Project: 6511 (Run 6, Clone 227, Gen 40): CoreStatus = 8B
johnT89
Post by johnT89 »
Ubuntu 10.10, 64bit.
Folded 250+ smp and gpu WUs and never seen this problem.
This problem occurred while running 4 uniprocessor wu's for testing purposes: 3 of them completed successfully, but not the fourth:
Launch directory:
Executable: ./fah6.exe
Arguments: -oneunit
[12:22:45] - Ask before connecting: No
[12:22:45] - User name:
[12:22:45] - User ID:
[12:22:45] - Machine ID: 5
[12:22:45]
[12:22:45] Loaded queue successfully.
[12:22:45]
[12:22:45] + Processing work unit
[12:22:45] Core required: FahCore_78.exe
[Febru:45] Core found.
[12:22:46] Working on queue slot 01 [February 27 12:22:46 UTC]
[12:22:46] + Working ...
[12:22:46]
[12:22:46] *------------------------------*
[12:22:46] Folding@Home Gromacs Core
[12:22:46] Version 1.90 (March 8, 2006)
[12:22:46]
[12:22:46] Preparing to commence simulation
[12:22:46] - Looking at optimizations...
[12:22:46] - Files status OK
[12:22:46] - Expanded 746747 -> 3750965 (decompressed 502.3 percent)
[12:22:46]
[12:22:46] Project: 6511 (Run 6, Clone 227, Gen 40)
[12:22:46]
[12:22:46] Assembly optimizations on if available.
[12:22:46] Entering M.D.
  Gromacs is Copyright (c) 1991-2003, University of Groningen, The Netherlands
        This inclusion of Gromacs code in the Folding@Home Core is under
        a special license (see http://folding.stanford.edu/gromacs.html)
         specially granted to Stanford by the copyright holders. If you
          are interested in using Gromacs, visit www.gromacs.org where
                you can download a free version of Gromacs under
         the terms of the GNU General Public License (GPL) as published
       by the Free Software Foundation; either version 2 of the License,
                     or (at your option) any later version.
[12:23:07] (Starting from checkpoint)
[12:23:07] Protein: UBIQUITIN MODEL1750 in water
[12:23:07]
[12:23:07] Writing local files
[12:23:07] Completed 165000 out of 250000 steps  (66%)
[12:23:07] Extra SSE boost OK.
Segmentation fault
[12:24:39] CoreStatus = 8B (139)
[12:24:39] Client-core communications error: ERROR 0x8b
[12:24:39] This is a sign of more serious problems, shutting down.
Re: Project: 6511 (Run 6, Clone 227, Gen 40): CoreStatus = 8
Unfortunately, there's only one EUE report for this WU in the DB ... it's a bit too early to conclude, but it looks like a bad one.
The WU has been successfully completed by another Donor.
