Project: 6806 (Run 2142, Clone 1, Gen 30)
DocJonz
Post by DocJonz »
One of my GTX 260's has been having great difficulty with this WU, getting unstable machine messages and then exceeding the EUE - anyone else had issues? (note: its not a new machine and has been happily Folding for months and months).
I switched the flag to nvidia_g80 to force a WU change, as it kept picking up the same WU, and its back running fine.
# Windows GPU Systray Edition #################################################
                       Folding@Home Client Version 6.30r2
                          http://folding.stanford.edu
Launch directory: C:\Documents and Settings\Williams\Application Data\Folding@home-gpu2
Arguments: -gpu 1 -forcegpu nvidia_fermi -advmethods
[08:29:05] - Ask before connecting: No
[08:29:05] - User name: DocJonz (Team 35947)
[08:29:05] - User ID: 5951470E0440660A
[08:29:05] - Machine ID: 3
[08:29:05]
[08:29:05] Gpu type=3 species=30.
[08:29:05] Work directory not found. Creating...
[08:29:05] Could not open work queue, generating new queue...
[08:29:05] Initialization complete
[08:29:05] - Preparing to get new work unit...
[08:29:05] Cleaning up work directory
[08:29:05] + Attempting to get work packet
[08:29:05] Passkey found
[08:29:05] - Connecting to assignment server
[08:29:06] - Successful: assigned to (171.64.65.64).
[08:29:06] + News From Folding@Home: Welcome to Folding@Home
[08:29:06] Loaded queue successfully.
[08:29:06] Gpu type=3 species=30.
[08:29:08] + Closed connections
[08:29:08]
[08:29:08] + Processing work unit
[08:29:08] Core required: FahCore_15.exe
[08:29:08] Core found.
[08:29:08] Working on queue slot 01 [January 23 08:29:08 UTC]
[08:29:08] + Working ...
[08:29:09]
[08:29:09] *------------------------------*
[08:29:09] Folding@Home GPU Core
[08:29:09] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[08:29:09]
[08:29:09] Build host: SimbiosNvdWin7
[08:29:09] Board Type: NVIDIA/CUDA
[08:29:09] Core      : x=15
[08:29:09]  Window's signal control handler registered.
[08:29:09] Preparing to commence simulation
[08:29:09] - Looking at optimizations...
[08:29:09] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[08:29:09] - Created dyn
[08:29:09] - Files status OK
[08:29:09] sizeof(CORE_PACKET_HDR) = 512 file=<>
[08:29:09] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[08:29:09] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[08:29:09] - Digital signature verified
[08:29:09]
[08:29:09] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:29:09]
[08:29:09] Assembly optimizations on if available.
[08:29:09] Entering M.D.
[08:29:12] Tpr hash work/wudata_01.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[08:29:12] Working on 2 PEPTIDE (1-42)
[08:29:12] Client config found, loading data.
[08:29:12] Starting GUI Server
[08:29:16] Setting checkpoint frequency: 500000
[08:32:40] Completed    500000 out of 50000000 steps (1%).
[08:32:40] mdrun_gpu returned 52
[08:32:40] NANs detected on GPU
[08:32:40]
[08:32:40] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:32:43] CoreStatus = 7A (122)
[08:32:43] Sending work to server
[08:32:43] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:32:43] - Read packet limit of 540015616... Set to 524286976.
[08:32:43] - Error: Could not get length of results file work/wuresults_01.dat
[08:32:43] - Error: Could not read unit 01 file. Removing from queue.
[08:32:43] - Preparing to get new work unit...
[08:32:43] Cleaning up work directory
[08:32:43] + Attempting to get work packet
[08:32:43] Passkey found
[08:32:43] Gpu type=3 species=30.
[08:32:43] - Connecting to assignment server
[08:32:54] - Successful: assigned to (171.64.65.64).
[08:32:54] + News From Folding@Home: Welcome to Folding@Home
[08:32:54] Loaded queue successfully.
[08:32:54] Gpu type=3 species=30.
[08:32:55] + Closed connections
[08:33:00]
[08:33:00] + Processing work unit
[08:33:00] Core required: FahCore_15.exe
[08:33:00] Core found.
[08:33:00] Working on queue slot 02 [January 23 08:33:00 UTC]
[08:33:00] + Working ...
[08:33:00]
[08:33:00] *------------------------------*
[08:33:00] Folding@Home GPU Core
[08:33:00] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[08:33:00]
[08:33:00] Build host: SimbiosNvdWin7
[08:33:00] Board Type: NVIDIA/CUDA
[08:33:00] Core      : x=15
[08:33:00]  Window's signal control handler registered.
[08:33:00] Preparing to commence simulation
[08:33:00] - Looking at optimizations...
[08:33:00] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[08:33:00] - Created dyn
[08:33:00] - Files status OK
[08:33:00] sizeof(CORE_PACKET_HDR) = 512 file=<>
[08:33:00] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[08:33:00] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[08:33:00] - Digital signature verified
[08:33:00]
[08:33:00] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:33:00]
[08:33:00] Assembly optimizations on if available.
[08:33:00] Entering M.D.
[08:33:02] Tpr hash work/wudata_02.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[08:33:03] Working on 2 PEPTIDE (1-42)
[08:33:03] Client config found, loading data.
[08:33:03] Starting GUI Server
[08:33:03] Setting checkpoint frequency: 500000
[08:36:27] Completed    500000 out of 50000000 steps (1%).
[08:36:27] mdrun_gpu returned 52
[08:36:27] NANs detected on GPU
[08:36:27]
[08:36:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:36:30] CoreStatus = 7A (122)
[08:36:30] Sending work to server
[08:36:30] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:36:30] - Read packet limit of 540015616... Set to 524286976.
[08:36:30] - Error: Could not get length of results file work/wuresults_02.dat
[08:36:30] - Error: Could not read unit 02 file. Removing from queue.
[08:36:30] - Preparing to get new work unit...
[08:36:30] Cleaning up work directory
[08:36:30] + Attempting to get work packet
[08:36:30] Passkey found
[08:36:30] Gpu type=3 species=30.
[08:36:30] - Connecting to assignment server
[08:36:31] - Successful: assigned to (171.64.65.64).
[08:36:31] + News From Folding@Home: Welcome to Folding@Home
[08:36:31] Loaded queue successfully.
[08:36:31] Gpu type=3 species=30.
[08:36:32] + Closed connections
[08:36:37]
[08:36:37] + Processing work unit
[08:36:37] Core required: FahCore_15.exe
[08:36:37] Core found.
[08:36:37] Working on queue slot 03 [January 23 08:36:37 UTC]
[08:36:37] + Working ...
[08:36:37]
[08:36:37] *------------------------------*
[08:36:37] Folding@Home GPU Core
[08:36:37] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[08:36:37]
[08:36:37] Build host: SimbiosNvdWin7
[08:36:37] Board Type: NVIDIA/CUDA
[08:36:37] Core      : x=15
[08:36:37]  Window's signal control handler registered.
[08:36:37] Preparing to commence simulation
[08:36:37] - Looking at optimizations...
[08:36:37] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[08:36:37] - Created dyn
[08:36:37] - Files status OK
[08:36:37] sizeof(CORE_PACKET_HDR) = 512 file=<>
[08:36:37] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[08:36:37] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[08:36:37] - Digital signature verified
[08:36:37]
[08:36:37] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:36:37]
[08:36:37] Assembly optimizations on if available.
[08:36:37] Entering M.D.
[08:36:39] Tpr hash work/wudata_03.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[08:36:40] Working on 2 PEPTIDE (1-42)
[08:36:40] Client config found, loading data.
[08:36:40] Starting GUI Server
[08:36:40] Setting checkpoint frequency: 500000
[08:39:54] Completed    500000 out of 50000000 steps (1%).
