Project: 6515 (Run 11, Clone 27, Gen 44)
k_madsen
Hardware configuration: diverse -)
Post by k_madsen »
amd 965 wartercolled and 1 ATI 5770 Gpu
3 normal clients and 1 gpu client with ati settings 85% of the cpu power used.
Hi
i got trouble every time i try to start core 3
It was starting after finish of last unit
yes it continnued after reboot
00:18:01] Completed 235000 out of 250000 steps  (94%)
[00:22:57] Writing local files
[00:22:57] Completed 237500 out of 250000 steps  (95%)
[00:27:53] Writing local files
[00:27:53] Completed 240000 out of 250000 steps  (96%)
[00:32:50] Writing local files
[00:32:50] Completed 242500 out of 250000 steps  (97%)
[00:37:46] Writing local files
[00:37:46] Completed 245000 out of 250000 steps  (98%)
[00:42:42] Writing local files
[00:42:42] Completed 247500 out of 250000 steps  (99%)
[00:47:38] Writing local files
[00:47:38] Completed 250000 out of 250000 steps  (100%)
[00:47:38] Writing final coordinates.
[00:47:38] Past main M.D. loop
[00:48:38]
[00:48:38] Finished Work Unit:
[00:48:38] - Reading up to 405792 from "work/wudata_04.arc": Read 405792
[00:48:38] - Reading up to 48560 from "work/wudata_04.xtc": Read 48560
[00:48:38] goefile size: 0
[00:48:38] logfile size: 23192
[00:48:38] Leaving Run
[00:48:41] - Writing 493884 bytes of core data to disk...
[00:48:42] Done: 493372 -> 447889 (compressed to 90.7 percent)
[00:48:42]   ... Done.
[00:48:42] - Shutting down core
[00:48:42]
[00:48:42] Folding@home Core Shutdown: FINISHED_UNIT
[00:48:46] CoreStatus = 64 (100)
[00:48:46] Sending work to server
[00:48:46] Project: 6505 (Run 11, Clone 349, Gen 11)
[00:48:46] - Read packet limit of 540015616... Set to 524286976.
[00:48:46] + Attempting to send results [January 21 00:48:46 UTC]
[00:48:53] + Results successfully sent
[00:48:53] Thank you for your contribution to Folding@Home.
[00:48:53] + Number of Units Completed: 325
[00:48:57] - Preparing to get new work unit...
[00:48:57] + Attempting to get work packet
[00:48:57] - Connecting to assignment server
[00:48:58] - Successful: assigned to (171.64.65.62).
[00:48:58] + News From Folding@Home: Welcome to Folding@Home
[00:48:59] Loaded queue successfully.
[00:49:01] + Closed connections
[00:49:01]
[00:49:01] + Processing work unit
[00:49:01] Core required: FahCore_78.exe
[00:49:01] Core found.
[00:49:01] Working on queue slot 05 [January 21 00:49:01 UTC]
[00:49:01] + Working ...
[00:49:01]
[00:49:01] *------------------------------*
[00:49:01] Folding@Home Gromacs Core
[00:49:01] Version 1.90 (March 8, 2006)
[00:49:01]
[00:49:01] Preparing to commence simulation
[00:49:01] - Assembly optimizations manually forced on.
[00:49:01] - Not checking prior termination.
[00:49:01] - Expanded 123331 -> 2097153 (decompressed 1700.4 percent)
[00:49:02] - Starting from initial work packet
[00:49:02]
[00:49:02] Project: 6515 (Run 11, Clone 27, Gen 44)
[00:49:02]
[00:49:02] Assembly optimizations on if available.
[00:49:02] Entering M.D.
[00:49:08] Gromacs error.
[00:49:08]
[00:49:08] Folding@home Core Shutdown: UNKNOWN_ERROR
[00:49:11] CoreStatus = 79 (121)
[00:49:11] Client-core communications error: ERROR 0x79
[00:49:11] This is a sign of more serious problems, shutting down.
[12:46:21] Service stop request received.
Folding@Home Client Shutdown.
To Beleave is something but to know is 1000 times better.
