Project: 6805 (Run 990, Clone 1, Gen 13)
rwh202
3x GTX 1080 Ti
3x GTX 1060
Various other bits and pieces
Post by rwh202 »
Hi,
This one failed to get going and kept looping a good hundred times before I noticed and reset it:
                       Folding@Home Client Version 6.40r1
                          http://folding.stanford.edu
Launch directory: Z:\home\rob\GPU1
Executable: Z:\home\rob\GPU1\Folding@home.exe
Arguments: -forcegpu nvidia_fermi
[13:17:58] - Ask before connecting: No
[13:17:58] - User name: rwh202 (Team yyy)
[13:17:58] - User ID: zzz
[13:17:58] - Machine ID: 2
[13:17:58]
[11:21:40] + Attempting to get work packet
[11:21:40] Gpu type=3 species=20.
[11:21:40] - Connecting to assignment server
[11:21:41] - Successful: assigned to (171.64.65.64).
[11:21:41] + News From Folding@Home: Welcome to Folding@Home
[11:21:41] Loaded queue successfully.
[11:21:41] Gpu type=3 species=20.
[11:21:42] + Closed connections
[11:21:42]
[11:21:42] + Processing work unit
[11:21:42] Core required: FahCore_15.exe
[11:21:42] Core found.
[11:21:42] Working on queue slot 02 [February 13 11:21:42 UTC]
[11:21:42] + Working ...
[11:21:42]
[11:21:42] *------------------------------*
[11:21:42] Folding@Home GPU Core
[11:21:42] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[11:21:42]
[11:21:42] Build host: SimbiosNvdWin7
[11:21:42] Board Type: NVIDIA/CUDA
[11:21:42] Core      : x=15
[11:21:42]  Window's signal control handler registered.
[11:21:42] Preparing to commence simulation
[11:21:42] - Looking at optimizations...
[11:21:42] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[11:21:42] - Created dyn
[11:21:42] - Files status OK
[11:21:42] sizeof(CORE_PACKET_HDR) = 512 file=<>
[11:21:42] - Expanded 881 -> 7771 (decompressed 882.0 percent)
[11:21:42] Called DecompressByteArray: compressed_data_size=881 data_size=7771, decompressed_data_size=7771 diff=0
[11:21:42] - Digital signature verified
[11:21:42]
[11:21:42] Project: 6805 (Run 990, Clone 1, Gen 13)
[11:21:42]
[11:21:42] Error: Could not write local file.  Exiting.
[11:21:42] GuardedRun: run failure in DynamicWrapper
[11:21:42] Run: GuardedRun completed.
[11:21:47] Shutting down core workthread not completede
[11:21:47]
[11:21:47] Folding@home Core Shutdown: FILE_IO_ERROR
[11:21:50] CoreStatus = 75 (117)
[11:21:50] Error opening or reading from a file.
[11:21:50] Deleting current work unit & continuing...
[11:21:54] - Preparing to get new work unit...
[11:21:54] Cleaning up work directory
[11:21:54] + Attempting to get work packet
[11:21:54] Gpu type=3 species=20.
[11:21:54] - Connecting to assignment server
[11:21:55] - Successful: assigned to (171.64.65.64).
[11:21:55] + News From Folding@Home: Welcome to Folding@Home
[11:21:55] Loaded queue successfully.
[11:21:55] Gpu type=3 species=20.
[11:21:56] + Closed connections
[11:22:01]
[11:22:01] + Processing work unit
[11:22:01] Core required: FahCore_15.exe
[11:22:01] Core found.
[11:22:01] Working on queue slot 03 [February 13 11:22:01 UTC]
[11:22:01] + Working ...
[11:22:01]
[11:22:01] *------------------------------*
[11:22:01] Folding@Home GPU Core
[11:22:01] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[11:22:01]
[11:22:01] Build host: SimbiosNvdWin7
[11:22:01] Board Type: NVIDIA/CUDA
[11:22:01] Core      : x=15
[11:22:01]  Window's signal control handler registered.
[11:22:01] Preparing to commence simulation
[11:22:01] - Looking at optimizations...