[08:39:54] mdrun_gpu returned 52
[08:39:54] NANs detected on GPU
[08:39:54]
[08:39:54] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:39:58] CoreStatus = 7A (122)
[08:39:58] Sending work to server
[08:39:58] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:39:58] - Read packet limit of 540015616... Set to 524286976.
[08:39:58] - Error: Could not get length of results file work/wuresults_03.dat
[08:39:58] - Error: Could not read unit 03 file. Removing from queue.
[08:39:58] - Preparing to get new work unit...
[08:39:58] Cleaning up work directory
[08:39:58] + Attempting to get work packet
[08:39:58] Passkey found
[08:39:58] Gpu type=3 species=30.
[08:39:58] - Connecting to assignment server
[08:39:59] - Successful: assigned to (171.64.65.64).
[08:39:59] + News From Folding@Home: Welcome to Folding@Home
[08:39:59] Loaded queue successfully.
[08:39:59] Gpu type=3 species=30.
[08:40:00] + Closed connections
[08:40:05]
[08:40:05] + Processing work unit
[08:40:05] Core required: FahCore_15.exe
[08:40:05] Core found.
[08:40:05] Working on queue slot 04 [January 23 08:40:05 UTC]
[08:40:05] + Working ...
[08:40:06]
[08:40:06] *------------------------------*
[08:40:06] Folding@Home GPU Core
[08:40:06] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[08:40:06]
[08:40:06] Build host: SimbiosNvdWin7
[08:40:06] Board Type: NVIDIA/CUDA
[08:40:06] Core      : x=15
[08:40:06]  Window's signal control handler registered.
[08:40:06] Preparing to commence simulation
[08:40:06] - Looking at optimizations...
[08:40:06] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[08:40:06] - Created dyn
[08:40:06] - Files status OK
[08:40:06] sizeof(CORE_PACKET_HDR) = 512 file=<>
[08:40:06] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[08:40:06] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[08:40:06] - Digital signature verified
[08:40:06]
[08:40:06] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:40:06]
[08:40:06] Assembly optimizations on if available.
[08:40:06] Entering M.D.
[08:40:08] Tpr hash work/wudata_04.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[08:40:08] Working on 2 PEPTIDE (1-42)
[08:40:08] Client config found, loading data.
[08:40:08] Starting GUI Server
[08:40:09] Setting checkpoint frequency: 500000
[08:43:22] Completed    500000 out of 50000000 steps (1%).
[08:43:22] mdrun_gpu returned 52
[08:43:22] NANs detected on GPU
[08:43:22]
[08:43:22] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:43:26] CoreStatus = 7A (122)
[08:43:26] Sending work to server
[08:43:26] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:43:26] - Read packet limit of 540015616... Set to 524286976.
[08:43:26] - Error: Could not get length of results file work/wuresults_04.dat
[08:43:26] - Error: Could not read unit 04 file. Removing from queue.
[08:43:26] - Preparing to get new work unit...
[08:43:26] Cleaning up work directory
[08:43:26] + Attempting to get work packet
[08:43:26] Passkey found
[08:43:26] Gpu type=3 species=30.
[08:43:26] - Connecting to assignment server
[08:43:27] - Successful: assigned to (171.64.65.64).
[08:43:27] + News From Folding@Home: Welcome to Folding@Home
[08:43:27] Loaded queue successfully.
[08:43:27] Gpu type=3 species=30.
[08:43:28] + Closed connections
[08:43:33]
[08:43:33] + Processing work unit
[08:43:33] Core required: FahCore_15.exe
[08:43:33] Core found.
[08:43:33] Working on queue slot 05 [January 23 08:43:33 UTC]
[08:43:33] + Working ...
[08:43:33]
[08:43:33] *------------------------------*
[08:43:33] Folding@Home GPU Core
[08:43:33] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[08:43:33]
[08:43:33] Build host: SimbiosNvdWin7
[08:43:33] Board Type: NVIDIA/CUDA
[08:43:33] Core      : x=15
[08:43:33]  Window's signal control handler registered.
[08:43:33] Preparing to commence simulation
[08:43:33] - Looking at optimizations...
[08:43:33] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[08:43:33] - Created dyn
[08:43:33] - Files status OK
[08:43:33] sizeof(CORE_PACKET_HDR) = 512 file=<>
[08:43:33] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[08:43:33] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[08:43:33] - Digital signature verified
[08:43:33]
[08:43:33] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:43:33]
[08:43:33] Assembly optimizations on if available.
[08:43:33] Entering M.D.
[08:43:35] Tpr hash work/wudata_05.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[08:43:35] Working on 2 PEPTIDE (1-42)
[08:43:35] Client config found, loading data.
[08:43:36] Starting GUI Server
[08:43:36] Setting checkpoint frequency: 500000
[08:46:49] Completed    500000 out of 50000000 steps (1%).
[08:46:49] mdrun_gpu returned 52
[08:46:49] NANs detected on GPU
[08:46:49]
[08:46:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[08:46:53] CoreStatus = 7A (122)
[08:46:53] Sending work to server
[08:46:53] Project: 6806 (Run 2142, Clone 1, Gen 30)
[08:46:53] - Read packet limit of 540015616... Set to 524286976.
[08:46:53] - Error: Could not get length of results file work/wuresults_05.dat
[08:46:53] - Error: Could not read unit 05 file. Removing from queue.
[08:46:53] EUE limit exceeded. Pausing 24 hours.
bollix47
Re: Project: 6806 (Run 2142, Clone 1, Gen 30)
Post by bollix47 »
The GTX 260 is not a fermi card but because you had -forcegpu nvidia_fermi in your arguments your gpu was being fed fermi WUs which it cannot compute. Changing the argument to -forcegpu nvidia_g80 has corrected the problem and you are now getting non-fermi WUs which do work on your card.
With the latest client and drivers that flag shouldn't be necessary any longer but having it won't bother anything as long as it's the correct one(i.e. nvidia_g80).
Please note this: (From my GPU Guide)
Using the -forcegpu flag with the wrong GPU will mess things up. It may invalidate the scientific results produced. DO NOT MISUSE THESE FLAGS. (Details)
Something seems weird with this WU : two people returned it with no error, but got 0 points ...
I guess we'll have to keep an eye on it ...
DocJonz
Post by DocJonz »
Points noted ... still interested to see if this is a problem WU ....
bollix47 wrote:The GTX 260 is not a fermi card but because you had -forcegpu nvidia_fermi in your arguments your gpu was being fed fermi WUs which it cannot compute. Changing the argument to -forcegpu nvidia_g80 has corrected the problem and you are now getting non-fermi WUs which do work on your card.
Using an incorrect flag (such as forcegpu nvidia_fermi when you don't have fermi hardware) SHOULD produce errors and SHOULD put your machine to sleep. The validity of the results is critical to the science and the Pnade Group must prohibit the improper use of -forcegpu, one way or another. The client doesn't have any other way of telling you that your configuration is invalid.
caintry_boy
Post by caintry_boy »
It's a problem WU for me, I'm running 2 x GTX460's one of which has been trying to run this WU all afternoon and evening and it always EUE's...loads the same WU and it's just a vicious cycle. These vid cards should be able to handle it...I tried it with the "-forcegpu nvidia_fermi" flag and without, no change...stock settings on the card that EUE's...
--- Opening Log file [February 10 22:53:24 UTC]
Launch directory: D:\Folding@Home\GPU1
Arguments: -gpu 0 -forcegpu nvidia_fermi
[22:53:24] - Ask before connecting: No
[22:53:24] - User name: caintry_boy (Team 32035)
[22:53:24] - User ID: 2632F19E01C921AC
[22:53:24] - Machine ID: 2
[22:53:24]
[22:53:24] Gpu type=3 species=30.
