Project: 6071 (Run 0, Clone 167, Gen 108)
bollix47
Post by bollix47 »
FYI
This WU causes a popup that shows FahCore_a3.exe has stopped working. Did a reboot and deleted the core .exe and the problem persisted.
Deleted queue.dat, unitinfo.txt, work\*.* and ran with -configonly to change the MachineID so I could get a different WU and it is running fine.
[17:10:09] Connecting to http://171.64.65.54:8080/
[17:10:10] Posted data.
[17:10:10] Initial: 0000; - Receiving payload (expected size: 1763814)
[17:10:14] - Downloaded at ~430 kB/s
[17:10:14] - Averaged speed for that direction ~379 kB/s
[17:10:14] + Received work.
[17:10:14] + Closed connections
[17:10:14]
[17:10:14] + Processing work unit
[17:10:14] Core required: FahCore_a3.exe
[17:10:14] Core found.
[17:10:14] Working on queue slot 04 [January 30 17:10:14 UTC]
[17:10:14] + Working ...
[17:10:14] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 04 -np 8 -priority 96 -checkpoint 30 -verbose -lifeline 5044 -version 630'
[17:10:14]
[17:10:14] *------------------------------*
[17:10:14] Folding@Home Gromacs SMP Core
[17:10:14] Version 2.22 (Mar 12, 2010)
[17:10:14]
[17:10:14] Preparing to commence simulation
[17:10:14] - Looking at optimizations...
[17:10:14] - Created dyn
[17:10:14] - Files status OK
[17:10:14] - Expanded 1763302 -> 2246261 (decompressed 127.3 percent)
[17:10:14] Called DecompressByteArray: compressed_data_size=1763302 data_size=2246261, decompressed_data_size=2246261 diff=0
[17:10:14] - Digital signature verified
[17:10:14]
[17:10:14] Project: 6071 (Run 0, Clone 167, Gen 108)
[17:10:14]
[17:10:14] Assembly optimizations on if available.
[17:10:14] Entering M.D.
[17:10:21] Completed 0 out of 500000 steps  (0%)
[17:10:49] CoreStatus = C0000029 (-1073741783)
[17:10:49] Client-core communications error: ERROR 0xc0000029
[17:10:49] Deleting current work unit & continuing...
[17:10:49] Killing all core threads
[17:10:49] Could not get process id information.  Please kill core process manually
Folding@Home Client Shutdown at user request.
Re: Project: 6071 (Run 0, Clone 167, Gen 108)
Many people had trouble with this WU, I marked it as bad.
