Project: 5737 (Run 3, Clone 577, Gen 84)
Mactin
Post by Mactin »
Instant UNSTABLE_MACHINE five times in a row.
Stopped "for 24 hours"
CTRL-C and restarted after about one hour
I got for a sixth time, same instant UNSTABLE_MACHINE
Then got p5736-r2-c608-g95, folds fine.
Looks like a bad WU to me.
User name : Martin_i7-980x_HD5870
Team : 96377
Logs:
[12:10:56] Completed 100%
[12:10:57] Successful run
[12:10:57] DynamicWrapper: Finished Work Unit: sleep=10000
[12:11:06] Reserved 219020 bytes for xtc file; Cosm status=0
[12:11:06] Allocated 219020 bytes for xtc file
[12:11:06] - Reading up to 219020 from "work/wudata_09.xtc": Read 219020
[12:11:06] Read 219020 bytes from xtc file; available packet space=786211444
[12:11:06] xtc file hash check passed.
[12:11:06] Reserved 33528 33528 786211444 bytes for arc file=<work/wudata_09.trr> Cosm status=0
[12:11:06] Allocated 33528 bytes for arc file
[12:11:06] - Reading up to 33528 from "work/wudata_09.trr": Read 33528
[12:11:06] Read 33528 bytes from arc file; available packet space=786177916
[12:11:06] trr file hash check passed.
[12:11:06] Allocated 560 bytes for edr file
[12:11:06] Read bedfile
[12:11:06] edr file hash check passed.
[12:11:06] Allocated 14301 bytes for logfile
[12:11:06] Read logfile
[12:11:06] GuardedRun: success in DynamicWrapper
[12:11:06] GuardedRun: done
[12:11:06] Run: GuardedRun completed.
[12:11:08] - Writing 267921 bytes of core data to disk...
[12:11:08] Done: 267409 -> 258909 (compressed to 96.8 percent)
[12:11:08]   ... Done.
[12:11:08] - Shutting down core
[12:11:08]
[12:11:08] Folding@home Core Shutdown: FINISHED_UNIT
[12:11:11] CoreStatus = 64 (100)
[12:11:11] Unit 9 finished with 96 percent of time to deadline remaining.
[12:11:11] Updated performance fraction: 0.960130
[12:11:11] Sending work to server
[12:11:11] Project: 5738 (Run 3, Clone 633, Gen 115)
[12:11:11] - Read packet limit of 540015616... Set to 524286976.
[12:11:11] + Attempting to send results [January 4 12:11:11 UTC]
[12:11:11] - Reading file work/wuresults_09.dat from core
[12:11:11]   (Read 259421 bytes from disk)
[12:11:11] Connecting to http://171.64.65.102:8080/
[12:11:14] Posted data.
[12:11:15] Initial: 0000; - Uploaded at ~63 kB/s
[12:11:15] - Averaged speed for that direction ~65 kB/s
[12:11:15] + Results successfully sent
[12:11:15] Thank you for your contribution to Folding@Home.
[12:11:15] + Number of Units Completed: 1678
[12:11:19] Trying to send all finished work units
[12:11:19] + No unsent completed units remaining.
[12:11:19] - Preparing to get new work unit...
[12:11:19] + Attempting to get work packet
[12:11:19] - Will indicate memory of 2048 MB
[12:11:19] - Connecting to assignment server
[12:11:19] Connecting to http://assign-GPU.stanford.edu:8080/
[12:11:19] Posted data.
[12:11:19] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:11:19] + News From Folding@Home: Welcome to Folding@Home
[12:11:20] Loaded queue successfully.
[12:11:20] Connecting to http://171.64.65.102:8080/
[12:11:20] Posted data.
[12:11:20] Initial: 0000; - Receiving payload (expected size: 62027)
[12:11:21] - Downloaded at ~60 kB/s
[12:11:21] - Averaged speed for that direction ~108 kB/s
[12:11:21] + Received work.
[12:11:21] Trying to send all finished work units
[12:11:21] + No unsent completed units remaining.
[12:11:21] + Closed connections
[12:11:21]
[12:11:21] + Processing work unit
[12:11:21] Core required: FahCore_11.exe
[12:11:21] Core found.
[12:11:21] Working on queue slot 00 [January 4 12:11:21 UTC]
[12:11:21] + Working ...