[22:53:24] Work directory not found. Creating...
[22:53:24] Could not open work queue, generating new queue...
[22:53:24] Initialization complete
[22:53:24] - Preparing to get new work unit...
[22:53:24] Cleaning up work directory
[22:53:24] + Attempting to get work packet
[22:53:24] Passkey found
[22:53:24] - Connecting to assignment server
[22:53:25] - Successful: assigned to (171.64.65.64).
[22:53:25] + News From Folding@Home: Welcome to Folding@Home
[22:53:25] Loaded queue successfully.
[22:53:25] Gpu type=3 species=30.
[22:53:26] + Closed connections
[22:53:26]
[22:53:26] + Processing work unit
[22:53:26] Core required: FahCore_15.exe
[22:53:26] Core not found.
[22:53:26] - Core is not present or corrupted.
[22:53:26] - Attempting to download new core...
[22:53:26] + Downloading new core: FahCore_15.exe
[22:53:27] + 10240 bytes downloaded
[22:53:27] + 20480 bytes downloaded
[22:53:27] + 30720 bytes downloaded
[22:53:27] + 40960 bytes downloaded
[22:53:27] + 51200 bytes downloaded
[22:53:27] + 61440 bytes downloaded
[22:53:27] + 71680 bytes downloaded
[22:53:29] + 81920 bytes downloaded
[22:53:29] + 92160 bytes downloaded
[22:53:29] + 102400 bytes downloaded
[22:53:30] + 112640 bytes downloaded
[22:53:31] + 122880 bytes downloaded
[22:53:32] + 133120 bytes downloaded
[22:53:33] + 143360 bytes downloaded
[22:53:34] + 153600 bytes downloaded
[22:53:34] + 163840 bytes downloaded
[22:53:34] + 174080 bytes downloaded
[22:53:35] + 184320 bytes downloaded
[22:53:35] + 194560 bytes downloaded
[22:53:37] + 204800 bytes downloaded
[22:53:37] + 215040 bytes downloaded
[22:53:38] + 225280 bytes downloaded
[22:53:38] + 235520 bytes downloaded
[22:53:38] + 245760 bytes downloaded
[22:53:39] + 256000 bytes downloaded
[22:53:41] + 266240 bytes downloaded
[22:53:41] + 276480 bytes downloaded
[22:53:41] + 286720 bytes downloaded
[22:53:42] + 296960 bytes downloaded
[22:53:42] + 307200 bytes downloaded
[22:53:42] + 317440 bytes downloaded
[22:53:43] + 327680 bytes downloaded
[22:53:44] + 337920 bytes downloaded
[22:53:45] + 348160 bytes downloaded
[22:53:47] + 358400 bytes downloaded
[22:53:47] + 368640 bytes downloaded
[22:53:47] + 378880 bytes downloaded
[22:53:47] + 389120 bytes downloaded
[22:53:48] + 399360 bytes downloaded
[22:53:49] + 409600 bytes downloaded
[22:53:50] + 419840 bytes downloaded
[22:53:52] + 430080 bytes downloaded
[22:53:53] + 440320 bytes downloaded
[22:53:53] + 450560 bytes downloaded
[22:53:53] + 460800 bytes downloaded
[22:53:53] + 471040 bytes downloaded
[22:53:55] + 481280 bytes downloaded
[22:53:56] + 491520 bytes downloaded
[22:53:56] + 501760 bytes downloaded
[22:53:57] + 512000 bytes downloaded
[22:53:57] + 522240 bytes downloaded
[22:53:57] + 532480 bytes downloaded
[22:53:57] + 542720 bytes downloaded
[22:53:57] + 552960 bytes downloaded
[22:53:58] + 563200 bytes downloaded
[22:53:59] + 573440 bytes downloaded
[22:53:59] + 583680 bytes downloaded
[22:54:00] + 593920 bytes downloaded
[22:54:00] + 604160 bytes downloaded
[22:54:00] + 614400 bytes downloaded
[22:54:00] + 624640 bytes downloaded
[22:54:01] + 634880 bytes downloaded
[22:54:02] + 645120 bytes downloaded
[22:54:03] + 655360 bytes downloaded
[22:54:04] + 665600 bytes downloaded
[22:54:04] + 675840 bytes downloaded
[22:54:04] + 686080 bytes downloaded
[22:54:04] + 696320 bytes downloaded
[22:54:04] + 706560 bytes downloaded
[22:54:05] + 716800 bytes downloaded
[22:54:05] + 727040 bytes downloaded
[22:54:06] + 737280 bytes downloaded
[22:54:06] + 747520 bytes downloaded
[22:54:06] + 757760 bytes downloaded
[22:54:06] + 768000 bytes downloaded
[22:54:06] + 778240 bytes downloaded
[22:54:06] + 788480 bytes downloaded
[22:54:07] + 798720 bytes downloaded
[22:54:07] + 808960 bytes downloaded
[22:54:07] + 819200 bytes downloaded
[22:54:07] + 829440 bytes downloaded
[22:54:09] + 839680 bytes downloaded
[22:54:10] + 849920 bytes downloaded
[22:54:10] + 860160 bytes downloaded
[22:54:10] + 870400 bytes downloaded
[22:54:11] + 880640 bytes downloaded
[22:54:13] + 890880 bytes downloaded
[22:54:14] + 901120 bytes downloaded
[22:54:14] + 911360 bytes downloaded
[22:54:15] + 921600 bytes downloaded
[22:54:15] + 931840 bytes downloaded
[22:54:15] + 942080 bytes downloaded
[22:54:16] + 952320 bytes downloaded
[22:54:16] + 962560 bytes downloaded
[22:54:17] + 972800 bytes downloaded
[22:54:18] + 983040 bytes downloaded
[22:54:18] + 993280 bytes downloaded
[22:54:18] + 1003520 bytes downloaded
[22:54:19] + 1013760 bytes downloaded
[22:54:19] + 1024000 bytes downloaded
[22:54:19] + 1034240 bytes downloaded
[22:54:19] + 1044480 bytes downloaded
[22:54:20] + 1054720 bytes downloaded
[22:54:20] + 1064960 bytes downloaded
[22:54:21] + 1075200 bytes downloaded
[22:54:21] + 1085440 bytes downloaded
[22:54:21] + 1095680 bytes downloaded
[22:54:21] + 1105920 bytes downloaded
[22:54:22] + 1116160 bytes downloaded
[22:54:22] + 1126400 bytes downloaded
[22:54:24] + 1136640 bytes downloaded
[22:54:25] + 1146880 bytes downloaded
[22:54:25] + 1157120 bytes downloaded
[22:54:25] + 1167360 bytes downloaded
[22:54:25] + 1177600 bytes downloaded
[22:54:26] + 1187840 bytes downloaded
[22:54:26] + 1198080 bytes downloaded
[22:54:27] + 1208320 bytes downloaded
[22:54:28] + 1218560 bytes downloaded
[22:54:28] + 1228800 bytes downloaded
[22:54:28] + 1239040 bytes downloaded
[22:54:28] + 1249280 bytes downloaded
[22:54:28] + 1259520 bytes downloaded
[22:54:31] + 1269760 bytes downloaded
[22:54:31] + 1280000 bytes downloaded
[22:54:32] + 1290240 bytes downloaded
[22:54:32] + 1300480 bytes downloaded
[22:54:33] + 1310720 bytes downloaded
[22:54:36] + 1320960 bytes downloaded
[22:54:36] + 1331200 bytes downloaded
[22:54:36] + 1341440 bytes downloaded
[22:54:38] + 1351680 bytes downloaded
[22:54:38] + 1361920 bytes downloaded
[22:54:38] + 1372160 bytes downloaded
[22:54:40] + 1382400 bytes downloaded
[22:54:41] + 1392640 bytes downloaded
[22:54:41] + 1402880 bytes downloaded
[22:54:41] + 1413120 bytes downloaded
[22:54:41] + 1422551 bytes downloaded
[22:54:41] Verifying core Core_15.fah...
