I have been running two clients one a cpu and one gpu. I have been getting 2 to 3 thousand points per day. Starting today the total points have not moved. Yet the status page shows an increase in total projects and total by type. My equipment is working and showes the status from both cpu adn gpu. My user name is Charles_Oldfield. How should I get this situation corrected? I have a history of the following.
I started with and older pc and ran it along with my new pc then I dropped the old unit and continued with the new one. Last week I added the gpu. I was thinking about upgrading my gpu but now I seem to have some doubt that will show results. Any Ideas?
Charles Oldfield
c.oldfield@sbcglobal.net
User Statistics Not Being Updated With Points
Re: User Statistics Not Being Updated With Points
Where are you looking that shows no points turned in today?
Kakao Stats shows you turned in 8 work units for 1740 points today.
http://kakaostats.com/usum.php?u=1502985
ChelseaOilman
I would check the logs for your GPU client. It looks like it might EUEing.
I can only see the last WU turned in by each client. This seems to be from an ATI GPU client.
Hi Charles_Oldfield (team 0),
Your WU (P5738 R3 C594 G148) was added to the stats database on 2011-02-01 13:08:37 for 0 points of credit.
Your WU (P5738 R3 C594 G148) was added to the stats database on 2011-02-01 18:08:56 for 0 points of credit.
When the WU error-ed out the first time it looks like you got issued the same WU again.
I right click the folding icon in the taskbar select user statistics and see the unit number ie 1110 total work items for Charles_ Oldfield 23 of these are from the gpu, 787 are fron the cpu and the rest are the old pc that is gone.
Those numbers are from 6:15am this morning. Kakao no activity from that time.
You must be correct as all seems to be working now. Just a day of elecreicity wasted. Thanks for your help.
Barney
Barney
