[22:49:53] - Couldn't send HTTP request to server
[22:49:53] + Could not connect to Work Server (results)
[22:49:53] (171.64.65.64:8080)
[22:49:53] + Retrying using alternative port
171.64.65.64 - Cannot upload results
It looks like the problem from 1 month ago is back. This made all my gpu clients get stuck unfortunately (FAH tracker is using oneunit flag!).
Xavier Zepherious
Re: 171.64.65.64 - Cannot upload results
having this issue too
takes awhile to finally connect
doesn't happen all the time...
[03:10:04] Project: 6805 (Run 3719, Clone 3, Gen 1)
[03:10:04] + Attempting to send results [March 8 03:10:04 UTC]
[03:10:04] Gpu type=3 species=20.
[03:11:34] - Couldn't send HTTP request to server
[03:11:34] + Could not connect to Work Server (results)
[03:11:34] (171.64.65.64:8080)
[03:11:34] + Retrying using alternative port
[03:12:39] - Couldn't send HTTP request to server
[03:12:39] + Could not connect to Work Server (results)
[03:12:39] (171.64.65.64:80)
[03:12:39] - Error: Could not transmit unit 01 (completed March 8) to work server.
[03:12:39] Keeping unit 01 in queue.
[03:12:39] Project: 6805 (Run 3719, Clone 3, Gen 1)
[03:12:39] + Attempting to send results [March 8 03:12:39 UTC]
[03:12:39] Gpu type=3 species=20.
[03:13:01] - Couldn't send HTTP request to server
[03:13:01] + Could not connect to Work Server (results)
[03:13:01] (171.64.65.64:8080)
[03:13:01] + Retrying using alternative port
[03:13:30] - Couldn't send HTTP request to server
[03:13:30] + Could not connect to Work Server (results)
[03:13:30] (171.64.65.64:80)
[03:13:30] - Error: Could not transmit unit 01 (completed March 8) to work server.
[03:13:30] + Attempting to send results [March 8 03:13:30 UTC]
[03:13:30] Gpu type=3 species=20.
[03:17:43] + Results successfully sent
[18:57:18] Project: 6805 (Run 3663, Clone 3, Gen 7)
[18:57:18] + Attempting to send results [March 8 18:57:18 UTC]
[18:57:18] Gpu type=3 species=20.
[18:58:43] - Couldn't send HTTP request to server
[18:58:43] + Could not connect to Work Server (results)
[18:58:43] (171.64.65.64:8080)
[18:58:43] + Retrying using alternative port
[19:02:44] - Couldn't send HTTP request to server
[19:02:44] + Could not connect to Work Server (results)
[19:02:44] (171.64.65.64:80)
[19:02:44] - Error: Could not transmit unit 09 (completed March 8) to work server.
[19:02:44] Keeping unit 09 in queue.
[19:02:44] Project: 6805 (Run 3663, Clone 3, Gen 7)
[19:02:44] + Attempting to send results [March 8 19:02:44 UTC]
[19:02:44] Gpu type=3 species=20.
[19:07:07] - Couldn't send HTTP request to server
[19:07:07] + Could not connect to Work Server (results)
[19:07:07] (171.64.65.64:8080)
[19:07:07] + Retrying using alternative port
[19:09:59] + Results successfully sent