[22:54:41] Signature is VALID
[22:54:41]
[22:54:41] Trying to unzip core FahCore_15.exe
[22:54:41] Decompressed FahCore_15.exe (3903488 bytes) successfully
[22:54:46] + Core successfully engaged
[22:54:52]
[22:54:52] + Processing work unit
[22:54:52] Core required: FahCore_15.exe
[22:54:52] Core found.
[22:54:52] Working on queue slot 01 [February 10 22:54:52 UTC]
[22:54:52] + Working ...
[22:54:52]
[22:54:52] *------------------------------*
[22:54:52] Folding@Home GPU Core
[22:54:52] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[22:54:52]
[22:54:52] Build host: SimbiosNvdWin7
[22:54:52] Board Type: NVIDIA/CUDA
[22:54:52] Core      : x=15
[22:54:52]  Window's signal control handler registered.
[22:54:52] Preparing to commence simulation
[22:54:52] - Looking at optimizations...
[22:54:52] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[22:54:52] - Created dyn
[22:54:52] - Files status OK
[22:54:52] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:54:52] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[22:54:52] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[22:54:52] - Digital signature verified
[22:54:52]
[22:54:52] Project: 6806 (Run 2142, Clone 1, Gen 30)
[22:54:52]
[22:54:52] Assembly optimizations on if available.
[22:54:52] Entering M.D.
[22:54:54] Tpr hash work/wudata_01.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[22:54:54] Working on 2 PEPTIDE (1-42)
[22:54:54] Client config found, loading data.
[22:54:54] Starting GUI Server
[22:54:54] Setting checkpoint frequency: 500000
[22:56:38] Completed    500000 out of 50000000 steps (1%).
[22:56:39] mdrun_gpu returned 52
[22:56:39] NANs detected on GPU
[22:56:39]
[22:56:39] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:56:42] CoreStatus = 7A (122)
[22:56:42] Sending work to server
[22:56:42] Project: 6806 (Run 2142, Clone 1, Gen 30)
[22:56:42] - Read packet limit of 540015616... Set to 524286976.
[22:56:42] - Error: Could not get length of results file work/wuresults_01.dat
[22:56:42] - Error: Could not read unit 01 file. Removing from queue.
[22:56:42] - Preparing to get new work unit...
[22:56:42] Cleaning up work directory
[22:56:42] + Attempting to get work packet
[22:56:42] Passkey found
[22:56:42] Gpu type=3 species=30.
[22:56:42] - Connecting to assignment server
[22:56:43] - Successful: assigned to (171.64.65.64).
[22:56:43] + News From Folding@Home: Welcome to Folding@Home
[22:56:43] Loaded queue successfully.
[22:56:43] Gpu type=3 species=30.
[22:56:44] + Closed connections
[22:56:49]
[22:56:49] + Processing work unit
[22:56:49] Core required: FahCore_15.exe
[22:56:49] Core found.
[22:56:49] Working on queue slot 02 [February 10 22:56:49 UTC]
[22:56:49] + Working ...
[22:56:49]
[22:56:49] *------------------------------*
[22:56:49] Folding@Home GPU Core
[22:56:49] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[22:56:49]
[22:56:49] Build host: SimbiosNvdWin7
[22:56:49] Board Type: NVIDIA/CUDA
[22:56:49] Core      : x=15
[22:56:49]  Window's signal control handler registered.
[22:56:49] Preparing to commence simulation
[22:56:49] - Looking at optimizations...
[22:56:49] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[22:56:49] - Created dyn
[22:56:49] - Files status OK
[22:56:49] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:56:49] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[22:56:49] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[22:56:49] - Digital signature verified
[22:56:49]
[22:56:49] Project: 6806 (Run 2142, Clone 1, Gen 30)
[22:56:49]
[22:56:49] Assembly optimizations on if available.
[22:56:49] Entering M.D.
[22:56:51] Tpr hash work/wudata_02.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[22:56:51] Working on 2 PEPTIDE (1-42)
[22:56:51] Client config found, loading data.
[22:56:51] Setting checkpoint frequency: 500000
[22:56:51] Starting GUI Server
[22:58:35] Completed    500000 out of 50000000 steps (1%).
[22:58:35] mdrun_gpu returned 52
[22:58:35] NANs detected on GPU
[22:58:35]
[22:58:35] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:58:39] CoreStatus = 7A (122)
[22:58:39] Sending work to server
[22:58:39] Project: 6806 (Run 2142, Clone 1, Gen 30)
[22:58:39] - Read packet limit of 540015616... Set to 524286976.
[22:58:39] - Error: Could not get length of results file work/wuresults_02.dat
[22:58:39] - Error: Could not read unit 02 file. Removing from queue.
[22:58:39] - Preparing to get new work unit...
[22:58:39] Cleaning up work directory
[22:58:39] + Attempting to get work packet
[22:58:39] Passkey found
[22:58:39] Gpu type=3 species=30.
[22:58:39] - Connecting to assignment server
[22:58:40] - Successful: assigned to (171.64.65.64).
[22:58:40] + News From Folding@Home: Welcome to Folding@Home
[22:58:40] Loaded queue successfully.
[22:58:40] Gpu type=3 species=30.
[22:58:41] + Closed connections
[22:58:46]
[22:58:46] + Processing work unit
[22:58:46] Core required: FahCore_15.exe
[22:58:46] Core found.
[22:58:46] Working on queue slot 03 [February 10 22:58:46 UTC]
[22:58:46] + Working ...
[22:58:46]
[22:58:46] *------------------------------*
[22:58:46] Folding@Home GPU Core
[22:58:46] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[22:58:46]
[22:58:46] Build host: SimbiosNvdWin7
[22:58:46] Board Type: NVIDIA/CUDA
[22:58:46] Core      : x=15
[22:58:46]  Window's signal control handler registered.
[22:58:46] Preparing to commence simulation
[22:58:46] - Looking at optimizations...
[22:58:46] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[22:58:46] - Created dyn
[22:58:46] - Files status OK
[22:58:46] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:58:46] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[22:58:46] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[22:58:46] - Digital signature verified
[22:58:46]
[22:58:46] Project: 6806 (Run 2142, Clone 1, Gen 30)
[22:58:46]
[22:58:46] Assembly optimizations on if available.
[22:58:46] Entering M.D.
[22:58:48] Tpr hash work/wudata_03.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[22:58:48] Working on 2 PEPTIDE (1-42)
[22:58:48] Client config found, loading data.
[22:58:48] Setting checkpoint frequency: 500000
[22:58:48] Starting GUI Server
[23:00:32] Completed    500000 out of 50000000 steps (1%).
[23:00:32] mdrun_gpu returned 52
[23:00:32] NANs detected on GPU
[23:00:32]
[23:00:32] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:00:36] CoreStatus = 7A (122)
[23:00:36] Sending work to server
[23:00:36] Project: 6806 (Run 2142, Clone 1, Gen 30)
[23:00:36] - Read packet limit of 540015616... Set to 524286976.
[23:00:36] - Error: Could not get length of results file work/wuresults_03.dat
[23:00:36] - Error: Could not read unit 03 file. Removing from queue.
[23:00:36] - Preparing to get new work unit...
[23:00:36] Cleaning up work directory
[23:00:36] + Attempting to get work packet
[23:00:36] Passkey found
[23:00:36] Gpu type=3 species=30.