[11:22:01] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[11:22:01] - Created dyn
[11:22:01] - Files status OK
[11:22:01] sizeof(CORE_PACKET_HDR) = 512 file=<>
[11:22:01] - Expanded 881 -> 7771 (decompressed 882.0 percent)
[11:22:01] Called DecompressByteArray: compressed_data_size=881 data_size=7771, decompressed_data_size=7771 diff=0
[11:22:01] - Digital signature verified
[11:22:01]
[11:22:01] Project: 6805 (Run 990, Clone 1, Gen 13)
[11:22:01]
[11:22:01] Error: Could not write local file.  Exiting.
[11:22:01] GuardedRun: run failure in DynamicWrapper
[11:22:01] Run: GuardedRun completed.
[11:22:06] Shutting down core workthread not completede
[11:22:06]
[11:22:06] Folding@home Core Shutdown: FILE_IO_ERROR
[11:22:09] CoreStatus = 75 (117)
[11:22:09] Error opening or reading from a file.
[11:22:09] Deleting current work unit & continuing...
This was on a GTX 460 that does run quite warm since I broke the fan, but it has run a few hundred WUs without problem and is now running a new unit OK.
Thanks
Rob
Re: Project: 6805 (Run 990, Clone 1, Gen 13)
No data in the WU Database yet. Have marked it for a follow-up.
gwildperson
Post by gwildperson »
I notice that you've used -forcegpu nvidia_fermi. That shouldn't be required for Client Version 6.40r1. Doesn't it detect your hardware correctly without it?
rwh202
3x GTX 1080 Ti
3x GTX 1060
Post by rwh202 »
gwildperson wrote:I notice that you've used -forcegpu nvidia_fermi. That shouldn't be required for Client Version 6.40r1. Doesn't it detect your hardware correctly without it?
No, I still need the -forcegpu flag - I don't think wine supports the same driver / device detection as native windows so I get the "at present your GPU is not supported ..." message otherwise.
I also took the opportunity to drop in the latest 6.41r2 executable and still the same.
Rob
Hyperlife
Post by Hyperlife »
rwh202 wrote:No, I still need the -forcegpu flag - I don't think wine supports the same driver / device detection as native windows so I get the "at present your GPU is not supported ..." message otherwise.
That's correct -- you must use the -forcegpu flag with Wine.
Nothing in the WU Database yet :(
tourbound129
Post by tourbound129 »
I picked up this exact same WU and it is giving me the same log that is posted above. It got picked up by one of my GTS 450's that has run hundreds of WU's without issue with temps in the high 50's/ low 60's.
I marked the WU as bad.
tourbound129
I can't seem to shake this WU. It keeps coming back over and over again. I keep deleting it and have gone as far as deleting everything associated with F@H but once I reinstall, my GTS 450 keeps getting it. The GTX 460 gets other work just fine in the same system and my GTS 450 in another rig is not having this problem either.
Any thoughts?
[01:34:51] Folding@home Core Shutdown: FILE_IO_ERROR
[01:34:54] CoreStatus = 75 (117)
[01:34:54] Error opening or reading from a file.
[01:34:54] Deleting current work unit & continuing...
[01:34:58] Trying to send all finished work units
[01:34:58] + No unsent completed units remaining.
[01:34:58] - Preparing to get new work unit...
[01:34:58] Cleaning up work directory
[01:34:58] + Attempting to get work packet
[01:34:58] Passkey found
[01:34:58] - Will indicate memory of 3060 MB
[01:34:58] Gpu type=3 species=20.
[01:34:58] - Connecting to assignment server
[01:34:58] Connecting to http://assign-GPU.stanford.edu:8080/
[01:34:59] Posted data.
[01:34:59] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[01:34:59] + News From Folding@Home: Welcome to Folding@Home
[01:34:59] Loaded queue successfully.
[01:34:59] Gpu type=3 species=20.
[01:34:59] Sent data
[01:34:59] Connecting to http://171.64.65.64:8080/
[01:35:00] Posted data.
[01:35:00] Initial: 0000; - Receiving payload (expected size: 1393)
[01:35:00] Conversation time very short, giving reduced weight in bandwidth avg
[01:35:00] - Downloaded at ~2 kB/s
[01:35:00] - Averaged speed for that direction ~2 kB/s
[01:35:00] + Received work.
[01:35:00] + Closed connections
Amaruk
Post by Amaruk »
You have to change the client's Machine ID to get a different assignment from the server before the current assignment times out. (5 days)
tourbound129
Thanks for the info. Back up and running now.
