Project: 6503 (Run 6, Clone 517, Gen 47) EUE at 45%
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
This is a classic WU run on an old Toshiba laptop.
[11:41:46] Gromacs cannot continue further.
[11:41:46] Going to send back what have done.
This WU was given partial credit, and a different WU was automatically loaded. The Core is happily munching along on the new WU.
No apparent HW problems.
Parenthetically, my HFM work unit history is showing 13 EUEs over some 723 WUs - a higher portion than I would have thought. All but one of these EUEs are on classic clients, the one being on my GPU client.
--- Opening Log file [January 28 02:23:59 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\xxx\Application Data\Folding@home-x86
Arguments: -verbosity 9 -advmethods
[02:23:59] - Ask before connecting: No
[02:23:59] - User name: GreyWhiskers (Team 0)
[02:23:59] - User ID: xxxx
[02:23:59] - Machine ID: 5
[02:23:59]
[02:23:59] Loaded queue successfully.
[02:23:59] Initialization complete
[02:24:00]
[03:30:01] Trying to send all finished work units
[03:30:01] + No unsent completed units remaining.
[03:30:01] - Preparing to get new work unit...
[03:30:01] + Attempting to get work packet
[03:30:01] - Will indicate memory of 2039 MB
[03:30:01] - Connecting to assignment server
[03:30:01] Connecting to http://assign.stanford.edu:8080/
[03:30:02] Posted data.
[03:30:02] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[03:30:02] + News From Folding@Home: Welcome to Folding@Home
[03:30:02] Loaded queue successfully.
[03:30:02] Connecting to http://171.64.65.62:8080/
[03:30:03] Posted data.
[03:30:03] Initial: 0000; - Receiving payload (expected size: 516477)
[03:30:04] - Downloaded at ~504 kB/s
[03:30:04] - Averaged speed for that direction ~489 kB/s
[03:30:04] + Received work.
[03:30:04] Trying to send all finished work units
[03:30:04] + No unsent completed units remaining.
[03:30:04] + Closed connections
[03:30:04]
[03:30:04] + Processing work unit
[03:30:04] Core required: FahCore_78.exe
[03:30:04] Core found.
[03:30:04] Working on queue slot 06 [January 31 03:30:04 UTC]
[03:30:04] + Working ...
[03:30:04] - Calling '.\FahCore_78.exe -dir work/ -suffix 06 -checkpoint 15 -verbose -lifeline 1908 -version 623'
[03:30:04]
[03:30:04] *------------------------------*
[03:30:04] Folding@Home Gromacs Core
[03:30:04] Version 1.90 (March 8, 2006)
[03:30:04]
[03:30:04] Preparing to commence simulation
[03:30:04] - Looking at optimizations...
[03:30:04] - Created dyn
[03:30:04] - Files status OK
[03:30:05] - Expanded 515965 -> 2533901 (decompressed 491.0 percent)
[03:30:05] - Starting from initial work packet
[03:30:05]
[03:30:05] Project: 6503 (Run 6, Clone 517, Gen 47)
[03:30:05]
[03:30:05] Assembly optimizations on if available.
[03:30:05] Entering M.D.
[03:30:12] Protein: TR462_B_7 in water
[03:30:12]
[03:30:12] Writing local files
[03:30:12] Extra SSE boost OK.
[03:30:12] Completed 0 out of 250000 steps  (0%)
[03:41:20] Writing local files
[03:41:20] Completed 2500 out of 250000 steps  (1%)
[03:52:32] Writing local files
[03:52:32] Completed 5000 out of 250000 steps  (2%)
[04:03:32] Writing local files
[04:03:32] Completed 7500 out of 250000 steps  (3%)
[04:14:35] Writing local files
[11:18:00] Completed 107500 out of 250000 steps  (43%)
[11:28:21] Writing local files
[11:28:21] Completed 110000 out of 250000 steps  (44%)
[11:38:41] Writing local files
[11:38:42] Completed 112500 out of 250000 steps  (45%)
[11:41:46] logfile size: 29128
[11:41:46] - Writing 29664 bytes of core data to disk...
[11:41:46] Done: 29152 -> 5447 (compressed to 18.6 percent)
[11:41:46]   ... Done.
[11:41:46]
[11:41:46] Folding@home Core Shutdown: EARLY_UNIT_END
[11:41:50] CoreStatus = 72 (114)
[11:41:50] Sending work to server
[11:41:50] Project: 6503 (Run 6, Clone 517, Gen 47)
[11:41:50] - Read packet limit of 540015616... Set to 524286976.
[11:41:50] + Attempting to send results [January 31 11:41:50 UTC]
[11:41:50] - Reading file work/wuresults_06.dat from core
[11:41:50]   (Read 5959 bytes from disk)
[11:41:50] Connecting to http://171.64.65.62:8080/
[11:41:50] Posted data.
[11:41:50] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[11:41:50] - Uploaded at ~13 kB/s
[11:41:50] - Averaged speed for that direction ~164 kB/s
[11:41:50] + Results successfully sent
[11:41:50] Thank you for your contribution to Folding@Home.
[11:41:54] Trying to send all finished work units
[11:41:54] + No unsent completed units remaining.
Re: Project: 6503 (Run 6, Clone 517, Gen 47) EUE at 45%
Someone else reported an EUE at the same place ... I suspect a bad WU, but we should wait for an additional report before marking it ...
