Project: 5781 (Run 0, Clone 751, Gen 404)
Fahrenheit451
Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB
Post by Fahrenheit451 »
Just FYI: Some hours later again a failure of a 5781 WU.
[17:24:36] + Processing work unit
[17:24:36] Core required: FahCore_11.exe
[17:24:36] Core found.
[17:24:36] Working on queue slot 04 [January 22 17:24:36 UTC]
[17:24:36] + Working ...
[17:24:36] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -priority 96 -checkpoint 15 -verbose -lifeline 5688 -version 623'
[17:24:36]
[17:24:36] *------------------------------*
[17:24:36] Folding@Home GPU Core
[17:24:36] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[17:24:36]
[17:24:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[17:24:36] Build host: amoeba
[17:24:36] Board Type: Nvidia
[17:24:36] Core      :
[17:24:36] Preparing to commence simulation
[17:24:36] - Looking at optimizations...
[17:24:36] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[17:24:36] - Created dyn
[17:24:36] - Files status OK
[17:24:36] - Expanded 64964 -> 344387 (decompressed 530.1 percent)
[17:24:36] Called DecompressByteArray: compressed_data_size=64964 data_size=344387, decompressed_data_size=344387 diff=0
[17:24:36] - Digital signature verified
[17:24:36]
[17:24:36] Project: 5781 (Run 0, Clone 751, Gen 404)
[17:24:36]
[17:24:36] Assembly optimizations on if available.
[17:24:36] Entering M.D.
[17:24:42] Tpr hash work/wudata_04.tpr:  2689620369 81068964 1786685427 493670645 1068330750
[17:24:42]
[17:24:42] Calling fah_main args: 14 usage=100
[17:24:42]
[17:24:42] Working on Great Red Owns Many ACres of Sand
[17:24:43] Client config found, loading data.
[17:24:44] Starting GUI Server
[17:26:52] Completed 1%
[17:29:00] Completed 2%
[17:31:08] Completed 3%
[17:33:17] Completed 4%
[17:35:25] Completed 5%
[17:37:34] Completed 6%
[17:39:42] Completed 7%
[17:41:51] Completed 8%
[17:43:59] Completed 9%
[17:46:07] Completed 10%
[17:48:16] Completed 11%
[17:50:24] Completed 12%
[17:52:33] Completed 13%
[17:54:41] Completed 14%
[17:56:49] Completed 15%
[17:58:58] Completed 16%
[18:01:06] Completed 17%
[18:03:15] Completed 18%
[18:05:23] Completed 19%
[18:07:32] Completed 20%
[18:09:40] Completed 21%
[18:11:48] Completed 22%
[18:13:57] Completed 23%
[18:16:05] Completed 24%
[18:18:14] Completed 25%
[18:20:22] Completed 26%
[18:22:30] Completed 27%
[18:24:39] Completed 28%
[18:26:48] Completed 29%
[18:28:56] Completed 30%
[18:31:05] Completed 31%
[18:33:13] Completed 32%
[18:35:21] Completed 33%
[18:37:30] Completed 34%
[18:39:38] Completed 35%
[18:41:47] Completed 36%
[18:43:55] Completed 37%
[18:46:04] Completed 38%
[18:48:12] Completed 39%
[18:50:20] Completed 40%
[18:52:29] Completed 41%
[18:54:37] Completed 42%
[18:56:46] Completed 43%
[18:58:54] Completed 44%
[19:01:02] Completed 45%
[19:03:11] Completed 46%
[19:05:19] Completed 47%
[19:07:28] Completed 48%
[19:09:36] Completed 49%
[19:11:45] Completed 50%
[19:13:53] Completed 51%
[19:16:01] Completed 52%
[19:18:10] Completed 53%
[19:20:18] Completed 54%
[19:22:27] Completed 55%
[19:24:35] Completed 56%
[19:26:43] Completed 57%
[19:28:52] Completed 58%
[19:29:58] - Autosending finished units... [January 22 19:29:58 UTC]
[19:29:58] Trying to send all finished work units
[19:29:58] + No unsent completed units remaining.
[19:29:58] - Autosend completed
[19:31:00] Completed 59%
[19:33:09] Completed 60%
[19:35:17] Completed 61%
[19:37:25] Completed 62%
[19:39:34] Completed 63%
[19:41:42] Completed 64%
[19:43:51] Completed 65%
[19:45:59] Completed 66%
[19:48:08] Completed 67%
[19:50:16] Completed 68%
[19:52:24] Completed 69%
[19:54:33] Completed 70%
[19:56:41] Completed 71%
[19:58:50] Completed 72%
[20:00:58] Completed 73%
[20:03:06] Completed 74%
[20:05:15] Completed 75%
[20:07:23] Completed 76%
[20:09:32] Completed 77%
[20:11:40] Completed 78%
[20:13:49] Completed 79%
[20:15:57] Completed 80%
[20:18:05] Completed 81%
[20:20:14] Completed 82%
[20:22:22] Completed 83%
[20:24:31] Completed 84%
[20:26:39] Completed 85%
[20:28:47] Completed 86%
[20:30:56] Completed 87%
[20:33:04] Completed 88%
[20:35:13] Completed 89%
[20:36:30] Run: exception thrown during GuardedRun
[20:36:30] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[20:36:30] Going to send back what have done -- stepsTotalG=20000000
[20:36:30] Work fraction=0.8959 steps=20000000.
[20:36:34] logfile size=10492 infoLength=10492 edr=0 trr=23
[20:36:34] + Opened results file
[20:36:34] - Writing 11028 bytes of core data to disk...
[20:36:34] Done: 10516 -> 3933 (compressed to 37.4 percent)
[20:36:34]   ... Done.
[20:36:34] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[20:36:34]
[20:36:34] Folding@home Core Shutdown: UNSTABLE_MACHINE
[20:36:38] CoreStatus = 7A (122)
[20:36:38] Sending work to server
[20:36:38] Project: 5781 (Run 0, Clone 751, Gen 404)
[20:36:38] - Read packet limit of 540015616... Set to 524286976.
[20:36:38] + Attempting to send results [January 22 20:36:38 UTC]
[20:36:38] - Reading file work/wuresults_04.dat from core
[20:36:38]   (Read 4445 bytes from disk)
[20:36:38] Connecting to http://171.67.108.21:8080/
[20:36:39] Posted data.
[20:36:39] Initial: 0000; - Uploaded at ~5 kB/s
[20:36:39] - Averaged speed for that direction ~29 kB/s
[20:36:39] + Results successfully sent
Re: Project: 5781 (Run 0, Clone 751, Gen 404)
Many people have been able to complete this WU ... and there's also a few EUEs reported ...
