Project: 6880 (Run 637, Clone 0, Gen 55)
dgermann
Post by dgermann »
I'm seeing multiple (over 20) "ERROR 0x0" failures at the same point (3%) with this WU.
System is a Intel Core 2 Duo E4500, 2.2 GHz, 1 GB RAM. Not sure if this is a bad WU or if my system is going south.
Thank you!
[13:24:44] + Attempting to get work packet
[13:24:44] - Connecting to assignment server
[13:24:44] - Successful: assigned to (171.67.108.33).
[13:24:44] + News From Folding@Home: Welcome to Folding@Home
[13:24:45] Loaded queue successfully.
[13:24:46] + Closed connections
[13:24:46]
[13:24:46] + Processing work unit
[13:24:46] Core required: FahCore_78.exe
[13:24:46] Core found.
[13:24:46] Working on Unit 06 [February 14 13:24:46]
[13:24:46] + Working ...
[13:24:46]
[13:24:46] *------------------------------*
[13:24:46] Folding@Home Gromacs Core
[13:24:46] Version 1.90 (March 8, 2006)
[13:24:46]
[13:24:46] Preparing to commence simulation
[13:24:46] - Looking at optimizations...
[13:24:46] - Created dyn
[13:24:46] - Files status OK
[13:24:46] - Expanded 375298 -> 1806556 (decompressed 481.3 percent)
[13:24:47] - Starting from initial work packet
[13:24:47]
[13:24:47] Project: 6880 (Run 637, Clone 0, Gen 55)
[13:24:47]
[13:24:47] Assembly optimizations on if available.
[13:24:47] Entering M.D.
[13:24:53] Protein: ALZHEIMER DISEASE AMYLOID
[13:24:53]
[13:24:53] Writing local files
[13:25:01] Extra SSE boost OK.
[13:25:01] Writing local files
[13:25:01] Completed 0 out of 250000 steps  (0%)
[13:29:49] Writing local files
[13:29:49] Completed 2500 out of 250000 steps  (1%)
[13:34:36] Writing local files
[13:34:36] Completed 5000 out of 250000 steps  (2%)
[13:39:24] Writing local files
[13:39:24] Completed 7500 out of 250000 steps  (3%)
[13:39:39] CoreStatus = 0 (0)
[13:39:39] Client-core communications error: ERROR 0x0
[13:39:39] Deleting current work unit & continuing...
[13:39:56] - Preparing to get new work unit...
[13:39:56] + Attempting to get work packet
[13:39:56] - Connecting to assignment server
[13:39:57] - Successful: assigned to (171.67.108.33).
[13:39:57] + News From Folding@Home: Welcome to Folding@Home
[13:39:57] Loaded queue successfully.
[13:39:59] + Closed connections
[13:40:04]
[13:40:04] + Processing work unit
[13:40:04] Core required: FahCore_78.exe
[13:40:04] Core found.
[13:40:04] Working on Unit 07 [February 14 13:40:04]
[13:40:04] + Working ...
[13:40:04]
[13:40:04] *------------------------------*
[13:40:04] Folding@Home Gromacs Core
[13:40:04] Version 1.90 (March 8, 2006)
[13:40:04]
[13:40:04] Preparing to commence simulation
[13:40:04] - Looking at optimizations...
[13:40:04] - Created dyn
[13:40:04] - Files status OK
[13:40:04] - Expanded 375298 -> 1806556 (decompressed 481.3 percent)
[13:40:05] - Starting from initial work packet
[13:40:05]
[13:40:05] Project: 6880 (Run 637, Clone 0, Gen 55)
[13:40:05]
[13:40:05] Assembly optimizations on if available.
[13:40:05] Entering M.D.
[13:40:11] Protein: ALZHEIMER DISEASE AMYLOID
[13:40:11]
[13:40:11] Writing local files
[13:40:19] Extra SSE boost OK.
[13:40:19] Writing local files
[13:40:19] Completed 0 out of 250000 steps  (0%)
[13:45:07] Writing local files
[13:45:07] Completed 2500 out of 250000 steps  (1%)
[13:49:54] Writing local files
[13:49:54] Completed 5000 out of 250000 steps  (2%)
[13:54:42] Writing local files
[13:54:42] Completed 7500 out of 250000 steps  (3%)
[13:54:57] CoreStatus = 0 (0)
[13:54:57] Client-core communications error: ERROR 0x0
[13:54:57] Deleting current work unit & continuing...
Re: Project: 6880 (Run 637, Clone 0, Gen 55)
Your report plus two other in the DB clearly indicates a bad WU. I've reported it.
