Project: 6023 (Run 0, Clone 92, Gen 368) - EUE at 0%
tmossman01
Post by tmossman01 »
Normally stable rig (no EUEs in months since bad RAM encountered)... reporting just in case. I am about to restart the client, if the same WU is loaded, I will report success or failure on retry.
[21:14:57] + Processing work unit
[21:14:57] Core required: FahCore_a3.exe
[21:14:57] Core found.
[21:14:57] Working on queue slot 03 [January 12 21:14:57 UTC]
[21:14:57] + Working ...
[21:14:57]
[21:14:57] *------------------------------*
[21:14:57] Folding@Home Gromacs SMP Core
[21:14:57] Version 2.22 (Mar 12, 2010)
[21:14:57]
[21:14:57] Preparing to commence simulation
[21:14:57] - Assembly optimizations manually forced on.
[21:14:57] - Not checking prior termination.
[21:14:57] - Expanded 1766834 -> 1967109 (decompressed 111.3 percent)
[21:14:57] Called DecompressByteArray: compressed_data_size=1766834 data_size=1967109, decompressed_data_size=1967109 diff=0
[21:14:57] - Digital signature verified
[21:14:57]
[21:14:57] Project: 6023 (Run 0, Clone 92, Gen 368)
[21:14:57]
[21:14:57] Assembly optimizations on if available.
[21:14:57] Entering M.D.
[21:15:03] Completed 0 out of 500000 steps  (0%)
tmossman01
Re: Project: 6023 (Run 0, Clone 92, Gen 368) - EUE at 0%
(failure was a c0000029)
tmossman01
Well problem is recurring and occurs with both -smp 5 and -smp 6. I will stand down folding until I can run some memory tests, as a C0000029 may be indicative of flaky memory (or someone can confirm a bad WU).
This one is a bad WU that failed every times.
I marked it.
tmossman01
Thanks for the reply.
Slash_2CPU
Post by Slash_2CPU »
Keep getting this one over and over. Thanks for at least letting us know it's bad, or I'd surely be tearing the machine open about now with a duster can and lowering my clocks.
Is this going to kill my bonus eligibility? I've probably returned 20+ of these at 0% EUE.
ASRock X99 WS i7-5930K @ 4.4GHz /2x GTX 970 @ 1.46GHz /4x4GB DDR4-2666
Phenom II X6 @ 3.7GHz /2x2GB DDR3-1680 /GTX 970 @ 1.40GHz
450-600K PPD @ ~850W
DocJonz
Post by DocJonz »
Definately a faulty WU - falls over at 0% on a rig that has done hundreds of consecutive WU's without issue - trouble is, it keeps trying to pick it up !!
Folding Stats (now via v8 webclient)
Standinwave
Hardware configuration: 3 x G6950, 1 x Q6600, 1 x 980X, 6 x GTX460, 1 x GTX465
Team 35947
ID 87514
Post by Standinwave »
DocJonz wrote:Definately a faulty WU - falls over at 0% on a rig that has done hundreds of consecutive WU's without issue - trouble is, it keeps trying to pick it up !!
Yeah! Cos nobody else wants it :lol:
gwildperson
Post by gwildperson »
Slash_2CPU wrote:Is this going to kill my bonus eligibility? I've probably returned 20+ of these at 0% EUE.
Let us know if it does. How many bonus-type WUs have you completed successfully?
Slash_2CPU
Hundreds? A lot. 2-3 bigadv boxes of various hardware configs plus 2-3 A3 boxes running about as long as bonuses have been available.
It did not seem to affect my PPD average much beyond just having 2 boxes out of work for about 8-16 hours, so I assume the bonus eligibility did not get affected.