[12:11:21] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -checkpoint 10 -verbose -lifeline 5768 -version 623'
[12:11:21]
[12:11:21] *------------------------------*
[12:11:21] Folding@Home GPU Core - Beta
[12:11:21] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:11:21]
[12:11:21] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:11:21] Build host: amoeba
[12:11:21] Board Type: AMD
[12:11:21] Core      :
[12:11:21] Preparing to commence simulation
[12:11:21] - Looking at optimizations...
[12:11:21] - Created dyn
[12:11:21] - Files status OK
[12:11:21] - Expanded 61515 -> 489152 (decompressed 795.1 percent)
[12:11:21] Called DecompressByteArray: compressed_data_size=61515 data_size=489152, decompressed_data_size=489152 diff=0
[12:11:21] - Digital signature verified
[12:11:21]
[12:11:21] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:11:21]
[12:11:21] Assembly optimizations on if available.
[12:11:21] Entering M.D.
[12:11:27] Tpr hash work/wudata_00.tpr:  876561312 3944870360 3930403429 2435652710 679827704
[12:11:27] Working on Protein
[12:11:29] Client config found, loading data.
[12:11:29] Starting GUI Server
[12:11:31] mdrun_gpu returned
[12:11:31] NANs detected on GPU
[12:11:31]
[12:11:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:11:36] CoreStatus = 7A (122)
[12:11:36] Sending work to server
[12:11:36] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:11:36] - Read packet limit of 540015616... Set to 524286976.
[12:11:36] - Error: Could not get length of results file work/wuresults_00.dat
[12:11:36] - Error: Could not read unit 00 file. Removing from queue.
[12:11:36] Trying to send all finished work units
[12:11:36] + No unsent completed units remaining.
[12:11:36] - Preparing to get new work unit...
[12:11:36] + Attempting to get work packet
[12:11:36] - Will indicate memory of 2048 MB
[12:11:36] - Connecting to assignment server
[12:11:36] Connecting to http://assign-GPU.stanford.edu:8080/
[12:11:36] Posted data.
[12:11:36] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:11:36] + News From Folding@Home: Welcome to Folding@Home
[12:11:36] Loaded queue successfully.
[12:11:36] Connecting to http://171.64.65.102:8080/
[12:11:37] Posted data.
[12:11:37] Initial: 0000; - Receiving payload (expected size: 62027)
[12:11:37] Conversation time very short, giving reduced weight in bandwidth avg
[12:11:37] - Downloaded at ~121 kB/s
[12:11:37] - Averaged speed for that direction ~110 kB/s
[12:11:37] + Received work.
[12:11:37] Trying to send all finished work units
[12:11:37] + No unsent completed units remaining.
[12:11:37] + Closed connections
[12:11:42]
[12:11:42] + Processing work unit
[12:11:42] Core required: FahCore_11.exe
[12:11:42] Core found.
[12:11:42] Working on queue slot 01 [January 4 12:11:42 UTC]
[12:11:42] + Working ...
[12:11:42] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -checkpoint 10 -verbose -lifeline 5768 -version 623'
[12:11:43]
[12:11:43] *------------------------------*
[12:11:43] Folding@Home GPU Core - Beta
[12:11:43] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:11:43]
[12:11:43] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:11:43] Build host: amoeba
[12:11:43] Board Type: AMD
[12:11:43] Core      :
[12:11:43] Preparing to commence simulation
[12:11:43] - Looking at optimizations...
[12:11:43] - Created dyn
[12:11:43] - Files status OK
[12:11:43] - Expanded 61515 -> 489152 (decompressed 795.1 percent)
[12:11:43] Called DecompressByteArray: compressed_data_size=61515 data_size=489152, decompressed_data_size=489152 diff=0
[12:11:43] - Digital signature verified
[12:11:43]
[12:11:43] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:11:43]
[12:11:43] Assembly optimizations on if available.
[12:11:43] Entering M.D.
[12:11:49] Tpr hash work/wudata_01.tpr:  876561312 3944870360 3930403429 2435652710 679827704
[12:11:49] Working on Protein
[12:11:50] Client config found, loading data.
