F@H not utilizing cpu fully
Hzuiel
Post by Hzuiel »
I have the smp2 beta and followed the install guide to the best of my ability, yet it doesn't look like it's using any more of my cpu than the simple gui version was. I have an overclocked quad core and i'd really like to crunch some numbers. Right now I'm hovering around 30% cpu utilization.
Re: F@H not utilizing cpu fully
Welcome to foldingforum.org, Hzuiel.
In the location where FAH-smp keeps it's data files, you should find a file called FAHlog(.txt). Please post it here so we can figure out what's going on.
Assuming that you're running Windows, look in Task_Manager for processes called FahCore_xx.exe. How many do you see and what are their names?
What is the version number of the SMP client that you're running?
Qinsp
Post by Qinsp »
When you configure, make sure you select big (fah6 -configonly, about the 4th question?)
Then launch with fah6 -smp
Quality Inspection - Corona, CA, USA
Dimensional Inspection Laboratory
Pat McSwain, President
Hzuiel
Post by Hzuiel »
--- Opening Log file [February 6 18:33:30 UTC]
                       Folding@Home Client Version 6.30
                          http://folding.stanford.edu
Launch directory: C:\Users\Jared Arand\FAH
Executable: C:\Users\Jared Arand\FAH\Folding@home-Win32-x86.exe
[18:33:30] Configuring Folding@Home...
[18:41:12] - Ask before connecting: No
[18:41:12] - User name: Hzuiel (Team 92318)
[18:41:12] - User ID: 45DFA7D06F56AFB5
[18:41:12] - Machine ID: 1
[18:41:12]
[18:41:12] Work directory not found. Creating...
[18:41:12] Could not open work queue, generating new queue...
[18:41:12] - Preparing to get new work unit...
[18:41:12] Cleaning up work directory
[18:41:12] + Attempting to get work packet
[18:41:12] - Connecting to assignment server
[18:41:13] - Successful: assigned to (171.64.65.79).
[18:41:13] + News From Folding@Home: Welcome to Folding@Home
[18:41:13] Loaded queue successfully.
[18:41:14] + Closed connections
[18:41:14]
[18:41:14] + Processing work unit
[18:41:14] Core required: FahCore_a4.exe
[18:41:14] Core not found.
[18:41:14] - Core is not present or corrupted.
[18:41:14] - Attempting to download new core...
[18:41:14] + Downloading new core: FahCore_a4.exe
[18:41:15] + 10240 bytes downloaded
[18:41:15] + 20480 bytes downloaded
[18:41:15] + 30720 bytes downloaded
[18:41:15] + 40960 bytes downloaded
[18:41:15] + 51200 bytes downloaded
[18:41:15] + 61440 bytes downloaded
[18:41:15] + 71680 bytes downloaded
[18:41:15] + 81920 bytes downloaded
[18:41:15] + 92160 bytes downloaded
[18:41:15] + 102400 bytes downloaded
[18:41:15] + 112640 bytes downloaded
[18:41:15] + 122880 bytes downloaded
[18:41:15] + 133120 bytes downloaded
[18:41:15] + 143360 bytes downloaded
[18:41:15] + 153600 bytes downloaded
[18:41:15] + 163840 bytes downloaded
[18:41:15] + 174080 bytes downloaded
[18:41:15] + 184320 bytes downloaded
[18:41:15] + 194560 bytes downloaded
[18:41:15] + 204800 bytes downloaded
[18:41:15] + 215040 bytes downloaded
[18:41:15] + 225280 bytes downloaded
[18:41:15] + 235520 bytes downloaded
[18:41:15] + 245760 bytes downloaded
[18:41:15] + 256000 bytes downloaded
[18:41:15] + 266240 bytes downloaded
[18:41:15] + 276480 bytes downloaded
[18:41:15] + 286720 bytes downloaded
[18:41:15] + 296960 bytes downloaded
[18:41:15] + 307200 bytes downloaded
[18:41:15] + 317440 bytes downloaded
[18:41:15] + 327680 bytes downloaded
[18:41:15] + 337920 bytes downloaded
[18:41:15] + 348160 bytes downloaded
[18:41:15] + 358400 bytes downloaded
[18:41:15] + 368640 bytes downloaded
[18:41:15] + 378880 bytes downloaded
[18:41:15] + 389120 bytes downloaded
[18:41:15] + 399360 bytes downloaded
[18:41:15] + 409600 bytes downloaded
[18:41:15] + 419840 bytes downloaded
[18:41:16] + 430080 bytes downloaded
[18:41:16] + 440320 bytes downloaded
[18:41:16] + 450560 bytes downloaded
[18:41:16] + 460800 bytes downloaded
[18:41:16] + 471040 bytes downloaded
[18:41:16] + 481280 bytes downloaded
[18:41:16] + 491520 bytes downloaded
[18:41:16] + 501760 bytes downloaded
[18:41:16] + 512000 bytes downloaded
[18:41:16] + 522240 bytes downloaded
[18:41:16] + 532480 bytes downloaded
[18:41:16] + 542720 bytes downloaded
[18:41:16] + 552960 bytes downloaded
[18:41:16] + 563200 bytes downloaded
[18:41:16] + 573440 bytes downloaded
[18:41:16] + 583680 bytes downloaded
[18:41:16] + 593920 bytes downloaded
[18:41:16] + 604160 bytes downloaded
[18:41:16] + 614400 bytes downloaded
[18:41:16] + 624640 bytes downloaded
[18:41:16] + 634880 bytes downloaded
[18:41:16] + 645120 bytes downloaded
[18:41:16] + 655360 bytes downloaded
[18:41:16] + 665600 bytes downloaded
[18:41:16] + 675840 bytes downloaded
[18:41:16] + 686080 bytes downloaded
[18:41:16] + 696320 bytes downloaded
[18:41:16] + 706560 bytes downloaded
[18:41:16] + 716800 bytes downloaded
[18:41:16] + 727040 bytes downloaded
[18:41:16] + 737280 bytes downloaded
[18:41:16] + 747520 bytes downloaded
[18:41:16] + 757760 bytes downloaded
[18:41:16] + 768000 bytes downloaded
[18:41:16] + 778240 bytes downloaded
[18:41:16] + 788480 bytes downloaded
[18:41:16] + 798720 bytes downloaded
[18:41:16] + 808960 bytes downloaded
[18:41:16] + 819200 bytes downloaded
[18:41:16] + 829440 bytes downloaded
[18:41:16] + 839680 bytes downloaded
[18:41:16] + 849920 bytes downloaded
[18:41:16] + 860160 bytes downloaded
[18:41:16] + 870400 bytes downloaded
[18:41:17] + 880640 bytes downloaded
[18:41:17] + 890880 bytes downloaded
[18:41:17] + 901120 bytes downloaded
[18:41:17] + 911360 bytes downloaded
[18:41:17] + 921600 bytes downloaded
[18:41:17] + 931840 bytes downloaded
[18:41:17] + 942080 bytes downloaded
[18:41:17] + 952320 bytes downloaded
[18:41:17] + 962560 bytes downloaded
[18:41:17] + 972800 bytes downloaded
[18:41:17] + 983040 bytes downloaded
[18:41:17] + 993280 bytes downloaded
[18:41:17] + 1003520 bytes downloaded
[18:41:17] + 1013760 bytes downloaded
[18:41:17] + 1024000 bytes downloaded
[18:41:17] + 1034240 bytes downloaded
[18:41:17] + 1044480 bytes downloaded
[18:41:17] + 1054720 bytes downloaded
