No appropriate work server was available; will try again in
sparkler
Post by sparkler »
im getting this and ive got a HD5850 and using -forcegpu ati_r800 -verbosity 9 flags cpu clients work fine though
[14:27:42] Loaded queue successfully.
[14:27:42] Initialization complete
[14:27:42] - Preparing to get new work unit...
[14:27:42] - Presenting message box asking to network.
[14:27:42] - Autosending finished units... [February 26 14:27:42 UTC]
[14:27:42] Trying to send all finished work units
[14:27:42] + No unsent completed units remaining.
[14:27:42] - Autosend completed
[14:27:43] + Attempting to get work packet
[14:27:43] - Will indicate memory of 8190 MB
[14:27:43] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 10, Stepping: 0
[14:27:43] - Connecting to assignment server
[14:27:43] Connecting to http://assign-GPU.stanford.edu:8080/
[14:27:44] Posted data.
[14:27:44] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:27:44] + Couldn't get work instructions.
[14:27:44] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[14:27:53] + Attempting to get work packet
[14:27:53] - Will indicate memory of 8190 MB
[14:27:53] - Connecting to assignment server
[14:27:53] Connecting to http://assign-GPU.stanford.edu:8080/
[14:27:54] Posted data.
[14:27:54] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:27:54] + Couldn't get work instructions.
[14:27:54] - Attempt #2  to get work failed, and no other work to do.
[14:28:19] + Attempting to get work packet
[14:28:19] - Will indicate memory of 8190 MB
[14:28:19] - Connecting to assignment server
[14:28:19] Connecting to http://assign-GPU.stanford.edu:8080/
[14:28:20] Posted data.
[14:28:20] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:28:20] + Couldn't get work instructions.
[14:28:20] - Attempt #3  to get work failed, and no other work to do.
[14:28:47] + Attempting to get work packet
[14:28:47] - Will indicate memory of 8190 MB
[14:28:47] - Connecting to assignment server
[14:28:47] Connecting to http://assign-GPU.stanford.edu:8080/
[14:28:48] Posted data.
[14:28:48] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:28:48] + Couldn't get work instructions.
[14:28:48] - Attempt #4  to get work failed, and no other work to do.
[14:29:31] + Attempting to get work packet
[14:29:31] - Will indicate memory of 8190 MB
[14:29:31] - Connecting to assignment server
[14:29:31] Connecting to http://assign-GPU.stanford.edu:8080/
[14:29:32] Posted data.
[14:29:32] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:29:32] + Couldn't get work instructions.
[14:29:32] - Attempt #5  to get work failed, and no other work to do.
[14:30:57] + Attempting to get work packet
[14:30:57] - Will indicate memory of 8190 MB
[14:30:57] - Connecting to assignment server
[14:30:57] Connecting to http://assign-GPU.stanford.edu:8080/
[14:30:58] Posted data.
[14:30:58] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:30:58] + Couldn't get work instructions.
[14:30:58] - Attempt #6  to get work failed, and no other work to do.
[14:33:40] + Attempting to get work packet
[14:33:40] - Will indicate memory of 8190 MB
[14:33:40] - Connecting to assignment server
[14:33:40] Connecting to http://assign-GPU.stanford.edu:8080/
[14:33:41] Posted data.
[14:33:41] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:33:41] + Couldn't get work instructions.
[14:33:41] - Attempt #7  to get work failed, and no other work to do.
Re: No appropriate work server was available; will try again
Since you didn't mention which client you're using ...
If you're using the 6.24 client (GPU2) the ati_r800 parameter is not recognized. You have to use ati_r700 to get work.
To have ati_r800 parameter recognized, you need the 6.34 client (GPU3).
sparkler
Post by sparkler »
im using 6.23 which the website recommends and the only other there is 6.41 thats for nvidia and i used ati_r700 and it works now thxs
