine: 2
[16:28:49] Digital signatures verified
[16:28:52] WARNING: Exception: 0: Could not bind socket to 127.0.0.1:52753: No error
[16:28:52] Completed 389300 out of 499375 steps (77%)
[16:29:18] Completed 389500 out of 499375 steps (77%)
[16:39:13] Completed 394500 out of 499375 steps (78%)
[16:49:09] Completed 399500 out of 499375 steps (80%)
[16:59:54] Completed 404500 out of 499375 steps (81%)
[17:10:13] Completed 409500 out of 499375 steps (82%)
[17:20:34] Completed 414500 out of 499375 steps (83%)
[17:30:53] Completed 419500 out of 499375 steps (84%)
[17:41:06] Completed 424500 out of 499375 steps (85%)
[17:51:10] Completed 429400 out of 499375 steps (85%)
[18:00:59] Completed 434400 out of 499375 steps (86%)
[18:10:49] Completed 439400 out of 499375 steps (87%)
[18:21:01] Completed 444400 out of 499375 steps (88%)
[18:31:40] Completed 449400 out of 499375 steps (89%)
[18:42:26] Completed 454400 out of 499375 steps (90%)
[18:52:50] Completed 459400 out of 499375 steps (91%)
--- Opening Log file [March 9 23:10:45 UTC]
[23:10:45] - Ask before connecting: No
[23:10:45] - User name: mrkvchm (Team 97103)
[23:10:45] - User ID: 2255BAFC61030934
[23:10:45] - Machine ID: 2
[23:10:45]
[23:10:45] Loaded queue successfully.
[23:10:45]
[23:10:45] + Processing work unit
[23:10:45] Core required: FahCore_b4.exe
[23:10:45] Core found.
[23:10:45] Working on queue slot 01 [March 9 23:10:45 UTC]
[23:10:45] + Working ...
[23:10:48] *********************** Log Started 09/Mar/2011 23:10:48 ***********************
[23:10:48] ************************** ProtoMol Folding@Home Core **************************
[23:10:48] Version: 25
[23:10:48] Type: 180
[23:10:48] Core: ProtoMol
[23:10:48] Website: http://folding.stanford.edu/
[23:10:48] Copyright: (c) 2009 Stanford University
[23:10:48] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[23:10:48] Args: -dir work/ -suffix 01 -nice 19 -checkpoint 15 -lifeline 4040 -version
[23:10:48] 634
[23:10:48] ************************************ Build *************************************
[23:10:48] Date: May 18 2010
[23:10:48] Time: 23:43:52
[23:10:48] Revision: 1819
[23:10:48] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[23:10:48] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[23:10:48] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[23:10:48] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[23:10:48] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[23:10:48] Platform: Windows XP
[23:10:48] Bits: 32
[23:10:48] Mode: Release
[23:10:48] ************************************ System ************************************
[23:10:48] OS: Microsoft Windows 7 Ultimate
[23:10:48] CPU: Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
[23:10:48] CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
[23:10:48] CPUs: 4 Logical, 1 Physical
[23:10:48] Memory: 6.00 GB
[23:10:48] Threads: Windows
[23:10:48] ********************************************************************************
[23:10:48] Project: 10034 (Run 450, Clone 0, Gen 97)
[23:10:48] Unit: 0x000000970001329c4bd49e7500016310
[23:10:48] User: 0x00000000000000000000000000000000
[23:10:48] Machine: 2
[23:10:48] Digital signatures verified
[23:10:52] WARNING: Exception: 0: Could not bind socket to 127.0.0.1:52753: No error
[23:10:52] Completed 462900 out of 499375 steps (92%)
[23:12:17] ERROR: ProtoMol ERROR: Corrupt DCD file. Size is 4378776, should be >= 4385076.
[23:12:17] Saving result file logfile_01.txt
[23:12:17] Saving result file checkpt
[23:12:17] Saving result file checkpt.crc
[23:12:17] Saving result file log.txt
[23:12:21] Saving result file protomol.conf
[23:12:21] Saving result file ww.8694.pos
[23:12:21] Saving result file ww.8694.vel
[23:12:21] Saving result file ww.dcd
[23:12:22] WARNING: While cleaning up: 0: Failed to remove directory '01': boost::filesystem::remove: The process cannot access the file because it is being used by another process: "01\ww.dcd"
[23:12:22] Folding@home Core Shutdown: BAD_WORK_UNIT
[23:12:26] CoreStatus = 72 (114)
[23:12:26] Sending work to server
[23:12:26] Project: 10034 (Run 450, Clone 0, Gen 97)
[23:12:26] + Attempting to send results [March 9 23:12:26 UTC]
--- Opening Log file [March 9 23:13:01 UTC]
[23:13:01] - Ask before connecting: No
[23:13:01] - User name: mrkvchm (Team 97103)
[23:13:01] - User ID: 2255BAFC61030934
[23:13:01] - Machine ID: 2
[23:13:01]
[23:13:02] Loaded queue successfully.