[18:41:17] + 1064960 bytes downloaded
[18:41:17] + 1075200 bytes downloaded
[18:41:17] + 1085440 bytes downloaded
[18:41:17] + 1095680 bytes downloaded
[18:41:17] + 1105920 bytes downloaded
[18:41:17] + 1116160 bytes downloaded
[18:41:17] + 1126400 bytes downloaded
[18:41:17] + 1136640 bytes downloaded
[18:41:17] + 1146880 bytes downloaded
[18:41:17] + 1157120 bytes downloaded
[18:41:17] + 1167360 bytes downloaded
[18:41:17] + 1177600 bytes downloaded
[18:41:17] + 1187840 bytes downloaded
[18:41:17] + 1198080 bytes downloaded
[18:41:17] + 1208320 bytes downloaded
[18:41:17] + 1218560 bytes downloaded
[18:41:17] + 1228800 bytes downloaded
[18:41:17] + 1239040 bytes downloaded
[18:41:17] + 1249280 bytes downloaded
[18:41:17] + 1259520 bytes downloaded
[18:41:17] + 1269760 bytes downloaded
[18:41:17] + 1280000 bytes downloaded
[18:41:17] + 1290240 bytes downloaded
[18:41:17] + 1300480 bytes downloaded
[18:41:17] + 1310720 bytes downloaded
[18:41:17] + 1320960 bytes downloaded
[18:41:18] + 1331200 bytes downloaded
[18:41:18] + 1341440 bytes downloaded
[18:41:18] + 1351680 bytes downloaded
[18:41:18] + 1361920 bytes downloaded
[18:41:18] + 1372160 bytes downloaded
[18:41:18] + 1382400 bytes downloaded
[18:41:18] + 1392640 bytes downloaded
[18:41:18] + 1402880 bytes downloaded
[18:41:18] + 1413120 bytes downloaded
[18:41:18] + 1423360 bytes downloaded
[18:41:18] + 1433600 bytes downloaded
[18:41:18] + 1443840 bytes downloaded
[18:41:18] + 1454080 bytes downloaded
[18:41:18] + 1464320 bytes downloaded
[18:41:18] + 1474560 bytes downloaded
[18:41:18] + 1484800 bytes downloaded
[18:41:18] + 1495040 bytes downloaded
[18:41:18] + 1505280 bytes downloaded
[18:41:18] + 1515520 bytes downloaded
[18:41:18] + 1525760 bytes downloaded
[18:41:18] + 1536000 bytes downloaded
[18:41:18] + 1546240 bytes downloaded
[18:41:18] + 1556480 bytes downloaded
[18:41:18] + 1566720 bytes downloaded
[18:41:18] + 1576960 bytes downloaded
[18:41:18] + 1587200 bytes downloaded
[18:41:18] + 1597440 bytes downloaded
[18:41:18] + 1607680 bytes downloaded
[18:41:18] + 1617920 bytes downloaded
[18:41:18] + 1628160 bytes downloaded
[18:41:18] + 1638400 bytes downloaded
[18:41:18] + 1648640 bytes downloaded
[18:41:18] + 1658880 bytes downloaded
[18:41:18] + 1669120 bytes downloaded
[18:41:18] + 1679360 bytes downloaded
[18:41:18] + 1689600 bytes downloaded
[18:41:18] + 1699840 bytes downloaded
[18:41:18] + 1710080 bytes downloaded
[18:41:18] + 1720320 bytes downloaded
[18:41:18] + 1730560 bytes downloaded
[18:41:18] + 1740800 bytes downloaded
[18:41:18] + 1751040 bytes downloaded
[18:41:18] + 1761280 bytes downloaded
[18:41:19] + 1771520 bytes downloaded
[18:41:19] + 1781760 bytes downloaded
[18:41:19] + 1792000 bytes downloaded
[18:41:19] + 1802240 bytes downloaded
[18:41:19] + 1812480 bytes downloaded
[18:41:19] + 1822720 bytes downloaded
[18:41:19] + 1832960 bytes downloaded
[18:41:19] + 1843200 bytes downloaded
[18:41:19] + 1853440 bytes downloaded
[18:41:19] + 1863680 bytes downloaded
[18:41:19] + 1873920 bytes downloaded
[18:41:19] + 1884160 bytes downloaded
[18:41:19] + 1894400 bytes downloaded
[18:41:19] + 1904640 bytes downloaded
[18:41:19] + 1914880 bytes downloaded
[18:41:19] + 1925120 bytes downloaded
[18:41:19] + 1935360 bytes downloaded
[18:41:19] + 1945600 bytes downloaded
[18:41:19] + 1955840 bytes downloaded
[18:41:19] + 1966080 bytes downloaded
[18:41:19] + 1976320 bytes downloaded
[18:41:19] + 1986560 bytes downloaded
[18:41:19] + 1996800 bytes downloaded
[18:41:19] + 2007040 bytes downloaded
[18:41:19] + 2017280 bytes downloaded
[18:41:19] + 2027520 bytes downloaded
[18:41:19] + 2037760 bytes downloaded
[18:41:19] + 2048000 bytes downloaded
[18:41:19] + 2058240 bytes downloaded
[18:41:19] + 2068480 bytes downloaded
[18:41:19] + 2078720 bytes downloaded
[18:41:19] + 2088960 bytes downloaded
[18:41:19] + 2099200 bytes downloaded
[18:41:19] + 2109440 bytes downloaded
[18:41:19] + 2119680 bytes downloaded
[18:41:19] + 2129920 bytes downloaded
[18:41:19] + 2140160 bytes downloaded
[18:41:19] + 2150400 bytes downloaded
[18:41:19] + 2160640 bytes downloaded
[18:41:19] + 2170880 bytes downloaded
[18:41:19] + 2181120 bytes downloaded
[18:41:19] + 2191360 bytes downloaded
[18:41:19] + 2201600 bytes downloaded
[18:41:19] + 2211840 bytes downloaded
[18:41:20] + 2222080 bytes downloaded
[18:41:20] + 2232320 bytes downloaded
[18:41:20] + 2242560 bytes downloaded
[18:41:20] + 2252800 bytes downloaded
[18:41:20] + 2263040 bytes downloaded
[18:41:20] + 2273280 bytes downloaded
[18:41:20] + 2283520 bytes downloaded
[18:41:20] + 2293760 bytes downloaded
[18:41:20] + 2304000 bytes downloaded
[18:41:20] + 2314240 bytes downloaded
[18:41:20] + 2324480 bytes downloaded
[18:41:20] + 2334720 bytes downloaded
[18:41:20] + 2344960 bytes downloaded
[18:41:20] + 2355200 bytes downloaded
[18:41:20] + 2365440 bytes downloaded
[18:41:20] + 2374817 bytes downloaded
[18:41:20] Verifying core Core_a4.fah...
[18:41:20] Signature is VALID
[18:41:20]
[18:41:20] Trying to unzip core FahCore_a4.exe
[18:41:21] Decompressed FahCore_a4.exe (7761408 bytes) successfully
[18:41:26] + Core successfully engaged
[18:41:31]
[18:41:31] + Processing work unit
[18:41:31] Core required: FahCore_a4.exe
[18:41:31] Core found.
[18:41:31] Working on queue slot 01 [February 6 18:41:31 UTC]
[18:41:31] + Working ...
[18:41:31]
[18:41:31] *------------------------------*
[18:41:31] Folding@Home Gromacs GB Core
[18:41:31] Version 2.25 (Sept. 16, 2010)
[18:41:31]
[18:41:31] Preparing to commence simulation
[18:41:31] - Looking at optimizations...
[18:41:31] - Created dyn
[18:41:31] - Files status OK
[18:41:31] - Expanded 255550 -> 397584 (decompressed 155.5 percent)
[18:41:31] Called DecompressByteArray: compressed_data_size=255550 data_size=397584, decompressed_data_size=397584 diff=0
[18:41:31] - Digital signature verified
[18:41:31]
[18:41:31] Project: 10424 (Run 46382, Clone 0, Gen 25)
[18:41:31]
[18:41:31] Assembly optimizations on if available.
[18:41:31] Entering M.D.