[12:11:50] Starting GUI Server
[12:11:53] mdrun_gpu returned
[12:11:53] NANs detected on GPU
[12:11:53]
[12:11:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:11:57] CoreStatus = 7A (122)
[12:11:57] Sending work to server
[12:11:57] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:11:57] - Read packet limit of 540015616... Set to 524286976.
[12:11:57] - Error: Could not get length of results file work/wuresults_01.dat
[12:11:57] - Error: Could not read unit 01 file. Removing from queue.
[12:11:57] Trying to send all finished work units
[12:11:57] + No unsent completed units remaining.
[12:11:57] - Preparing to get new work unit...
[12:11:57] + Attempting to get work packet
[12:11:57] - Will indicate memory of 2048 MB
[12:11:57] - Connecting to assignment server
[12:11:57] Connecting to http://assign-GPU.stanford.edu:8080/
[12:11:58] Posted data.
[12:11:58] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:11:58] + News From Folding@Home: Welcome to Folding@Home
[12:11:58] Loaded queue successfully.
[12:11:58] Connecting to http://171.64.65.102:8080/
[12:11:58] Initial: 0000; - Receiving payload (expected size: 62027)
[12:11:59] - Downloaded at ~60 kB/s
[12:11:59] - Averaged speed for that direction ~100 kB/s
[12:11:59] + Received work.
[12:11:59] Trying to send all finished work units
[12:11:59] + No unsent completed units remaining.
[12:11:59] + Closed connections
[12:12:04]
[12:12:04] + Processing work unit
[12:12:04] Core required: FahCore_11.exe
[12:12:04] Core found.
[12:12:04] Working on queue slot 02 [January 4 12:12:04 UTC]
[12:12:04] + Working ...
[12:12:04] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -checkpoint 10 -verbose -lifeline 5768 -version 623'
[12:12:04]
[12:12:04] *------------------------------*
[12:12:04] Folding@Home GPU Core - Beta
[12:12:04] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:12:04]
[12:12:04] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:12:04] Build host: amoeba
[12:12:04] Board Type: AMD
[12:12:04] Core      :
[12:12:04] Preparing to commence simulation
[12:12:04] - Looking at optimizations...
[12:12:04] - Created dyn
[12:12:04] - Files status OK
[12:12:04] - Expanded 61515 -> 489152 (decompressed 795.1 percent)
[12:12:04] Called DecompressByteArray: compressed_data_size=61515 data_size=489152, decompressed_data_size=489152 diff=0
[12:12:04] - Digital signature verified
[12:12:04]
[12:12:04] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:12:04]
[12:12:04] Assembly optimizations on if available.
[12:12:04] Entering M.D.
[12:12:10] Tpr hash work/wudata_02.tpr:  876561312 3944870360 3930403429 2435652710 679827704
[12:12:11] Working on Protein
[12:12:12] Client config found, loading data.
[12:12:12] Starting GUI Server
[12:12:14] mdrun_gpu returned
[12:12:14] NANs detected on GPU
[12:12:14]
[12:12:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:12:19] CoreStatus = 7A (122)
[12:12:19] Sending work to server
[12:12:19] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:12:19] - Read packet limit of 540015616... Set to 524286976.
[12:12:19] - Error: Could not get length of results file work/wuresults_02.dat
[12:12:19] - Error: Could not read unit 02 file. Removing from queue.
[12:12:19] Trying to send all finished work units
[12:12:19] + No unsent completed units remaining.
[12:12:19] - Preparing to get new work unit...
[12:12:19] + Attempting to get work packet
[12:12:19] - Will indicate memory of 2048 MB
[12:12:19] - Connecting to assignment server
[12:12:19] Connecting to http://assign-GPU.stanford.edu:8080/
[12:12:19] Posted data.
[12:12:19] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:12:19] + News From Folding@Home: Welcome to Folding@Home
[12:12:19] Loaded queue successfully.
[12:12:19] Connecting to http://171.64.65.102:8080/
[12:12:20] Posted data.
[12:12:20] Initial: 0000; - Receiving payload (expected size: 62027)
[12:12:21] - Downloaded at ~60 kB/s
[12:12:21] - Averaged speed for that direction ~92 kB/s
[12:12:21] + Received work.
[12:12:21] Trying to send all finished work units
[12:12:21] + No unsent completed units remaining.
[12:12:21] + Closed connections
[12:12:26]
[12:12:26] + Processing work unit
[12:12:26] Core required: FahCore_11.exe
[12:12:26] Core found.
