Project: 5781 (Run 12, Clone 470, Gen 404)
Fahrenheit451
Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB
Post by Fahrenheit451 »
Just for your information. I think it's one of the randomly occurring errors.
[10:46:56] + Processing work unit
[10:46:56] Core required: FahCore_11.exe
[10:46:56] Core found.
[10:46:56] Working on queue slot 01 [January 22 10:46:56 UTC]
[10:46:56] + Working ...
[10:46:56] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 5688 -version 623'
[10:46:56]
[10:46:56] *------------------------------*
[10:46:56] Folding@Home GPU Core
[10:46:56] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[10:46:56]
[10:46:56] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[10:46:56] Build host: amoeba
[10:46:56] Board Type: Nvidia
[10:46:56] Core      :
[10:46:56] Preparing to commence simulation
[10:46:56] - Looking at optimizations...
[10:46:56] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[10:46:56] - Created dyn
[10:46:56] - Files status OK
[10:46:56] - Expanded 64927 -> 344387 (decompressed 530.4 percent)
[10:46:56] Called DecompressByteArray: compressed_data_size=64927 data_size=344387, decompressed_data_size=344387 diff=0
[10:46:56] - Digital signature verified
[10:46:56]
[10:46:56] Project: 5781 (Run 12, Clone 470, Gen 404)
[10:46:56]
[10:46:56] Assembly optimizations on if available.
[10:46:56] Entering M.D.
[10:47:02] Tpr hash work/wudata_01.tpr:  763403188 344786104 775724311 374696951 2193690000
[10:47:02]
[10:47:02] Calling fah_main args: 14 usage=100
[10:47:02]
[10:47:03] Working on Great Red Owns Many ACres of Sand
[10:47:04] Client config found, loading data.
[10:47:04] Starting GUI Server
[10:49:14] Completed 1%
[10:51:24] Completed 2%
[10:53:34] Completed 3%
[10:55:44] Completed 4%
[10:57:54] Completed 5%
[11:00:02] Completed 6%
[11:02:12] Completed 7%
[11:04:23] Completed 8%
[11:06:33] Completed 9%
[11:07:21] Run: exception thrown during GuardedRun
[11:07:21] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[11:07:21] Going to send back what have done -- stepsTotalG=20000000
[11:07:21] Work fraction=0.0929 steps=20000000.
[11:07:25] logfile size=11855 infoLength=11855 edr=0 trr=23
[11:07:25] + Opened results file
[11:07:25] - Writing 12391 bytes of core data to disk...
[11:07:25] Done: 11879 -> 4166 (compressed to 35.0 percent)
[11:07:25]   ... Done.
[11:07:25] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[11:07:25]
[11:07:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:07:28] CoreStatus = 7A (122)
[11:07:28] Sending work to server
[11:07:28] Project: 5781 (Run 12, Clone 470, Gen 404)
[11:07:28] - Read packet limit of 540015616... Set to 524286976.
[11:07:28] + Attempting to send results [January 22 11:07:28 UTC]
[11:07:28] - Reading file work/wuresults_01.dat from core
[11:07:28]   (Read 4678 bytes from disk)
[11:07:28] Connecting to http://171.67.108.21:8080/
[11:07:29] Posted data.
[11:07:29] Initial: 0000; - Uploaded at ~5 kB/s
[11:07:29] - Averaged speed for that direction ~34 kB/s
[11:07:29] + Results successfully sent
[11:07:29] Thank you for your contribution to Folding@Home.
Re: Project: 5781 (Run 12, Clone 470, Gen 404)
Some people have been able to return it successfully ...