[18:41:37] Completed 0 out of 2000000 steps  (0%)
[18:51:26] Completed 20000 out of 2000000 steps  (1%)
[19:01:13] Completed 40000 out of 2000000 steps  (2%)
[19:10:59] Completed 60000 out of 2000000 steps  (3%)
[19:20:47] Completed 80000 out of 2000000 steps  (4%)
[19:30:36] Completed 100000 out of 2000000 steps  (5%)
[19:40:26] Completed 120000 out of 2000000 steps  (6%)
[19:50:16] Completed 140000 out of 2000000 steps  (7%)
[20:00:08] Completed 160000 out of 2000000 steps  (8%)
[20:10:04] Completed 180000 out of 2000000 steps  (9%)
[20:19:58] Completed 200000 out of 2000000 steps  (10%)
[20:29:48] Completed 220000 out of 2000000 steps  (11%)
[20:39:39] Completed 240000 out of 2000000 steps  (12%)
[20:49:29] Completed 260000 out of 2000000 steps  (13%)
[20:59:22] Completed 280000 out of 2000000 steps  (14%)
[21:09:13] Completed 300000 out of 2000000 steps  (15%)
[21:19:04] Completed 320000 out of 2000000 steps  (16%)
[21:28:55] Completed 340000 out of 2000000 steps  (17%)
[21:38:46] Completed 360000 out of 2000000 steps  (18%)
[21:48:37] Completed 380000 out of 2000000 steps  (19%)
[21:58:27] Completed 400000 out of 2000000 steps  (20%)
[22:08:17] Completed 420000 out of 2000000 steps  (21%)
[22:18:07] Completed 440000 out of 2000000 steps  (22%)
[22:27:58] Completed 460000 out of 2000000 steps  (23%)
[22:37:49] Completed 480000 out of 2000000 steps  (24%)
[22:47:39] Completed 500000 out of 2000000 steps  (25%)
[22:57:28] Completed 520000 out of 2000000 steps  (26%)
[23:07:18] Completed 540000 out of 2000000 steps  (27%)
[23:17:08] Completed 560000 out of 2000000 steps  (28%)
[23:26:57] Completed 580000 out of 2000000 steps  (29%)
[23:36:46] Completed 600000 out of 2000000 steps  (30%)
[23:46:35] Completed 620000 out of 2000000 steps  (31%)
[23:56:24] Completed 640000 out of 2000000 steps  (32%)
[00:06:13] Completed 660000 out of 2000000 steps  (33%)
[00:16:02] Completed 680000 out of 2000000 steps  (34%)
[00:25:50] Completed 700000 out of 2000000 steps  (35%)
[00:35:43] Completed 720000 out of 2000000 steps  (36%)
[00:45:37] Completed 740000 out of 2000000 steps  (37%)
[00:55:25] Completed 760000 out of 2000000 steps  (38%)
[01:06:51] Completed 780000 out of 2000000 steps  (39%)
[01:18:46] Completed 800000 out of 2000000 steps  (40%)
[01:30:10] Completed 820000 out of 2000000 steps  (41%)
[01:41:58] Completed 840000 out of 2000000 steps  (42%)
[01:53:41] Completed 860000 out of 2000000 steps  (43%)
[02:06:04] Completed 880000 out of 2000000 steps  (44%)
[02:18:23] Completed 900000 out of 2000000 steps  (45%)
[02:30:41] Completed 920000 out of 2000000 steps  (46%)
[02:43:05] Completed 940000 out of 2000000 steps  (47%)
[02:55:26] Completed 960000 out of 2000000 steps  (48%)
[03:07:34] Completed 980000 out of 2000000 steps  (49%)
[03:19:28] Completed 1000000 out of 2000000 steps  (50%)
[03:31:13] Completed 1020000 out of 2000000 steps  (51%)
[03:43:17] Completed 1040000 out of 2000000 steps  (52%)
[03:55:14] Completed 1060000 out of 2000000 steps  (53%)
[04:07:39] Completed 1080000 out of 2000000 steps  (54%)
[04:20:20] Completed 1100000 out of 2000000 steps  (55%)
[04:33:04] Completed 1120000 out of 2000000 steps  (56%)
[04:45:45] Completed 1140000 out of 2000000 steps  (57%)
I'm basically copied the installer into 3 different folders and ran 3 copies of it in order to utilized closer to 80% of my cpu.
I'm also running it on another dualcore desktop and my ps3, crankin out those numbers, lol.
You have forgotten the -smp flag hence the SMP2 Beta Client v6.30 has defaulted to the Classic Client Mode.
If you want to run the SMP2 Beta Client v6.30 then:
Step 1: Add -oneunit flag to the shortcuts (Details).
Step 2: Once the 3 Classic Clients finish their WUs, you can then delete the 2 copied you made.
Step 3: Replace the -oneunit flag with the -smp flag in the shortcut for the first copy.
Step 4: Start the Client using the (-smp) shortcut and your FAHlog will be similar to this:
--- Opening Log file [February 6 14:28:51 UTC]
Launch directory: E:\F@H SMP2
Executable: E:\F@H SMP2\Folding@home-Win32-x86.exe
Arguments: -smp -verbosity 9
[14:28:51] - Ask before connecting: No
[14:28:51] - User name: PantherX (Team 69411)
[14:28:51] - User ID:
[14:28:51] - Machine ID: 1
The -verbosity 9 flag makes the FAHlog more detailed which helps in troubleshooting so you may to add it too.
That way, the Client will use 100% of the CPU. Furthermore, you may want to use the passkey so that you can take advantage of the Bonus points once you qualify for it.
Hzuiel
Post by Hzuiel »
Alright, I will try that and let you know how it works. Right now though my work units are still a ways from completion.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Once you have added -smp to one of the clients then you should remove the other now extraneous clients you created.
echa
Post by echa »
I've got my GPU running at about 98% with the GPU client and I'm trying to figure out how to get the same with the CPU client. I've added -smp and set the file limit to big but I'm still only seeing about 40% of my processor being used.
--- Opening Log file [February 26 00:20:45 UTC]
                       Folding@Home Client Version 6.34
Launch directory: E:\Shared\Stuff to Save
Executable: E:\Shared\Stuff to Save\FAH6.34-win32-SMP.exe
Arguments: -verbosity 9 -smp
[00:20:45] - Ask before connecting: No
[00:20:45] - User name: Daniel_Cullen (Team 0)
[00:20:45] - User ID: 26064D20497D57EB
[00:20:45] - Machine ID: 1
[00:20:45]
[00:20:45] Loaded queue successfully.
[00:20:45]
[00:20:45] - Autosending finished units... [February 26 00:20:45 UTC]
[00:20:45] + Processing work unit
[00:20:45] Trying to send all finished work units
[00:20:45] Work type 78 not eligible for variable processors
[00:20:45] + No unsent completed units remaining.
[00:20:45] Core required: FahCore_78.exe
[00:20:45] - Autosend completed
[00:20:45] Core found.
[00:20:45] Working on queue slot 01 [February 26 00:20:45 UTC]
[00:20:45] + Working ...
[00:20:45] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -nice 19 -checkpoint 15 -verbose -lifeline 5932 -version 634'
[00:20:45]
[00:20:45] *------------------------------*
[00:20:45] Folding@Home Gromacs Core
[00:20:45] Version 1.90 (March 8, 2006)
[00:20:45]
[00:20:45] Preparing to commence simulation
[00:20:45] - Looking at optimizations...
[00:20:45] - Files status OK
[00:20:46] - Expanded 375804 -> 1806556 (decompressed 480.7 percent)
[00:20:46]
[00:20:46] Project: 6880 (Run 609, Clone 3, Gen 73)
[00:20:46]
[00:20:46] Assembly optimizations on if available.
[00:20:46] Entering M.D.
[00:21:06] (Starting from checkpoint)
[00:21:06] Protein: ALZHEIMER DISEASE AMYLOID
[00:21:06]
[00:21:06] Writing local files
[00:21:49] Completed 2500 out of 250000 steps  (1%)
[00:21:49] Extra SSE boost OK.
If it helps, I'm running:
Win 7 home premium x64
i7 920 @ 2.67GHz
Nvidia GTX 570
6GB DDR3 @ 1333
1.25TB HDD space spread across 2 HDDs(one 500gb and one 750).
750W PSU
Welcome to the F@H Forum echa,
It looks like the Client downloaded a Classic WU before so is now processing it. Once it finishes this WU, it should download a SMP2 WU which uses FahCore_a3 and will use 100% of the CPU.
Fahrenheit451
Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB
Post by Fahrenheit451 »
@echa: You should add a passkey to your configuration to get a bonus after your 10th SMP WU (http://folding.stanford.edu/English/FAQ-passkey).
dandos23
Post by dandos23 »
Hi guys
I seem to be having the same problem and have followed everything in here and on the install guide (I think I did it right).
Here is the text file.
--- Opening Log file [June 22 17:24:17 UTC]
Launch directory: C:\Users\Dave\FAH
Executable: C:\Users\Dave\FAH\FAH6.exe
[17:24:17] Configuring Folding@Home...
[17:31:23] - Ask before connecting: Yes
[17:31:23] - User name: dandos23 (Team 208177)
[17:31:23] - User ID: 19123DDA3328CFB2
[17:31:23] - Machine ID: 1
[17:31:23]
[17:31:23] Work directory not found. Creating...
[17:31:23] Could not open work queue, generating new queue...
[17:31:23] - Preparing to get new work unit...
[17:31:23] - Autosending finished units... [June 22 17:31:23 UTC]
[17:31:23] - Presenting message box asking to network.
[17:31:23] Trying to send all finished work units
[17:31:23] + No unsent completed units remaining.
[17:31:23] - Autosend completed
[17:31:27] Cleaning up work directory
[17:31:27] + Attempting to get work packet
[17:31:27] Passkey found
[17:31:27] - Will indicate memory of 8190 MB
[17:31:27] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 4, Stepping: 3
[17:31:27] - Connecting to assignment server
[17:31:27] Connecting to http://assign.stanford.edu:8080/
[17:31:29] Posted data.
[17:31:29] Initial: 8F80; - Successful: assigned to (128.143.48.226).
[17:31:29] + News From Folding@Home: Welcome to Folding@Home
[17:31:29] Loaded queue successfully.
[17:31:29] Sent data
[17:31:29] Connecting to http://128.143.48.226:8080/
[17:31:30] Posted data.