[23:00:36] - Connecting to assignment server
[23:00:37] - Successful: assigned to (171.64.65.64).
[23:00:37] + News From Folding@Home: Welcome to Folding@Home
[23:00:37] Loaded queue successfully.
[23:00:37] Gpu type=3 species=30.
[23:00:38] + Closed connections
[23:00:43]
[23:00:43] + Processing work unit
[23:00:43] Core required: FahCore_15.exe
[23:00:43] Core found.
[23:00:43] Working on queue slot 04 [February 10 23:00:43 UTC]
[23:00:43] + Working ...
[23:00:43]
[23:00:43] *------------------------------*
[23:00:43] Folding@Home GPU Core
[23:00:43] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[23:00:43]
[23:00:43] Build host: SimbiosNvdWin7
[23:00:43] Board Type: NVIDIA/CUDA
[23:00:43] Core      : x=15
[23:00:43]  Window's signal control handler registered.
[23:00:43] Preparing to commence simulation
[23:00:43] - Looking at optimizations...
[23:00:43] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[23:00:43] - Created dyn
[23:00:43] - Files status OK
[23:00:43] sizeof(CORE_PACKET_HDR) = 512 file=<>
[23:00:43] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[23:00:43] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[23:00:43] - Digital signature verified
[23:00:43]
[23:00:43] Project: 6806 (Run 2142, Clone 1, Gen 30)
[23:00:43]
[23:00:43] Assembly optimizations on if available.
[23:00:43] Entering M.D.
[23:00:45] Tpr hash work/wudata_04.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[23:00:45] Working on 2 PEPTIDE (1-42)
[23:00:45] Client config found, loading data.
[23:00:45] Starting GUI Server
[23:00:45] Setting checkpoint frequency: 500000
[23:02:29] Completed    500000 out of 50000000 steps (1%).
[23:02:29] mdrun_gpu returned 52
[23:02:29] NANs detected on GPU
[23:02:29]
[23:02:29] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:02:33] CoreStatus = 7A (122)
[23:02:33] Sending work to server
[23:02:33] Project: 6806 (Run 2142, Clone 1, Gen 30)
[23:02:33] - Read packet limit of 540015616... Set to 524286976.
[23:02:33] - Error: Could not get length of results file work/wuresults_04.dat
[23:02:33] - Error: Could not read unit 04 file. Removing from queue.
[23:02:33] - Preparing to get new work unit...
[23:02:33] Cleaning up work directory
[23:02:33] + Attempting to get work packet
[23:02:33] Passkey found
[23:02:33] Gpu type=3 species=30.
[23:02:33] - Connecting to assignment server
[23:02:33] - Successful: assigned to (171.64.65.64).
[23:02:33] + News From Folding@Home: Welcome to Folding@Home
[23:02:34] Loaded queue successfully.
[23:02:34] Gpu type=3 species=30.
[23:02:35] + Closed connections
[23:02:40]
[23:02:40] + Processing work unit
[23:02:40] Core required: FahCore_15.exe
[23:02:40] Core found.
[23:02:40] Working on queue slot 05 [February 10 23:02:40 UTC]
[23:02:40] + Working ...
[23:02:40]
[23:02:40] *------------------------------*
[23:02:40] Folding@Home GPU Core
[23:02:40] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[23:02:40]
[23:02:40] Build host: SimbiosNvdWin7
[23:02:40] Board Type: NVIDIA/CUDA
[23:02:40] Core      : x=15
[23:02:40]  Window's signal control handler registered.
[23:02:40] Preparing to commence simulation
[23:02:40] - Looking at optimizations...
[23:02:40] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[23:02:40] - Created dyn
[23:02:40] - Files status OK
[23:02:40] sizeof(CORE_PACKET_HDR) = 512 file=<>
[23:02:40] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[23:02:40] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[23:02:40] - Digital signature verified
[23:02:40]
[23:02:40] Project: 6806 (Run 2142, Clone 1, Gen 30)
[23:02:40]
[23:02:40] Assembly optimizations on if available.
[23:02:40] Entering M.D.
[23:02:42] Tpr hash work/wudata_05.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[23:02:42] Working on 2 PEPTIDE (1-42)
[23:02:42] Client config found, loading data.
[23:02:42] Setting checkpoint frequency: 500000
[23:02:42] Starting GUI Server
[23:04:26] Completed    500000 out of 50000000 steps (1%).
[23:04:26] mdrun_gpu returned 52
[23:04:26] NANs detected on GPU
[23:04:26]
[23:04:26] Folding@home Core Shutdown: UNSTABLE_MACHINE
[23:04:30] CoreStatus = 7A (122)
[23:04:30] Sending work to server
[23:04:30] Project: 6806 (Run 2142, Clone 1, Gen 30)
[23:04:30] - Read packet limit of 540015616... Set to 524286976.
[23:04:30] - Error: Could not get length of results file work/wuresults_05.dat
[23:04:30] - Error: Could not read unit 05 file. Removing from queue.
[23:04:30] EUE limit exceeded. Pausing 24 hours.
Folding@Home Client Shutdown.
--- Opening Log file [February 11 04:27:09 UTC]
[04:27:09] - Ask before connecting: No
[04:27:09] - User name: caintry_boy (Team 32035)
[04:27:09] - User ID: 2632F19E01C921AC
[04:27:09] - Machine ID: 2
[04:27:09]
[04:27:09] Gpu type=3 species=30.
[04:27:09] Work directory not found. Creating...
[04:27:09] Could not open work queue, generating new queue...
[04:27:09] Initialization complete
[04:27:09] - Preparing to get new work unit...
[04:27:09] Cleaning up work directory
[04:27:09] + Attempting to get work packet
[04:27:09] Passkey found
[04:27:09] - Connecting to assignment server
[04:27:10] - Successful: assigned to (171.64.65.64).
[04:27:10] + News From Folding@Home: Welcome to Folding@Home
[04:27:10] Loaded queue successfully.
[04:27:10] Gpu type=3 species=30.
[04:27:12] + Closed connections
[04:27:12]
[04:27:12] + Processing work unit
[04:27:12] Core required: FahCore_15.exe
[04:27:12] Core not found.
[04:27:12] - Core is not present or corrupted.
[04:27:12] - Attempting to download new core...