Re: Project: 6515 (Run 11, Clone 27, Gen 44)
It looks like a bad WU :(
Delete you queue.dat file and your /work folder to get another WU that works (you might have to repeat the delete process a few times before you got another WU).
gmcintire
Post by gmcintire »
I have the exact same project as the OP, with same Run, Clone and Gen. Having the same issue. I've deleted queue.dat and /work folder several times over the past 2 days and I keep getting the same wu. Is there anything else I can do?
gmcintire
Post by gmcintire »
Nevermind, I finally got another one. Whew!
gmcintire wrote:I have the exact same project as the OP, with same Run, Clone and Gen. Having the same issue. I've deleted queue.dat and /work folder several times over the past 2 days and I keep getting the same wu. Is there anything else I can do?
Making reports like this is important, even if you've moved on to another WU.
The servers are supposed to limit the number of times they reassign WUs. Sometimes that works and sometimes not. In fact, when the client fails to report the problem to the server, it can be really pretty bad. We can't always tell whether the problem is in the WU itself or the Donor's hardware but once there are "enough" reports, we can stop the WU manually so it doesn't keep going out to more and more people.
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
Looks like it's back again after 8 days. At the end of the sequence below, I was assigned a different WU which seems to be working fine.
04:14:02:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
04:14:26:Unit 00:
04:14:26:Unit 00:Folding@home Core Shutdown: UNKNOWN_ERROR
04:14:26:Unit 00:
04:14:27:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
04:15:30:Unit 00:Folding@home Core Shutdown: UNKNOWN_ERROR
04:15:31:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
04:16:40:Starting Unit 00
04:17:04:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
04:19:17:Starting Unit 00
04:19:41:FahCore running Unit 00 returned: UNKNOWN_ERROR (121)
04:19:41:WARNING: Unit 00 Too many errors, failing
04:19:41:Sending unit results: id:00 state:SEND project:6515 run:11 clone:27 gen:44 core:0x78 unit:0x32a0ba2a4dd889d0002c001b000b1973
04:19:42:WARNING: Work server too old for fail report, dumping
04:19:42:Cleaning up Unit 00
*********************** Log Started 20/May/2011-15:55:00 ***********************
15:55:00:************************* Folding@home Client *************************
15:55:00:      Website: http://folding.stanford.edu/
15:55:00:    Copyright: (c) 2009,2010 Stanford University
15:55:00:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:55:00:         Args: --lifeline 2956
15:55:00:       Config: C:/Documents and Settings/Admin/Application
15:55:00:               Data/FAHClient/config.xml
15:55:00:******************************** Build ********************************
15:55:00:      Version: 7.1.21
15:55:00:         Date: Mar 23 2011
15:55:00:         Time: 15:13:48
15:55:00:      SVN Rev: 2883
15:55:00:       Branch: fah/trunk/client
15:55:00:     Compiler: Intel(R) C++ MSVC 1500 mode 1110
15:55:00:      Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE
15:55:00:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
15:55:00:     Platform: win32 XP
15:55:00:         Bits: 32
15:55:00:         Mode: Release
15:55:00:******************************* System ********************************
15:55:00:           OS: Microsoft Windows XP Home Edition
15:55:00:          CPU: Intel(R) Pentium(R) M processor 1.73GHz