[17:31:30] Initial: 0000; - Receiving payload (expected size: 1490265)
[17:31:36] - Downloaded at ~242 kB/s
[17:31:36] - Averaged speed for that direction ~242 kB/s
[17:31:36] + Received work.
[17:31:36] + Connections closed: You may now disconnect
[17:31:36]
[17:31:36] + Processing work unit
[17:31:36] Work type a6 not eligible for variable processors
[17:31:36] Core required: FahCore_a6.exe
[17:31:36] Core not found.
[17:31:36] - Core is not present or corrupted.
[17:31:36] - Attempting to download new core...
[17:31:36] + Downloading new core: FahCore_a6.exe
[17:31:36] Downloading core (/~pande/Win32/x86/Core_a6.fah from www.stanford.edu)
[17:31:36] - Presenting message box asking to network.
[17:31:39] Initial: AFDE; + 10240 bytes downloaded
[17:31:39] Initial: 9A0D; + 20480 bytes downloaded
[17:31:39] Initial: B53A; + 30720 bytes downloaded
[17:31:39] Initial: 0353; + 40960 bytes downloaded
[17:31:39] Initial: 3AB8; + 51200 bytes downloaded
[17:31:39] Initial: B568; + 61440 bytes downloaded
[17:31:39] Initial: 0676; + 71680 bytes downloaded
[17:31:39] Initial: CAFA; + 81920 bytes downloaded
[17:31:40] Initial: FA6C; + 92160 bytes downloaded
[17:31:40] Initial: 1860; + 102400 bytes downloaded
[17:31:40] Initial: 7BD7; + 112640 bytes downloaded
[17:31:40] Initial: 2CDB; + 122880 bytes downloaded
[17:31:40] Initial: 6D41; + 133120 bytes downloaded
[17:31:40] Initial: 3FCA; + 143360 bytes downloaded
[17:31:40] Initial: 9DE5; + 153600 bytes downloaded
[17:31:40] Initial: 3318; + 163840 bytes downloaded
[17:31:40] Initial: 1092; + 174080 bytes downloaded
[17:31:40] Initial: A73A; + 184320 bytes downloaded
[17:31:40] Initial: AEAB; + 194560 bytes downloaded
[17:31:40] Initial: F42A; + 204800 bytes downloaded
[17:31:40] Initial: 0EA7; + 215040 bytes downloaded
[17:31:40] Initial: D98F; + 225280 bytes downloaded
[17:31:40] Initial: D99B; + 235520 bytes downloaded
[17:31:40] Initial: 5FE8; + 245760 bytes downloaded
[17:31:40] Initial: 8DF5; + 256000 bytes downloaded
[17:31:41] Initial: B846; + 266240 bytes downloaded
[17:31:41] Initial: 50D6; + 276480 bytes downloaded
[17:31:41] Initial: D74C; + 286720 bytes downloaded
[17:31:41] Initial: 71BC; + 296960 bytes downloaded
[17:31:41] Initial: E2DF; + 307200 bytes downloaded
[17:31:41] Initial: 71E3; + 317440 bytes downloaded
[17:31:41] Initial: 118A; + 327680 bytes downloaded
[17:31:41] Initial: F9B3; + 337920 bytes downloaded
[17:31:41] Initial: 099E; + 348160 bytes downloaded
[17:31:41] Initial: 2108; + 358400 bytes downloaded
[17:31:41] Initial: 7C24; + 368640 bytes downloaded
[17:31:41] Initial: EEB5; + 378880 bytes downloaded
[17:31:41] Initial: F6C1; + 389120 bytes downloaded
[17:31:41] Initial: B3B6; + 399360 bytes downloaded
[17:31:41] Initial: E6B5; + 409600 bytes downloaded
[17:31:41] Initial: B8BB; + 419840 bytes downloaded
[17:31:41] Initial: 253E; + 430080 bytes downloaded
[17:31:42] Initial: 61F9; + 440320 bytes downloaded
[17:31:42] Initial: 50B6; + 450560 bytes downloaded
[17:31:42] Initial: 6519; + 460800 bytes downloaded
[17:31:42] Initial: A758; + 471040 bytes downloaded
[17:31:42] Initial: 0E4E; + 481280 bytes downloaded
[17:31:42] Initial: 321C; + 491520 bytes downloaded
[17:31:42] Initial: C9AF; + 501760 bytes downloaded
[17:31:42] Initial: 94DA; + 512000 bytes downloaded
[17:31:42] Initial: 9888; + 522240 bytes downloaded
[17:31:42] Initial: 6161; + 532480 bytes downloaded
[17:31:42] Initial: 39D6; + 542720 bytes downloaded
[17:31:42] Initial: 0C30; + 552960 bytes downloaded
[17:31:42] Initial: 43C3; + 563200 bytes downloaded
[17:31:42] Initial: 37B6; + 573440 bytes downloaded
[17:31:42] Initial: CEB3; + 583680 bytes downloaded
[17:31:42] Initial: 8C9F; + 593920 bytes downloaded
[17:31:42] Initial: 6172; + 604160 bytes downloaded
[17:31:43] Initial: 756B; + 614400 bytes downloaded
[17:31:43] Initial: 56AD; + 624640 bytes downloaded
[17:31:43] Initial: C89B; + 634880 bytes downloaded
[17:31:43] Initial: 3AAF; + 645120 bytes downloaded
[17:31:43] Initial: 4F12; + 655360 bytes downloaded
[17:31:43] Initial: 5098; + 665600 bytes downloaded
[17:31:43] Initial: B24E; + 675840 bytes downloaded
[17:31:43] Initial: 770E; + 686080 bytes downloaded
[17:31:43] Initial: 31D2; + 696320 bytes downloaded
[17:31:43] Initial: 92A2; + 706560 bytes downloaded
[17:31:43] Initial: 7FF3; + 716800 bytes downloaded
[17:31:43] Initial: 0E6D; + 727040 bytes downloaded
[17:31:43] Initial: 62C7; + 737280 bytes downloaded
[17:31:43] Initial: 149F; + 747520 bytes downloaded
[17:31:43] Initial: 114B; + 757760 bytes downloaded
[17:31:43] Initial: D1CA; + 768000 bytes downloaded
[17:31:43] Initial: 7332; + 778240 bytes downloaded
[17:31:44] Initial: D559; + 788480 bytes downloaded
[17:31:44] Initial: 8A07; + 798720 bytes downloaded
[17:31:44] Initial: C510; + 808960 bytes downloaded
[17:31:44] Initial: 926A; + 819200 bytes downloaded
[17:31:44] Initial: 9428; + 829440 bytes downloaded
[17:31:44] Initial: CACF; + 839680 bytes downloaded
[17:31:44] Initial: 641A; + 849920 bytes downloaded
[17:31:44] Initial: 39B0; + 860160 bytes downloaded
[17:31:44] Initial: 40B8; + 870400 bytes downloaded
[17:31:44] Initial: 711A; + 880640 bytes downloaded
[17:31:44] Initial: 563C; + 890880 bytes downloaded
[17:31:44] Initial: EEEF; + 901120 bytes downloaded
[17:31:44] Initial: 4110; + 911360 bytes downloaded
[17:31:44] Initial: 9451; + 921600 bytes downloaded
[17:31:44] Initial: CF1B; + 931840 bytes downloaded
[17:31:44] Initial: 4F84; + 942080 bytes downloaded
[17:31:45] Initial: B7AB; + 952320 bytes downloaded
[17:31:45] Initial: 0555; + 962560 bytes downloaded
[17:31:45] Initial: 228A; + 972800 bytes downloaded
[17:31:45] Initial: 4E4C; + 983040 bytes downloaded
[17:31:45] Initial: 6D90; + 993280 bytes downloaded
[17:31:45] Initial: 7533; + 1003520 bytes downloaded
[17:31:45] Initial: 0082; + 1013760 bytes downloaded
[17:31:45] Initial: 1EEC; + 1024000 bytes downloaded
[17:31:45] Initial: 735B; + 1034240 bytes downloaded
[17:31:45] Initial: 1586; + 1044480 bytes downloaded
[17:31:45] Initial: E7EC; + 1054720 bytes downloaded
[17:31:45] Initial: 928D; + 1064960 bytes downloaded
[17:31:45] Initial: 81D9; + 1075200 bytes downloaded
[17:31:45] Initial: 0D24; + 1085440 bytes downloaded
[17:31:46] Initial: D6A0; + 1095680 bytes downloaded
[17:31:46] Initial: A626; + 1105920 bytes downloaded
