PPD and comparisons...
MegaRock91
- Hardware configuration: AMD Phenom II x6 1055T 2.8Ghz
12GB 1333Mhz G.Skill RAM
730W RaidMax PSU
ATI Radeon HD 5770 (800 Processing cores, 850Mhz clock)
Windows 7 Professional x64
Well I've already started techically, for a while. And usually I look at my rank or Team Rank for an idea of how good I am doing. So I wanted to know, what is an average PPD for folding? Or if not Average, then what is one that I can be proud of?
Specs that matter:
AMD Phenom II 1055T 2.Ghz Hex Core
HIS Radeon HD 5770 (800 processing units and 850Mhz clock)
Windows 7 Professional Edition x64
According to FAHmon, SMP core(using 3 of 6 cores, big units on) generates 2409 PPD
single core runs 256.75 PPD
And the GPU one FAHmon will no calculate, though I've determined that it folds maybe about 1277 PPD (taking the current unit score, and using time frames to estimate Minutes/frame)
So are these good scores? I'd compare to looking around, but it seems a lot of people posting PPD's are either extreme OC'ers or just plain better then me at this point.
btw my current config I have SMP on 3 cores for big units, single core ProtoMol core and GPU2 on their own cores, leaving 1 of the 6 free for my own needs.
And cooling is not a problem, neither CPU nor GPU breach 45C(50C at the worst)
Specs that matter:
Team: 195773
Goal: To help Pande
Wish: Waffles
Goal: To help Pande
Wish: Waffles
Re: PPD and comparisons...
The answer to this can get pretty complex. Average PPD comparisons across clients vary greatly. I have an Athlon XP running the classic client that gets between 100 and 300 PPD. I also have a 2P system running bigadv that gets about 80,000+ PPD. The Athlon has run non-stop since 2006. I built the bigadv system myself. In the end I'm proud of them both, for different reasons.MegaRock91 wrote:So I wanted to know, what is an average PPD for folding? Or if not Average, then what is one that I can be proud of?
Right now I am running 2 bigadv, 7 classic, 7 GPU2, 2 GPU3, and 1 PS3. I guess you could say I like variety.
Ultimately, each of us has to decide what it is that we can be proud of.
Nathan_P
Not currently folding
MegaRock91 wrote:Well I've already started techically, for a while. And usually I look at my rank or Team Rank for an idea of how good I am doing. So I wanted to know, what is an average PPD for folding? Or if not Average, then what is one that I can be proud of?
Specs that matter:
Persoanlly for that rig i would run 1 instance of smp 6 and stop folding on the 5770 until the openCL core comes out for ATI. Running my own x6 i get just over 11k PPD but mines at 3.5 so i reckon 8-9k PPD depending on the WU for your machine.
MegaRock91
730W RaidMax PSU
1) would 5 cores for SMP be okay? I really would like to use one core for myself. This rig is used to view the internet, among other average things like Office and multimedia activites(aka, using MS Word, and watching videos with VLC)Nathan_P wrote:
2) when is the new OpenCL core coming out? Anytime soon?
3)Also, does HD Radeon 5770 support OpenCL? I read somewhere that 5770's lack OpenCL support. Though I think it was fixed. Not sure though.
Team: 195773
Goal: To help Pande
Wish: Waffles
Goal: To help Pande
Wish: Waffles
Fahrenheit451
- Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB - Location: Bonn, Germany
1) I agree with Nathan_P. 5 would be ok but I recommend to use all 6 cores (running -smp flag). FAH runs at low priority so you will not see any lag during your activities (office, internet, video watching). It should also work while you're playing games, but here it depends on the game. If you like to play graphics and CPU intense games like FPS you should stop FAH in the meantime, if you play Solitaire you can let it run. And don't use the 5770 for folding.
2) "When it is done." (old ID software citation). The new v7 FAH client should be released this quarter, but nobody knows. See also Vijay Pandes blog: http://folding.typepad.com/ for more information.
3) Google is your friend
According to AMD product description your card supports OpenCL (http://www.amd.com/us/products/desktop/ ... iew.aspx#2).
MegaRock91
730W RaidMax PSU
Alright, thank you!
Well then 6 cores it is. After my single core finish's its last work unit, I'll switch.
Team: 195773
Goal: To help Pande
Wish: Waffles
Goal: To help Pande
Wish: Waffles
HendricksSA
MegaRock91, welcome to the Fold. I'm also running X6 power. Mixing normal use with folding requires some fine tuning to get the best mix of points per day. If you plan to use the computer frequently for other things, yes SMP 5 may be good to consider. The SMP client runs at a very low priority. It will yield to everything ... but if you force it to yield too often the progress will really suffer. I don't think we have any word on when the ATI clients will be updated. The version 7 client is anticipated this quarter but I have no info on what is in version 7 and do not know if it contains the long awaited ATI client or not. The current ATI client uses considerable CPU processing time and you need to experiment with the environment variables to find the optimal PPD. My linux X6 averages 9-14K without a GPU client. My Vista64 X6 averages 6-9K while running a GPU client. Amaruk said it well ... we pick what we are proud of. Any folding contributes and all contributions matter.
Nathan_P
5 cores would be good - though i've found that just letting it run all 6 works for ME except in heavy gaming sessions - experiment with you favorite programs and see which works for you. Net browsing and word should be fine.MegaRock91 wrote:1) would 5 cores for SMP be okay? I really would like to use one core for myself. This rig is used to view the internet, among other average things like Office and multimedia activites(aka, using MS Word, and watching videos with VLC)Nathan_P wrote:
OpenCL is due "soon". however this is PG so their "soon" is slightly different to our "soon". I have noticed taht there are a couple of beta projects floating around that are testing the new core so progress is being made.
Not sure on the last question but i would imagine so.
EDIT I checked Wikipedia (http://en.wikipedia.org/wiki/Comparison ... sing_units) and found that OpenCL 1.1 is supported on HD 5000 Series GPU and HD 6000 Series GPU. HD 4000 Series and below doesn't have OpenCL.
So far, there hasn't been any official announcement for the requirements of running FahCore_16 on ATI/AMD GPUs so you will have to watch the usual places for more information