[23:13:02] - Preparing to get new work unit...
[23:13:02] Cleaning up work directory
[23:13:02] + Attempting to get work packet
[23:13:02] - Connecting to assignment server
[23:13:02] Project: 10034 (Run 450, Clone 0, Gen 97)
[23:13:02] + Attempting to send results [March 9 23:13:02 UTC]
[23:13:04] - Successful: assigned to (129.74.85.15).
[23:13:04] + News From Folding@Home: Welcome to Folding@Home
[23:13:05] Loaded queue successfully.
[23:13:08] + Closed connections
[23:13:08]
[23:13:08] + Processing work unit
[23:13:08] Core required: FahCore_b4.exe
[23:13:08] Core found.
[23:13:08] Working on queue slot 02 [March 9 23:13:08 UTC]
[23:13:08] + Working ...
[23:13:23] *********************** Log Started 09/Mar/2011 23:13:23 ***********************
[23:13:23] ************************** ProtoMol Folding@Home Core **************************
[23:13:23] Version: 25
[23:13:23] Type: 180
[23:13:23] Core: ProtoMol
[23:13:23] Website: http://folding.stanford.edu/
[23:13:23] Copyright: (c) 2009 Stanford University
[23:13:23] Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[23:13:23] Args: -dir work/ -suffix 02 -nice 19 -checkpoint 15 -lifeline 3620 -version
[23:13:23] 634
[23:13:23] ************************************ Build *************************************
[23:13:23] Date: May 18 2010
[23:13:23] Time: 23:43:52
[23:13:23] Revision: 1819
[23:13:23] Compiler: Intel(R) C++ MSVC 1500 mode 1110
[23:13:23] Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[23:13:23] /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[23:13:23] Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[23:13:23] XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[23:13:23] Platform: Windows XP
[23:13:23] Bits: 32
[23:13:23] Mode: Release
[23:13:23] ************************************ System ************************************
[23:13:23] OS: Microsoft Windows 7 Ultimate
[23:13:23] CPU: Intel(R) Core(TM)2 Quad CPU Q9000 @ 2.00GHz
[23:13:23] CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
[23:13:23] CPUs: 4 Logical, 1 Physical
[23:13:23] Memory: 6.00 GB
[23:13:23] Threads: Windows
[23:13:23] ********************************************************************************
[23:13:23] Project: 10032 (Run 174, Clone 0, Gen 120)
[23:13:23] Unit: 0x000000b80001329c4bd49d76000112d3
[23:13:23] User: 0x00000000000000000000000000000000
[23:13:23] Machine: 2
[23:13:23] Reading tar file par_all27_prot_lipid.inp
[23:13:23] Reading tar file scpismQuartic.inp
[23:13:23] Reading tar file ww.pdb
[23:13:23] Reading tar file ww.psf
[23:13:23] Reading tar file checkpt
[23:13:23] Reading tar file ww.9789.pos
[23:13:23] Reading tar file ww.9789.vel
[23:13:23] Reading tar file protomol.conf
[23:13:23] Reading tar file core.xml
[23:13:23] Digital signatures verified
[23:13:23] Completed 0 out of 499375 steps (0%)
[23:13:23] WARNING: Exception: 0: Could not bind socket to 127.0.0.1:52753: No error
[23:14:08] + Results successfully sent
[23:14:08] Thank you for your contribution to Folding@Home.
[23:24:20] Completed 5000 out of 499375 steps (1%)
I know the stat pages update every hour or so, but do the clients report back continuously as they work? or do they only report back when they upload a WU? I think one of my clients just uploaded one back, but that prolly wont reflect since that was less than an hour ago.
Thanks again for the help.
Re: Forgot passkey. Am I screwed? - Resolved
Glad that you read the FAQs and figured out
Nonetheless, the Client only connects to the server when uploading the wuresult (processed WU) or when it requests a new WU to process. Other than then those two common situations, no other server connections are made by the Client. Once the WU has been successfully uploaded, it needs to be processed by the Stats system and then only it will be displayed in your profile.
