Hello. I got a pretty large WU I think, and I read through the log and found out it said "Warning: long 1-4 interactions" and was wondering what that means. It is 18.07 here, so it has been working on the same thing for a while now so I'm a bit concerned if something is broken or something.
[16:20:52] - Looking at optimizations...
[16:20:52] - Files status OK
[16:20:53] - Expanded 3610122 -> 16858811 (decompressed 466.9 percent)
[16:20:54]
[16:20:54] Project: 1487 (Run 0, Clone 553, Gen 21)
[16:20:54]
[16:20:54] Assembly optimizations on if available.
[16:20:54] Entering M.D.
[16:21:17] (Starting from checkpoint)
[16:21:17] Protein: p1487_DPPC_DOPC_CHOL
[16:21:17] Writing local files
[16:21:17] Completed 81619 out of 1000000 steps (8%)
[16:21:19] Extra 3DNow boost OK.
[16:21:19] Extra SSE boost OK.
[16:21:20] Warning: long 1-4 interactions
I'll let someone else handle the definition, but this thing takes 7-14 days, depending on your hardware. Don't worry about the slow progress. I'm on day 5 of one right now.
edit- On other WUs, "Long 1-4" will cause an EUE. On the 1487, it's "normal" and will just keep running.
# Linux Console Edition #######################################################
Folding@Home Client Version 5.04beta
http://folding.stanford.edu
Launch directory: /opt/foldingathome/1
Executable: /opt/foldingathome/1/FAH504-Linux.exe
[17:17:52] - Ask before connecting: No
[17:17:52] - User name: Torstein_Winterseth (Team 37651)
[17:17:52] - User ID: 663242D128BF6401
[17:17:52] - Machine ID: 1
[17:17:52]
[17:17:52] Work directory not found. Creating...
[17:17:52] Loaded queue successfully.
[17:17:52] + Benchmarking ...
[17:17:57]
[17:17:57] + Processing work unit
[17:17:57] Core required: FahCore_a0.exe
[17:17:57] Core found.
[17:17:57] Working on Unit 07 [March 24 17:17:57]
[17:17:57] + Working ...
[17:17:57]
[17:17:57] *------------------------------*
[17:17:57] Folding@Home Gromacs 3.3 Core
[17:17:57] Version 1.92 (April 17. 2007)
[17:17:57]
[17:17:57] Preparing to commence simulation
[17:17:57] - Looking at optimizations...
[17:17:57] - Created dyn
[17:17:57] - Files status OK
[17:17:57]
[17:17:57] Folding@home Core Shutdown: MISSING_WORK_FILES
[17:17:57] CoreStatus = 74 (116)
[17:17:57] The core could not find the work files specified. Removing from queue
[17:17:57] Deleting current work unit & continuing...
[17:17:57] - Preparing to get new work unit...
[17:17:57] + Attempting to get work packet
[17:17:57] - Connecting to assignment server
[17:17:58] - Successful: assigned to (171.64.65.111).
[17:17:58] + News From Folding@Home: Welcome to Folding@Home
[17:17:58] Loaded queue successfully.
[17:18:29] + Closed connections
[17:18:34]
[17:18:34] + Processing work unit
[17:18:34] Core required: FahCore_81.exe
[17:18:34] Core found.
[17:18:34] Working on Unit 08 [March 24 17:18:34]
[17:18:34] + Working ...
[17:18:34]
[17:18:34] *------------------------------*
[17:18:34] Folding@Home Gromacs Simulated Tempering Core
[17:18:34] Version 1.00 (Dec 9, 2006)
[17:18:34]
[17:18:34] Preparing to commence simulation
[17:18:34] - Looking at optimizations...
[17:18:34] - Created dyn
[17:18:34] - Files status OK
[17:18:35] - Expanded 1836189 -> 11202468 (decompressed 610.0 percent)
[17:18:35] - Starting from initial work packet
[17:18:35]
[17:18:35] Project: 3439 (Run 5, Clone 47, Gen 0)
[17:18:35]
[17:18:35] Assembly optimizations on if available.
[17:18:35] Entering M.D.
[17:18:42] Protein: p3439_ci2wt3M_folded_Amber03_Native
[17:18:42]
[17:18:42] Writing local files
[17:18:44] Extra SSE boost OK.
[17:18:45] Writing local files
[17:18:45] Completed 0 out of 50000 steps (0%)
[17:26:54] Writing local files
[17:26:54] Completed 500 out of 50000 steps (1%)
