The two computers (identical) are running a quad core i5 and nvidia GeForce 310 cpu and 64-bit win7. From what I've found, this card is CUDA enabled, and should be capable of running the GPU client, although I'm sure it won't be setting any records. I went ahead and got the newest drivers, and I think I installed CUDA, too. This is embarrassing, I used to be great with computers, but haven't done much with them for a few years. Getting CUDA on my mac was much easier, but all I see on the Windows page is developer stuff, but I got that tool kit. I'm not sure if it's required, or what.
I installed the 6.32 GPU client (really not sure what's ideal for these cards, and I'm also not sure why it shows up as version 6.30r2, is that normal?) and they sat showing "working 0/0" for quite a while. Eventually they picked up work, but when it was finished they went back to "working 0/0" and haven't gotten work since. It shows this log file.
--- Opening Log file [January 18 21:57:42 UTC]
# Windows GPU Systray Edition #################################################
Folding@Home Client Version 6.30r2
http://folding.stanford.edu
Launch directory: C:\Users\Bonnie\AppData\Roaming\Folding@home-gpu
[21:57:42] - Ask before connecting: No
[21:57:42] - User name: PrinceValorum (Team 11314)
[21:57:42] - User ID: ###
[21:57:42] - Machine ID: 2
[21:57:42]
[21:57:42] Gpu type=2 species=30.
[21:57:42] Loaded queue successfully.
[21:57:42] Initialization complete
[21:57:42]
[21:57:42] + Processing work unit
[21:57:42] Core required: FahCore_15.exe
[21:57:42] Core found.
[21:57:42] Working on queue slot 08 [January 18 21:57:42 UTC]
[21:57:42] + Working ...
[21:57:44]
[21:57:44] *------------------------------*
[21:57:44] Folding@Home GPU Core
[21:57:44] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[21:57:44]
[21:57:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[21:57:44] Build host: amoeba
[21:57:44] Board Type: NVIDIA/CUDA
[21:57:44] Core : x=15
[21:57:44] Window's signal control handler registered.
[21:57:44] Preparing to commence simulation
[21:57:44] - Looking at optimizations...
[21:57:44] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[21:57:44] - Created dyn
[21:57:44] - Files status OK
[21:57:44] sizeof(CORE_PACKET_HDR) = 512 file=<>
[21:57:44] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[21:57:44] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[21:57:44] - Digital signature verified
[21:57:44]
[21:57:44] Project: 11177 (Run 8, Clone 137, Gen 0)
[21:57:44]
[21:57:44] Assembly optimizations on if available.
[21:57:44] Entering M.D.
[21:57:46] Tpr hash work/wudata_08.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[21:57:47] Working on ALZHEIMER'S DISEASE AMYLOID
[21:57:47] Client config found, loading data.
[21:57:47] Starting GUI Server
[21:57:50] Finished fah_main
[21:57:50]
[21:57:50] Successful run
[21:57:50] DynamicWrapper: Finished Work Unit: sleep=10000
[21:57:59] Reserved 0 bytes for xtc file; Cosm status=0
[21:57:59] Reserved 0 0 786430464 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[21:57:59] Allocated 0 bytes for edr file
[21:57:59] Error: could not open bedfile, but going on anyway
[21:57:59] - Checksum of file (work/wudata_08.edr) read from disk doesn't match
[21:57:59] edrfile file hash check failed.
[21:57:59]
[21:57:59] Folding@home Core Shutdown: FILE_IO_ERROR
[21:58:03] CoreStatus = 75 (117)
[21:58:03] Error opening or reading from a file.
[21:58:03] Deleting current work unit & continuing...
[21:58:07] - Preparing to get new work unit...
[21:58:07] Cleaning up work directory
[21:58:07] + Attempting to get work packet
[21:58:07] Gpu type=2 species=30.
[21:58:07] - Connecting to assignment server
[21:58:08] - Successful: assigned to (171.67.108.31).
[21:58:08] + News From Folding@Home: Welcome to Folding@Home
[21:58:08] Loaded queue successfully.
[21:58:08] Gpu type=2 species=30.
[21:58:09] + Closed connections
[21:58:14]
[21:58:14] + Processing work unit
[21:58:14] Core required: FahCore_15.exe
[21:58:14] Core found.
[21:58:14] Working on queue slot 09 [January 18 21:58:14 UTC]
[21:58:14] + Working ...
[21:58:14]
[21:58:14] *------------------------------*
[21:58:14] Folding@Home GPU Core
[21:58:14] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[21:58:14]
[21:58:14] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[21:58:14] Build host: amoeba
[21:58:14] Board Type: NVIDIA/CUDA
[21:58:14] Core : x=15
[21:58:14] Window's signal control handler registered.
[21:58:14] Preparing to commence simulation
[21:58:14] - Looking at optimizations...
[21:58:14] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[21:58:14] - Created dyn
[21:58:14] - Files status OK
[21:58:14] sizeof(CORE_PACKET_HDR) = 512 file=<>
[21:58:14] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[21:58:14] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[21:58:14] - Digital signature verified
[21:58:14]
[21:58:14] Project: 11177 (Run 8, Clone 137, Gen 0)
[21:58:14]
[21:58:14] Assembly optimizations on if available.
[21:58:14] Entering M.D.
[21:58:16] Tpr hash work/wudata_09.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[21:58:16] Working on ALZHEIMER'S DISEASE AMYLOID
[21:58:16] Client config found, loading data.
[21:58:16] Starting GUI Server
[21:58:17] Finished fah_main
[21:58:17]
[21:58:17] Successful run
[21:58:17] DynamicWrapper: Finished Work Unit: sleep=10000
[21:58:27] Reserved 0 bytes for xtc file; Cosm status=0
[21:58:27] Reserved 0 0 786430464 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[21:58:27] Allocated 0 bytes for edr file
[21:58:27] Error: could not open bedfile, but going on anyway
[21:58:27] - Checksum of file (work/wudata_09.edr) read from disk doesn't match
[21:58:27] edrfile file hash check failed.
[21:58:27]
[21:58:27] Folding@home Core Shutdown: FILE_IO_ERROR
[21:58:31] CoreStatus = 75 (117)
[21:58:31] Error opening or reading from a file.
[21:58:31] Deleting current work unit & continuing...
[21:58:35] - Preparing to get new work unit...
[21:58:35] Cleaning up work directory
[21:58:35] + Attempting to get work packet
[21:58:35] Gpu type=2 species=30.
[21:58:35] - Connecting to assignment server
[21:58:35] - Successful: assigned to (171.67.108.31).
[21:58:35] + News From Folding@Home: Welcome to Folding@Home
[21:58:36] Loaded queue successfully.
[21:58:36] Gpu type=2 species=30.
[21:58:39] + Closed connections
[21:58:44]
[21:58:44] + Processing work unit
[21:58:44] Core required: FahCore_15.exe
[21:58:44] Core found.
[21:58:44] Working on queue slot 00 [January 18 21:58:44 UTC]
[21:58:44] + Working ...
[21:58:44]
[21:58:44] *------------------------------*
[21:58:44] Folding@Home GPU Core
[21:58:44] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[21:58:44]
[21:58:44] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[21:58:44] Build host: amoeba
[21:58:44] Board Type: NVIDIA/CUDA
[21:58:44] Core : x=15
[21:58:44] Window's signal control handler registered.
[21:58:44] Preparing to commence simulation
[21:58:44] - Looking at optimizations...
[21:58:44] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[21:58:44] - Created dyn
[21:58:44] - Files status OK
[21:58:44] sizeof(CORE_PACKET_HDR) = 512 file=<>
[21:58:44] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[21:58:44] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[21:58:44] - Digital signature verified
[21:58:44]
[21:58:44] Project: 11177 (Run 8, Clone 137, Gen 0)
[21:58:44]
[21:58:44] Assembly optimizations on if available.
[21:58:44] Entering M.D.
[21:58:47] Tpr hash work/wudata_00.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[21:58:47] Working on ALZHEIMER'S DISEASE AMYLOID
[21:58:47] Client config found, loading data.
[21:58:47] Starting GUI Server
[21:58:47] Finished fah_main
[21:58:47]
[21:58:47] Successful run
[21:58:47] DynamicWrapper: Finished Work Unit: sleep=10000
[21:58:57] Reserved 0 bytes for xtc file; Cosm status=0
[21:58:57] Reserved 0 0 786430464 bytes for arc file=<work/wudata_00.trr> Cosm status=0
[21:58:57] Allocated 0 bytes for edr file
[21:58:57] Error: could not open bedfile, but going on anyway
[21:58:57] - Checksum of file (work/wudata_00.edr) read from disk doesn't match
[21:58:57] edrfile file hash check failed.
[21:58:57]
[21:58:57] Folding@home Core Shutdown: FILE_IO_ERROR
[21:59:01] CoreStatus = 75 (117)
[21:59:01] Error opening or reading from a file.
[21:59:01] Deleting current work unit & continuing...
[21:59:05] - Preparing to get new work unit...
[21:59:05] Cleaning up work directory
[21:59:05] + Attempting to get work packet
[21:59:05] Gpu type=2 species=30.
[21:59:05] - Connecting to assignment server
[21:59:06] - Successful: assigned to (171.67.108.31).
[21:59:06] + News From Folding@Home: Welcome to Folding@Home
[21:59:06] Loaded queue successfully.
[21:59:06] Gpu type=2 species=30.
[21:59:07] + Closed connections
[21:59:12]
[21:59:12] + Processing work unit
[21:59:12] Core required: FahCore_15.exe
[21:59:12] Core found.
[21:59:12] Working on queue slot 01 [January 18 21:59:12 UTC]
[21:59:12] + Working ...
[21:59:12]
[21:59:12] *------------------------------*
[21:59:12] Folding@Home GPU Core
[21:59:12] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[21:59:12]
[21:59:12] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[21:59:12] Build host: amoeba
[21:59:12] Board Type: NVIDIA/CUDA
[21:59:12] Core : x=15
[21:59:12] Window's signal control handler registered.
[21:59:12] Preparing to commence simulation
[21:59:12] - Looking at optimizations...
[21:59:12] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[21:59:12] - Created dyn
[21:59:12] - Files status OK
[21:59:12] sizeof(CORE_PACKET_HDR) = 512 file=<>
[21:59:12] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[21:59:12] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[21:59:12] - Digital signature verified
[21:59:12]
[21:59:12] Project: 11177 (Run 8, Clone 137, Gen 0)
[21:59:12]
[21:59:12] Assembly optimizations on if available.
[21:59:12] Entering M.D.
[21:59:14] Tpr hash work/wudata_01.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[21:59:14] Working on ALZHEIMER'S DISEASE AMYLOID
[21:59:14] Client config found, loading data.
[21:59:14] Starting GUI Server
[21:59:14] Finished fah_main
[21:59:14]
[21:59:14] Successful run
[21:59:14] DynamicWrapper: Finished Work Unit: sleep=10000
[21:59:24] Reserved 0 bytes for xtc file; Cosm status=0
[21:59:24] Reserved 0 0 786430464 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[21:59:24] Allocated 0 bytes for edr file
[21:59:24] Error: could not open bedfile, but going on anyway
[21:59:24] - Checksum of file (work/wudata_01.edr) read from disk doesn't match
[21:59:24] edrfile file hash check failed.
[21:59:24]
[21:59:24] Folding@home Core Shutdown: FILE_IO_ERROR
[21:59:28] CoreStatus = 75 (117)
[21:59:28] Error opening or reading from a file.
[21:59:28] Deleting current work unit & continuing...
[21:59:32] - Preparing to get new work unit...
[21:59:32] Cleaning up work directory
[21:59:32] + Attempting to get work packet
[21:59:32] Gpu type=2 species=30.
[21:59:32] - Connecting to assignment server
[21:59:33] - Successful: assigned to (171.67.108.31).
[21:59:33] + News From Folding@Home: Welcome to Folding@Home
[21:59:33] Loaded queue successfully.
[21:59:33] Gpu type=2 species=30.
[21:59:34] + Closed connections
[21:59:39]
[21:59:39] + Processing work unit
[21:59:39] Core required: FahCore_15.exe
[21:59:39] Core found.
[21:59:39] Working on queue slot 02 [January 18 21:59:39 UTC]
[21:59:39] + Working ...
[21:59:39]
[21:59:39] *------------------------------*
[21:59:39] Folding@Home GPU Core
[21:59:39] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[21:59:39]
[21:59:39] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[21:59:39] Build host: amoeba
[21:59:39] Board Type: NVIDIA/CUDA
[21:59:39] Core : x=15
[21:59:39] Window's signal control handler registered.
[21:59:39] Preparing to commence simulation
[21:59:39] - Looking at optimizations...
[21:59:39] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[21:59:39] - Created dyn
[21:59:39] - Files status OK
[21:59:39] sizeof(CORE_PACKET_HDR) = 512 file=<>
[21:59:39] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[21:59:39] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[21:59:39] - Digital signature verified
[21:59:39]
[21:59:39] Project: 11177 (Run 8, Clone 137, Gen 0)
[21:59:39]
[21:59:39] Assembly optimizations on if available.
[21:59:39] Entering M.D.
[21:59:41] Tpr hash work/wudata_02.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[21:59:41] Working on ALZHEIMER'S DISEASE AMYLOID
[21:59:41] Client config found, loading data.
[21:59:41] Starting GUI Server
[21:59:42] Finished fah_main
[21:59:42]
[21:59:42] Successful run
[21:59:42] DynamicWrapper: Finished Work Unit: sleep=10000
[21:59:52] Reserved 0 bytes for xtc file; Cosm status=0
[21:59:52] Reserved 0 0 786430464 bytes for arc file=<work/wudata_02.trr> Cosm status=0
[21:59:52] Allocated 0 bytes for edr file
[21:59:52] Error: could not open bedfile, but going on anyway
[21:59:52] - Checksum of file (work/wudata_02.edr) read from disk doesn't match
[21:59:52] edrfile file hash check failed.
[21:59:52]
[21:59:52] Folding@home Core Shutdown: FILE_IO_ERROR
[21:59:56] CoreStatus = 75 (117)
[21:59:56] Error opening or reading from a file.
[21:59:56] Deleting current work unit & continuing...
[22:00:00] - Preparing to get new work unit...
[22:00:00] Cleaning up work directory
[22:00:00] + Attempting to get work packet
[22:00:00] Gpu type=2 species=30.
[22:00:00] - Connecting to assignment server
[22:00:00] - Successful: assigned to (171.67.108.31).
[22:00:00] + News From Folding@Home: Welcome to Folding@Home
[22:00:01] Loaded queue successfully.
[22:00:01] Gpu type=2 species=30.
[22:00:01] + Closed connections
[22:00:06]
[22:00:06] + Processing work unit
[22:00:06] Core required: FahCore_15.exe
[22:00:06] Core found.
[22:00:06] Working on queue slot 03 [January 18 22:00:06 UTC]
[22:00:06] + Working ...
[22:00:07]
[22:00:07] *------------------------------*
[22:00:07] Folding@Home GPU Core
[22:00:07] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:00:07]
[22:00:07] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:00:07] Build host: amoeba
[22:00:07] Board Type: NVIDIA/CUDA
[22:00:07] Core : x=15
[22:00:07] Window's signal control handler registered.
[22:00:07] Preparing to commence simulation
[22:00:07] - Looking at optimizations...
[22:00:07] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[22:00:07] - Created dyn
[22:00:07] - Files status OK
[22:00:07] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:00:07] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:00:07] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:00:07] - Digital signature verified
[22:00:07]
[22:00:07] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:00:07]
[22:00:07] Assembly optimizations on if available.
[22:00:07] Entering M.D.
[22:00:09] Tpr hash work/wudata_03.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:00:09] Working on ALZHEIMER'S DISEASE AMYLOID
[22:00:09] Client config found, loading data.
[22:00:09] Starting GUI Server
[22:00:09] Finished fah_main
[22:00:09]
[22:00:09] Successful run
[22:00:09] DynamicWrapper: Finished Work Unit: sleep=10000
[22:00:19] Reserved 0 bytes for xtc file; Cosm status=0
[22:00:19] Reserved 0 0 786430464 bytes for arc file=<work/wudata_03.trr> Cosm status=0
[22:00:19] Allocated 0 bytes for edr file
[22:00:19] Error: could not open bedfile, but going on anyway
[22:00:19] - Checksum of file (work/wudata_03.edr) read from disk doesn't match
[22:00:19] edrfile file hash check failed.
[22:00:19]
[22:00:19] Folding@home Core Shutdown: FILE_IO_ERROR
[22:00:23] CoreStatus = 75 (117)
[22:00:23] Error opening or reading from a file.
[22:00:23] Deleting current work unit & continuing...
[22:00:27] - Preparing to get new work unit...
[22:00:27] Cleaning up work directory
[22:00:27] + Attempting to get work packet
[22:00:27] Gpu type=2 species=30.
[22:00:27] - Connecting to assignment server
[22:00:28] - Successful: assigned to (171.67.108.31).
[22:00:28] + News From Folding@Home: Welcome to Folding@Home
[22:00:28] Loaded queue successfully.
[22:00:28] Gpu type=2 species=30.
[22:00:29] + Closed connections
[22:00:34]
[22:00:34] + Processing work unit
[22:00:34] Core required: FahCore_15.exe
[22:00:34] Core found.
[22:00:34] Working on queue slot 04 [January 18 22:00:34 UTC]
[22:00:34] + Working ...
[22:00:34]
[22:00:34] *------------------------------*
[22:00:34] Folding@Home GPU Core
[22:00:34] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:00:34]
[22:00:34] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:00:34] Build host: amoeba
[22:00:34] Board Type: NVIDIA/CUDA
[22:00:34] Core : x=15
[22:00:34] Window's signal control handler registered.
[22:00:34] Preparing to commence simulation
[22:00:34] - Looking at optimizations...
[22:00:34] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[22:00:34] - Created dyn
[22:00:34] - Files status OK
[22:00:34] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:00:34] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:00:34] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:00:34] - Digital signature verified
[22:00:34]
[22:00:34] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:00:34]
[22:00:34] Assembly optimizations on if available.
[22:00:34] Entering M.D.
[22:00:36] Tpr hash work/wudata_04.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:00:36] Working on ALZHEIMER'S DISEASE AMYLOID
[22:00:36] Client config found, loading data.
[22:00:36] Starting GUI Server
[22:00:36] Finished fah_main
[22:00:36]
[22:00:36] Successful run
[22:00:36] DynamicWrapper: Finished Work Unit: sleep=10000
[22:00:46] Reserved 0 bytes for xtc file; Cosm status=0
[22:00:46] Reserved 0 0 786430464 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[22:00:46] Allocated 0 bytes for edr file
[22:00:46] Error: could not open bedfile, but going on anyway
[22:00:46] - Checksum of file (work/wudata_04.edr) read from disk doesn't match
[22:00:46] edrfile file hash check failed.
[22:00:46]
[22:00:46] Folding@home Core Shutdown: FILE_IO_ERROR
[22:00:50] CoreStatus = 75 (117)
[22:00:50] Error opening or reading from a file.
[22:00:50] Deleting current work unit & continuing...
[22:00:54] - Preparing to get new work unit...
[22:00:54] Cleaning up work directory
[22:00:54] + Attempting to get work packet
[22:00:54] Gpu type=2 species=30.
[22:00:54] - Connecting to assignment server
[22:00:55] - Successful: assigned to (171.67.108.31).
[22:00:55] + News From Folding@Home: Welcome to Folding@Home
[22:00:55] Loaded queue successfully.
[22:00:55] Gpu type=2 species=30.
[22:00:56] + Closed connections
[22:01:01]
[22:01:01] + Processing work unit
[22:01:01] Core required: FahCore_15.exe
[22:01:01] Core found.
[22:01:01] Working on queue slot 05 [January 18 22:01:01 UTC]
[22:01:01] + Working ...
[22:01:01]
[22:01:01] *------------------------------*
[22:01:01] Folding@Home GPU Core
[22:01:01] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:01:01]
[22:01:01] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:01:01] Build host: amoeba
[22:01:01] Board Type: NVIDIA/CUDA
[22:01:01] Core : x=15
[22:01:01] Window's signal control handler registered.
[22:01:01] Preparing to commence simulation
[22:01:01] - Looking at optimizations...
[22:01:01] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[22:01:01] - Created dyn
[22:01:01] - Files status OK
[22:01:01] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:01:01] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:01:01] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:01:01] - Digital signature verified
[22:01:01]
[22:01:01] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:01:01]
[22:01:01] Assembly optimizations on if available.
[22:01:01] Entering M.D.
[22:01:04] Tpr hash work/wudata_05.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:01:04] Working on ALZHEIMER'S DISEASE AMYLOID
[22:01:04] Client config found, loading data.
[22:01:04] Starting GUI Server
[22:01:04] Finished fah_main
[22:01:04]
[22:01:04] Successful run
[22:01:04] DynamicWrapper: Finished Work Unit: sleep=10000
[22:01:14] Reserved 0 bytes for xtc file; Cosm status=0
[22:01:14] Reserved 0 0 786430464 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[22:01:14] Allocated 0 bytes for edr file
[22:01:14] Error: could not open bedfile, but going on anyway
[22:01:14] - Checksum of file (work/wudata_05.edr) read from disk doesn't match
[22:01:14] edrfile file hash check failed.
[22:01:14]
[22:01:14] Folding@home Core Shutdown: FILE_IO_ERROR
[22:01:18] CoreStatus = 75 (117)
[22:01:18] Error opening or reading from a file.
[22:01:18] Deleting current work unit & continuing...
[22:01:22] - Preparing to get new work unit...
[22:01:22] Cleaning up work directory
[22:01:22] + Attempting to get work packet
[22:01:22] Gpu type=2 species=30.
[22:01:22] - Connecting to assignment server
[22:01:23] - Successful: assigned to (171.67.108.31).
[22:01:23] + News From Folding@Home: Welcome to Folding@Home
[22:01:23] Loaded queue successfully.
[22:01:23] Gpu type=2 species=30.
[22:01:25] + Closed connections
[22:01:30]
[22:01:30] + Processing work unit
[22:01:30] Core required: FahCore_15.exe
[22:01:30] Core found.
[22:01:30] Working on queue slot 06 [January 18 22:01:30 UTC]
[22:01:30] + Working ...
[22:01:30]
[22:01:30] *------------------------------*
[22:01:30] Folding@Home GPU Core
[22:01:30] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:01:30]
[22:01:30] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:01:30] Build host: amoeba
[22:01:30] Board Type: NVIDIA/CUDA
[22:01:30] Core : x=15
[22:01:30] Window's signal control handler registered.
[22:01:30] Preparing to commence simulation
[22:01:30] - Looking at optimizations...
[22:01:30] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[22:01:30] - Created dyn
[22:01:30] - Files status OK
[22:01:30] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:01:30] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:01:30] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:01:30] - Digital signature verified
[22:01:30]
[22:01:30] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:01:30]
[22:01:30] Assembly optimizations on if available.
[22:01:30] Entering M.D.
[22:01:32] Tpr hash work/wudata_06.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:01:32] Working on ALZHEIMER'S DISEASE AMYLOID
[22:01:32] Client config found, loading data.
[22:01:32] Starting GUI Server
[22:01:33] Finished fah_main
[22:01:33]
[22:01:33] Successful run
[22:01:33] DynamicWrapper: Finished Work Unit: sleep=10000
[22:01:42] Reserved 0 bytes for xtc file; Cosm status=0
[22:01:42] Reserved 0 0 786430464 bytes for arc file=<work/wudata_06.trr> Cosm status=0
[22:01:42] Allocated 0 bytes for edr file
[22:01:42] Error: could not open bedfile, but going on anyway
[22:01:42] - Checksum of file (work/wudata_06.edr) read from disk doesn't match
[22:01:42] edrfile file hash check failed.
[22:01:42]
[22:01:42] Folding@home Core Shutdown: FILE_IO_ERROR
[22:01:47] CoreStatus = 75 (117)
[22:01:47] Error opening or reading from a file.
[22:01:47] Deleting current work unit & continuing...
[22:01:51] - Preparing to get new work unit...
[22:01:51] Cleaning up work directory
[22:01:51] + Attempting to get work packet
[22:01:51] Gpu type=2 species=30.
[22:01:51] - Connecting to assignment server
[22:01:51] - Successful: assigned to (171.67.108.31).
[22:01:51] + News From Folding@Home: Welcome to Folding@Home
[22:01:51] Loaded queue successfully.
[22:01:52] + Closed connections
[22:01:57]
[22:01:57] + Processing work unit
[22:01:57] Core required: FahCore_15.exe
[22:01:57] Core found.
[22:01:57] Working on queue slot 07 [January 18 22:01:57 UTC]
[22:01:57] + Working ...
[22:01:57]
[22:01:57] *------------------------------*
[22:01:57] Folding@Home GPU Core
[22:01:57] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:01:57]
[22:01:57] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:01:57] Build host: amoeba
[22:01:57] Board Type: NVIDIA/CUDA
[22:01:57] Core : x=15
[22:01:57] Window's signal control handler registered.
[22:01:57] Preparing to commence simulation
[22:01:57] - Looking at optimizations...
[22:01:57] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[22:01:57] - Created dyn
[22:01:57] - Files status OK
[22:01:57] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:01:57] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:01:57] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:01:57] - Digital signature verified
[22:01:57]
[22:01:57] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:01:57]
[22:01:57] Assembly optimizations on if available.
[22:01:57] Entering M.D.
[22:01:59] Tpr hash work/wudata_07.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:01:59] Working on ALZHEIMER'S DISEASE AMYLOID
[22:01:59] Client config found, loading data.
[22:01:59] Starting GUI Server
[22:02:00] Finished fah_main
[22:02:00]
[22:02:00] Successful run
[22:02:00] DynamicWrapper: Finished Work Unit: sleep=10000
[22:02:10] Reserved 0 bytes for xtc file; Cosm status=0
[22:02:10] Reserved 0 0 786430464 bytes for arc file=<work/wudata_07.trr> Cosm status=0
[22:02:10] Allocated 0 bytes for edr file
[22:02:10] Error: could not open bedfile, but going on anyway
[22:02:10] - Checksum of file (work/wudata_07.edr) read from disk doesn't match
[22:02:10] edrfile file hash check failed.
[22:02:10]
[22:02:10] Folding@home Core Shutdown: FILE_IO_ERROR
[22:02:14] CoreStatus = 75 (117)
[22:02:14] Error opening or reading from a file.
[22:02:14] Deleting current work unit & continuing...
[22:02:18] - Preparing to get new work unit...
[22:02:18] Cleaning up work directory
[22:02:18] + Attempting to get work packet
[22:02:18] Gpu type=2 species=30.
[22:02:18] - Connecting to assignment server
[22:02:19] - Successful: assigned to (171.67.108.31).
[22:02:19] + News From Folding@Home: Welcome to Folding@Home
[22:02:19] Loaded queue successfully.
[22:02:19] Gpu type=2 species=30.
[22:02:20] + Closed connections
[22:02:25]
[22:02:25] + Processing work unit
[22:02:25] Core required: FahCore_15.exe
[22:02:25] Core found.
[22:02:25] Working on queue slot 08 [January 18 22:02:25 UTC]
[22:02:25] + Working ...
[22:02:25] - Calling '.\FahCore_15.exe -dir work/ -suffix 08 -nice 19 -checkpoint 15 -verbose -lifeline 3780 -version 630'
[22:02:25]
[22:02:25] *------------------------------*
[22:02:25] Folding@Home GPU Core
[22:02:25] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:02:25]
[22:02:25] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:02:25] Build host: amoeba
[22:02:25] Board Type: NVIDIA/CUDA
[22:02:25] Core : x=15
[22:02:25] Window's signal control handler registered.
[22:02:25] Preparing to commence simulation
[22:02:25] - Looking at optimizations...
[22:02:25] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[22:02:25] - Created dyn
[22:02:25] - Files status OK
[22:02:25] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:02:25] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:02:25] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:02:25] - Digital signature verified
[22:02:25]
[22:02:25] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:02:25]
[22:02:25] Assembly optimizations on if available.
[22:02:25] Entering M.D.
[22:02:27] Tpr hash work/wudata_08.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:02:27] Working on ALZHEIMER'S DISEASE AMYLOID
[22:02:27] Client config found, loading data.
[22:02:27] Starting GUI Server
[22:02:27] Finished fah_main
[22:02:27]
[22:02:27] Successful run
[22:02:27] DynamicWrapper: Finished Work Unit: sleep=10000
[22:02:30] ***** Got a SIGTERM signal (2)
[22:02:30] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [January 18 22:02:34 UTC]
Arguments: -verbosity 9
[22:02:34] - Ask before connecting: No
[22:02:34] - User name: PrinceValorum (Team 11314)
[22:02:34] - User ID: ###
[22:02:34] - Machine ID: 2
[22:02:34]
[22:02:34] Gpu type=2 species=30.
[22:02:34] Loaded queue successfully.
[22:02:35] Initialization complete
[22:02:35]
[22:02:35] + Processing work unit
[22:02:35] - Autosending finished units... [January 18 22:02:35 UTC]
[22:02:35] Trying to send all finished work units
[22:02:35] + No unsent completed units remaining.
[22:02:35] - Autosend completed
[22:02:35] Core required: FahCore_15.exe
[22:02:35] Core found.
[22:02:35] Working on queue slot 08 [January 18 22:02:35 UTC]
[22:02:35] + Working ...
[22:02:35] - Calling '.\FahCore_15.exe -dir work/ -suffix 08 -nice 19 -checkpoint 15 -verbose -lifeline 3752 -version 630'
[22:02:35]
[22:02:35] *------------------------------*
[22:02:35] Folding@Home GPU Core
[22:02:35] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:02:35]
[22:02:35] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:02:35] Build host: amoeba
[22:02:35] Board Type: NVIDIA/CUDA
[22:02:35] Core : x=15
[22:02:35] Window's signal control handler registered.
[22:02:35] Preparing to commence simulation
[22:02:35] - Ensuring status. Please wait.
[22:02:35]
[22:02:35] Folding@home Core Shutdown: CLIENT_DIED
[22:02:57] bytes for edr file
[22:02:57] Error: could not open bedfile, but going on anyway
[22:02:57] - Checksum of file (work/wudata_08.edr) read from disk doesn't match
[22:02:57] edrfile file hash check failed.
[22:02:57]
[22:02:57] Folding@home Core Shutdown: FILE_IO_ERROR
[22:02:59] CoreStatus = 75 (117)
[22:02:59] Error opening or reading from a file.
[22:02:59] Deleting current work unit & continuing...
[22:03:03] Trying to send all finished work units
[22:03:03] + No unsent completed units remaining.
[22:03:03] - Preparing to get new work unit...
[22:03:03] Cleaning up work directory
[22:03:03] + Attempting to get work packet
[22:03:03] - Will indicate memory of 4055 MB
[22:03:03] Gpu type=2 species=30.
[22:03:03] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 14, Stepping: 5
[22:03:03] - Connecting to assignment server
[22:03:03] Connecting to http://assign-GPU.stanford.edu:8080/
[22:03:04] Posted data.
[22:03:04] Initial: 43AB; - Successful: assigned to (171.67.108.31).
[22:03:04] + News From Folding@Home: Welcome to Folding@Home
[22:03:04] Loaded queue successfully.
[22:03:04] Gpu type=2 species=30.
[22:03:04] Empty passkey
[22:03:04] Connecting to http://171.67.108.31:8080/
[22:03:04] Initial: 0000; - Receiving payload (expected size: 42163)
[22:03:05] - Downloaded at ~41 kB/s
[22:03:05] - Averaged speed for that direction ~50 kB/s
[22:03:05] + Received work.
[22:03:05] + Closed connections
[22:03:10]
[22:03:10] + Processing work unit
[22:03:10] Core required: FahCore_15.exe
[22:03:10] Core found.
[22:03:10] Working on queue slot 09 [January 18 22:03:10 UTC]
[22:03:10] + Working ...
[22:03:10] - Calling '.\FahCore_15.exe -dir work/ -suffix 09 -nice 19 -checkpoint 15 -verbose -lifeline 3752 -version 630'
[22:03:10]
[22:03:10] *------------------------------*
[22:03:10] Folding@Home GPU Core
[22:03:10] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:03:10]
[22:03:10] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:03:10] Build host: amoeba
[22:03:10] Board Type: NVIDIA/CUDA
[22:03:10] Core : x=15
[22:03:10] Window's signal control handler registered.
[22:03:10] Preparing to commence simulation
[22:03:10] - Looking at optimizations...
[22:03:10] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[22:03:10] - Created dyn
[22:03:10] - Files status OK
[22:03:10] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:03:10] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:03:10] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:03:10] - Digital signature verified
[22:03:10]
[22:03:10] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:03:10]
[22:03:10] Assembly optimizations on if available.
[22:03:10] Entering M.D.
[22:03:12] Tpr hash work/wudata_09.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:03:12] Working on ALZHEIMER'S DISEASE AMYLOID
[22:03:12] Client config found, loading data.
[22:03:13] Starting GUI Server
[22:03:13] Finished fah_main
[22:03:13]
[22:03:13] Successful run
[22:03:13] DynamicWrapper: Finished Work Unit: sleep=10000
[22:03:23] Reserved 0 bytes for xtc file; Cosm status=0
[22:03:23] Reserved 0 0 786430464 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[22:03:23] Allocated 0 bytes for edr file
[22:03:23] Error: could not open bedfile, but going on anyway
[22:03:23] - Checksum of file (work/wudata_09.edr) read from disk doesn't match
[22:03:23] edrfile file hash check failed.
[22:03:23]
[22:03:23] Folding@home Core Shutdown: FILE_IO_ERROR
[22:03:26] CoreStatus = 75 (117)
[22:03:26] Error opening or reading from a file.
[22:03:26] Deleting current work unit & continuing...
[22:03:30] Trying to send all finished work units
[22:03:30] + No unsent completed units remaining.
[22:03:30] - Preparing to get new work unit...
[22:03:30] Cleaning up work directory
[22:03:30] + Attempting to get work packet
[22:03:30] - Will indicate memory of 4055 MB
[22:03:30] Gpu type=2 species=30.
[22:03:30] - Connecting to assignment server
[22:03:30] Connecting to http://assign-GPU.stanford.edu:8080/
[22:03:31] Posted data.
[22:03:31] Initial: 43AB; - Successful: assigned to (171.67.108.31).
[22:03:31] + News From Folding@Home: Welcome to Folding@Home
[22:03:31] Loaded queue successfully.
[22:03:31] Gpu type=2 species=30.
[22:03:31] Empty passkey
[22:03:31] Connecting to http://171.67.108.31:8080/
[22:03:31] Initial: 0000; - Receiving payload (expected size: 42163)
[22:03:32] - Downloaded at ~41 kB/s
[22:03:32] - Averaged speed for that direction ~48 kB/s
[22:03:32] + Received work.
[22:03:32] + Closed connections
[22:03:37]
[22:03:37] + Processing work unit
[22:03:37] Core required: FahCore_15.exe
[22:03:37] Core found.
[22:03:37] Working on queue slot 00 [January 18 22:03:37 UTC]
[22:03:37] + Working ...
[22:03:37] - Calling '.\FahCore_15.exe -dir work/ -suffix 00 -nice 19 -checkpoint 15 -verbose -lifeline 3752 -version 630'
[22:03:37]
[22:03:37] *------------------------------*
[22:03:37] Folding@Home GPU Core
[22:03:37] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:03:37]
[22:03:37] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:03:37] Build host: amoeba
[22:03:37] Board Type: NVIDIA/CUDA
[22:03:37] Core : x=15
[22:03:37] Window's signal control handler registered.
[22:03:37] Preparing to commence simulation
[22:03:37] - Looking at optimizations...
[22:03:37] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[22:03:37] - Created dyn
[22:03:37] - Files status OK
[22:03:37] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:03:37] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:03:37] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:03:37] - Digital signature verified
[22:03:37]
[22:03:37] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:03:37]
[22:03:37] Assembly optimizations on if available.
[22:03:37] Entering M.D.
[22:03:39] Tpr hash work/wudata_00.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:03:39] Working on ALZHEIMER'S DISEASE AMYLOID
[22:03:39] Client config found, loading data.
[22:03:39] Starting GUI Server
[22:03:40] Finished fah_main
[22:03:40]
[22:03:40] Successful run
[22:03:40] DynamicWrapper: Finished Work Unit: sleep=10000
[22:03:49] Reserved 0 bytes for xtc file; Cosm status=0
[22:03:49] Reserved 0 0 786430464 bytes for arc file=<work/wudata_00.trr> Cosm status=0
[22:03:49] Allocated 0 bytes for edr file
[22:03:49] Error: could not open bedfile, but going on anyway
[22:03:49] - Checksum of file (work/wudata_00.edr) read from disk doesn't match
[22:03:49] edrfile file hash check failed.
[22:03:49]
[22:03:49] Folding@home Core Shutdown: FILE_IO_ERROR
[22:03:54] CoreStatus = 75 (117)
[22:03:54] Error opening or reading from a file.
[22:03:54] Deleting current work unit & continuing...
[22:03:58] Trying to send all finished work units
[22:03:58] + No unsent completed units remaining.
[22:03:58] - Preparing to get new work unit...
[22:03:58] Cleaning up work directory
[22:03:58] + Attempting to get work packet
[22:03:58] - Will indicate memory of 4055 MB
[22:03:58] Gpu type=2 species=30.
[22:03:58] - Connecting to assignment server
[22:03:58] Connecting to http://assign-GPU.stanford.edu:8080/
[22:03:58] Posted data.
[22:03:58] Initial: 43AB; - Successful: assigned to (171.67.108.31).
[22:03:58] + News From Folding@Home: Welcome to Folding@Home
[22:03:58] Loaded queue successfully.
[22:03:58] Empty passkey
[22:03:58] Connecting to http://171.67.108.31:8080/
[22:03:59] Posted data.
[22:03:59] Initial: 0000; - Receiving payload (expected size: 42163)
[22:03:59] Conversation time very short, giving reduced weight in bandwidth avg
[22:03:59] - Downloaded at ~82 kB/s
[22:03:59] - Averaged speed for that direction ~52 kB/s
[22:03:59] + Received work.
[22:03:59] + Closed connections
[22:04:04]
[22:04:04] + Processing work unit
[22:04:04] Core required: FahCore_15.exe
[22:04:04] Core found.
[22:04:04] Working on queue slot 01 [January 18 22:04:04 UTC]
[22:04:04] + Working ...
[22:04:04] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -checkpoint 15 -verbose -lifeline 3752 -version 630'
[22:04:04]
[22:04:04] *------------------------------*
[22:04:04] Folding@Home GPU Core
[22:04:04] Version 2.15 (Tue Nov 16 08:44:57 PST 2010)
[22:04:04]
[22:04:04] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.42 for 80x86
[22:04:04] Build host: amoeba
[22:04:04] Board Type: NVIDIA/CUDA
[22:04:04] Core : x=15
[22:04:04] Window's signal control handler registered.
[22:04:04] Preparing to commence simulation
[22:04:04] - Looking at optimizations...
[22:04:04] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[22:04:04] - Created dyn
[22:04:04] - Files status OK
[22:04:04] sizeof(CORE_PACKET_HDR) = 512 file=<>
[22:04:04] - Expanded 41651 -> 167707 (decompressed 402.6 percent)
[22:04:04] Called DecompressByteArray: compressed_data_size=41651 data_size=167707, decompressed_data_size=167707 diff=0
[22:04:04] - Digital signature verified
[22:04:04]
[22:04:04] Project: 11177 (Run 8, Clone 137, Gen 0)
[22:04:04]
[22:04:04] Assembly optimizations on if available.
[22:04:04] Entering M.D.
[22:04:06] Tpr hash work/wudata_01.tpr: 1678237579 1849312479 2314914281 3503328554 4033782978
[22:04:06] Working on ALZHEIMER'S DISEASE AMYLOID
[22:04:06] Client config found, loading data.
[22:04:06] Starting GUI Server
[22:04:07] Finished fah_main
[22:04:07]
[22:04:07] Successful run
[22:04:07] DynamicWrapper: Finished Work Unit: sleep=10000After a bit of investigating on my own, I began to think that maybe the 6.32 client was too advanced for the cards, since it talked about the Fermi stuff, so I uninstalled it and reinstalled the older 6.23 version. Then when I start it, it says that the graphics card isn't supported, or my drivers aren't new enough. I just updated them days ago, so I know the drivers aren't outdated, but I updated them again. What ensued caused more frustration, and reminded me why I lost interest in technology.
I checked the driver info from the Device Manager:
"Driver date: 9/24/2009
Driver version: 8.16.11.9104"
Then I clicked on the nVidia Control Panel from the desktop (right click) and got this:
"Nvidia Control Panel, System Information: Driver version 191.04"
That was right after I installed the newest 266.58 driver...
So I'm hung up and feeling pretty discouraged about the whole thing, but I'd like to get this straightened out. Thanks for taking the time to read it, I know it's a pretty mammoth first post..
