1) I have the flags -SMP 6 -advmethods -verbosity 9 set. After reading mixed reviews on -forceasm, should I include this flag as well (also is -forceSSE no longer a working flag for AMD chips)?
2) I understand -bigadv seems to work only on Intel i7 CPUs, I can only use this flag if I emulate an 8 core VM?.
3) Are -SMP 6 and SMP pretty much the same for my cpu (I guess I should run -SMP 5 if I want to run a GPU client)?
4) I haven't folded very much (probably less than 2 WU), so my PPD with HFM shows only about 600-800PPD. This will increase once I've completed like 7-8 WU right?
5) Aside from the above flags, is there anything I am missing that will help increase my folding?
Thanks for your time in reading all that.