[12:12:26] Working on queue slot 03 [January 4 12:12:26 UTC]
[12:12:26] + Working ...
[12:12:26] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -checkpoint 10 -verbose -lifeline 5768 -version 623'
[12:12:26]
[12:12:26] *------------------------------*
[12:12:26] Folding@Home GPU Core - Beta
[12:12:26] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:12:26]
[12:12:26] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:12:26] Build host: amoeba
[12:12:26] Board Type: AMD
[12:12:26] Core      :
[12:12:26] Preparing to commence simulation
[12:12:26] - Looking at optimizations...
[12:12:26] - Created dyn
[12:12:26] - Files status OK
[12:12:26] - Expanded 61515 -> 489152 (decompressed 795.1 percent)
[12:12:26] Called DecompressByteArray: compressed_data_size=61515 data_size=489152, decompressed_data_size=489152 diff=0
[12:12:26] - Digital signature verified
[12:12:26]
[12:12:26] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:12:26]
[12:12:26] Assembly optimizations on if available.
[12:12:26] Entering M.D.
[12:12:32] Tpr hash work/wudata_03.tpr:  876561312 3944870360 3930403429 2435652710 679827704
[12:12:32] Working on Protein
[12:12:33] Client config found, loading data.
[12:12:33] Starting GUI Server
[12:12:36] mdrun_gpu returned
[12:12:36] NANs detected on GPU
[12:12:36]
[12:12:36] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:12:40] CoreStatus = 7A (122)
[12:12:40] Sending work to server
[12:12:40] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:12:40] - Read packet limit of 540015616... Set to 524286976.
[12:12:40] - Error: Could not get length of results file work/wuresults_03.dat
[12:12:40] - Error: Could not read unit 03 file. Removing from queue.
[12:12:40] Trying to send all finished work units
[12:12:40] + No unsent completed units remaining.
[12:12:40] - Preparing to get new work unit...
[12:12:40] + Attempting to get work packet
[12:12:40] - Will indicate memory of 2048 MB
[12:12:40] - Connecting to assignment server
[12:12:40] Connecting to http://assign-GPU.stanford.edu:8080/
[12:12:41] Posted data.
[12:12:41] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[12:12:41] + News From Folding@Home: Welcome to Folding@Home
[12:12:41] Loaded queue successfully.
[12:12:41] Connecting to http://171.64.65.102:8080/
[12:12:41] Initial: 0000; - Receiving payload (expected size: 62027)
[12:12:42] - Downloaded at ~60 kB/s
[12:12:42] - Averaged speed for that direction ~85 kB/s
[12:12:42] + Received work.
[12:12:42] Trying to send all finished work units
[12:12:42] + No unsent completed units remaining.
[12:12:42] + Closed connections
[12:12:47]
[12:12:47] + Processing work unit
[12:12:47] Core required: FahCore_11.exe
[12:12:47] Core found.
[12:12:47] Working on queue slot 04 [January 4 12:12:47 UTC]
[12:12:47] + Working ...
[12:12:47] - Calling '.\FahCore_11.exe -dir work/ -suffix 04 -checkpoint 10 -verbose -lifeline 5768 -version 623'
[12:12:47]
[12:12:47] *------------------------------*
[12:12:47] Folding@Home GPU Core - Beta
[12:12:47] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[12:12:47]
[12:12:47] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:12:47] Build host: amoeba
[12:12:47] Board Type: AMD
[12:12:47] Core      :
[12:12:47] Preparing to commence simulation
[12:12:47] - Looking at optimizations...
[12:12:47] - Created dyn
[12:12:47] - Files status OK
[12:12:47] - Expanded 61515 -> 489152 (decompressed 795.1 percent)
[12:12:47] Called DecompressByteArray: compressed_data_size=61515 data_size=489152, decompressed_data_size=489152 diff=0
[12:12:47] - Digital signature verified
[12:12:47]
[12:12:47] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:12:47]
[12:12:47] Assembly optimizations on if available.
[12:12:47] Entering M.D.
[12:12:53] Tpr hash work/wudata_04.tpr:  876561312 3944870360 3930403429 2435652710 679827704
[12:12:53] Working on Protein
[12:12:55] Client config found, loading data.
