Project: 6051 (Run 0, Clone 2, Gen 282)
codysluder
Post by codysluder »
[05:18:17] Folding@Home Gromacs SMP Core
[05:18:17] Version 2.19 (Mar 12, 2010)
[05:18:17]
[05:18:17] Preparing to commence simulation
[05:18:17] - Ensuring status. Please wait.
[05:18:27] - Assembly optimizations manually forced on.
[05:18:27] - Not checking prior termination.
[05:18:27] - Expanded 1763917 -> 2252021 (decompressed 127.6 percent)
[05:18:27] Called DecompressByteArray: compressed_data_size=1763917 data_size=2252021, decompressed_data_size=2252021 diff=0
[05:18:27] - Digital signature verified
[05:18:27]
[05:18:27] Project: 6051 (Run 0, Clone 2, Gen 282)
[05:18:27]
[05:18:27] Assembly optimizations on if available.
[05:18:27] Entering M.D.
[05:18:33] Using Gromacs checkpoints
[05:18:33] mdrun returned 255
[05:18:33] Going to send back what have done -- stepsTotalG=0
[05:18:33] Work fraction=0.0000 steps=0.
[05:18:37] logfile size=29674 infoLength=29674 edr=0 trr=25
[05:18:37] logfile size: 29674 info=29674 bed=0 hdr=25
[05:18:37] - Writing 30212 bytes of core data to disk...
[05:18:37]   ... Done.
[05:18:38]
[05:18:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[05:18:42] CoreStatus = 7A (122)
[05:18:42] Sending work to server
One immediate error and an otherwise stable machine moved on to other successful WUs.
Re: Project: 6051 (Run 0, Clone 2, Gen 282)
Well ... someone else had an immediate failure, but a third person completed it ...
codysluder wrote:[05:18:17] Folding@Home Gromacs SMP Core
There's a newer version of the core available. I'm not sure what the changes were, but if the people who are running 2.19 are getting errors and the people running 2.22 are not, it's time for the Pande Group to force an update.
Dobrodav
Post by Dobrodav »
Running 6051 0.1.350 WU
ETA is 2 days. Is that normal ? Should i drop it or continue to run ? Estimateted score ?
Sys specs: PhenomII X4 3000ghz 6 gb ram. V7 .1.21 client-type=advanced; extra core options = -forceasm, with one additional GPU slot running (nvidia gb200)
Welcome to the F@H Forum Dobrodav,
If you can complete the WU before the Preferred Deadline, there isn't any issue at all as long as you have already been qualified for the bonus points. If you haven't qualified for the bonus points, you will get base points only.