[17:31:46] Initial: AC80; + 1116160 bytes downloaded
[17:31:46] Initial: BBD3; + 1126400 bytes downloaded
[17:31:46] Initial: 5AD7; + 1136640 bytes downloaded
[17:31:46] Initial: 1A45; + 1146880 bytes downloaded
[17:31:46] Initial: 8320; + 1157120 bytes downloaded
[17:31:46] Initial: 3DD9; + 1167360 bytes downloaded
[17:31:46] Initial: 242A; + 1177600 bytes downloaded
[17:31:46] Initial: 9612; + 1187840 bytes downloaded
[17:31:46] Initial: 3F76; + 1198080 bytes downloaded
[17:31:46] Initial: 56C7; + 1208320 bytes downloaded
[17:31:46] Initial: 774B; + 1218560 bytes downloaded
[17:31:46] Initial: 22EA; + 1228800 bytes downloaded
[17:31:46] Initial: 0322; + 1239040 bytes downloaded
[17:31:46] Initial: 0DBC; + 1249280 bytes downloaded
[17:31:46] Initial: 9C57; + 1259520 bytes downloaded
[17:31:47] Initial: FD63; + 1269760 bytes downloaded
[17:31:47] Initial: A259; + 1280000 bytes downloaded
[17:31:47] Initial: 3BE3; + 1290240 bytes downloaded
[17:31:47] Initial: 8AA0; + 1300480 bytes downloaded
[17:31:47] Initial: B8FE; + 1310720 bytes downloaded
[17:31:47] Initial: 68EF; + 1320960 bytes downloaded
[17:31:47] Initial: 1D88; + 1331200 bytes downloaded
[17:31:47] Initial: 8BBC; + 1341440 bytes downloaded
[17:31:47] Initial: 04D5; + 1351680 bytes downloaded
[17:31:47] Initial: 1584; + 1361920 bytes downloaded
[17:31:47] Initial: AE62; + 1372160 bytes downloaded
[17:31:47] Initial: 0044; + 1382400 bytes downloaded
[17:31:47] Initial: E195; + 1392640 bytes downloaded
[17:31:47] Initial: CAF7; + 1402880 bytes downloaded
[17:31:47] Initial: 3821; + 1413120 bytes downloaded
[17:31:47] Initial: A585; + 1423360 bytes downloaded
[17:31:47] Initial: 0B17; + 1433600 bytes downloaded
[17:31:48] Initial: A1C1; + 1443840 bytes downloaded
[17:31:48] Initial: 425D; + 1454080 bytes downloaded
[17:31:48] Initial: 3BC5; + 1464320 bytes downloaded
[17:31:48] Initial: 9FDF; + 1474560 bytes downloaded
[17:31:48] Initial: AC4C; + 1484800 bytes downloaded
[17:31:48] Initial: 42FC; + 1495040 bytes downloaded
[17:31:48] Initial: B120; + 1505280 bytes downloaded
[17:31:48] Initial: DD64; + 1515520 bytes downloaded
[17:31:48] Initial: 226A; + 1525760 bytes downloaded
[17:31:48] Initial: 2295; + 1536000 bytes downloaded
[17:31:48] Initial: 280A; + 1546240 bytes downloaded
[17:31:48] Initial: A461; + 1556480 bytes downloaded
[17:31:48] Initial: 476E; + 1566720 bytes downloaded
[17:31:48] Initial: 1091; + 1576960 bytes downloaded
[17:31:48] Initial: D9E4; + 1587200 bytes downloaded
[17:31:48] Initial: 05D8; + 1597440 bytes downloaded
[17:31:48] Initial: D4FE; + 1607680 bytes downloaded
[17:31:49] Initial: AD56; + 1617920 bytes downloaded
[17:31:49] Initial: 904D; + 1628160 bytes downloaded
[17:31:49] Initial: 8811; + 1638400 bytes downloaded
[17:31:49] Initial: 7A0A; + 1648640 bytes downloaded
[17:31:49] Initial: D8B8; + 1658880 bytes downloaded
[17:31:49] Initial: 2D53; + 1669120 bytes downloaded
[17:31:49] Initial: 55B9; + 1679360 bytes downloaded
[17:31:49] Initial: FB53; + 1689600 bytes downloaded
[17:31:49] Initial: 687D; + 1699840 bytes downloaded
[17:31:49] Initial: ACC3; + 1710080 bytes downloaded
[17:31:49] Initial: 3F57; + 1720320 bytes downloaded
[17:31:49] Initial: 156A; + 1730560 bytes downloaded
[17:31:49] Initial: 7109; + 1740800 bytes downloaded
[17:31:49] Initial: 5FF9; + 1751040 bytes downloaded
[17:31:49] Initial: 4DA7; + 1761280 bytes downloaded
[17:31:49] Initial: 358F; + 1771520 bytes downloaded
[17:31:49] Initial: 0962; + 1781760 bytes downloaded
[17:31:50] Initial: 8ADA; + 1792000 bytes downloaded
[17:31:50] Initial: 9A13; + 1802240 bytes downloaded
[17:31:50] Initial: 9B68; + 1812480 bytes downloaded
[17:31:50] Initial: EA10; + 1822720 bytes downloaded
[17:31:50] Initial: 848B; + 1832960 bytes downloaded
[17:31:50] Initial: 73CD; + 1843200 bytes downloaded
[17:31:50] Initial: C960; + 1853440 bytes downloaded
[17:31:50] Initial: 7EE3; + 1863680 bytes downloaded
[17:31:50] Initial: D718; + 1873920 bytes downloaded
[17:31:50] Initial: 967A; + 1884160 bytes downloaded
[17:31:50] Initial: EF7E; + 1894400 bytes downloaded
[17:31:50] Initial: 421D; + 1904640 bytes downloaded
[17:31:50] Initial: CE45; + 1914880 bytes downloaded
[17:31:50] Initial: 6CE2; + 1925120 bytes downloaded
[17:31:50] Initial: 509C; + 1935360 bytes downloaded
[17:31:50] Initial: 0467; + 1945600 bytes downloaded
[17:31:50] Initial: 3591; + 1955840 bytes downloaded
[17:31:51] Initial: 5454; + 1966080 bytes downloaded
[17:31:51] Initial: 67DA; + 1976320 bytes downloaded
[17:31:51] Initial: 211C; + 1986560 bytes downloaded
[17:31:51] Initial: 64CF; + 1996800 bytes downloaded
[17:31:51] Initial: 6A0C; + 2007040 bytes downloaded
[17:31:51] Initial: 41D5; + 2017280 bytes downloaded
[17:31:51] Initial: 3B0A; + 2027520 bytes downloaded
[17:31:51] Initial: 11C5; + 2037760 bytes downloaded
[17:31:51] Initial: 0D23; + 2048000 bytes downloaded
[17:31:51] Initial: 167A; + 2058240 bytes downloaded
[17:31:51] Initial: D4AF; + 2068480 bytes downloaded
[17:31:51] Initial: A79F; + 2078720 bytes downloaded
[17:31:51] Initial: BA48; + 2088960 bytes downloaded
[17:31:51] Initial: C114; + 2099200 bytes downloaded
[17:31:51] Initial: 4B3C; + 2109440 bytes downloaded
[17:31:51] Initial: BFB7; + 2119680 bytes downloaded
[17:31:51] Initial: BD07; + 2129920 bytes downloaded
[17:31:52] Initial: 5145; + 2140160 bytes downloaded
[17:31:52] Initial: 0614; + 2150400 bytes downloaded
[17:31:52] Initial: 4708; + 2160640 bytes downloaded
[17:31:52] Initial: 22E0; + 2170880 bytes downloaded
[17:31:52] Initial: FBEF; + 2181120 bytes downloaded
[17:31:52] Initial: A88A; + 2191360 bytes downloaded
[17:31:52] Initial: F513; + 2201600 bytes downloaded
[17:31:52] Initial: 8B58; + 2211840 bytes downloaded
[17:31:52] Initial: 9E91; + 2222080 bytes downloaded
[17:31:52] Initial: 1127; + 2232320 bytes downloaded
[17:31:52] Initial: 5BCE; + 2242560 bytes downloaded
[17:31:52] Initial: D569; + 2252800 bytes downloaded
[17:31:52] Initial: D9DB; + 2263040 bytes downloaded
[17:31:52] Initial: EBED; + 2273280 bytes downloaded
[17:31:52] Initial: 26A3; + 2283520 bytes downloaded
[17:31:52] Initial: 4A46; + 2293760 bytes downloaded
[17:31:52] Initial: C97E; + 2304000 bytes downloaded
[17:31:53] Initial: BFFB; + 2314240 bytes downloaded
[17:31:53] Initial: B4E6; + 2324480 bytes downloaded
[17:31:53] Initial: 5E33; + 2334720 bytes downloaded