[12:12:55] Starting GUI Server
[12:12:58] mdrun_gpu returned
[12:12:58] NANs detected on GPU
[12:12:58]
[12:12:58] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:13:02] CoreStatus = 7A (122)
[12:13:02] Sending work to server
[12:13:02] Project: 5737 (Run 3, Clone 577, Gen 84)
[12:13:02] - Read packet limit of 540015616... Set to 524286976.
[12:13:02] - Error: Could not get length of results file work/wuresults_04.dat
[12:13:02] - Error: Could not read unit 04 file. Removing from queue.
[12:13:02] EUE limit exceeded. Pausing 24 hours.
[13:20:28] ***** Got a SIGTERM signal (2)
[13:20:28] Killing all core threads
Folding@Home Client Shutdown.
--- Opening Log file [January 4 13:20:31 UTC]
                          http://folding.stanford.edu
Launch directory: C:\Program Files (x86)\folding\m3 GPU
Executable: C:\Program Files (x86)\folding\m3 GPU\Folding@home-Win32-GPU.exe
Arguments: -local -gpu 0 -verbosity 9 -forcegpu ati_r700 -config
[13:20:31] - Ask before connecting: No
[13:20:31] - User name: Martin_i7-980x_HD5870 (Team 96377)
[13:20:31] - User ID: 6C6A12517E046D46
[13:20:31] - Machine ID: 4
[13:20:31]
[13:20:31] Configuring Folding@Home...
[13:20:34] - Ask before connecting: No
[13:20:34] - User name: Martin_i7-980x_HD5870 (Team 96377)
[13:20:34] - User ID: 6C6A12517E046D46
[13:20:34] - Machine ID: 4
[13:20:34]
[13:20:34] Loaded queue successfully.
[13:20:34] - Preparing to get new work unit...
[13:20:34] - Autosending finished units... [January 4 13:20:34 UTC]
[13:20:34] + Attempting to get work packet
[13:20:34] Trying to send all finished work units
[13:20:34] - Will indicate memory of 2048 MB
[13:20:34] + No unsent completed units remaining.
[13:20:34] - Detect CPU.[13:20:34] - Autosend completed
 Vendor: GenuineIntel, Family: 6, Model: 12, Stepping: 2
[13:20:34] - Connecting to assignment server
[13:20:34] Connecting to http://assign-GPU.stanford.edu:8080/
[13:20:35] Posted data.
[13:20:35] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:20:35] + News From Folding@Home: Welcome to Folding@Home
[13:20:35] Loaded queue successfully.
[13:20:35] Connecting to http://171.64.65.102:8080/
[13:20:35] Initial: 0000; - Receiving payload (expected size: 62027)
[13:20:36] - Downloaded at ~60 kB/s
[13:20:36] - Averaged speed for that direction ~80 kB/s
[13:20:36] + Received work.
[13:20:36] + Closed connections
[13:20:36]
[13:20:36] + Processing work unit
[13:20:36] Core required: FahCore_11.exe
[13:20:36] Core found.
[13:20:36] Working on queue slot 05 [January 4 13:20:36 UTC]
[13:20:36] + Working ...
[13:20:36] - Calling '.\FahCore_11.exe -dir work/ -suffix 05 -checkpoint 10 -verbose -lifeline 5824 -version 623'
[13:20:36]
[13:20:36] *------------------------------*
[13:20:36] Folding@Home GPU Core - Beta
[13:20:36] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:20:36]
[13:20:36] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:20:36] Build host: amoeba
[13:20:36] Board Type: AMD
[13:20:36] Core      :
[13:20:36] Preparing to commence simulation
[13:20:36] - Looking at optimizations...
[13:20:36] - Created dyn
[13:20:36] - Files status OK
[13:20:36] - Expanded 61515 -> 489152 (decompressed 795.1 percent)
[13:20:36] Called DecompressByteArray: compressed_data_size=61515 data_size=489152, decompressed_data_size=489152 diff=0
[13:20:36] - Digital signature verified
[13:20:36]
[13:20:36] Project: 5737 (Run 3, Clone 577, Gen 84)
[13:20:36]
[13:20:36] Assembly optimizations on if available.
[13:20:36] Entering M.D.
