Here's an example from one of the error logs:
Arguments: -oneunit -forceasm -smp 5
[20:33:56] Work directory not found. Creating...
[20:33:56] Could not open work queue, generating new queue...
[20:33:56] - Preparing to get new work unit...
[20:33:56] Cleaning up work directory
[20:33:56] + Attempting to get work packet
[20:33:56] Passkey found
[20:33:56] - Connecting to assignment server
[20:34:00] - Successful: assigned to (171.64.65.75).
[20:34:00] + News From Folding@Home: Welcome to Folding@Home
[20:34:00] Loaded queue successfully.
[20:34:09] + Closed connections
[20:34:09]
[20:34:09] + Processing work unit
[20:34:09] Core required: FahCore_a3.exe
[20:34:09] Core found.
[20:34:09] Working on queue slot 01 [March 8 20:34:09 UTC]
[20:34:09] + Working ...
[20:34:09]
[20:34:09] *------------------------------*
[20:34:09] Folding@Home Gromacs SMP Core
[20:34:09] Version 2.27 (Dec. 15, 2010)
[20:34:09]
[20:34:09] Preparing to commence simulation
[20:34:09] - Assembly optimizations manually forced on.
[20:34:09] - Not checking prior termination.
[20:34:09] - Expanded 538173 -> 1267180 (decompressed 235.4 percent)
[20:34:09] Called DecompressByteArray: compressed_data_size=538173 data_size=1267180, decompressed_data_size=1267180 diff=0
[20:34:10] - Digital signature verified
[20:34:10]
[20:34:10] Project: 10113 (Run 46, Clone 6, Gen 0)
[20:34:10]
[20:34:10] Assembly optimizations on if available.
[20:34:10] Entering M.D.
[20:34:16] Mapping NT from 5 to 5
[20:34:16] mdrun returned 255
[20:34:16] Going to send back what have done -- stepsTotalG=4000000
[20:34:16] Work fraction=0.0000 steps=4000000.
[20:34:20] logfile size=0 infoLength=0 edr=0 trr=25
[20:34:20] logfile size: 0 info=0 bed=0 hdr=25
[20:34:20] - Writing 643 bytes of core data to disk...
[20:34:20] Done: 131 -> 148 (compressed to 112.9 percent)
[20:34:20] ... Done.
[20:34:20]
[20:34:20] Folding@home Core Shutdown: EARLY_UNIT_END
[20:34:24] CoreStatus = 72 (114)
[20:34:24] Sending work to server
[20:34:24] Project: 10113 (Run 46, Clone 6, Gen 0)
[20:34:24] + Attempting to send results [March 8 20:34:24 UTC]
[20:34:27] + Results successfully sent
[20:34:27] Thank you for your contribution to Folding@Home.
[20:34:31] + -oneunit flag given and have now finished a unit. Exiting.
Folding@Home Client Shutdown.
- 10113 (Run 28, Clone 9, Gen 0)
- 10113 (Run 30, Clone 9, Gen 0)
- 10113 (Run 33, Clone 9, Gen 0)
- 10114 (Run 73, Clone 8, Gen 0)
- 10114 (Run 75, Clone 8, Gen 0)
- 10114 (Run 76, Clone 8, Gen 0)
- 10115 (Run 65, Clone 7, Gen 0)
- 10115 (Run 66, Clone 7, Gen 0)
- 10115 (Run 67, Clone 7, Gen 0)
- 10115 (Run 69, Clone 7, Gen 0)
I use the latest FAH GPU Tracker V2 (3.52) with latest clients. I've got zero failed WUs before this.
CPU: AMD Phenom II X6 1055T
GPU: XFX Radeon HD 5850
Clock speeds are at stock and temps are not too high.
Tried re-installing the FAH GPU Tracker, but it didn't work. I also tried to change -smp 5 flag to -smp 4, but still no result. What next?
Ask, if you need some additional info and thank you!
(Sorry if this is on the wrong area or there's already a topic from this same thing