[17:31:53] Initial: 4DA6; + 2344960 bytes downloaded
[17:31:53] Initial: 4847; + 2355200 bytes downloaded
[17:31:53] Initial: B834; + 2365440 bytes downloaded
[17:31:53] Initial: 8A4A; + 2375680 bytes downloaded
[17:31:53] Initial: 5211; + 2385920 bytes downloaded
[17:31:53] Initial: 1AC2; + 2396160 bytes downloaded
[17:31:53] Initial: 784E; + 2406400 bytes downloaded
[17:31:53] Initial: 83FD; + 2416640 bytes downloaded
[17:31:53] Initial: A043; + 2426880 bytes downloaded
[17:31:53] Initial: E89D; + 2437120 bytes downloaded
[17:31:53] Initial: 518C; + 2447360 bytes downloaded
[17:31:53] Initial: 6496; + 2457600 bytes downloaded
[17:31:53] Initial: DBB9; + 2467840 bytes downloaded
[17:31:53] Initial: C5E2; + 2478080 bytes downloaded
[17:31:53] Initial: CF2E; + 2488320 bytes downloaded
[17:31:54] Initial: B516; + 2498560 bytes downloaded
[17:31:54] Initial: ACBD; + 2508800 bytes downloaded
[17:31:54] Initial: 26D3; + 2519040 bytes downloaded
[17:31:54] Initial: 3419; + 2529280 bytes downloaded
[17:31:54] Initial: 994A; + 2539520 bytes downloaded
[17:31:54] Initial: 45F7; + 2549760 bytes downloaded
[17:31:54] Initial: 4F44; + 2560000 bytes downloaded
[17:31:54] Initial: DE47; + 2570240 bytes downloaded
[17:31:54] Initial: 9A2E; + 2580480 bytes downloaded
[17:31:54] Initial: CE3A; + 2590720 bytes downloaded
[17:31:54] Initial: BA48; + 2600960 bytes downloaded
[17:31:54] Initial: D7DF; + 2611200 bytes downloaded
[17:31:54] Initial: AA14; + 2621440 bytes downloaded
[17:31:54] Initial: 7C9D; + 2631680 bytes downloaded
[17:31:54] Initial: 2B59; + 2641920 bytes downloaded
[17:31:54] Initial: 03D1; + 2652160 bytes downloaded
[17:31:55] Initial: 33CC; + 2662400 bytes downloaded
[17:31:55] Initial: EB6A; + 2672640 bytes downloaded
[17:31:55] Initial: 0985; + 2682880 bytes downloaded
[17:31:55] Initial: C2D1; + 2693120 bytes downloaded
[17:31:55] Initial: ADC8; + 2703360 bytes downloaded
[17:31:55] Initial: 52D4; + 2713600 bytes downloaded
[17:31:55] Initial: 0C92; + 2723840 bytes downloaded
[17:31:55] Initial: A3BF; + 2734080 bytes downloaded
[17:31:55] Initial: 434E; + 2744320 bytes downloaded
[17:31:55] Initial: 2008; + 2754560 bytes downloaded
[17:31:55] Initial: 83C0; + 2764800 bytes downloaded
[17:31:55] Initial: C06D; + 2775040 bytes downloaded
[17:31:55] Initial: E083; + 2785280 bytes downloaded
[17:31:55] Initial: 410E; + 2795520 bytes downloaded
[17:31:55] Initial: 592C; + 2805760 bytes downloaded
[17:31:55] Initial: 71CA; + 2816000 bytes downloaded
[17:31:55] Initial: EB4C; + 2826240 bytes downloaded
[17:31:56] Initial: 48B6; + 2836480 bytes downloaded
[17:31:56] Initial: 60B8; + 2846720 bytes downloaded
[17:31:56] Initial: 1423; + 2856960 bytes downloaded
[17:31:56] Initial: E4AD; + 2867200 bytes downloaded
[17:31:56] Initial: 0652; + 2877440 bytes downloaded
[17:31:56] Initial: C8B2; + 2887680 bytes downloaded
[17:31:56] Initial: 5E8C; + 2897920 bytes downloaded
[17:31:56] Initial: 9D50; + 2908160 bytes downloaded
[17:31:56] Initial: 67B8; + 2918400 bytes downloaded
[17:31:56] Initial: 6DBF; + 2928640 bytes downloaded
[17:31:56] Initial: AEF3; + 2938880 bytes downloaded
[17:31:56] Initial: 1EBE; + 2949120 bytes downloaded
[17:31:56] Initial: 8BA3; + 2959360 bytes downloaded
[17:31:56] Initial: 7C1E; + 2969600 bytes downloaded
[17:31:56] Initial: 47DC; + 2979840 bytes downloaded
[17:31:56] Initial: A35D; + 2990080 bytes downloaded
[17:31:56] Initial: E46C; + 3000320 bytes downloaded
[17:31:57] Initial: A7AE; + 3010560 bytes downloaded
[17:31:57] Initial: 2A93; + 3020800 bytes downloaded
[17:31:57] Initial: F292; + 3031040 bytes downloaded
[17:31:57] Initial: 38D5; + 3041280 bytes downloaded
[17:31:57] Initial: 0C14; + 3051520 bytes downloaded
[17:31:57] Initial: 3D06; + 3061760 bytes downloaded
[17:31:57] Initial: 5592; + 3072000 bytes downloaded
[17:31:57] Initial: 3CAE; + 3082240 bytes downloaded
[17:31:57] Initial: 0F31; + 3092480 bytes downloaded
[17:31:57] Initial: 764B; + 3102720 bytes downloaded
[17:31:57] Initial: 905B; + 3112960 bytes downloaded
[17:31:57] Initial: E13D; + 3123200 bytes downloaded
[17:31:57] Initial: AEC3; + 3133440 bytes downloaded
[17:31:57] Initial: F8F5; + 3143680 bytes downloaded
[17:31:57] Initial: F49D; + 3153920 bytes downloaded
[17:31:57] Initial: C8E5; + 3164160 bytes downloaded
[17:31:57] Initial: F6B9; + 3174400 bytes downloaded
[17:31:58] Initial: 88C9; + 3184640 bytes downloaded
[17:31:58] Initial: 25FD; + 3194880 bytes downloaded
[17:31:58] Initial: 92AA; + 3205120 bytes downloaded
[17:31:58] Initial: 7EB6; + 3215360 bytes downloaded
[17:31:58] Initial: 06F2; + 3225600 bytes downloaded
[17:31:58] Initial: 6C68; + 3235840 bytes downloaded
[17:31:58] Initial: 9446; + 3246080 bytes downloaded
[17:31:58] Initial: A869; + 3256320 bytes downloaded
[17:31:58] Initial: EA9C; + 3266560 bytes downloaded
[17:31:58] Initial: 23E1; + 3276800 bytes downloaded
[17:31:58] Initial: 6F4F; + 3287040 bytes downloaded
[17:31:58] Initial: BB1F; + 3297280 bytes downloaded
[17:31:58] Initial: 0634; + 3307520 bytes downloaded
[17:31:58] Initial: 2525; + 3317760 bytes downloaded
[17:31:58] Initial: E7F5; + 3328000 bytes downloaded
[17:31:58] Initial: 2900; + 3338240 bytes downloaded
[17:31:58] Initial: 43D9; + 3348480 bytes downloaded
[17:31:59] Initial: 1EED; + 3358720 bytes downloaded
[17:31:59] Initial: 1511; + 3368960 bytes downloaded
[17:31:59] Initial: 616B; + 3379200 bytes downloaded
[17:31:59] Initial: 6477; + 3389440 bytes downloaded
[17:31:59] Initial: 2F85; + 3399680 bytes downloaded
[17:31:59] Initial: 461B; + 3409920 bytes downloaded
[17:31:59] Initial: 2FC9; + 3420160 bytes downloaded
[17:31:59] Initial: 250A; + 3430400 bytes downloaded
[17:31:59] Initial: A8D0; + 3440640 bytes downloaded
[17:31:59] Initial: 6934; + 3450880 bytes downloaded
[17:31:59] Initial: 9579; + 3461120 bytes downloaded
[17:31:59] Initial: 7539; + 3471360 bytes downloaded
[17:31:59] Initial: 1A50; + 3481600 bytes downloaded
[17:31:59] Initial: 1E20; + 3491840 bytes downloaded
[17:31:59] Initial: 5A23; + 3502080 bytes downloaded
[17:31:59] Initial: E8E3; + 3512320 bytes downloaded
[17:31:59] Initial: 29CE; + 3522560 bytes downloaded
[17:32:00] Initial: 0E3A; + 3532800 bytes downloaded
[17:32:00] Initial: E5C1; + 3543040 bytes downloaded
[17:32:00] Initial: 1399; + 3553280 bytes downloaded
[17:32:00] Initial: 036D; + 3563520 bytes downloaded