[13:20:42] Tpr hash work/wudata_05.tpr:  876561312 3944870360 3930403429 2435652710 679827704
[13:20:43] Working on Protein
[13:20:43] Client config found, loading data.
[13:20:43] Starting GUI Server
[13:20:46] mdrun_gpu returned
[13:20:46] NANs detected on GPU
[13:20:46]
[13:20:46] Folding@home Core Shutdown: UNSTABLE_MACHINE
[13:20:50] CoreStatus = 7A (122)
[13:20:50] Sending work to server
[13:20:50] Project: 5737 (Run 3, Clone 577, Gen 84)
[13:20:50] - Read packet limit of 540015616... Set to 524286976.
[13:20:50] - Error: Could not get length of results file work/wuresults_05.dat
[13:20:50] - Error: Could not read unit 05 file. Removing from queue.
[13:20:50] Trying to send all finished work units
[13:20:50] + No unsent completed units remaining.
[13:20:50] - Preparing to get new work unit...
[13:20:50] + Attempting to get work packet
[13:20:50] - Will indicate memory of 2048 MB
[13:20:50] - Connecting to assignment server
[13:20:50] Connecting to http://assign-GPU.stanford.edu:8080/
[13:20:51] Posted data.
[13:20:51] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:20:51] + News From Folding@Home: Welcome to Folding@Home
[13:20:51] Loaded queue successfully.
[13:20:51] Connecting to http://171.64.65.102:8080/
[13:20:52] Posted data.
[13:20:52] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[13:20:52] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[13:21:11] + Attempting to get work packet
[13:21:11] - Will indicate memory of 2048 MB
[13:21:11] - Connecting to assignment server
[13:21:11] Connecting to http://assign-GPU.stanford.edu:8080/
[13:21:12] Posted data.
[13:21:12] Initial: 40AB; - Successful: assigned to (171.64.65.102).
[13:21:12] + News From Folding@Home: Welcome to Folding@Home
[13:21:12] Loaded queue successfully.
[13:21:12] Connecting to http://171.64.65.102:8080/
[13:21:13] Posted data.
[13:21:13] Initial: 0000; - Receiving payload (expected size: 97223)
[13:21:13] Conversation time very short, giving reduced weight in bandwidth avg
[13:21:13] - Downloaded at ~189 kB/s
[13:21:13] - Averaged speed for that direction ~92 kB/s
[13:21:13] + Received work.
[13:21:13] Trying to send all finished work units
[13:21:13] + No unsent completed units remaining.
[13:21:13] + Closed connections
[13:21:18]
[13:21:18] + Processing work unit
[13:21:18] Core required: FahCore_11.exe
[13:21:18] Core found.
[13:21:18] Working on queue slot 06 [January 4 13:21:18 UTC]
[13:21:18] + Working ...
[13:21:18] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -checkpoint 10 -verbose -lifeline 5824 -version 623'
[13:21:19]
[13:21:19] *------------------------------*
[13:21:19] Folding@Home GPU Core - Beta
[13:21:19] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[13:21:19]
[13:21:19] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[13:21:19] Build host: amoeba
[13:21:19] Board Type: AMD
[13:21:19] Core      :
[13:21:19] Preparing to commence simulation
[13:21:19] - Looking at optimizations...
[13:21:19] - Created dyn
[13:21:19] - Files status OK
[13:21:19] - Expanded 96711 -> 489152 (decompressed 505.7 percent)
[13:21:19] Called DecompressByteArray: compressed_data_size=96711 data_size=489152, decompressed_data_size=489152 diff=0
[13:21:19] - Digital signature verified
[13:21:19]
[13:21:19] Project: 5736 (Run 2, Clone 608, Gen 95)
[13:21:19]
[13:21:19] Assembly optimizations on if available.
[13:21:19] Entering M.D.
[13:21:25] Tpr hash work/wudata_06.tpr:  2113811604 2168652460 3321803631 3630061874 2583398470
[13:21:26] Working on Protein
[13:21:26] Client config found, loading data.
[13:21:27] Starting GUI Server
[13:23:28] Completed 1%
[13:25:22] Completed 2%
[13:27:16] Completed 3%
[13:56:55] Completed 18%
[13:58:44] Completed 19%
Re: Project: 5737 (Run 3, Clone 577, Gen 84)
There only one report on the DB yet, but it's an immediate EUE too ...
Marked as bad.
