http://fah-web.stanford.edu/awards/cert.php
I need help when I clink on the certificate link on my stat page (username=websafe) the certificate shows 0 points and 0 WU any help on fixing this thank you.
Re: http://fah-web.stanford.edu/awards/cert.php
Did you complete and return at least one WU before trying to look at your certificate ?
If yes, did you wait until the stats update ?
Yes I have been folding for some time I have over 3.2 mill points it use to work fine
- Pande Group Member
We took a look. There's something strange with this one dealing with capitalization. Our records show the name should be "Websafe". If you go to
http://fah-web.stanford.edu/cgi-bin/mai ... me=Websafe
that should work.
that should work.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
Chair, Biophysics
Stanford University
VijayPande wrote:We took a look. There's something strange with this one dealing with capitalization. Our records show the name should be "Websafe". If you go to
//fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=Websafe
that should work.
Thank you very much Prof. Pande
This is the first time I have had to post so to get help on this from you so fast I am going to build one more i7 rig this month to fold 24/7