[17:32:00] Initial: 554A; + 3573760 bytes downloaded
[17:32:00] Initial: A913; + 3584000 bytes downloaded
[17:32:00] Initial: 411A; + 3594240 bytes downloaded
[17:32:00] Initial: D285; + 3604480 bytes downloaded
[17:32:00] Initial: D3ED; + 3614720 bytes downloaded
[17:32:00] Initial: E74E; + 3624960 bytes downloaded
[17:32:00] Initial: 77DF; + 3635200 bytes downloaded
[17:32:00] Initial: 87CD; + 3645440 bytes downloaded
[17:32:00] Initial: 5BF4; + 3655680 bytes downloaded
[17:32:00] Initial: AE79; + 3665920 bytes downloaded
[17:32:00] Initial: E3F2; + 3676160 bytes downloaded
[17:32:00] Initial: D56F; + 3686400 bytes downloaded
[17:32:00] Initial: 0206; + 3696640 bytes downloaded
[17:32:01] Initial: BE8F; + 3706880 bytes downloaded
[17:32:01] Initial: 5DB6; + 3717120 bytes downloaded
[17:32:01] Initial: 1A68; + 3727360 bytes downloaded
[17:32:01] Initial: 1646; + 3737600 bytes downloaded
[17:32:01] Initial: DE7C; + 3747840 bytes downloaded
[17:32:01] Initial: 89A0; + 3758080 bytes downloaded
[17:32:01] Initial: 5B1A; + 3768320 bytes downloaded
[17:32:01] Initial: A4C3; + 3778560 bytes downloaded
[17:32:01] Initial: 8FA2; + 3788800 bytes downloaded
[17:32:01] Initial: 90DC; + 3799040 bytes downloaded
[17:32:01] Initial: FE9A; + 3809280 bytes downloaded
[17:32:01] Initial: ECD1; + 3819520 bytes downloaded
[17:32:01] Initial: 4903; + 3829760 bytes downloaded
[17:32:01] Initial: 68CF; + 3840000 bytes downloaded
[17:32:01] Initial: 215D; + 3850240 bytes downloaded
[17:32:01] Initial: F0B3; + 3860480 bytes downloaded
[17:32:01] Initial: 90BB; + 3870720 bytes downloaded
[17:32:02] Initial: B105; + 3880960 bytes downloaded
[17:32:02] Initial: 16E5; + 3891200 bytes downloaded
[17:32:02] Initial: 3756; + 3901440 bytes downloaded
[17:32:02] Initial: 92CD; + 3911680 bytes downloaded
[17:32:02] Initial: 9921; + 3921920 bytes downloaded
[17:32:02] Initial: B931; + 3932160 bytes downloaded
[17:32:02] Initial: 090D; + 3942400 bytes downloaded
[17:32:02] Initial: AA99; + 3952640 bytes downloaded
[17:32:02] Initial: 1738; + 3962880 bytes downloaded
[17:32:02] Initial: ECC7; + 3973120 bytes downloaded
[17:32:02] Initial: 20DE; + 3983360 bytes downloaded
[17:32:02] Initial: EC8E; + 3993600 bytes downloaded
[17:32:02] Initial: 8C1B; + 4003840 bytes downloaded
[17:32:02] Initial: 641A; + 4014080 bytes downloaded
[17:32:02] Initial: 13EC; + 4024320 bytes downloaded
[17:32:02] Initial: 53A3; + 4034560 bytes downloaded
[17:32:02] Initial: 8F08; + 4044800 bytes downloaded
[17:32:03] Initial: 0E0B; + 4055040 bytes downloaded
[17:32:03] Initial: 0C7B; + 4065280 bytes downloaded
[17:32:03] Initial: 0000; + 4075520 bytes downloaded
[17:32:03] Initial: 3591; + 4085760 bytes downloaded
[17:32:03] Initial: 2EA8; + 4096000 bytes downloaded
[17:32:03] Initial: 2EAB; + 4106240 bytes downloaded
[17:32:03] Initial: 569F; + 4116480 bytes downloaded
[17:32:03] Initial: B7F7; + 4126720 bytes downloaded
[17:32:03] Initial: D3E2; + 4136960 bytes downloaded
[17:32:03] Initial: 252C; + 4147200 bytes downloaded
[17:32:03] Initial: 2532; + 4157440 bytes downloaded
[17:32:03] Initial: 73B0; + 4167680 bytes downloaded
[17:32:03] Initial: 0733; + 4177920 bytes downloaded
[17:32:03] Initial: D530; + 4188160 bytes downloaded
[17:32:03] Initial: B429; + 4198400 bytes downloaded
[17:32:03] Initial: 45D1; + 4208640 bytes downloaded
[17:32:03] Initial: A8A8; + 4218880 bytes downloaded
[17:32:04] Initial: DE70; + 4229120 bytes downloaded
[17:32:04] Initial: 25E3; + 4239360 bytes downloaded
[17:32:04] Initial: 79C4; + 4249600 bytes downloaded
[17:32:04] Initial: AF2C; + 4259840 bytes downloaded
[17:32:04] Initial: 6B12; + 4270080 bytes downloaded
[17:32:04] Initial: AF7F; + 4280320 bytes downloaded
[17:32:04] Initial: 019E; + 4290560 bytes downloaded
[17:32:04] Initial: 67EA; + 4300800 bytes downloaded
[17:32:04] Initial: F675; + 4311040 bytes downloaded
[17:32:04] Initial: DFC6; + 4321280 bytes downloaded
[17:32:04] Initial: 1D99; + 4331520 bytes downloaded
[17:32:04] Initial: 475B; + 4341760 bytes downloaded
[17:32:04] Initial: 2275; + 4352000 bytes downloaded
[17:32:04] Initial: 5E2F; + 4362240 bytes downloaded
[17:32:04] Initial: C648; + 4372480 bytes downloaded
[17:32:04] Initial: C4B1; + 4382720 bytes downloaded
[17:32:04] Initial: 3FC5; + 4392960 bytes downloaded
[17:32:05] Initial: AA10; + 4403200 bytes downloaded
[17:32:05] Initial: 5757; + 4413440 bytes downloaded
[17:32:05] Initial: D127; + 4423680 bytes downloaded
[17:32:05] Initial: 3F64; + 4433920 bytes downloaded
[17:32:05] Initial: 46B9; + 4444160 bytes downloaded
[17:32:05] Initial: 385A; + 4454400 bytes downloaded
[17:32:05] Initial: 58E8; + 4464640 bytes downloaded
[17:32:05] Initial: 0E83; + 4474880 bytes downloaded
[17:32:05] Initial: C2F1; + 4485120 bytes downloaded
[17:32:05] Initial: 4010; + 4495360 bytes downloaded
[17:32:05] Initial: 8824; + 4505600 bytes downloaded
[17:32:05] Initial: 7914; + 4515840 bytes downloaded
[17:32:05] Initial: 4168; + 4526080 bytes downloaded
[17:32:05] Initial: F40B; + 4536320 bytes downloaded
[17:32:05] Initial: D072; + 4546560 bytes downloaded
[17:32:05] Initial: F2D2; + 4556800 bytes downloaded
[17:32:05] Initial: 2A92; + 4567040 bytes downloaded
[17:32:06] Initial: 0DB0; + 4577280 bytes downloaded
[17:32:06] Initial: 78A9; + 4587520 bytes downloaded
[17:32:06] Initial: 001C; + 4597760 bytes downloaded
[17:32:06] Initial: 0623; + 4608000 bytes downloaded
[17:32:06] Initial: D521; + 4618240 bytes downloaded
[17:32:06] Initial: D853; + 4628480 bytes downloaded
[17:32:06] Initial: 93C6; + 4638720 bytes downloaded
[17:32:06] Initial: 1328; + 4648960 bytes downloaded
[17:32:06] Initial: 189E; + 4659200 bytes downloaded
[17:32:06] Initial: 7264; + 4669440 bytes downloaded
[17:32:06] Initial: 6ACD; + 4679680 bytes downloaded
[17:32:06] Initial: 5391; + 4689920 bytes downloaded
[17:32:06] Initial: 1597; + 4700160 bytes downloaded
[17:32:06] Initial: 11C7; + 4710400 bytes downloaded
[17:32:06] Initial: DDFB; + 4720640 bytes downloaded
[17:32:06] Initial: 2666; + 4730880 bytes downloaded
[17:32:06] Initial: 6488; + 4741120 bytes downloaded
[17:32:07] Initial: D492; + 4751360 bytes downloaded
[17:32:07] Initial: 6074; + 4761600 bytes downloaded
[17:32:07] Initial: 3C08; + 4771840 bytes downloaded
[17:32:07] Initial: 8351; + 4782080 bytes downloaded
[17:32:07] Initial: 9B8E; + 4792320 bytes downloaded