[04:27:12] + Downloading new core: FahCore_15.exe
[04:27:13] + 10240 bytes downloaded
[04:27:13] + 20480 bytes downloaded
[04:27:13] + 30720 bytes downloaded
[04:27:13] + 40960 bytes downloaded
[04:27:13] + 51200 bytes downloaded
[04:27:13] + 61440 bytes downloaded
[04:27:13] + 71680 bytes downloaded
[04:27:13] + 81920 bytes downloaded
[04:27:13] + 92160 bytes downloaded
[04:27:13] + 102400 bytes downloaded
[04:27:13] + 112640 bytes downloaded
[04:27:13] + 122880 bytes downloaded
[04:27:13] + 133120 bytes downloaded
[04:27:13] + 143360 bytes downloaded
[04:27:13] + 153600 bytes downloaded
[04:27:14] + 163840 bytes downloaded
[04:27:14] + 174080 bytes downloaded
[04:27:14] + 184320 bytes downloaded
[04:27:14] + 194560 bytes downloaded
[04:27:14] + 204800 bytes downloaded
[04:27:14] + 215040 bytes downloaded
[04:27:14] + 225280 bytes downloaded
[04:27:14] + 235520 bytes downloaded
[04:27:14] + 245760 bytes downloaded
[04:27:14] + 256000 bytes downloaded
[04:27:14] + 266240 bytes downloaded
[04:27:15] + 276480 bytes downloaded
[04:27:15] + 286720 bytes downloaded
[04:27:15] + 296960 bytes downloaded
[04:27:15] + 307200 bytes downloaded
[04:27:15] + 317440 bytes downloaded
[04:27:15] + 327680 bytes downloaded
[04:27:15] + 337920 bytes downloaded
[04:27:15] + 348160 bytes downloaded
[04:27:15] + 358400 bytes downloaded
[04:27:15] + 368640 bytes downloaded
[04:27:15] + 378880 bytes downloaded
[04:27:15] + 389120 bytes downloaded
[04:27:15] + 399360 bytes downloaded
[04:27:15] + 409600 bytes downloaded
[04:27:15] + 419840 bytes downloaded
[04:27:15] + 430080 bytes downloaded
[04:27:15] + 440320 bytes downloaded
[04:27:15] + 450560 bytes downloaded
[04:27:16] + 460800 bytes downloaded
[04:27:16] + 471040 bytes downloaded
[04:27:17] + 481280 bytes downloaded
[04:27:17] + 491520 bytes downloaded
[04:27:17] + 501760 bytes downloaded
[04:27:17] + 512000 bytes downloaded
[04:27:17] + 522240 bytes downloaded
[04:27:17] + 532480 bytes downloaded
[04:27:17] + 542720 bytes downloaded
[04:27:17] + 552960 bytes downloaded
[04:27:17] + 563200 bytes downloaded
[04:27:17] + 573440 bytes downloaded
[04:27:17] + 583680 bytes downloaded
[04:27:17] + 593920 bytes downloaded
[04:27:17] + 604160 bytes downloaded
[04:27:17] + 614400 bytes downloaded
[04:27:17] + 624640 bytes downloaded
[04:27:17] + 634880 bytes downloaded
[04:27:18] + 645120 bytes downloaded
[04:27:18] + 655360 bytes downloaded
[04:27:18] + 665600 bytes downloaded
[04:27:18] + 675840 bytes downloaded
[04:27:18] + 686080 bytes downloaded
[04:27:18] + 696320 bytes downloaded
[04:27:18] + 706560 bytes downloaded
[04:27:18] + 716800 bytes downloaded
[04:27:18] + 727040 bytes downloaded
[04:27:18] + 737280 bytes downloaded
[04:27:18] + 747520 bytes downloaded
[04:27:18] + 757760 bytes downloaded
[04:27:18] + 768000 bytes downloaded
[04:27:19] + 778240 bytes downloaded
[04:27:19] + 788480 bytes downloaded
[04:27:19] + 798720 bytes downloaded
[04:27:19] + 808960 bytes downloaded
[04:27:19] + 819200 bytes downloaded
[04:27:19] + 829440 bytes downloaded
[04:27:19] + 839680 bytes downloaded
[04:27:19] + 849920 bytes downloaded
[04:27:20] + 860160 bytes downloaded
[04:27:20] + 870400 bytes downloaded
[04:27:20] + 880640 bytes downloaded
[04:27:20] + 890880 bytes downloaded
[04:27:20] + 901120 bytes downloaded
[04:27:20] + 911360 bytes downloaded
[04:27:20] + 921600 bytes downloaded
[04:27:20] + 931840 bytes downloaded
[04:27:20] + 942080 bytes downloaded
[04:27:20] + 952320 bytes downloaded
[04:27:20] + 962560 bytes downloaded
[04:27:20] + 972800 bytes downloaded
[04:27:20] + 983040 bytes downloaded
[04:27:20] + 993280 bytes downloaded
[04:27:20] + 1003520 bytes downloaded
[04:27:20] + 1013760 bytes downloaded
[04:27:20] + 1024000 bytes downloaded
[04:27:20] + 1034240 bytes downloaded
[04:27:20] + 1044480 bytes downloaded
[04:27:21] + 1054720 bytes downloaded
[04:27:21] + 1064960 bytes downloaded
[04:27:21] + 1075200 bytes downloaded
[04:27:21] + 1085440 bytes downloaded
[04:27:21] + 1095680 bytes downloaded
[04:27:21] + 1105920 bytes downloaded
[04:27:21] + 1116160 bytes downloaded
[04:27:22] + 1126400 bytes downloaded
[04:27:22] + 1136640 bytes downloaded
[04:27:22] + 1146880 bytes downloaded
[04:27:22] + 1157120 bytes downloaded
[04:27:22] + 1167360 bytes downloaded
[04:27:22] + 1177600 bytes downloaded
[04:27:22] + 1187840 bytes downloaded
[04:27:22] + 1198080 bytes downloaded
[04:27:22] + 1208320 bytes downloaded
[04:27:22] + 1218560 bytes downloaded
[04:27:22] + 1228800 bytes downloaded
[04:27:22] + 1239040 bytes downloaded
[04:27:22] + 1249280 bytes downloaded
[04:27:22] + 1259520 bytes downloaded
[04:27:22] + 1269760 bytes downloaded
[04:27:22] + 1280000 bytes downloaded
[04:27:22] + 1290240 bytes downloaded
[04:27:22] + 1300480 bytes downloaded
[04:27:22] + 1310720 bytes downloaded
[04:27:22] + 1320960 bytes downloaded
[04:27:23] + 1331200 bytes downloaded
[04:27:23] + 1341440 bytes downloaded
[04:27:23] + 1351680 bytes downloaded
[04:27:23] + 1361920 bytes downloaded
[04:27:23] + 1372160 bytes downloaded
[04:27:23] + 1382400 bytes downloaded
[04:27:23] + 1392640 bytes downloaded
[04:27:23] + 1402880 bytes downloaded
[04:27:23] + 1413120 bytes downloaded
[04:27:23] + 1422551 bytes downloaded
[04:27:23] Verifying core Core_15.fah...
[04:27:24] Signature is VALID
[04:27:24]
[04:27:24] Trying to unzip core FahCore_15.exe
[04:27:24] Decompressed FahCore_15.exe (3903488 bytes) successfully
[04:27:29] + Core successfully engaged
[04:27:34]
[04:27:34] + Processing work unit
[04:27:34] Core required: FahCore_15.exe
[04:27:34] Core found.
[04:27:34] Working on queue slot 01 [February 11 04:27:34 UTC]
[04:27:34] + Working ...
[04:27:34]
[04:27:34] *------------------------------*
[04:27:34] Folding@Home GPU Core
[04:27:34] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[04:27:34]
[04:27:34] Build host: SimbiosNvdWin7
[04:27:34] Board Type: NVIDIA/CUDA
[04:27:34] Core      : x=15
[04:27:34]  Window's signal control handler registered.
[04:27:34] Preparing to commence simulation
[04:27:34] - Looking at optimizations...
[04:27:34] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[04:27:34] - Created dyn
[04:27:34] - Files status OK
[04:27:34] sizeof(CORE_PACKET_HDR) = 512 file=<>
[04:27:34] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[04:27:34] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[04:27:34] - Digital signature verified
[04:27:34]
[04:27:34] Project: 6806 (Run 2142, Clone 1, Gen 30)
[04:27:34]
[04:27:34] Assembly optimizations on if available.
[04:27:34] Entering M.D.
[04:27:36] Tpr hash work/wudata_01.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[04:27:36] Working on 2 PEPTIDE (1-42)
[04:27:36] Client config found, loading data.
[04:27:37] Starting GUI Server
[04:27:37] Setting checkpoint frequency: 500000
[04:29:21] Completed    500000 out of 50000000 steps (1%).
[04:29:21] mdrun_gpu returned 52
[04:29:21] NANs detected on GPU
[04:29:21]
[04:29:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:29:24] CoreStatus = 7A (122)
[04:29:24] Sending work to server
[04:29:24] Project: 6806 (Run 2142, Clone 1, Gen 30)
[04:29:24] - Read packet limit of 540015616... Set to 524286976.
[04:29:24] - Error: Could not get length of results file work/wuresults_01.dat
[04:29:24] - Error: Could not read unit 01 file. Removing from queue.
[04:29:24] - Preparing to get new work unit...
[04:29:24] Cleaning up work directory
[04:29:24] + Attempting to get work packet
[04:29:24] Passkey found
[04:29:24] Gpu type=3 species=30.
[04:29:24] - Connecting to assignment server
[04:29:25] - Successful: assigned to (171.64.65.64).
[04:29:25] + News From Folding@Home: Welcome to Folding@Home
[04:29:25] Loaded queue successfully.
[04:29:25] Gpu type=3 species=30.
[04:29:26] + Closed connections
[04:29:31]
[04:29:31] + Processing work unit
[04:29:31] Core required: FahCore_15.exe
[04:29:31] Core found.
[04:29:31] Working on queue slot 02 [February 11 04:29:31 UTC]
[04:29:31] + Working ...
[04:29:31]
[04:29:31] *------------------------------*
[04:29:31] Folding@Home GPU Core
[04:29:31] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[04:29:31]
[04:29:31] Build host: SimbiosNvdWin7
[04:29:31] Board Type: NVIDIA/CUDA
[04:29:31] Core      : x=15
[04:29:31]  Window's signal control handler registered.
[04:29:31] Preparing to commence simulation
[04:29:31] - Looking at optimizations...
[04:29:31] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[04:29:31] - Created dyn
[04:29:31] - Files status OK
[04:29:31] sizeof(CORE_PACKET_HDR) = 512 file=<>
[04:29:31] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[04:29:31] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[04:29:31] - Digital signature verified
[04:29:31]
[04:29:31] Project: 6806 (Run 2142, Clone 1, Gen 30)
[04:29:31]
[04:29:31] Assembly optimizations on if available.
[04:29:31] Entering M.D.
[04:29:33] Tpr hash work/wudata_02.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[04:29:33] Working on 2 PEPTIDE (1-42)
[04:29:33] Client config found, loading data.
[04:29:34] Setting checkpoint frequency: 500000
[04:29:34] Starting GUI Server
--- Opening Log file [February 11 04:32:16 UTC]
Arguments: -gpu 0
[04:32:16] - Ask before connecting: No
[04:32:16] - User name: caintry_boy (Team 32035)
[04:32:16] - User ID: 2632F19E01C921AC
[04:32:16] - Machine ID: 2
[04:32:16]
[04:32:16] Gpu type=3 species=30.
[04:32:16] Work directory not found. Creating...
[04:32:16] Could not open work queue, generating new queue...
[04:32:16] Initialization complete
[04:32:16] - Preparing to get new work unit...
[04:32:16] Cleaning up work directory
[04:32:16] + Attempting to get work packet
[04:32:16] Passkey found
[04:32:16] - Connecting to assignment server
[04:32:17] - Successful: assigned to (171.64.65.64).
[04:32:17] + News From Folding@Home: Welcome to Folding@Home
[04:32:17] Loaded queue successfully.
[04:32:17] Gpu type=3 species=30.
[04:32:18] + Closed connections
[04:32:18]
[04:32:18] + Processing work unit
[04:32:18] Core required: FahCore_15.exe
[04:32:18] Core not found.
[04:32:18] - Core is not present or corrupted.
[04:32:18] - Attempting to download new core...
[04:32:18] + Downloading new core: FahCore_15.exe
[04:32:18] + 10240 bytes downloaded
[04:32:18] + 20480 bytes downloaded
[04:32:18] + 30720 bytes downloaded
[04:32:18] + 40960 bytes downloaded
[04:32:18] + 51200 bytes downloaded
[04:32:18] + 61440 bytes downloaded
[04:32:18] + 71680 bytes downloaded
[04:32:18] + 81920 bytes downloaded
[04:32:19] + 92160 bytes downloaded
[04:32:19] + 102400 bytes downloaded
[04:32:19] + 112640 bytes downloaded
[04:32:19] + 122880 bytes downloaded
[04:32:19] + 133120 bytes downloaded
[04:32:19] + 143360 bytes downloaded
[04:32:19] + 153600 bytes downloaded
[04:32:19] + 163840 bytes downloaded
[04:32:19] + 174080 bytes downloaded
[04:32:19] + 184320 bytes downloaded
[04:32:19] + 194560 bytes downloaded
[04:32:19] + 204800 bytes downloaded
[04:32:19] + 215040 bytes downloaded
[04:32:19] + 225280 bytes downloaded
[04:32:19] + 235520 bytes downloaded
[04:32:19] + 245760 bytes downloaded
[04:32:19] + 256000 bytes downloaded
[04:32:19] + 266240 bytes downloaded
[04:32:20] + 276480 bytes downloaded
[04:32:20] + 286720 bytes downloaded
[04:32:20] + 296960 bytes downloaded
[04:32:20] + 307200 bytes downloaded
[04:32:20] + 317440 bytes downloaded
[04:32:20] + 327680 bytes downloaded
[04:32:20] + 337920 bytes downloaded
[04:32:20] + 348160 bytes downloaded
[04:32:20] + 358400 bytes downloaded
[04:32:21] + 368640 bytes downloaded
[04:32:21] + 378880 bytes downloaded
[04:32:21] + 389120 bytes downloaded
[04:32:21] + 399360 bytes downloaded
[04:32:21] + 409600 bytes downloaded
[04:32:21] + 419840 bytes downloaded
[04:32:21] + 430080 bytes downloaded
[04:32:22] + 440320 bytes downloaded
[04:32:22] + 450560 bytes downloaded
[04:32:22] + 460800 bytes downloaded
[04:32:22] + 471040 bytes downloaded
[04:32:22] + 481280 bytes downloaded
[04:32:22] + 491520 bytes downloaded
[04:32:22] + 501760 bytes downloaded
[04:32:22] + 512000 bytes downloaded
[04:32:22] + 522240 bytes downloaded
[04:32:22] + 532480 bytes downloaded
[04:32:23] + 542720 bytes downloaded
[04:32:23] + 552960 bytes downloaded
[04:32:23] + 563200 bytes downloaded
[04:32:23] + 573440 bytes downloaded
[04:32:23] + 583680 bytes downloaded
[04:32:23] + 593920 bytes downloaded
[04:32:23] + 604160 bytes downloaded
[04:32:23] + 614400 bytes downloaded
[04:32:24] + 624640 bytes downloaded
[04:32:24] + 634880 bytes downloaded
[04:32:25] + 645120 bytes downloaded
[04:32:25] + 655360 bytes downloaded
[04:32:25] + 665600 bytes downloaded
[04:32:25] + 675840 bytes downloaded
[04:32:25] + 686080 bytes downloaded
[04:32:25] + 696320 bytes downloaded
[04:32:25] + 706560 bytes downloaded
[04:32:25] + 716800 bytes downloaded
[04:32:25] + 727040 bytes downloaded
[04:32:26] + 737280 bytes downloaded
[04:32:26] + 747520 bytes downloaded
[04:32:26] + 757760 bytes downloaded
[04:32:26] + 768000 bytes downloaded
[04:32:26] + 778240 bytes downloaded
[04:32:26] + 788480 bytes downloaded
[04:32:26] + 798720 bytes downloaded
[04:32:26] + 808960 bytes downloaded
[04:32:26] + 819200 bytes downloaded
[04:32:26] + 829440 bytes downloaded
[04:32:26] + 839680 bytes downloaded
[04:32:26] + 849920 bytes downloaded
[04:32:26] + 860160 bytes downloaded
[04:32:26] + 870400 bytes downloaded
[04:32:26] + 880640 bytes downloaded
[04:32:26] + 890880 bytes downloaded
[04:32:26] + 901120 bytes downloaded
[04:32:26] + 911360 bytes downloaded
[04:32:27] + 921600 bytes downloaded
[04:32:27] + 931840 bytes downloaded
[04:32:27] + 942080 bytes downloaded
[04:32:27] + 952320 bytes downloaded
[04:32:27] + 962560 bytes downloaded
[04:32:27] + 972800 bytes downloaded
[04:32:27] + 983040 bytes downloaded
[04:32:27] + 993280 bytes downloaded
[04:32:27] + 1003520 bytes downloaded
[04:32:27] + 1013760 bytes downloaded
[04:32:27] + 1024000 bytes downloaded
[04:32:27] + 1034240 bytes downloaded
[04:32:27] + 1044480 bytes downloaded
[04:32:28] + 1054720 bytes downloaded
[04:32:28] + 1064960 bytes downloaded
[04:32:28] + 1075200 bytes downloaded
[04:32:28] + 1085440 bytes downloaded
[04:32:28] + 1095680 bytes downloaded
[04:32:28] + 1105920 bytes downloaded
[04:32:28] + 1116160 bytes downloaded
[04:32:28] + 1126400 bytes downloaded
[04:32:28] + 1136640 bytes downloaded
[04:32:28] + 1146880 bytes downloaded
[04:32:28] + 1157120 bytes downloaded
[04:32:28] + 1167360 bytes downloaded
[04:32:28] + 1177600 bytes downloaded
[04:32:28] + 1187840 bytes downloaded
[04:32:28] + 1198080 bytes downloaded
[04:32:28] + 1208320 bytes downloaded
[04:32:28] + 1218560 bytes downloaded
[04:32:28] + 1228800 bytes downloaded
[04:32:28] + 1239040 bytes downloaded
[04:32:29] + 1249280 bytes downloaded
[04:32:29] + 1259520 bytes downloaded
[04:32:29] + 1269760 bytes downloaded
[04:32:30] + 1280000 bytes downloaded
[04:32:30] + 1290240 bytes downloaded
[04:32:30] + 1300480 bytes downloaded
[04:32:30] + 1310720 bytes downloaded
[04:32:30] + 1320960 bytes downloaded
[04:32:30] + 1331200 bytes downloaded
[04:32:30] + 1341440 bytes downloaded
[04:32:30] + 1351680 bytes downloaded
[04:32:30] + 1361920 bytes downloaded
[04:32:30] + 1372160 bytes downloaded
[04:32:30] + 1382400 bytes downloaded
[04:32:30] + 1392640 bytes downloaded
[04:32:31] + 1402880 bytes downloaded
[04:32:31] + 1413120 bytes downloaded
[04:32:31] + 1422551 bytes downloaded
[04:32:31] Verifying core Core_15.fah...
[04:32:31] Signature is VALID
[04:32:31]
[04:32:31] Trying to unzip core FahCore_15.exe
[04:32:31] Decompressed FahCore_15.exe (3903488 bytes) successfully
[04:32:36] + Core successfully engaged
[04:32:41]
[04:32:41] + Processing work unit
[04:32:41] Core required: FahCore_15.exe
[04:32:41] Core found.
[04:32:41] Working on queue slot 01 [February 11 04:32:41 UTC]
[04:32:41] + Working ...
[04:32:41]
[04:32:41] *------------------------------*
[04:32:41] Folding@Home GPU Core
[04:32:41] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[04:32:41]
[04:32:41] Build host: SimbiosNvdWin7
[04:32:41] Board Type: NVIDIA/CUDA
[04:32:41] Core      : x=15
[04:32:41]  Window's signal control handler registered.
[04:32:41] Preparing to commence simulation
[04:32:42] - Looking at optimizations...
[04:32:42] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[04:32:42] - Created dyn
[04:32:42] - Files status OK
[04:32:42] sizeof(CORE_PACKET_HDR) = 512 file=<>
[04:32:42] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[04:32:42] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[04:32:42] - Digital signature verified
[04:32:42]
[04:32:42] Project: 6806 (Run 2142, Clone 1, Gen 30)
[04:32:42]
[04:32:42] Assembly optimizations on if available.
[04:32:42] Entering M.D.
[04:32:44] Tpr hash work/wudata_01.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[04:32:44] Working on 2 PEPTIDE (1-42)
[04:32:44] Client config found, loading data.
[04:32:44] Starting GUI Server
[04:32:44] Setting checkpoint frequency: 500000
[04:34:28] Completed    500000 out of 50000000 steps (1%).
[04:34:28] mdrun_gpu returned 52
[04:34:28] NANs detected on GPU
[04:34:28]
[04:34:28] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:34:31] CoreStatus = 7A (122)
[04:34:31] Sending work to server
[04:34:31] Project: 6806 (Run 2142, Clone 1, Gen 30)
[04:34:31] - Read packet limit of 540015616... Set to 524286976.
[04:34:31] - Error: Could not get length of results file work/wuresults_01.dat
[04:34:31] - Error: Could not read unit 01 file. Removing from queue.
[04:34:31] - Preparing to get new work unit...
[04:34:31] Cleaning up work directory
[04:34:31] + Attempting to get work packet
[04:34:31] Passkey found
[04:34:31] Gpu type=3 species=30.
[04:34:31] - Connecting to assignment server
[04:34:32] - Successful: assigned to (171.64.65.64).
[04:34:32] + News From Folding@Home: Welcome to Folding@Home
[04:34:32] Loaded queue successfully.
[04:34:32] Gpu type=3 species=30.
[04:34:33] + Closed connections
[04:34:38]
[04:34:38] + Processing work unit
[04:34:38] Core required: FahCore_15.exe
[04:34:38] Core found.
[04:34:38] Working on queue slot 02 [February 11 04:34:38 UTC]
[04:34:38] + Working ...
[04:34:38]
[04:34:38] *------------------------------*
[04:34:38] Folding@Home GPU Core
[04:34:38] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[04:34:38]
[04:34:38] Build host: SimbiosNvdWin7
[04:34:38] Board Type: NVIDIA/CUDA
[04:34:38] Core      : x=15
[04:34:38]  Window's signal control handler registered.
[04:34:38] Preparing to commence simulation
[04:34:38] - Looking at optimizations...
[04:34:38] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[04:34:38] - Created dyn
[04:34:38] - Files status OK
[04:34:38] sizeof(CORE_PACKET_HDR) = 512 file=<>
[04:34:38] - Expanded 39880 -> 172159 (decompressed 431.6 percent)
[04:34:38] Called DecompressByteArray: compressed_data_size=39880 data_size=172159, decompressed_data_size=172159 diff=0
[04:34:38] - Digital signature verified
[04:34:38]
[04:34:38] Project: 6806 (Run 2142, Clone 1, Gen 30)
[04:34:38]
[04:34:38] Assembly optimizations on if available.
[04:34:38] Entering M.D.
[04:34:40] Tpr hash work/wudata_02.tpr:  1424526170 491524668 1520117875 3040399645 1933038313
[04:34:40] Working on 2 PEPTIDE (1-42)
[04:34:40] Client config found, loading data.
[04:34:41] Setting checkpoint frequency: 500000
[04:34:41] Starting GUI Server
edit: what the heck do I have to do to get a different WU?? I've forgotten it's been so long...
:idea:
WU Database shows 3 Donors with successful completions but got 0 points. I have marked it for a follow-up.
EDIT ->
caintry_boy wrote:...edit: what the heck do I have to do to get a different WU?? I've forgotten it's been so long...
Here you go:
Step 1: Stop the F@h Client
Step 2: Delete the Work folder
Step 3: Delete the queue.dat file
Step 4: Change the Machine ID to another unique value
Step 5: Start the F@h Client
caintry_boy
Thanks PantherX...got it!