15:55:00:       CPU ID: GenuineIntel Family 6 Model 13 Stepping 8
15:55:00:         CPUs: 1
15:55:00:       Memory: 1.99GiB
15:55:00:  Free Memory: 1.11GiB
15:55:00:      Threads: WINDOWS_THREADS
15:55:00:         GPUs: 0
15:55:00:         CUDA: Not detected
15:55:00:   On Battery: false
15:55:00:   UTC offset: -7
15:55:00:          PID: 3624
15:55:00:          CWD: C:/Documents and Settings/Admin/Application Data/FAHClient
15:55:00:Win32 Service: false
15:55:00:***********************************************************************
15:55:00:<config>
15:55:00:  <service-description v='Folding@home Client'/>
15:55:00:  <service-restart v='true'/>
15:55:00:  <service-restart-delay v='5000'/>
15:55:00:
15:55:00:  <!-- Client Control -->
15:55:00:  <cycle-rate v='4'/>
15:55:00:  <cycles v='-1'/>
15:55:00:  <data-directory v='.'/>
15:55:00:  <exec-directory v='C:\Program Files\FAHClient'/>
15:55:00:  <exit-when-done v='false'/>
15:55:00:  <max-delay v='21600'/>
15:55:00:  <min-delay v='60'/>
15:55:00:  <threads v='4'/>
15:55:00:
15:55:00:  <!-- Configuration -->
15:55:00:  <config-rotate v='true'/>
15:55:00:  <config-rotate-dir v='configs'/>
15:55:00:  <config-rotate-max v='16'/>
15:55:00:
15:55:00:  <!-- Debugging -->
15:55:00:  <assignment-servers>
15:55:00:    assign3.stanford.edu:8080 assign4.stanford.edu:80
15:55:00:  </assignment-servers>
15:55:00:  <capture-directory v='capture'/>
15:55:00:  <capture-sockets v='false'/>
15:55:00:  <debug-sockets v='false'/>
15:55:00:  <exception-locations v='true'/>
15:55:00:  <gpu-assignment-servers>
15:55:00:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
15:55:00:  </gpu-assignment-servers>
15:55:00:  <stack-traces v='false'/>
15:55:00:
15:55:00:  <!-- Error Handling -->
15:55:00:  <max-slot-errors v='5'/>
15:55:00:  <max-unit-errors v='5'/>
15:55:00:
15:55:00:  <!-- FahCore Control -->
15:55:00:  <checkpoint v='15'/>
15:55:00:  <core-dir v='cores'/>
15:55:00:  <core-priority v='idle'/>
15:55:00:  <cpu-affinity v='false'/>
15:55:00:  <cpu-usage v='100'/>
15:55:00:  <no-assembly v='false'/>
15:55:00:
15:55:00:  <!-- Folding Slot Configuration -->
15:55:00:  <client-subtype v='STDCLI'/>
15:55:00:  <client-type v='normal'/>
15:55:00:  <cpu-species v='X86_PENTIUM_II'/>
15:55:00:  <cpu-type v='X86'/>
15:55:00:  <cpus v='1'/>
15:55:00:  <extra-core-args v='-forceasm'/>
15:55:00:  <gpu v='false'/>
15:55:00:  <gpu-id v='0'/>
15:55:00:  <max-packet-size v='normal'/>
15:55:00:  <os-species v='WIN_XP'/>
15:55:00:  <os-type v='WIN32'/>
15:55:00:  <project-key v='0'/>
15:55:00:  <smp v='false'/>
15:55:00:
15:55:00:  <!-- Logging -->
15:55:00:  <log v='log.txt'/>
15:55:00:  <log-color v='false'/>
15:55:00:  <log-crlf v='true'/>
15:55:00:  <log-date v='false'/>
15:55:00:  <log-debug v='true'/>
15:55:00:  <log-domain v='false'/>
15:55:00:  <log-header v='true'/>
15:55:00:  <log-level v='true'/>
15:55:00:  <log-no-info-header v='true'/>
15:55:00:  <log-redirect v='false'/>
15:55:00:  <log-rotate v='true'/>
15:55:00:  <log-rotate-dir v='logs'/>
15:55:00:  <log-rotate-max v='16'/>
15:55:00:  <log-short-level v='false'/>
15:55:00:  <log-simple-domains v='true'/>
15:55:00:  <log-thread-id v='false'/>
15:55:00:  <log-time v='true'/>
15:55:00:  <log-to-screen v='true'/>
15:55:00:  <log-truncate v='false'/>
15:55:00:  <verbosity v='4'/>
15:55:00:
15:55:00:  <!-- Process Control -->
15:55:00:  <child v='false'/>
15:55:00:  <daemon v='false'/>
15:55:00:  <pid v='false'/>
15:55:00:  <pid-file v='Folding@home Client.pid'/>
15:55:00:  <respawn v='false'/>
15:55:00:  <service v='false'/>
15:55:00:
15:55:00:  <!-- Remote Command Server -->
15:55:00:  <command-address v='0.0.0.0'/>
15:55:00:  <command-allow v='127.0.0.1'/>
15:55:00:  <command-allow-no-pass v='127.0.0.1'/>
15:55:00:  <command-deny v='0.0.0.0/0'/>
15:55:00:  <command-deny-no-pass v='0.0.0.0/0'/>
15:55:00:  <command-port v='36330'/>
15:55:00:  <password v=''/>
15:55:00:
15:55:00:  <!-- Slot Control -->
15:55:00:  <max-shutdown-wait v='60'/>
15:55:00:  <pause-on-battery v='true'/>
15:55:00:  <pause-on-start v='false'/>
15:55:00:
15:55:00:  <!-- User Information -->
15:55:00:  <machine-id v='0'/>
15:55:00:  <passkey v='********************************'/>
15:55:00:  <team v='0'/>
15:55:00:  <user v='GreyWhiskers'/>
15:55:00:
15:55:00:  <!-- Work Unit Control -->
15:55:00:  <dump-after-deadline v='true'/>
15:55:00:  <max-queue v='16'/>
15:55:00:  <max-units v='0'/>
15:55:00:  <next-unit-percentage v='99'/>
15:55:00:
15:55:00:  <!-- Folding Slots -->
15:55:00:  <slot id='0' type='UNIPROCESSOR'>
15:55:00:    <client-type v='advanced'/>
15:55:00:  </slot>
15:55:00:</config>
snip
03:18:24:Unit 01:Writing local files
03:18:24:Unit 01:Completed 240000 out of 250000 steps  (96%)
03:32:05:Unit 01:Writing local files
03:32:05:Unit 01:Completed 242500 out of 250000 steps  (97%)
03:44:53:Unit 01:Writing local files
03:44:53:Unit 01:Completed 245000 out of 250000 steps  (98%)
03:58:05:Unit 01:Writing local files
03:58:05:Unit 01:Completed 247500 out of 250000 steps  (99%)
03:58:06:Connecting to assign3.stanford.edu:8080
03:58:06:News: Welcome to Folding@Home
03:58:06:Assigned to work server 171.64.65.62
03:58:06:Requesting new work unit for slot 00: RUNNING uniprocessor from 171.64.65.62
03:58:06:Connecting to 171.64.65.62:8080
03:58:07:Slot 00: Downloading 120.94KiB
03:58:07:Slot 00: Download complete
03:58:07:Received Unit: id:00 state:DOWNLOAD project:6515 run:11 clone:27 gen:44 core:0x78 unit:0x32a0ba2a4dd889d0002c001b000b1973
04:12:51:Unit 01:Writing local files
04:12:51:Unit 01:Completed 250000 out of 250000 steps  (100%)
04:12:51:Unit 01:Writing final coordinates.
04:12:52:Unit 01:Past main M.D. loop
04:13:52:Unit 01:
04:13:52:Unit 01:Finished Work Unit:
04:13:52:Unit 01:- Reading up to 546672 from "01/wudata_01.arc": Read 546672
04:13:52:Unit 01:- Reading up to 182068 from "01/wudata_01.xtc": Read 182068
04:13:52:Unit 01:goefile size: 0
04:13:52:Unit 01:logfile size: 74626
04:13:52:Unit 01:Leaving Run
04:13:54:Unit 01:- Writing 847846 bytes of core data to disk...
04:13:55:Unit 01:Done: 847334 -> 732907 (compressed to 86.4 percent)
04:13:55:Unit 01:  ... Done.
04:13:55:Unit 01:- Shutting down core
04:13:55:Unit 01:
04:13:55:Unit 01:Folding@home Core Shutdown: FINISHED_UNIT
04:13:55:FahCore running Unit 01 returned: FINISHED_UNIT (100)
04:13:55:Sending unit results: id:01 state:SEND project:6510 run:15 clone:4 gen:92 core:0x78 unit:0x780702224dd71474005c0004000f196e
04:13:55:Starting Unit 00
04:13:55:Unit 01: Uploading 716.23KiB
04:13:55:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 3624 -version 701 -checkpoint 15 -forceasm
04:13:55:Connecting to 171.64.65.62:8080
04:13:56:Started core on PID 4696
04:13:56:FahCore 0x78 started
04:13:56:Unit 00:
04:13:56:Unit 00:*------------------------------*
04:13:56:Unit 00:Folding@Home Gromacs Core
04:13:56:Unit 00:Version 1.90 (March 8, 2006)
04:13:56:Unit 00:
04:13:56:Unit 00:Preparing to commence simulation
04:13:56:Unit 00:- Assembly optimizations manually forced on.
04:13:56:Unit 00:- Not checking prior termination.
04:13:56:Unit 00:- Expanded 123331 -> 2097153 (decompressed 1700.4 percent)
04:13:56:Unit 00:- Starting from initial work packet
04:13:56:Unit 00:
04:13:56:Unit 00:Project: 6515 (Run 11, Clone 27, Gen 44)
04:13:56:Unit 00:
04:13:56:Unit 00:Assembly optimizations on if available.
04:13:56:Unit 00:Entering M.D.
04:13:59:Unit 01: Upload complete
04:13:59:Server responded WORK_ACK (400)
04:13:59:Cleaning up Unit 01
04:14:03:Starting Unit 00
04:14:03:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 3624 -version 701 -checkpoint 15 -forceasm
04:14:03:Started core on PID 2144
04:14:03:FahCore 0x78 started
04:14:03:Unit 00:
04:14:03:Unit 00:*------------------------------*
04:14:03:Unit 00:Folding@Home Gromacs Core
04:14:03:Unit 00:Version 1.90 (March 8, 2006)
04:14:03:Unit 00:
04:14:03:Unit 00:Preparing to commence simulation
04:14:03:Unit 00:- Ensuring status. Please wait.
04:14:20:Unit 00:- Assembly optimizations manually forced on.
04:14:20:Unit 00:- Not checking prior termination.
04:14:20:Unit 00:- Expanded 123331 -> 2097153 (decompressed 1700.4 percent)
04:14:20:Unit 00:- Starting from initial work packet
04:14:20:Unit 00:
04:14:20:Unit 00:Project: 6515 (Run 11, Clone 27, Gen 44)
04:14:20:Unit 00:
04:14:20:Unit 00:Assembly optimizations on if available.
04:14:20:Unit 00:Entering M.D.
04:14:26:Unit 00:Gromacs error.
04:14:26:Unit 00:
04:15:03:Starting Unit 00
04:15:03:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 3624 -version 701 -checkpoint 15 -forceasm
04:15:05:Started core on PID 5936
04:15:05:FahCore 0x78 started
04:15:07:Unit 00:
04:15:07:Unit 00:*------------------------------*
04:15:07:Unit 00:Folding@Home Gromacs Core
04:15:07:Unit 00:Version 1.90 (March 8, 2006)
04:15:07:Unit 00:
04:15:07:Unit 00:Preparing to commence simulation
04:15:07:Unit 00:- Ensuring status. Please wait.
04:15:24:Unit 00:- Assembly optimizations manually forced on.
04:15:24:Unit 00:- Not checking prior termination.
04:15:24:Unit 00:- Expanded 123331 -> 2097153 (decompressed 1700.4 percent)
04:15:24:Unit 00:- Starting from initial work packet
04:15:24:Unit 00:
04:15:24:Unit 00:Project: 6515 (Run 11, Clone 27, Gen 44)
04:15:24:Unit 00:
04:15:24:Unit 00:Assembly optimizations on if available.
04:15:24:Unit 00:Entering M.D.
04:15:30:Unit 00:Gromacs error.
04:15:30:Unit 00:
04:16:40:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 3624 -version 701 -checkpoint 15 -forceasm
04:16:40:Started core on PID 4820
04:16:40:FahCore 0x78 started
04:16:41:Unit 00:
04:16:41:Unit 00:*------------------------------*
04:16:41:Unit 00:Folding@Home Gromacs Core
04:16:41:Unit 00:Version 1.90 (March 8, 2006)
04:16:41:Unit 00:
04:16:41:Unit 00:Preparing to commence simulation
04:16:41:Unit 00:- Ensuring status. Please wait.
04:16:57:Unit 00:- Assembly optimizations manually forced on.
04:16:57:Unit 00:- Not checking prior termination.