[17:32:07] Initial: EE5E; + 4802560 bytes downloaded
[17:32:07] Initial: F6B9; + 4812800 bytes downloaded
[17:32:07] Initial: 1EE7; + 4823040 bytes downloaded
[17:32:07] Initial: 8EEA; + 4833280 bytes downloaded
[17:32:07] Initial: 1242; + 4843520 bytes downloaded
[17:32:07] Initial: F123; + 4853760 bytes downloaded
[17:32:07] Initial: 0999; + 4864000 bytes downloaded
[17:32:07] Initial: 87E3; + 4874240 bytes downloaded
[17:32:07] Initial: 164A; + 4884480 bytes downloaded
[17:32:07] Initial: 71E0; + 4894720 bytes downloaded
[17:32:07] Initial: 1EAB; + 4904960 bytes downloaded
[17:32:07] Initial: 7E9B; + 4915200 bytes downloaded
[17:32:08] Initial: 9555; + 4925440 bytes downloaded
[17:32:08] Initial: 166D; + 4935680 bytes downloaded
[17:32:08] Initial: 8D71; + 4945920 bytes downloaded
[17:32:08] Initial: D819; + 4956160 bytes downloaded
[17:32:08] Initial: F4EC; + 4966400 bytes downloaded
[17:32:08] Initial: 8FB9; + 4976640 bytes downloaded
[17:32:08] Initial: 5CF7; + 4986880 bytes downloaded
[17:32:08] Initial: E3AE; + 4997120 bytes downloaded
[17:32:08] Initial: C9D1; + 5007360 bytes downloaded
[17:32:08] Initial: A614; + 5017600 bytes downloaded
[17:32:08] Initial: 0631; + 5027840 bytes downloaded
[17:32:08] Initial: AA31; + 5038080 bytes downloaded
[17:32:08] Initial: 4961; + 5048320 bytes downloaded
[17:32:08] Initial: E0E1; + 5058560 bytes downloaded
[17:32:08] Initial: FB1D; + 5068800 bytes downloaded
[17:32:08] Initial: 0A97; + 5079040 bytes downloaded
[17:32:08] Initial: 6BF5; + 5089280 bytes downloaded
[17:32:09] Initial: A979; + 5099520 bytes downloaded
[17:32:09] Initial: 13FF; + 5109760 bytes downloaded
[17:32:09] Initial: AA2A; + 5120000 bytes downloaded
[17:32:09] Initial: 90A8; + 5130240 bytes downloaded
[17:32:09] Initial: B0E4; + 5140480 bytes downloaded
[17:32:09] Initial: B5BA; + 5150720 bytes downloaded
[17:32:09] Initial: 8573; + 5160960 bytes downloaded
[17:32:09] Initial: 5FBD; + 5171200 bytes downloaded
[17:32:09] Initial: 89C3; + 5181440 bytes downloaded
[17:32:09] Initial: 8FA3; + 5191680 bytes downloaded
[17:32:09] Initial: 6170; + 5201920 bytes downloaded
[17:32:09] Initial: DAF8; + 5212160 bytes downloaded
[17:32:09] Initial: EBA5; + 5222400 bytes downloaded
[17:32:09] Initial: 3DEF; + 5232640 bytes downloaded
[17:32:09] Initial: 36B9; + 5242880 bytes downloaded
[17:32:09] Initial: 3A37; + 5253120 bytes downloaded
[17:32:09] Initial: 7BAD; + 5263360 bytes downloaded
[17:32:10] Initial: 0611; + 5273600 bytes downloaded
[17:32:10] Initial: 0B65; + 5283840 bytes downloaded
[17:32:10] Initial: D259; + 5294080 bytes downloaded
[17:32:10] Initial: E9F0; + 5304320 bytes downloaded
[17:32:10] Initial: 28BE; + 5314560 bytes downloaded
[17:32:10] Initial: CB33; + 5324800 bytes downloaded
[17:32:10] Initial: EC9E; + 5335040 bytes downloaded
[17:32:10] Initial: 51E7; + 5345280 bytes downloaded
[17:32:10] Initial: C2FC; + 5355520 bytes downloaded
[17:32:10] Initial: B56F; + 5365760 bytes downloaded
[17:32:10] Initial: 0741; + 5376000 bytes downloaded
[17:32:10] Initial: C70B; + 5386240 bytes downloaded
[17:32:10] Initial: 346D; + 5396480 bytes downloaded
[17:32:10] Initial: 59AD; + 5406720 bytes downloaded
[17:32:10] Initial: D21A; + 5416960 bytes downloaded
[17:32:10] Initial: 1742; + 5427200 bytes downloaded
[17:32:10] Initial: DF54; + 5437440 bytes downloaded
[17:32:11] Initial: 93F0; + 5447680 bytes downloaded
[17:32:11] Initial: 37AB; + 5457920 bytes downloaded
[17:32:11] Initial: 9062; + 5468160 bytes downloaded
[17:32:11] Initial: 201C; + 5478400 bytes downloaded
[17:32:11] Initial: 1468; + 5488640 bytes downloaded
[17:32:11] Initial: BE8A; + 5498880 bytes downloaded
[17:32:11] Initial: B9EF; + 5509120 bytes downloaded
[17:32:11] Initial: 5910; + 5519360 bytes downloaded
[17:32:11] Initial: 928C; + 5529600 bytes downloaded
[17:32:11] Initial: 6CFF; + 5539840 bytes downloaded
[17:32:11] Initial: 3F39; + 5550080 bytes downloaded
[17:32:11] Initial: 0000; + 5560320 bytes downloaded
[17:32:11] Initial: F5E1; + 5570560 bytes downloaded
[17:32:11] Initial: 1425; + 5580800 bytes downloaded
[17:32:11] Initial: 5E54; + 5591040 bytes downloaded
[17:32:11] Initial: 2A65; + 5601280 bytes downloaded
[17:32:11] Initial: 9C3D; + 5608424 bytes downloaded
[17:32:12] Verifying core Core_a6.fah...
[17:32:12] Signature is VALID
[17:32:12]
[17:32:12] Trying to unzip core FahCore_a6.exe
[17:32:14] Decompressed FahCore_a6.exe (17457152 bytes) successfully
[17:32:19] + Core successfully engaged
[17:32:25]
[17:32:25] + Processing work unit
[17:32:25] Work type a6 not eligible for variable processors
[17:32:25] Core required: FahCore_a6.exe
[17:32:25] Core found.
[17:32:25] Working on queue slot 01 [June 22 17:32:25 UTC]
[17:32:25] + Working ...
[17:32:25] - Calling '.\FahCore_a6.exe -dir work/ -suffix 01 -nice 19 -checkpoint 15 -verbose -lifeline 6140 -version 634'
[17:32:25]
[17:32:25] *------------------------------*
[17:32:25] Folding@Home Gromacs Core
[17:32:25] Version 2.28 (Wed Mar 23 13:51:17 PDT 2011)
[17:32:25]
[17:32:25] Preparing to commence simulation
[17:32:25] - Looking at optimizations...
[17:32:25] - Created dyn
[17:32:25] - Files status OK
[17:32:26] - Expanded 1489753 -> 2420320 (decompressed 162.4 percent)
[17:32:26] Called DecompressByteArray: compressed_data_size=1489753 data_size=2420320, decompressed_data_size=2420320 diff=0
[17:32:26] - Digital signature verified
[17:32:26]
[17:32:26] Project: 3867 (Run 2392, Clone 0, Gen 3)
[17:32:26]
[17:32:26] Assembly optimizations on if available.
[17:32:26] Entering M.D.
[17:32:32] Mapping NT from 1 to 1
[17:32:33] Completed 0 out of 250000 steps  (0%)
Am I missing something?
Tim_H
Hardware configuration: *FAH001
Asus M2N-SLI Deluxe
Phenom II X4 940 BE at 3.5GHz
2x GTS 250
4x 1GB Patriot DDR2 800
*FAH002
MSI P7N Platinum
Xeon X3330
2x 9600GT
1x 8800GS
2x 2GB Kingston DDR2 1066
*Ogre
Gigabyte (model)
Core 2 Quad q9400
2x 2GB Gskill DDR2 800
Gts 250
Post by Tim_H »
You are having the same problem as the OP, should just need to add the -smp argument\flag and wait for it to finish the current unit. At that time it should start on a SMP unit and utilize all cores
You may have to restart the Client and then add the -smp flag by using one of these methods (http://fahwiki.net/index.php/How_do_I_a ... _client%3F). The FAHlog should look like this:
