Project: 6885 (Run 122, Clone 4, Gen 28)
zavisalych
Post by zavisalych »
I have 9 units for which "Server reports problem with unit" error appears. The result files for these units remains on my HD in the work directory, but I can't re-send them using "send all" flag or using qfix. I can't find similar problems on the forum and in FAQs. Below is the log of the most recent one. My PC is not overclocked Intel i5 CPU. I run several FAH processes at once (from different directories) because each process takes only 25% of CPU. Should I worry about this problem and change something to avoid it or it's normal workflow?
                          http://folding.stanford.edu
Launch directory: d:\F@H\2
Service: d:\F@H\2\Folding@home-Win32-x86.exe
Arguments: -svcstart -d d:\F@H\2 -verbosity 9
Launched as a service.
Entered d:\F@H\2 to do work.
[05:22:17] - Ask before connecting: No
[05:22:17] - User name: zavisalych (Team 47191)
[05:22:17] - User ID: B4C60F155EE600D
[05:22:17] - Machine ID: 2
[05:22:17]
[05:22:17] Loaded queue successfully.
[05:22:17]
[05:22:17] + Processing work unit
[05:22:17] - Autosending finished units... [05:22:17]
[05:22:17] Core required: FahCore_78.exe
[05:22:17] Trying to send all finished work units
[05:22:17] + No unsent completed units remaining.
[05:22:17] - Autosend completed
[05:22:17] Core found.
[05:22:17] Working on queue slot 05 [January 15 05:22:17 UTC]
[05:22:17] + Working ...
[05:22:17] - Calling '.\FahCore_78.exe -dir work/ -suffix 05 -noassembly -checkpoint 15 -service -verbose -lifeline 4592 -version 623'
[05:22:18]
[05:22:18] *------------------------------*
[05:22:18] Folding@Home Gromacs Core
[05:22:18] Version 1.90 (March 8, 2006)
[05:22:18]
[05:22:18] Preparing to commence simulation
[05:22:18] - User disabled assembly optimizations.
[05:22:18] - Files status OK
[05:22:18] - Expanded 371828 -> 1798060 (decompressed 483.5 percent)
[05:22:18] - Starting from initial work packet
[05:22:18]
[05:22:18] Project: 6885 (Run 122, Clone 4, Gen 28)
[05:22:18]
[05:22:18] Entering M.D.
[05:22:24] Protein: ALZHEIMERS DISEASE AMYLOID
[05:22:24]
[05:22:24] Writing local files
[05:23:08] Writing local files
[05:23:08] Completed 0 out of 250000 steps  (0%)
[05:38:08] Timered checkpoint triggered.
[05:38:10] Writing local files
[15:26:28] Completed 250000 out of 250000 steps  (100%)
[15:26:28] Writing final coordinates.
[15:26:29] Past main M.D. loop
[15:27:28]
[15:27:28] Finished Work Unit:
[15:27:28] - Reading up to 292752 from "work/wudata_05.arc": Read 292752
[15:27:28] - Reading up to 260412 from "work/wudata_05.xtc": Read 260412
[15:27:28] goefile size: 0
[15:27:28] logfile size: 30748
[15:27:28] Leaving Run
[15:27:30] - Writing 589820 bytes of core data to disk...
[15:27:30] Done: 589308 -> 560447 (compressed to 95.1 percent)
[15:27:30]   ... Done.
[15:27:31] - Shutting down core
[15:27:31]
[15:27:31] Folding@home Core Shutdown: FINISHED_UNIT
[15:27:34] CoreStatus = 64 (100)
[15:27:34] Unit 5 finished with 84 percent of time to deadline remaining.
[15:27:34] Updated performance fraction: 0.916201
[15:27:34] Sending work to server
[15:27:34] Project: 6885 (Run 122, Clone 4, Gen 28)
[15:27:34] + Attempting to send results [January 16 15:27:34 UTC]
[15:27:34] - Reading file work/wuresults_05.dat from core
[15:27:34]   (Read 560959 bytes from disk)
[15:27:34] Connecting to http://171.67.108.33:8080/
[15:27:37] Posted data.
[15:27:37] Initial: 0000; - Uploaded at ~182 kB/s
[15:27:37] - Averaged speed for that direction ~132 kB/s
[15:27:37] - Server reports problem with unit.
[15:27:37] Trying to send all finished work units
[15:27:37] + No unsent completed units remaining.
sortofageek
Re: Project: 6885 (Run 122, Clone 4, Gen 28)
Post by sortofageek »
Just an FYI, there are no results in the database thus far for Project: 6885 (Run 122, Clone 4, Gen 28).
Project: 6885 (Run 122, Clone 4, Gen 28) was successfully completed some time ago and Gen 30 has now been completed as of 2011-01-27.