04:16:58:Unit 00:- Expanded 123331 -> 2097153 (decompressed 1700.4 percent)
04:16:58:Unit 00:- Starting from initial work packet
04:16:58:Unit 00:
04:16:58:Unit 00:Project: 6515 (Run 11, Clone 27, Gen 44)
04:16:58:Unit 00:
04:16:58:Unit 00:Assembly optimizations on if available.
04:16:58:Unit 00:Entering M.D.
04:19:17:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 3624 -version 701 -checkpoint 15 -forceasm
04:19:17:Started core on PID 5980
04:19:17:FahCore 0x78 started
04:19:18:Unit 00:
04:19:18:Unit 00:*------------------------------*
04:19:18:Unit 00:Folding@Home Gromacs Core
04:19:18:Unit 00:Version 1.90 (March 8, 2006)
04:19:18:Unit 00:
04:19:18:Unit 00:Preparing to commence simulation
04:19:18:Unit 00:- Ensuring status. Please wait.
04:19:35:Unit 00:- Assembly optimizations manually forced on.
04:19:35:Unit 00:- Not checking prior termination.
04:19:35:Unit 00:- Expanded 123331 -> 2097153 (decompressed 1700.4 percent)
04:19:35:Unit 00:- Starting from initial work packet
04:19:35:Unit 00:
04:19:35:Unit 00:Project: 6515 (Run 11, Clone 27, Gen 44)
04:19:35:Unit 00:
04:19:35:Unit 00:Assembly optimizations on if available.
04:19:35:Unit 00:Entering M.D.
04:19:42:Connecting to assign3.stanford.edu:8080
04:19:42:News: Welcome to Folding@Home
04:19:42:Assigned to work server 171.64.65.62
04:19:42:Requesting new work unit for slot 00: READY uniprocessor from 171.64.65.62
04:19:42:Connecting to 171.64.65.62:8080
04:19:43:Slot 00: Downloading 508.66KiB
04:19:43:Slot 00: Download complete
04:19:43:Received Unit: id:00 state:DOWNLOAD project:6503 run:14 clone:554 gen:86 core:0x78 unit:0x1a9651684dd88ee00056022a000e1967
04:21:18:Downloading core from http://www.stanford.edu/~pande/Win32/x86/Core_78.fah
04:21:18:Connecting to www.stanford.edu:80
04:21:19:WARNING: FahCore type in core package seems to be in wrong byte order.
04:21:19:FahCore 78: Downloading 805.62KiB
04:21:20:FahCore 78: Download complete
04:21:20:Valid core signature
04:21:20:WARNING: FahCore has not changed since last download, aborting core update
04:21:20:Starting Unit 00
04:21:20:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 3624 -version 701 -checkpoint 15 -forceasm
04:21:20:Started core on PID 2872
04:21:20:FahCore 0x78 started
04:21:20:Unit 00:
04:21:20:Unit 00:*------------------------------*
04:21:20:Unit 00:Folding@Home Gromacs Core
04:21:20:Unit 00:Version 1.90 (March 8, 2006)
04:21:20:Unit 00:
04:21:20:Unit 00:Preparing to commence simulation
04:21:20:Unit 00:- Assembly optimizations manually forced on.
04:21:20:Unit 00:- Not checking prior termination.
04:21:20:Unit 00:- Expanded 520352 -> 2539153 (decompressed 487.9 percent)
04:21:20:Unit 00:- Starting from initial work packet
04:21:21:Unit 00:
04:21:21:Unit 00:Project: 6503 (Run 14, Clone 554, Gen 86)
04:21:21:Unit 00:
04:21:21:Unit 00:Assembly optimizations on if available.
04:21:21:Unit 00:Entering M.D.
04:21:27:Unit 00:Protein: TR462_B_15 in water
04:21:27:Unit 00:
04:21:27:Unit 00:Writing local files
04:21:27:Unit 00:Extra SSE boost OK.
04:21:28:Unit 00:Writing local files
04:21:28:Unit 00:Completed 0 out of 250000 steps  (0%)
04:31:18:Unit 00:Writing local files
04:31:18:Unit 00:Completed 2500 out of 250000 steps  (1%)
The WU (P6515,R11,C27,G44) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
